path: root/arch/arm/mach-netx
2006-12-13[ARM] 4013/1: clocksource driver for netxSascha Hauer
Add a clocksource driver for netx systems Signed-off-by: Luotao Fu <lfu@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Remove compatibility layer for ARM irqsRussell King
set_irq_chipdata -> set_irq_chip_data get_irq_chipdata -> get_irq_chip_data do_level_IRQ -> handle_level_irq do_edge_IRQ -> handle_edge_irq do_simple_IRQ -> handle_simple_irq irqdesc -> irq_desc irqchip -> irq_chip Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] ARM: fixup irqflags breakage after ARM genirq mergeThomas Gleixner
The irgflags consolidation did conflict with the ARM to generic IRQ conversion and was not applied for ARM. Fix it up. Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-20[ARM] Include asm/hardware.h not asm/arch/hardware.hRussell King
2006-06-19[ARM] 3576/1: netX: board support for NXEB500HMI development boardSascha Hauer
Patch from Sascha Hauer This patch adds the board specific code for the Hilscher NXEB500HMI development board. Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3575/1: netX: board support for NXDB500 development boardSascha Hauer
Patch from Sascha Hauer This patch adds the board specific code for the Hilscher NXDB500 development board. Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3574/1: netX: board support for NXDKN development boardSascha Hauer
Patch from Sascha Hauer This patch adds the board specific code for the Hilscher NXDKN development board. Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3569/2: netX: driver for XMAC/XPEC enginesSascha Hauer
Patch from Sascha Hauer The netX processors have generic network bitstream engines (XMAC/XPEC). This driver adds support for firmware loading and start, stop, reset commands. Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3568/2: netX: pointer fifo driverSascha Hauer
Patch from Sascha Hauer This patch adds support for the pointer FIFOs on netX. Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3567/2: arm: base support for Hilscher netXSascha Hauer
Patch from Sascha Hauer This patch adds the base support for Hilscher's netX network processors. Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-19[ARM] 3572/1: netX: framebuffer driver for Hilscher netXSascha Hauer
Patch from Sascha Hauer This patch adds framebuffer support for Hilscher's netX network processors. Signed-off-by: Robert Schwebel <r.schwebel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
