path: root/arch/arm/mach-mx3
2010-09-01Merge branch 'imx-for-2.6.36' of git://git.pengutronix.de/git/imx/linux-2.6Russell King
2010-08-23ARM: imx: fix build failure concerning otg/ulpiUwe Kleine-König
The build failure was introduced by 13dd0c9 (USB: otg/ulpi: extend the generic ulpi driver.) Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-17clock-imx35: Calculate the base clock rate for the IPU unitJuergen Beisert
The mx3fb driver needs the clock the IPU runs in order to calculate the divider for the LCD clock. This patch adds the clock rate calculation routine for the i.MX35 CPU. Signed-off-by: Juergen Beisert <jbe@pengutronix.de> Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-08-17clock-imx35: correct arm and ahb clock calculationMarc Kleine-Budde
According to the Datasheet: "i.MX35 (MCIMX35) Multimedia Applications Processor Reference Manual, Rev. 2" "Figure 14-24. Clock Control And Gating" change the result of get_rate_ahb based on the frequency returned by get_rate_arm to calculate the proper rate. Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-08-17clock-imx35: fix divider if ahb is source for ipg_perMarc Kleine-Budde
According to the Datasheet: "i.MX35 (MCIMX35) Multimedia Applications Processor Reference Manual, Rev. 2" "Table 14-6. PDR0 Field Descriptions" the divider is CCM_PER_AHB[3:0] + 1. This patch adds the missing + 1. Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-08-17i.MX35: remove get_3_3_div helper functionSascha Hauer
In the v2 reference manual there are no dividers combined of two dividers. Instead, all dividers are simple 6bit dividers. I assume the combined dividers only exist in preliminary hardware. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-08-17mx35: Fix boot ROM hang in internal boot modeHans J. Koch
If a watchdog reset occurs after booting in internal boot mode, the i.MX35 won't boot anymore. The boot ROM code seems to assume that some clocks are turned on (they are after a power-on reset). This patch turns on the necessary clocks. Signed-off-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Reported-by: John Ogness <jogness@linutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-08-16eukrea-baseboards: fix the merge in one fileEric Bénard
Last change I did made a big mess in function names and CONFIG names, this patch fixes this so that the baseboard support is really built when selected. Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-08-15Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: mtd/nand_ids: Fix buswidth mtd/m25p80: fix test for end of loop mtd/m25p80: retlen is never NULL MIPS: Fix gen_nand probe structures contents gen_nand: Test if nr_chips field is valid BFIN: Fix gen_nand probe structures contents nand/denali: move all hardware initialization work to denali_hw_init nand/denali: Add a page check in denali_read_page & denali_read_page_raw nand/denali: use cpu_relax() while waiting for hardware interrupt nand/denali: change read_status function method nand/denali: Fixed check patch warnings ARM: Fix gen_nand probe structures contents mtd/nand_base: fix kernel-doc warnings & typos nand/denali: use dev_xx debug function to replace nand_dbg_print and some printk nand/denali: Fixed handle ECC error bugs nand/denali: use iowrite32() to replace denali_write32() nand/denali: Fixed probe function bugs
2010-08-12ARM: Fix gen_nand probe structures contentsMarek Vasut
These three platforms didn't properly fill nr_chips in gen_nand registration and therefore depended on gen_nand bug fixed by commit 81cbb0b17796d81cbd92defe113cf2a7c7a21fbb ("mtd: gen_nand: fix support for multiple chips") Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2010-08-10USB: otg/ulpi: extend the generic ulpi driver.Igor Grinberg
1) Introduce ulpi specific flags for control of the ulpi phy 2) Extend the generic ulpi driver with support for Function and Interface control of upli phy 3) Update the platforms using the generic ulpi driver with new ulpi flags 4) Remove the otg control flags not in use Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-07-29Merge branch 'for-rmk' of git://git.pengutronix.de/git/imx/linux-2.6 into ↵Russell King
devel-stable
2010-07-26imx: move gpio init after to irq initJason Wang
The commit 9a763bf "get rid of mxc_gpio_init" changed gpio_init and irq_init sequence. Usually we will call set_irq_chained_handler in gpio_init functions, this should be called after the irq_init called, otherwise the chained irq can't get propoer irq_chip and this irq will remain masked even we called set_irq_chained_handler. Signed-off-by: Jason Wang <jason77.wang@gmail.com> Tested-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-07-26eukrea-baseboards: merge includes in one fileEric Bénard
as per suggested by Sascha Signed-off-by: Eric Bénard <eric@eukrea.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-07-26Fix KConfig warningEric Bénard
