With the new omap_prm driver added unconditionally, omap2 builds
fail when the reset controller subsystem is disabled:
drivers/soc/ti/omap_prm.o: In function `omap_prm_probe':
omap_prm.c:(.text+0x2d4): undefined reference to `devm_reset_controller_register'
Link: https://lore.kernel.org/r/20191216132132.3330811-1-arnd@arndb.de
Fixes: 3e99cb214f03 ("soc: ti: add initial PRM driver with reset control support")
Add initial PRM (Power and Reset Management) driver for TI OMAP class
SoCs. Initially this driver only supports reset control, but can be
extended to support rest of the functionality, like powerdomain
control, PRCM irq support etc.
Signed-off-by: Tero Kristo <t-kristo@ti.com>
Reviewed-by: Philipp Zabel <p.zabel@pengutronix.de>
Reviewed-by: Tony Lindgren <tony@atomide.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
Add SPDX license identifiers to all Make/Kconfig files which:
- Have no license information of any form
These files fall under the project license, GPL v2 only. The resulting SPDX
license identifier is:
GPL-2.0-only
The default for Kconfig options is always n, so there's no need to
explicitly state a "n" default.
Acked-by: Robert Jarzmik <robert.jarzmik@free.fr>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Most of the PM code needed for am335x and am437x can be moved into a
module under drivers but some core code must remain in mach-omap2 at the
moment. This includes some internal clockdomain APIs and low-level ARM
APIs which are also not exported for use by modules.
Implement a few functions that handle these low-level platform
operations can be passed to the pm33xx module through the use of
platform data.
In addition to this, to be able to share data structures between C and
the sleep33xx and sleep43xx assembly code, we can automatically generate
all of the C struct member offsets and sizes as macros by processing
pm-asm-offsets.c into assembly code and then extracting the relevant
data as is done for the generated platform asm-offsets.h files.
Finally, add amx3_common_pm_init to create a dummy platform_device for
pm33xx so that our soon to be introduced pm33xx module can probe on
am335x and am437x platforms to enable basic suspend to mem and standby
support.
Signed-off-by: Dave Gerlach <d-gerlach@ti.com>
Acked-by: Santosh Shilimkar <ssantosh@kernel.org>
We can handle the sysc interconnect target module in a generic way
for many TI SoCs. Initially let's just enable runtime PM with
autosuspend, and probe the children. This can already be used for
idling interconnect target modules that don't have any device driver
available for the child devices.
For now, the "ti,hwmods" custom binding is still required. That will
be eventually deprecated in later patches. And more features will be
added, such as parsing for sysc capabilities so we can continue
removing the legacy platform data.
Cc: Benoît Cousson <bcousson@baylibre.com>
Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Nishanth Menon <nm@ti.com>
Cc: Matthijs van Duin <matthijsvanduin@gmail.com>
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Peter Ujfalusi <peter.ujfalusi@ti.com>
Cc: Sakari Ailus <sakari.ailus@iki.fi>
Cc: Tero Kristo <t-kristo@ti.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
PINCTRL_TI_IODELAY should be enabled so that "pinctrl_dev" can be created
for pinctrl entries populated with iodelay values in device tree data.
Select PINCTRL_TI_IODELAY for SOC_DRA7XX here.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
AM437x makes use of the omap_l3_noc driver so explicitly select
OMAP_INTERCONNECT in the Kconfig for SOC_AM43XX to ensure it gets enabled
for AM43XX only builds.
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup
Merge "drop last omap3 board files for v4.8" from Tony Lindgren:
Remove the last two legacy board-*.c files for omap3 for legacy
booting for v4.8 to allow making mach-omap2 device tree only for
v4.9.
We've had Nokia N900 and omap3 LDP board-*.c files remaining
while other omap3 devices have been device tree only for quite
a while now. Also N900 and LDP have had device tree based booting
working for years now, but few drivers for N900 were still only
working in legacy only mode until recently. With the remaining
issues out of the way, we discussed on the mailing lists that
we're finally OK to remove the remaining board-*.c files.
For the timing of this pull request, I wanted to wait until
v4.8-rc1 is out to make sure the legacy booting still works fine
after the merge window before doing it.
