path: root/arch/arm/mach-omap1
2011-10-31Merge branch 'next/fixes' into next/cleanupArnd Bergmann
Conflicts: arch/arm/mach-mxs/include/mach/gpio.h arch/arm/plat-mxc/include/mach/gpio.h drivers/video/omap/lcd_apollon.c drivers/video/omap/lcd_ldp.c drivers/video/omap/lcd_overo.c
2011-10-31Merge branch 'depends/rmk/memory_h' into next/fixesArnd Bergmann
Fix up all conflicts between the memory.h cleanup and bug fixes. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2011-10-08Merge branch 'depends/rmk/devel-stable' into next/cleanupArnd Bergmann
2011-09-26ARM: OMAP: mcbsp: Move address definitions to arch/arm/mach-omap1/mcbsp.cJarkko Nikula
These address definitions are OMAP1 specific can be in single source file. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-09-26ARM: OMAP: mcbsp: Implement generic register accessJarkko Nikula
Register access can be made more generic by calculating register address offsets runtime from common register definitions and by using reg_size and reg_step variables that are passed via platform data. Common register definitions are possible since McBSP registers are ordered similarly between OMAP versions. Remove also references to OMAP2+ specific config_type variable from generic McBSP code since other variables and feature flags are better to carry needed information from platform code. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-09-26ARM: OMAP: mcbsp: Move out omap_mcbsp_register_board_cfg from ↵Jarkko Nikula
plat-omap/devices.c Only OMAP1s are using omap_mcbsp_register_board_cfg after OMAP2+ hwmod conversion so it can be moved to mach-omap1/mcbsp.c. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-09-26ARM: OMAP: move OMAP1 memory config from plat/memory.h to its mach/memory.hNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com>
2011-09-26ARM: mach-omap1: clean up debug-macro.SNicolas Pitre
This achieves two goals: 1) Get rid of omap_uart_v2p() and omap_uart_p2v() which were the last users of PLAT_PHYS_OFFSET. 2) Remove the probing of the M bit in the CP15 control reg and make the access to the .data variables completely position independent. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Tested-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-09-26ARM: plat-omap: make OMAP_UART_INFO into a relative offsetNicolas Pitre
This is the first step to remove PLAT_PHYS_OFFSET usage from the debug UART code. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Tested-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-09-26ARM: add an extra temp register to the low level debugging addruart macroNicolas Pitre
Some platforms (like OMAP not to name it) are doing rather complicated hacks just to determine the base UART address to use. Let's give their addruart macro some slack by providing an extra work register which will allow for much needed cleanups. This is basically a no-op as this commit is only adding the extra argument to the macro but no one is using it yet. Signed-off-by: nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-08-23Merge branch 'atag_offset' of git://git.linaro.org/people/nico/linux into ↵Russell King
devel-stable
2011-08-22ARM: omap: Setup consistent dma size at boot timeJon Medhurst
Signed-off-by: Jon Medhurst <tixy@yxit.co.uk> CC: Tony Lindgren <tony@atomide.com>
2011-08-21ARM: mach-omap1: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-08-08ARM: gpio: convert includes of mach/gpio.h and asm/gpio.h to linux/gpio.hRussell King
