path: root/arch/arm/mach-nomadik
2010-07-22ARM: AMBA: Add pclk definition for platforms using primecellsRussell King
Add a dummy clk definition for the APB pclk signal on all platforms using the AMBA bus infrastructure. This ensures that these platforms continue to work when the core amba bus code controls the APB pclk. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-27ARM: 6145/1: ux500 MTU clockrate correctionLinus Walleij
This adjusts the clockrate for the MTU timer. On the different UX500 variants this rate is different. The platform can also have been set up at hardware initialization, bootloader or early init for different clock speeds. To have the clock framework available early so the timers can use them, the clock initialization for Nomadik and ux500 is moved to IRQ init time. A custom per-clock callback is added to handle special cases like this. This solves a user-visible bug: without this patch the current UX500 platforms will not be synchronized to wall-clock time and the platform will drift in time. Acked-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-20ARM: 6137/1: nomadik hwrng: Add clock supportSrinidhi Kasagar
This adds the clock support to the Nomadik RNG driver Signed-off-by: srinidhi kasagar <srinidhi.kasagar@stericsson.com> Acked-by: Linus walleij <linus.walleij@stericsson.com> Acked-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-06ARM: 6104/1: nomadik-gpio: use clk APIRabin Vincent
Add clocks with appropriate names in platforms that use it, and use the clk API in nomadik-gpio. Acked-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-06ARM: 6103/1: nomadik: define clocks staticallyRabin Vincent
Add a table for clocks to be defined statically, so that new clocks can be added without having to call nmdk_clk_create() for each of them. Remove the now unused nmdk_clk_create() function. Acked-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-19ARM: 5972/1: nomadik-gpio: convert to platform driverRabin Vincent
On the U8500 platform there are four GPIO blocks, each with a 4K address space, including the peripheral identification. However, each of these blocks have a varying number of banks, each of which have 32 GPIOs and an interrupt line. The current nomadik-gpio driver implementation can handle each of these sub-banks easily with one instance each, but cannot as-is be hooked up to them because it is an AMBA driver and it expects to see a peripheral with the appropriate peripheral ids but having only one bank and only one interrupt. Solve this by converting the driver to a platform driver. Acked-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-19ARM: 5969/1: nomadik: move gpio to plat-nomadikRabin Vincent
Move the Nomadik GPIO driver to plat-nomadik so that it can also be used on the Ux500 platform. The mach-nomadik include/mach/gpio.h is replaced by one that includes the one now in plat-nomadik, so that code doesn't need to include the one in plat specifically, and can instead use <linux/gpio.h> as usual. Acked-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-01Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (100 commits) ARM: Eliminate decompressor -Dstatic= PIC hack ARM: 5958/1: ARM: U300: fix inverted clk round rate ARM: 5956/1: misplaced parentheses ARM: 5955/1: ep93xx: move timer defines into core.c and document ARM: 5954/1: ep93xx: move gpio interrupt support to gpio.c ARM: 5953/1: ep93xx: fix broken build of clock.c ARM: 5952/1: ARM: MM: Add ARM_L1_CACHE_SHIFT_6 for handle inside each ARCH Kconfig ARM: 5949/1: NUC900 add gpio virtual memory map ARM: 5948/1: Enable timer0 to time4 clock support for nuc910 ARM: 5940/2: ARM: MMCI: remove custom DBG macro and printk ARM: make_coherent(): fix problems with highpte, part 2 MM: Pass a PTE pointer to update_mmu_cache() rather than the PTE itself ARM: 5945/1: ep93xx: include correct irq.h in core.c ARM: 5933/1: amba-pl011: support hardware flow control ARM: 5930/1: Add PKMAP area description to memory.txt. ARM: 5929/1: Add checks to detect overlap of memory regions. ARM: 5928/1: Change type of VMALLOC_END to unsigned long. ARM: 5927/1: Make delimiters of DMA area globally visibly. ARM: 5926/1: Add "Virtual kernel memory..." printout. ARM: 5920/1: OMAP4: Enable L2 Cache ... Fix up trivial conflict in arch/arm/mach-mx25/clock.c