And for v4.8, let's not touch any other platform data in case we
still need to revert for some reason. This makes the revert just a
question of adding back the legacy board-*.c files.
Then if no issues, we can remove the unused remaining platform
data later on for v4.9.
* tag 'omap-for-v4.8/legacy-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: OMAP2+: Drop legacy board file for LDP
ARM: OMAP2+: Drop legacy board file for n900
Pull ARM SoC cleanups from Olof Johansson:
"The cleanup branch keeps going down in size as we've completed a lot
of the major legacy platform removals and conversions.
A handful of changes this time around, some of the themes or larger
sets are:
- A bunch of i.MX cleanups around platform detection, init call cleanups
- Misc fixes of missing/implicit includes
- Removal of ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (40 commits)
ARM: mps2: fix typo
ARM: s3c64xx: avoid warning about 'struct device_node'
bus: mvebu-mbus: make mvebu_mbus_syscore_ops static
bus: mvebu-mbus: fix __iomem on register pointers
ARM: tegra: Remove board_init_funcs array
ARM: iop: Fix indentation
ARM: imx: remove cpu_is_mx*()
ARM: imx: remove last call to cpu_is_mx5*
ARM: imx: rework mx27_pm_init() call
ARM: imx: deconstruct mx3_idle
ARM: imx: deconstruct mxc_rnga initialization
ARM: imx: remove cpu_is_mx1 check
ARM: i.MX: Do not explicitly call l2x0_of_init()
ARM: i.MX: system.c: Tweak prefetch settings for performance
ARM: i.MX: system.c: Replace magic numbers
ARM: i.MX: system.c: Remove redundant errata 752271 code
ARM: i.MX: system.c: Convert goto to if statement
ARM: Kirkwood: fix kirkwood_pm_init() declaration/type
ARM: Kirkwood: make kirkwood_disable_mbus_error_propagation() static
ARM: orion5x: make orion5x_legacy_handle_irq static
Let's drop the last two remaining omap3 legacy boot board files.
Let's only use the device tree based booting known to work for
these two boards.
We still have two omap3 boards booting in legacy mode in addition
to device tree based booting. All the other ten or so omap2+ SoCs
have been booting using device tree mode only for years now. This
has allowed us to get rid of quite a bit of arch/arm/mach-omap2
related platform init code in favor of dts and driver changes.
Pretty much the only remaining known users for omap3 legacy boot
board files are Kevin's and Russell's boot test systems, and N900
kernel tree maintained by Pali and Ivaylo. And all of them are
also supporting the device tree based booting. The legacy booting
mode has been kept around mostly to verify against regressions.
As there is still a slim chance of possible other uses of the
mainline kernel for these boards, let's just drop the board
files for v4.8, and let's not touch the related platform init
code until around v4.9 time if no issues are found. This makes
it trivial for us to add back the board files with a simple revert.
these two boards.
Acked-By: Sebastian Reichel <sre@kernel.org>
Acked-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Acked-by: Pali Rohár <pali.rohar@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes
Fixes for omaps for v4.7-rc cycle:
- Fix dra7 for hardware issues limiting L4Per and L3init power domains
to on state. Without this the devices may not work correctly after
some time of use because of asymmetric aging. And related to this,
let's also remove the unusable states.
- Always select omap interconnect for am43x as otherwise the am43x
only configurations will not boot properly. This can happen easily
for any product kernels that leave out other SoCs to save memory.
- Fix DSS PLL2 addresses that have gone unused for now
- Select erratum 430973 for omap3, this is now safe to do and can
save quite a bit of debugging time for people who may have left
it out.
* tag 'omap-for-v4.7/fixes-powedomain' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: OMAP: DRA7: powerdomain data: Remove unused pwrsts_mem_ret
ARM: OMAP: DRA7: powerdomain data: Remove unused pwrsts_logic_ret
ARM: OMAP: DRA7: powerdomain data: Set L3init and L4per to ON
ARM: OMAP2+: Select OMAP_INTERCONNECT for SOC_AM43XX
ARM: dts: DRA74x: fix DSS PLL2 addresses
ARM: OMAP2: Enable Errata 430973 for OMAP3
+ Linux 4.7-rc2
AM43XX SoCs make use of the omap_l3_noc driver so explicitly select
OMAP_INTERCONNECT in the Kconfig for SOC_AM43XX to ensure it always gets
enabled for AM43XX only builds.