Convert arch/arm includes of mach/gpio.h and asm/gpio.h to linux/gpio.h before we start consolidating the individual platform implementations of the gpio header files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-26Merge branch 'next/cross-platform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: Consolidate the clkdev header files ARM: set vga memory base at run-time ARM: convert PCI defines to variables ARM: pci: make pcibios_assign_all_busses use pci_has_flag ARM: remove unnecessary mach/hardware.h includes pci: move microblaze and powerpc pci flag functions into asm-generic powerpc: rename ppc_pci_*_flags to pci_*_flags Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'next/cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (133 commits) ARM: EXYNOS4: Change devname for FIMD clkdev ARM: S3C64XX: Cleanup mach/regs-fb.h from mach-s3c64xx ARM: S5PV210: Cleanup mach/regs-fb.h from mach-s5pv210 ARM: S5PC100: Cleanup mach/regs-fb.h from mach-s5pc100 ARM: S3C24XX: Use generic s3c_set_platdata for devices ARM: S3C64XX: Use generic s3c_set_platdata for OneNAND ARM: SAMSUNG: Use generic s3c_set_platdata for NAND ARM: SAMSUNG: Use generic s3c_set_platdata for USB OHCI ARM: SAMSUNG: Use generic s3c_set_platdata for HWMON ARM: SAMSUNG: Use generic s3c_set_platdata for FB ARM: SAMSUNG: Use generic s3c_set_platdata for TS ARM: S3C64XX: Add PWM backlight support on SMDK6410 ARM: S5P64X0: Add PWM backlight support on SMDK6450 ARM: S5P64X0: Add PWM backlight support on SMDK6440 ARM: S5PC100: Add PWM backlight support on SMDKC100 ARM: S5PV210: Add PWM backlight support on SMDKV210 ARM: EXYNOS4: Add PWM backlight support on SMDKC210 ARM: EXYNOS4: Add PWM backlight support on SMDKV310 ARM: SAMSUNG: Create a common infrastructure for PWM backlight support clocksource: convert 32-bit down counting clocksource on S5PV210/S5P64X0 ... Fix up trivial conflict in arch/arm/mach-imx/mach-scb9328.c
2011-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: (51 commits) PM: Improve error code of pm_notifier_call_chain() PM: Add "RTC" to PM trace time stamps to avoid confusion PM / Suspend: Export suspend_set_ops, suspend_valid_only_mem PM / Suspend: Add .suspend_again() callback to suspend_ops PM / OPP: Introduce function to free cpufreq table ARM / shmobile: Return -EBUSY from A4LC power off if A3RV is active PM / Domains: Take .power_off() error code into account ARM / shmobile: Use genpd_queue_power_off_work() ARM / shmobile: Use pm_genpd_poweroff_unused() PM / Domains: Introduce function to power off all unused PM domains OMAP: PM: disable idle on suspend for GPIO and UART OMAP: PM: omap_device: add API to disable idle on suspend OMAP: PM: omap_device: add system PM methods for PM domain handling OMAP: PM: omap_device: conditionally use PM domain runtime helpers PM / Runtime: Add new helper function: pm_runtime_status_suspended() PM / Domains: Queue up power off work only if it is not pending PM / Domains: Improve handling of wakeup devices during system suspend PM / Domains: Do not restore all devices on power off error PM / Domains: Allow callbacks to execute all runtime PM helpers PM / Domains: Do not execute device callbacks under locks ...
2011-07-22Merge branch 'gpio/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'gpio/next' of git://git.secretlab.ca/git/linux-2.6: (61 commits) gpio/mxc/mxs: fix build error introduced by the irq_gc_ack() renaming mcp23s08: add i2c support mcp23s08: isolate spi specific parts mcp23s08: get rid of setup/teardown callbacks gpio/tegra: dt: add binding for gpio polarity mcp23s08: remove unused work queue gpio/da9052: remove a redundant assignment for gpio->da9052 gpio/mxc: add device tree probe support ARM: mxc: use ARCH_NR_GPIOS to define gpio number gpio/mxc: get rid of the uses of cpu_is_mx() gpio/mxc: add missing initialization of basic_mmio_gpio shadow variables gpio: Move mpc5200 gpio driver to drivers/gpio GPIO: DA9052 GPIO module v3 gpio/tegra: Use engineering names in DT compatible property of/gpio: Add new method for getting gpios under different property names gpio/dt: Refine GPIO device tree binding gpio/ml-ioh: fix off-by-one for displaying variable i in dev_err gpio/pca953x: Deprecate meaningless device-tree bindings gpio/pca953x: Remove dynamic platform data pointer gpio/pca953x: Fix IRQ support. ...