2010-02-25Merge branch 'misc2' into develRussell King
2010-02-15ARM: 5928/1: Change type of VMALLOC_END to unsigned long.Fenkart/Bostandzhyan
Makes it consistent with VMALLOC_START Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: 5910/1: ARM: Add tmp register for addruart and loadspTony Lindgren
Otherwise more complicated uart configuration won't be possible. We can use r1 for tmp register for both head.S and debug.S. NOTE: This patch depends on another patch to add the the tmp register into all debug-macro.S files. That can be done with: $ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/" arch/arm/*/include/*/debug-macro.S Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-19hwrng: nomadik - Add platform device for rng in cpu-8815Alessandro Rubini
Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com> Acked-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-12-16Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: (90 commits) jffs2: Fix long-standing bug with symlink garbage collection. mtd: OneNAND: Fix test of unsigned in onenand_otp_walk() mtd: cfi_cmdset_0002, fix lock imbalance Revert "mtd: move mxcnd_remove to .exit.text" mtd: m25p80: add support for Macronix MX25L4005A kmsg_dump: fix build for CONFIG_PRINTK=n mtd: nandsim: add support for 4KiB pages mtd: mtdoops: refactor as a kmsg_dumper mtd: mtdoops: make record size configurable mtd: mtdoops: limit the maximum mtd partition size mtd: mtdoops: keep track of used/unused pages in an array mtd: mtdoops: several minor cleanups core: Add kernel message dumper to call on oopses and panics mtd: add ARM pismo support mtd: pxa3xx_nand: Fix PIO data transfer mtd: nand: fix multi-chip suspend problem mtd: add support for switching old SST chips into QRY mode mtd: fix M29W800D dev_id and uaddr mtd: don't use PF_MEMALLOC mtd: Add bad block table overrides to Davinci NAND driver ... Fixed up conflicts (mostly trivial) in drivers/mtd/devices/m25p80.c drivers/mtd/maps/pcmciamtd.c drivers/mtd/nand/pxa3xx_nand.c kernel/printk.c
2009-11-28ARM: 5786/1: Introduce plat-nomadik, MTU code re-organizationSrinidhi Kasagar
Introduce the plat-nomadik folder for ST-Ericsson machines including the existing nomadik 8815 architecture. This also moves the existing MTU (MultiTimerUnit) of nomadik 8815 to the proposed plat-nomadik and adds HAS_MTU. The patch has been re-based to 2.6.32-rc6 Signed-off-by: srinidhi kasagar <srinidhi.kasagar@stericsson.com> Acked-by: Alessandro Rubini <rubini@unipv.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-09-24ARM Nomadik: use new OneNand name and pdataAlessandro Rubini
This enables the onenand with the new platform device name. Moreover, it fixes a related typo that doesn't deserve a separate patch. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-09-20mtd: OneNand support for Nomadik 8815 SoC (on NHK8815 board)Alessandro Rubini
2009-09-20mtd: nand: driver for Nomadik 8815 SoC (on NHK8815 board)Alessandro Rubini
Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-07-02[ARM] 5587/1: nomadik: add l2ccAlessandro Rubini
Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-02[ARM] 5586/1: nomadik board: added ethernetAlessandro Rubini
2009-07-02[ARM] 5585/1: nomadik: add gpio-i2c devicesAlessandro Rubini
2009-07-02[ARM] 5584/1: nomadik: add gpio driver and devicesAlessandro Rubini
2009-07-02[ARM] 5590/1: Add basic support for ST Nomadik 8815 SoC and evaluation boardAlessandro Rubini
This patch adds the basic infrastructure for the Nomadik 8815 CPU and the "Nomadik Hardware Kit" NHK8815. This patch only includes the serial console and core stuff, no drivers. Signed-off-by: Alessandro Rubini <rubini@unipv.it> Acked-by: Andrea Gallo <andrea.gallo@stericsson.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