Enable Erratum 430973 similar to commit 5c86c5339c56 ("ARM:
omap2plus_defconfig: Enable ARM erratum 430973 for omap3") - Since
multiple defconfigs can exist from various points of view (multi_v7,
omap2plus etc.. it is always better to enable the erratum from the
Kconfig selection point of view so that downstream kernels dont have
to rediscover this all over again.
Reported-by: Grygorii Strashko <grygorii.strashko@ti.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
This replaces:
- "select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB" as this can
now be selected directly.
- "select ARCH_WANT_OPTIONAL_GPIOLIB" with no dependency: GPIOLIB
is now selectable by everyone, so we need not declare our
intent to select it.
When ordering the symbols the following rationale was used:
if the selects were in alphabetical order, I moved select GPIOLIB
to be in alphabetical order, but if the selects were not
maintained in alphabetical order, I just replaced
"select ARCH_REQUIRE_GPIOLIB" with "select GPIOLIB".
Cc: Michael Büsch <m@bues.ch>
Cc: arm@kernel.org
This patch explicitly enables the fixes for the below errata applicable
for AM43x Socs as was done for OMAP4.
754322: Faulty MMU translations following ASID switch
775420: A data cache maintenance operation which aborts,
followed by an ISB, without any DSB in-between,
might lead to deadlock
Add workaround for Cortex-A15 ARM erratum 801819 which says in summary
that "A livelock can occur in the L2 cache arbitration that might
prevent a snoop from completing. Under certain conditions this can
cause the system to deadlock. "
Recommended workaround is as follows:
Do both of the following:
1) Do not use the write-back no-allocate memory type.
2) Do not issue write-back cacheable stores at any time when the cache
is disabled (SCTLR.C=0) and the MMU is enabled (SCTLR.M=1). Because it
is implementation defined whether cacheable stores update the cache when
the cache is disabled it is not expected that any portable code will
execute cacheable stores when the cache is disabled.
For implementations of Cortex-A15 configured without the “L2 arbitration
register slice” option (typically one or two core systems), you must
also do the following:
3) Disable write-streaming in each CPU by setting ACTLR[28:25] = 0b1111
So, we provide an option to disable write streaming on OMAP5 and DRA7.
It is a rare condition to occur and may be enabled selectively based
on platform acceptance of risk.
Applies to: A15 revisions r2p0, r2p1, r2p2, r2p3 or r2p4 and REVIDR[3]
is set to 0.
Based on ARM errata Document revision 18.0 (22 Nov 2013)
Note: the configuration for the workaround needs to be done with
each CPU bringup, since CPU0 bringup is done by bootloader, it is
recommended to have the workaround in the bootloader, kernel also does
ensure that CPU0 has the workaround and makes the workaround active
when CPU1 gets active.
With CONFIG_SMP disabled, it is expected to be done by the bootloader.
This does show significant degradation in synthetic tests such as
mbw (https://packages.qa.debian.org/m/mbw.html)
mbw -n 100 100|grep AVG (on a test platform)
Without enabling the erratum:
AVG Method: MEMCPY Elapsed: 0.13406 MiB: 100.00000 Copy: 745.913 MiB/s
AVG Method: DUMB Elapsed: 0.06746 MiB: 100.00000 Copy: 1482.357 MiB/s
AVG Method: MCBLOCK Elapsed: 0.03058 MiB: 100.00000 Copy: 3270.569 MiB/s
After enabling the erratum:
AVG Method: MEMCPY Elapsed: 0.13757 MiB: 100.00000 Copy: 726.913 MiB/s
AVG Method: DUMB Elapsed: 0.12024 MiB: 100.00000 Copy: 831.668 MiB/s
AVG Method: MCBLOCK Elapsed: 0.09243 MiB: 100.00000 Copy: 1081.942 MiB/s
Most benchmarks are designed for specific performance analysis, so
overall usecase must be considered before making a decision to
enable/disable the erratum workaround.
Pending internal investigation, the erratum is kept disabled by default.