2011-07-21Merge branch 'next-samsung-cleanup' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung into next/cleanup
2011-07-19ARM: Consolidate the clkdev header filesKyungmin Park
Now most of ARM machines has the alsmot same __clk_get/put() macro So place it at the arch/arm/include/asm/clkdev.h and remove the reduntant header files But some machines don't have the same form as above. It can use the machince specific clkdev file by HAVE_MACH_CLKDEV config Now there are only 3 caese. 1) define the clk structure with clkdev macro => Need to move clk structure to proper header file arch/arm/mach-versatile/include/mach/clkdev.h arch/arm/mach-realview/include/mach/clkdev.h arch/arm/mach-vexpress/include/mach/clkdev.h arch/arm/mach-integrator/include/mach/clkdev.h 2) export the __clk_get/put function at clock.c arch/arm/mach-shmobile/include/mach/clkdev.h 3) demuxing the clk source arch/arm/mach-u300/include/mach/clkdev.h Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2011-07-15Merge branch 'pm-domains' into for-linusRafael J. Wysocki
* pm-domains: (33 commits) ARM / shmobile: Return -EBUSY from A4LC power off if A3RV is active PM / Domains: Take .power_off() error code into account ARM / shmobile: Use genpd_queue_power_off_work() ARM / shmobile: Use pm_genpd_poweroff_unused() PM / Domains: Introduce function to power off all unused PM domains PM / Domains: Queue up power off work only if it is not pending PM / Domains: Improve handling of wakeup devices during system suspend PM / Domains: Do not restore all devices on power off error PM / Domains: Allow callbacks to execute all runtime PM helpers PM / Domains: Do not execute device callbacks under locks PM / Domains: Make failing pm_genpd_prepare() clean up properly PM / Domains: Set device state to "active" during system resume ARM: mach-shmobile: sh7372 A3RV requires A4LC PM / Domains: Export pm_genpd_poweron() in header ARM: mach-shmobile: sh7372 late pm domain off ARM: mach-shmobile: Runtime PM late init callback ARM: mach-shmobile: sh7372 D4 support ARM: mach-shmobile: sh7372 A4MP support ARM: mach-shmobile: sh7372: make sure that fsi is peripheral of spu2 ARM: mach-shmobile: sh7372 A3SG support ...
2011-07-07omap: mcbsp: Remove port number enumsJarkko Nikula
These McBSP port number enums are used only in two places in the McBSP code so we may remove then and just use numeric values like rest of the code does. Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-07-04omap: drop __initdata tags from static struct platform_device declarationsJanusz Krzysztofik
Pointers to statically declared platform device structures which are registered with platform_device_register() are then used during run time to access these structure members, for example from platform_uevent() and much more. Therefore, these structures should never be placed inside sections which are dropped after boot. Fix platform devices incorrectly tagged with __initdata which happen to exist inside OMAP sub-trees. This bug has exhibited itself on my ARM/OMAP1 based Amstrad Delta videophone after commit 6d3163ce86dd386b4f7bda80241d7fea2bc0bb1d, "mm: check if any page in a pageblock is reserved before marking it MIGRATE_RESERVE", resulting in reading from several /sys/device/platform/*/uevent files always ending up with segmentation faults. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Acked-by: Felipe Balbi <balbi@ti.com> Cc: Varadarajan, Charulatha <charu@ti.com> Cc: Jarkko Nikula <jhnikula@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-07-02PM: Rename clock management functionsRafael J. Wysocki
The common PM clock management functions may be used for system suspend/resume as well as for runtime PM, so rename them accordingly. Modify kerneldoc comments describing these functions and kernel messages printed by them, so that they refer to power management in general rather that to runtime PM. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-07-02PM / Domains: Rename struct dev_power_domain to struct dev_pm_domainRafael J. Wysocki
The naming convention used by commit 7538e3db6e015e890825fbd9f86599b (PM: Add support for device power domains), which introduced the struct dev_power_domain type for representing device power domains, evidently confuses some developers who tend to think that objects of this type must correspond to "power domains" as defined by hardware, which is not the case. Namely, at the kernel level, a struct dev_power_domain object can represent arbitrary set of devices that are mutually dependent power management-wise and need not belong to one hardware power domain. To avoid that confusion, rename struct dev_power_domain to struct dev_pm_domain and rename the related pointers in struct device and struct pm_clk_notifier_block from pwr_domain to pm_domain. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Kevin Hilman <khilman@ti.com>
2011-06-29Merge branch 'for_3.1/pm-misc' of ↵Tony Lindgren
