path: root/arch/arm/mach-ns9xxx
2008-03-08[ARM] 4851/1: ns9xxx: fix size of gpioresUwe Kleine-König
GPIO_MAX is the number of the last gpio, not the number of gpios. So the bitmap must provide GPIO_MAX + 1 bits. Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] 4595/1: ns9xxx: define registers as void __iomem * instead of volatile u32Uwe Kleine-König
As a consequence registers are now accessed with __raw_{read,write}[bl]. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] 4594/1: ns9xxx: use the new gpio functionsUwe Kleine-König
Up to now only board-a9m9750dev.c used GPIOs. It just wrote directly into the corresponding registers. Now it properly reserves the gpio and uses the API function to configure it. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] 4593/1: ns9xxx: implement generic clockeventsUwe Kleine-König
2007-10-12[ARM] 4592/1: ns9xxx: clocksource driverUwe Kleine-König
2007-10-12[ARM] 4590/1: ns9xxx: add gpio handling functionsUwe Kleine-König
This implementation conforms to the general GPIO API introduced in 2.6.21. This patch was signed-of by David Brownell before I exported the functions using EXPORT_SYMBOL. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] 4589/1: ns9xxx: acknowledge IRQ_EXT2 in the demux routine for FPGA irqsUwe Kleine-König
The FPGA on the a9m9750dev board interrupts the CPU via EXT2. So to acknowledge any FPGA interrupt IRQ_EXT2 must be acknowledged. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] 4545/1: ns9xxx: simplify irq ack'ingUwe Kleine-König
Now the drivers are responsible to clear the irq in the respective device, which seems to be the normal thing to do. So the ack'ing of the timer irq moved to time.c. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-20[ARM] 4493/1: ns9xxx: disable a non-reloading timer before ack'ing its irqUwe Kleine-König
The HRM states that is must be done this way ... Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-20[ARM] 4487/1: ns9xxx: complete definition of GPIO related registersUwe Kleine-König
I changed the naming to be more obvious---unfortunately the HRM doesn't specify these. Moreover the numbering is changed to be zero indexed as this is more natural. Adjust all callers. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-20[ARM] 4486/1: ns9xxx: fix a typo in the register definitions.Uwe Kleine-König
Fixed all users. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-20[ARM] 4485/1: ns9xxx: pass the correct irq number to the interrupt handlersUwe Kleine-König
2007-07-20[ARM] 4483/1: ns9xxx: fix three sparse warnings: symbol 'xyz' was not declared.Uwe Kleine-König
make ns9xxx_ack_irq_functions static and add one include to get declarations for ns9xxx_map_io and ns9xxx_init_machine. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-20[ARM] 4482/1: ns9xxx: fix compilation for mach-type CC9P9360JSUwe Kleine-König
I must have written the patch introducing support for this machine deep in the night... Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-20[ARM] spelling fixesSimon Arlott
Spelling fixes in arch/arm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08Add IRQF_IRQPOLL flag on armBernhard Walle
Add IRQF_IRQPOLL for each timer interrupt. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-21[ARM] 4301/1: add mach type cc9p9360jsUwe Kleine-König
The support for that machine is not yet complete, but it's enough to be useful as a test platform for the serial and ethernet driver. Moreover a typo in the product name is fixed that I missed in the last patch. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-08[ARM] 4247/1: Fix long name for cc9p9360devUwe Kleine-König
The Product Manager of the cc9p insist on using the correct product names. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-17[ARM] 4210/1: base for new machine type "NetSilicon NS9360"Uwe Kleine-König