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Tony Lindgren <tony@atomide.com>
Suggested-by: Richard Woodruff <r-woodruff2@ti.com>
Suggested-by: Brad Griffis <bgriffis@ti.com>
Make sure to tell the kernel that AM437x devices have ARM TWD timer.
Signed-off-by: Felipe Balbi <balbi@ti.com>
[grygorii.strashko@ti.com: drop ARM Global timer selection, because
it's incompatible with PM (cpuidle/cpufreq). So, it's unsafe to enable
it unconditionally]
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
System will misbehave in the following case:
- AM43XX only build (UP);
- CONFIG_CPU_IDLE=y
- ARM TWD timer enabled and selected as clockevent device.
In the above case, It's expected that broadcast timer will be used as
backup timer when CPUIdle will put MPU in low power states where ARM
TWD will stop and lose its context. But, the CONFIG_SMP might not be
selected when kernel is built for AM43XX SoC only and, as result,
GENERIC_CLOCKEVENTS_BROADCAST option will not be selected also. This
will break CPUIdle and System will stuck in low power states.
Hence, fix it by selecting GENERIC_CLOCKEVENTS_BROADCAST option for
AM43XX SoCs always and add empty tick_broadcast() function
implementation - no need to send any IPI on UP. After this change
timer1 will be selected as broadcast timer the same way as for SMP,
and CPUIdle will work properly.
Enable REGULATOR_FIXED_VOLTAGE for all OMAP2+ platforms
otherwise system can't boot from SD-card when kernel is
built for single SoC (for example, with CONFIG_SOC_DRA7XX=y only).
It's also required for almost all TI SoC's platforms.
"Again we have a sizable (but not huge) cleanup branch with a net delta
of about -3k lines.
Main contents here is:
- A bunch of development/cleanup of a few PXA boards
- Removal of bockw platforms on shmobile, since the platform has now
gone completely multiplatform. Whee!
- move of the 32kHz timer on OMAP to a proper timesource
- Misc cleanup of older OMAP material (incl removal of one board
file)
- Switch over to new common PWM lookup support for several platforms
There's also a handful of other cleanups across the tree, but the
above are the major pieces"
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (103 commits)
ARM: OMAP3: hwmod data: Remove legacy mailbox data and addrs
ARM: DRA7: hwmod data: Remove spinlock hwmod addrs
ARM: OMAP4: hwmod data: Remove spinlock hwmod addrs
ARM: DRA7/AM335x/AM437x: hwmod: Remove gpmc address space from hwmod data
ARM: Remove __ref on hotplug cpu die path
ARM: Remove open-coded version of IRQCHIP_DECLARE
arm: omap2: board-generic: use omap4_local_timer_init for AM437x
ARM: DRA7/AM335x/AM437x: hwmod: Remove elm address space from hwmod data
ARM: OMAP: Remove duplicated operand in OR operation
clocksource: ti-32k: make it depend on GENERIC_CLOCKSOURCE
ARM: pxa: remove incorrect __init annotation on pxa27x_set_pwrmode
ARM: pxa: raumfeld: make some variables static
ARM: OMAP: Change all cpu_is_* occurences to soc_is_* for id.c
ARM: OMAP2+: Rename cpu_is macros to soc_is
arm: omap2: timer: limit hwmod usage to non-DT boots
arm: omap2+: select 32k clocksource driver
clocksource: add TI 32.768 Hz counter driver
arm: omap2: timer: rename omap_sync32k_timer_init()
arm: omap2: timer: always call clocksource_of_init() when DT
arm: omap2: timer: move realtime_counter_init() around
Pull dmaengine updates from Vinod Koul:
"This time we have a very typical update which is mostly fixes and
updates to drivers and no new drivers.