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-omap-pm into devel-cleanup Conflicts: arch/arm/mach-omap2/pm-debug.c arch/arm/mach-omap2/pm.h
2011-06-27omap2+: Reserve clocksource and timesource and initialize dmtimer laterTony Lindgren
There's no need to initialize the dmtimer framework early. Just mark the clocksource and timesource as reserved, and initialize dmtimer with an arch_initcall. Signed-off-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-06-20omap: Set separate timer init functions to avoid cpu_is_omap testsTony Lindgren
This is needed for the following patches so we can initialize the rest of the hardware timers later on. As with the init_irq calls, there's no need to do cpu_is_omap calls during the timer init as we only care about the major omap generation. This means that we can initialize the sys_timer with the .timer entries alone. Note that for now we just set stubs for the various sys_timer entries that will get populated in a later patch. The following patches will also remove the omap_dm_timer_init calls and change the init for the rest of the hardware timers to happen with an arch_initcall. Signed-off-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-06-16gpio/omap: cleanup show revision, remove cpu_is checks, display only onceKevin Hilman
Remove cpu_is_* checks from gpio_show_revision() by passing in the revision address offset from platform data. SoCs with no revision register (15xx, 7xx, and all MPUIOs) use -1 (actually, USHRT_MAX) to signify no register. While here, all GPIO banks are assumed to be the same revision, so fix show_revision() to only show the revision for the first bank it finds. This removes duplicate GPIO revision prints during boot. Thanks to Charulatha V <charu@ti.com> for finding/fixing a few -1s that were missed in the original patch. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-06-16gpio/omap: conslidate enable/disable of GPIO IRQs, remove ifdefsKevin Hilman
Cleanup GPIO IRQ enable/disable handling by removing SoC-specific Also split enable/disable IRQ into separate functions for better readability and also facilitate potentially moving to generic irq_chip in the future. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-06-16gpio/omap: consolidate IRQ status handling, remove #ifdefsKevin Hilman
Cleanup IRQ status handling by passing IRQ status register offsets via platform data. Cleans up clearing of GPIO IRQ status and GPIO ISR handler. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-06-16gpio/omap: consolidate direction, input, output, remove #ifdefsKevin Hilman
Add register offset fields to GPIO platform_data for registers. This patch adds registers that control direction, input and output data. Using these register offsets in the common driver allows removal of #ifdefs and greatly improves readability. Also create dedicated data out functions: one for banks with dedicated set/clear registers, and another for banks with a single mask register. Signed-off-by: Kevin Hilman <khilman@ti.com>
2011-06-16omap: Use separate init_irq functions to avoid cpu_is_omap tests earlyTony Lindgren
This allows us to remove cpu_is_omap calls from init_irq functions. There should not be any need for cpu_is_omap calls as at this point. During the timer init we only care about SoC generation, and not about subrevisions. The main reason for the patch is that we want to initialize only minimal omap specific code from the init_early call. Signed-off-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-06-14OMAP1: PM: register notifiers with generic clock ops even when !PM_RUNTIMEKevin Hilman
When runtime PM is disabled, device clocks need to be enabled on device add and disabled on device remove. This currently is not happening because in the !PM_RUNTIME case, no notifiers are registered for OMAP1 devices. Fix this by ensuring notifiers are registered, even in the !PM_RUNTIME case. Reported-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Tested-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-06-01arch/arm/mach-omap1/dma.c: Invert calls to platform_device_put and ↵Julia Lawall
platform_device_del Platform_device_del should be called before platform_device_put, as platform_device_put can delete the structure. Additionally, improve the error handling code for the call to ioremap, so that it calls platform_device_put. The semantic match that finds this problem is: (http://coccinelle.lip6.fr/) // <smpl> @@ expression e1,e2; @@ *platform_device_put(e1); ... when != e1 = e2 *platform_device_del(e1); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-05-23Merge branches 'consolidate-clksrc', 'consolidate-flash', ↵Russell King
'consolidate-generic', 'consolidate-smp', 'consolidate-stmp' and 'consolidate-zones' into consolidate
2011-05-23clocksource: convert OMAP1 to 32-bit down counting clocksourceRussell King