- the biggest change is coming from Peter for edma cleanup which even
caused some last minute regression, things seem settled now
- idma64 and dw updates
- iotdma updates
- module autoload fixes for various drivers
- scatter gather support for hdmac"
* tag 'dmaengine-4.4-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (77 commits)
dmaengine: edma: Add dummy driver skeleton for edma3-tptc
Revert "ARM: DTS: am33xx: Use the new DT bindings for the eDMA3"
Revert "ARM: DTS: am437x: Use the new DT bindings for the eDMA3"
dmaengine: dw: some Intel devices has no memcpy support
dmaengine: dw: platform: provide platform data for Intel
dmaengine: dw: don't override platform data with autocfg
dmaengine: hdmac: Add scatter-gathered memset support
dmaengine: hdmac: factorise memset descriptor allocation
dmaengine: virt-dma: Fix kernel-doc annotations
dmaengine: edma: New device tree binding
dmaengine: Kconfig: edma: Select TI_DMA_CROSSBAR in case of ARCH_OMAP
dmaengine: ti-dma-crossbar: Add support for crossbar on AM33xx/AM43xx
dmaengine: edma: Merge the of parsing functions
dmaengine: edma: Do not allocate memory for edma_rsv_info in case of DT boot
dmaengine: edma: Refactor the dma device and channel struct initialization
dmaengine: edma: Get qDMA channel information from HW also
dmaengine: edma: Merge map_dmach_to_queue into assign_channel_eventq
dmaengine: edma: Correct PaRAM access function names (_parm_ to _param_)
On boards with more than 2GB of RAM booting goes wrong with things not
working and we're getting lots of l3 warnings:
WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147
l3_interrupt_handler+0x260/0x384()
44000000.ocp:L3 Custom Error: MASTER MMC6 TARGET DMM1 (Idle):
Data Access in User mode during Functional access
[<c044e158>] (scsi_add_host_with_dma) from [<c04705c8>]
(ata_scsi_add_hosts+0x5c/0x18c)
[<c04705c8>] (ata_scsi_add_hosts) from [<c046b13c>]
(ata_host_register+0x150/0x2cc)
[<c046b13c>] (ata_host_register) from [<c046b38c>]
(ata_host_activate+0xd4/0x124)
[<c046b38c>] (ata_host_activate) from [<c047f42c>]
(ahci_host_activate+0x5c/0x194)
[<c047f42c>] (ahci_host_activate) from [<c0480854>]
(ahci_platform_init_host+0x1f0/0x3f0)
[<c0480854>] (ahci_platform_init_host) from [<c047c9dc>]
(ahci_probe+0x70/0x98)
[<c047c9dc>] (ahci_probe) from [<c04220cc>]
(platform_drv_probe+0x54/0xb4)
Let's fix the issue by enabling ZONE_DMA for LPAE. Note that we need to
limit dma_zone_size to 2GB as the rest of the RAM is beyond the 4GB limit.
Let's also fix things for dra7 as done in similar patches in the TI tree
by Lokesh Vutla <lokeshvutla@ti.com>.
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Now that we have a 32k clocksource driver, let's
select it for OMAP2PLUS builds.
Move the code out from arch/arm/common and merge it inside of the dmaengine
driver.
This change is done with as minimal (if eny) functional change to the code
as possible to avoid introducing regression.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
OMAP5 SoC has Cortex-A15 which does not use TWD timer. It uses
ARCH_TIMER instead, clean up unwanted configuration and enable
OMAP_INTERCONNECT and OPP which is necessary for expected functionality
on the SoC.
Reported-by: Carlos Hernandez <ceh@ti.com>
Reported-by: Felipe Balbi <balbi@ti.com>
DRA7 does use OPP, uses OMAP interconnect and also does require SCU.
These are missing in the SoC only build of DRA7 breaking various PM
features in DRA7 only build.
Pull ARM development updates from Russell King:
"Included in this update:
- moving PSCI code from ARM64/ARM to drivers/
- removal of some architecture internals from global kernel view
- addition of software based "privileged no access" support using the
old domains register to turn off the ability for kernel
loads/stores to access userspace. Only the proper accessors will
be usable.
- addition of early fixup support for early console
- re-addition (and reimplementation) of OMAP special interconnect
barrier
- removal of finish_arch_switch()
- only expose cpuX/online in sysfs if hotpluggable
- a number of code cleanups"
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (41 commits)
ARM: software-based priviledged-no-access support
ARM: entry: provide uaccess assembly macro hooks
ARM: entry: get rid of multiple macro definitions
ARM: 8421/1: smp: Collapse arch_cpu_idle_dead() into cpu_die()
ARM: uaccess: provide uaccess_save_and_enable() and uaccess_restore()
ARM: mm: improve do_ldrd_abort macro
ARM: entry: ensure that IRQs are enabled when calling syscall_trace_exit()
ARM: entry: efficiency cleanups
ARM: entry: get rid of asm_trace_hardirqs_on_cond
ARM: uaccess: simplify user access assembly
ARM: domains: remove DOMAIN_TABLE
ARM: domains: keep vectors in separate domain
ARM: domains: get rid of manager mode for user domain
ARM: domains: move initial domain setting value to asm/domains.h
ARM: domains: provide domain_mask()
ARM: domains: switch to keeping domain value in register
ARM: 8419/1: dma-mapping: harmonize definition of DMA_ERROR_CODE
ARM: 8417/1: refactor bitops functions with BIT_MASK() and BIT_WORD()
ARM: 8416/1: Feroceon: use of_iomap() to map register base
ARM: 8415/1: early fixmap support for earlycon
* fixes: (28 commits)
ARM: ux500: add an SMP enablement type and move cpu nodes
ARM: dts: keystone: fix dt bindings to use post div register for mainpll
ARM: nomadik: disable UART0 on Nomadik boards
ARM: dts: i.MX35: Fix can support.
ARM: OMAP2+: hwmod: Fix _wait_target_ready() for hwmods without sysc
ARM: dts: add CPU OPP and regulator supply property for exynos4210
ARM: dts: Update video-phy node with syscon phandle for exynos3250
ARM: keystone: dts: rename pcie nodes to help override status
ARM: keystone: dts: fix dt bindings for PCIe
ARM: pxa: fix dm9000 platform data regression
ARM: DRA7: hwmod: fix gpmc hwmod
ARM: dts: Correct audio input route & set mic bias for am335x-pepper
ARM: OMAP2+: Add HAVE_ARM_SCU for AM43XX
MAINTAINERS: digicolor: add dts files
ARM: ux500: fix MMC/SD card regression
ARM: ux500: define serial port aliases
ARM: dts: OMAP5: Add #iommu-cells property to IOMMUs
ARM: dts: OMAP4: Add #iommu-cells property to IOMMUs
ARM: dts: Fix frequency scaling on Gumstix Pepper
ARM: dts: configure regulators for Gumstix Pepper
Restore the OMAP4 barrier behaviour using the new implementation which
allows multiplatform systems to hook into the mb() and wmb() ARM
implementations to perform any necessary additional barrier maintanence.
Acked-by: Richard Woodruff <r-woodruff2@ti.com>
This reverts commit 606da4826b89b044b51e3a84958b802204cfe4c7.
We actually need this code for proper behaviour of OMAP4, and it needs
fixing a different way other than just removing the code. Disabling
code which is necessary in the hopes of persuing multiplatform kernels
is a stupid approach.
CONFIG_HAVE_ARM_SCU only gets selected if CONFIG_SMP is selected in an OMAP
system, however AM43XX needs this option regardless of CONFIG_SMP and also
for an AM43XX only build as it is important for controlling power in the SoC.
Without this we cannot suspend the CPU for SoC suspend or cpuidle. The
ARM Cortex A9 needs SCU CPU Power Status bits to be set to off mode in order
for the PRCM to transition the MPU to low power modes.
We've been moving all omap2+ based systems to boot in device tree only
mode for a few years now. Only omap3 has legacy booting support
remaining. Most omap3 boards already have related arch/arm/boot/*.dts*
files for booting with device tree.
This board has support for device tree based booting, and we've been
printing warnings about the legacy booting being deprecated for a
few merge cycles now. Let's attempt to remove the legacy booting
for it.
The reason for removing the legacy booting support now rather than
later is we can simply revert this patch if necessary if we run
into some unexpected issues that are not trivial to fix for the
Cc: Tim Nordell <tim.nordell@logicpd.com>
for it.
for it.
Cc: Florian Vaussard <florian.vaussard@epfl.ch>
Acked-by: Ash Charles <ashcharles@gmail.com>
for it.
Cc: Dmitry Lifshitz <lifshitz@compulab.co.il>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Pull ARM SoC late changes from Olof Johansson:
"We were expecting to sit on this branch through most of the merge
window since the contents was merged into our tree late, but we ended
up sitting on all of our contents so it can go in with the rest.