Convert the OMAP1 32-bit down counting clocksource to the generic clocksource infrastructure. Tested-by: Tony Lindgren <tony@atomide.com> Cc: linux-omap@vger.kernel.org Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-23ARM: omap1: convert to using readl/writel instead of volatile structRussell King
2011-05-23ARM: omap1: delete useless interrupt handlerRussell King
The OMAP1 clocksource interrupt handler just increments a variable which otherwise isn't used, so this seems to be unnecessary. Tony Lindgren confirms, so lets remove it. Acked-by: Kevin Hilman <khilman@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Cc: linux-omap@vger.kernel.org Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-20ARM: 6910/1: MTD: physmap: let set_vpp() pass a platform_device instead of a ↵Marc Zyngier
map_info The set_vpp() method provided by physmap passes a map_info back to the platform code, which has little relevance as far as the platform is concerned (this parameter is completely unused). Instead, pass the platform_device, which can be used in the pismo driver to retrieve some important information in a nicer way, instead of the hack that was in place. The empty set_vpp function in board-at572d940hf_ek.c is left untouched, as the board/SoC is scheduled for removal. Cc: Andrew Victor <linux@maxim.org.za> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Ben Dooks <ben-linux@fluff.org> Acked-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-05-16OMAP1 / PM: Use generic clock manipulation routines for runtime PMRafael J. Wysocki
Convert OMAP1 to using the new generic clock manipulation routines and a device power domain for runtime PM instead of overriding the platform bus type's runtime PM callbacks. This allows us to simplify OMAP1-specific code and to share some code with other platforms (shmobile in particular). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Kevin Hilman <khilman@ti.com>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-17Merge branch 'omap-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: (258 commits) omap: zoom: host should not pull up wl1271's irq line arm: plat-omap: iommu: fix request_mem_region() error path OMAP2+: Common CPU DIE ID reading code reads wrong registers for OMAP4430 omap4: mux: Remove duplicate mux modes omap: iovmm: don't check 'da' to set IOVMF_DA_FIXED flag omap: iovmm: disallow mapping NULL address when IOVMF_DA_ANON is set omap2+: mux: Fix compile when CONFIG_OMAP_MUX is not selected omap4: board-omap4panda: Initialise the serial pads omap3: board-3430sdp: Initialise the serial pads omap4: board-4430sdp: Initialise the serial pads omap2+: mux: Add macro for configuring static with omap_hwmod_mux_init omap2+: mux: Remove the use of IDLE flag omap2+: Add separate list for dynamic pads to mux perf: add OMAP support for the new power events OMAP4: Add IVA OPP enteries. OMAP4: Update Voltage Rail Values for MPU, IVA and CORE OMAP4: Enable 800 MHz and 1 GHz MPU-OPP OMAP3+: OPP: Replace voltage values with Macros OMAP3: wdtimer: Fix CORE idle transition Watchdog: omap_wdt: add fine grain runtime-pm ... Fix up various conflicts in - arch/arm/mach-omap2/board-omap3evm.c - arch/arm/mach-omap2/clock3xxx_data.c - arch/arm/mach-omap2/usb-musb.c - arch/arm/plat-omap/include/plat/usb.h - drivers/usb/musb/musb_core.h
2011-03-16Merge branch 'p2v' into develRussell King
Conflicts: arch/arm/kernel/module.c arch/arm/mach-s5pv210/sleep.S
2011-03-16Merge branches 'at91', 'ep93xx', 'errata', 'footbridge', 'fncpy', 'gemini', ↵Russell King
'irqdata', 'pm', 'sh', 'smp', 'spear', 'ux500' and 'via' into devel
2011-03-08OMAP1: McBSP: fix build break for non-multi-OMAP1 configsPaul Walmsley
Commit 3cf32bba8ca0e0052ca41d74d455a5805b7fea85 ("OMAP: McBSP: Convert McBSP to platform device model") breaks compilation with non-multi-OMAP1 configs: CC arch/arm/mach-omap1/mcbsp.o arch/arm/mach-omap1/mcbsp.c: In function 'omap1_mcbsp_init': arch/arm/mach-omap1/mcbsp.c:384: warning: dereferencing 'void *' pointer arch/arm/mach-omap1/mcbsp.c:387: error: invalid use of void expression arch/arm/mach-omap1/mcbsp.c:390: warning: dereferencing 'void *' pointer arch/arm/mach-omap1/mcbsp.c:393: error: invalid use of void expression Fix by avoiding NULL dereferences. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kishon Vijay Abraham I <kishon@ti.com> Cc: Tony Lindgren <tony@atomide.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> [tony@atomide.com: updated description not to remove unnecessary branch name] Signed-off-by: Tony Lindgren <tony@atomide.com>
2011-02-24OMAP: McBSP: Convert McBSP to platform device modelKishon Vijay Abraham I
Implement McBSP as platform device and add support for registering through platform device layer using resource structures. Later in this patch series, OMAP2+ McBSP driver would be modified to use hwmod framework after populating the omap2+ hwmod database. Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Acked-by: Jarkko Nikula <jhnikula@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