The contents here is:
- a large branch of cleanups of the CM/PRM blocks on OMAP.
- a couple of patches plumbing up CM/PRM on OMAP5 and DRA7.
- a branch with DT updates for Freescale i.MX. including some
shuffling from .dts to .dtsi (include) files that causes a little
churn"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (78 commits)
ARM: OMAP2+: Fix booting with configs that don't have MFD_SYSCON
ARM: OMAP4+: control: add support for initializing control module via DT
ARM: dts: dra7: add minimal l4 bus layout with control module support
ARM: dts: omap5: add minimal l4 bus layout with control module support
ARM: OMAP4+: control: remove support for legacy pad read/write
ARM: OMAP4: display: convert display to use syscon for dsi muxing
ARM: dts: omap4: add minimal l4 bus layout with control module support
ARM: dts: am4372: add minimal l4 bus layout with control module support
ARM: dts: am43xx-epos-evm: fix pinmux node layout
ARM: dts: am33xx: add minimal l4 bus layout with control module support
ARM: dts: omap3: add minimal l4 bus layout with control module support
ARM: dts: omap24xx: add minimal l4 bus layout with control module support
ARM: OMAP2+: control: add syscon support for register accesses
ARM: OMAP2+: id: cache omap_type value
ARM: OMAP2+: control: remove API for getting control module base address
ARM: OMAP2+: clock: add low-level support for regmap
ARM: OMAP4+: PRM: get rid of cpu_is_omap44xx calls from interrupt init
ARM: OMAP4+: PRM: setup prm_features from the PRM init time flags
ARM: OMAP2+: CM: move SoC specific init calls within a generic API
ARM: OMAP4+: PRM: determine prm_device_inst based on DT compatibility
"We've got a fairly large cleanup branch this time. The bulk of this
is removal of non-DT platforms of several flavors:
- Atmel at91 platforms go full-DT, with removal of remaining
board-file based support
- OMAP removes legacy board files for three more platforms
- removal of non-DT mach-msm, newer Qualcomm platforms now live in
mach-qcom
- Freescale i.MX25 also removes non-DT platform support"
Most of the rest of the changes here are fallout from the above, i.e. for
example removal of drivers that now lack platforms, etc.
* tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (58 commits)
mmc: Remove msm_sdcc driver
gpio: Remove gpio-msm-v1 driver
ARM: Remove mach-msm and associated ARM architecture code
ARM: shmobile: cpuidle: Remove the pointless default driver
ARM: davinci: dm646x: Add interrupt resource for McASPs
ARM: davinci: irqs: Correct McASP1 TX interrupt definition for DM646x
ARM: davinci: dm646x: Clean up the McASP DMA resources
ARM: davinci: devices-da8xx: Add support for McASP2 on da830
ARM: davinci: devices-da8xx: Clean up and correct the McASP device creation
ARM: davinci: devices-da8xx: Add interrupt resource to McASP structs
ARM: davinci: devices-da8xx: Add resource name for the McASP DMA request
ARM: OMAP2+: Remove legacy support for omap3 TouchBook
ARM: OMAP3: Remove legacy support for devkit8000
ARM: OMAP3: Remove legacy support for EMA-Tech Stalker board
ARM: shmobile: Consolidate the pm code for R-Car Gen2
ARM: shmobile: r8a7791: Correct SYSCIER value
ARM: shmobile: r8a7790: Correct SYSCIER value
ARM: at91: remove old setup
ARM: at91: sama5d4: remove useless map_io
ARM: at91: sama5 use SoC detection infrastructure
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/late
Merge "urgent omap boot fix for v4.1 if MFD_SYSCON is not set" from Tony
Lindgren:
Urgent pull request for v4.1 to booting for custom kernel
.config files that do not have MFD_SYSCON set.
Omaps now have a dependency to MFD_SYSCON for system control
module generic register area and some clocks with the changes
done in omap-for-v4.1/prcm-dts branch.
This can be pulled on top of omap-for-v4.1/prcm-dts, or into
fixes for v4.1.
We already do have a slight MFD_SYSCON dependency for
REGULATOR_PBIAS for dual voltage MMC cards on the first MMC
bus for many devices, so from that point of view this can
also be merged separately from omap-for-v4.1/prcm-dts.
* tag 'omap-for-v4.1/prcm-dts-mfd-syscon-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
With the recent changes omaps have developed a dependency to MFD_SYSCON.
This is used for system control module generic register area and some
clocks.
We do have it selected in omap2plus_defconfig, but targeted config
files may not have it selected. Let's make sure it's selected like
few other ARM platforms are already doing.
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
ARM errata 798181 is applicable for OMAP5/DRA7 based devices. So enable
the same in the build.
DRA7xx is based on Cortex-A15 r2p2 revision.
ARM Errata extract and workaround information is as below.
On Cortex-A15 (r0p0..r3p2) the TLBI*IS/DSB operations are not
adequately shooting down all use of the old entries. The
ARM_ERRATA_798181 option enables the Linux kernel workaround
for this erratum which sends an IPI to the CPUs that are running
the same ASID as the one being invalidated.
Signed-off-by: Praneeth Bajjuri <praneeth@ti.com>
Acked-by: Nishanth Menon <nm@ti.com>
As it seems this board only has minimal support upstreamed for the
legacy booting and has not seen activity for on the mailing lists
for a few years, let's attempt to remove the related legacy board-*.c
file.
I do not have this board, but it seems getting the same level of
support with device tree based booting is mostly just configuring
the .dts file. And there is no need to upgrade the boot loader as
we can boot with appended DTB too. And most of the omap3 boards
seem to be related to omap3-evm, and omap3beagleboard that are
supported with device tree based booting.
If somebody is using this board actively with the mainline kernel,
please communicate this to the linux-omap mailing list so we can
get the board booting with device tree based support. I can help
some too getting the minimal device tree based booting going if
help is needed.
The reason for attempting to remove this board now is that I'd
rather get the remaining omap3 legacy booting support into a known
state where we at least have a .dts file being written for the
remaining legacy boards. That is because for the next few merge
cycles we can still revert this patch if absolutely necessary,
but I'd rather not get suprised by missing .dts files at the point
where we are ready to drop all remaining omap3 legacy booting
support later on.
Cc: Gregoire Gentil <gregoire@gentil.com>
Cc: Radek Pilar <mrkva@mrkva.eu>
file.
help is needed.
support later on.
http://www.embest-tech.com/product/single-board-computers/index.html
Cc: Thomas Weber <thomas@tomweber.eu>
file.
help is needed.
support later on.
Also looks like this board is no longer listed on ema-tech.com
product page at:
http://ema-tech.com/en/categories.html
Cc: Jason Lam <lzg@ema-tech.com>
The Kconfig-Option OMAP4_ERRATA_I688 is never visible due to a
contradiction in it's dependencies.
The option requires ARCH_MULTIPLATFORM to be 'disabled'. However, an
enclosing menu requires either ARCH_MULTI_V6 or ARCH_MULTI_V7 to be
enabled. These options inherit a dependency from an enclosing menu,
that requires ARCH_MULTIPLATFORM to be 'enabled'.
This is a contradiction and made this option also unavailable for
non-multiplatform configurations.
Since there are no selects on OMAP4_ERRATA_I688, which would ignore
dependencies, the code related to that option is dead and can be
removed.
This (logical) defect has been found with the undertaker tool.
(https://undertaker.cs.fau.de)
Signed-off-by: Stefan Hengelein <stefan.hengelein@fau.de>
We still have SND_OMAP_SOC_AM3517EVM depending on MACH_OMAP3517EVM,
so let's keep MACH_OMAP3517EVM Kconfig option around for a little
bit longer.
This removes the dependency between ARM SoC changes and the ASoC
changes, and allows the following three options for the driver:
1. Update the driver for device tree based booting
2. Initialize the driver with legacy platform data, then update
3. Just remove the driver if there are no audio users for
3517-evm board
Reported-by: Paul Bolle <pebolle@tiscali.nl>
This board is working with device tree based booting so there should
not be any need to keep the legacy booting support around. People
using this board can boot it with appended DTB with existing bootloader.
By removing the 3517 legacy booting support we can get a bit closer to
making all of omap3 boot in device tree only mode.