This patch fixes the following Kconfig warning : "arch/arm/mach-mx25/Kconfig:18:warning: choice value used outside its choice group Signed-off-by: Eric Bénard <eric@eukrea.com> Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-07-26mbimxsd baseboards : remove unnecessary includeEric Bénard
2010-07-26pcm043: register flexcan deviceMarc Kleine-Budde
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-07-26imx: dynamically register flexcan devices for mx25 and mx35Marc Kleine-Budde
In order to make this patch compile, even if the flexcan driver with it's header defining the platform data isn't merged yet, two ifdefs have been added. They effect that the "imx_add_flexcan" function results in a no-op function if the driver hasn't been activated. These ifdefs can be removed after the flexcan driver has been merged. Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-07-26mx35: adjust flexcan clock definitionMarc Kleine-Budde
2010-07-26mx31_3ds: revert 3ds debug board relate codeJason Wang
Because we add a 3ds debug board support in mxc level, we remove those redundant codes from board level. Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-07-26Merge branch 'imx/for-2.6.36' of git://git.pengutronix.de/git/ukl/linux-2.6 ↵Uwe Kleine-König
into HEAD There are some more conflicts than detected by git, namely support for the newly added cpuimx machines needed to be converted to dynamic device registration. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Conflicts: arch/arm/mach-imx/Makefile arch/arm/mach-imx/devices.c arch/arm/mach-imx/devices.h arch/arm/mach-imx/eukrea_mbimx27-baseboard.c arch/arm/mach-mx2/Kconfig arch/arm/mach-mx25/Makefile arch/arm/mach-mx25/devices.c arch/arm/plat-mxc/include/mach/mx25.h arch/arm/plat-mxc/include/mach/mxc_nand.h
2010-07-26mx31_3ds: Handle USB OTG GPIO ErrorsFabio Estevam
Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-07-26i.MX35: add cpuimx35 support and its baseboardEric Bénard
* cpuimx35 integrates i.MX35, RAM, NAND, Ethernet, I2C RTC, USB Host, USB OTG and I2C touchscreen controller * mbimxsd provides access to LCD, Audio, LED, Switch button, UART ... Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-07-26i.MX35: return IPU clock's value for mx3fbEric Bénard
without this patch, ipu_clk's value is 0 thus preventing mx3fb from calculating the right divisor for pixel clock generator. Signed-off-by: Eric Bénard <eric@eukrea.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-07-26pcm037/pcm043/pca100: fix ULPI-related build warningsWolfram Sang
Like this one (if CONFIG_USB_ULPI is not set): arch/arm/mach-mx3/mach-pcm043.c:312: warning: 'otg_pdata' defined but not used arch/arm/mach-mx3/mach-pcm043.c:317: warning: 'usbh1_pdata' defined but not used Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-07-26ARM: mx3: mx31lilly: pass mc13783 SPI IRQ pinDaniel Mack
This makes the resistive touch interface work. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-07-01ARM: mx3: mx31lilly: fix build error for !CONFIG_USB_ULPIDaniel Mack
arch/arm/mach-mx3/built-in.o: In function `mx31lilly_board_init': mach-kzm_arm11_01.c:(.init.text+0x674): undefined reference to `otg_ulpi_create' mach-kzm_arm11_01.c:(.init.text+0x68c): undefined reference to `otg_ulpi_create' mach-kzm_arm11_01.c:(.init.text+0x744): undefined reference to `mxc_ulpi_access_ops' make: *** [.tmp_vmlinux1] Error 1 Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-06-30ARM: mx3: complement uart init routine with an exit routineUwe Kleine-König
moboard_uart0_init requests a gpio. Without an exit function that frees that gpio again binding the uart a second time doesn't work. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2010-06-30ARM: imx: dynamically register imx-uart devices (imx35)Uwe Kleine-König
2010-06-30ARM: imx: dynamically register imx-uart devices (imx31)Uwe Kleine-König
2010-06-30ARM: imx: dynamically register spi_imx devices (imx35)Uwe Kleine-König
2010-06-30ARM: imx: dynamically register spi_imx devices (imx31)Uwe Kleine-König
2010-06-30ARM: imx: dynamically register imx-i2c devices (imx35)Uwe Kleine-König
2010-06-30ARM: imx: dynamically register imx-i2c devices (imx31)Uwe Kleine-König
2010-06-30ARM: imx: Change the way nand devices are registered (imx35)Uwe Kleine-König
Make use of new mechanism to register a nand device. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2010-06-30ARM: imx: Change the way nand devices are registered (imx31)Uwe Kleine-König
2010-06-30ARM: mx3: remove paragraphs with old address of the FSFUwe Kleine-König
As the kernel contains a copy of the GPL anyhow just get rid of the address specification instead of fixing it. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2010-06-24ARM: imx: get rid of mxc_gpio_initUwe Kleine-König
This function is defined once for each imx family and so is in the way when compiling a kernel for more than one SoC. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2010-06-24ARM: mx3/mx31ads: fold board header in its only userUwe Kleine-König
Moreover remove unused definitions. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2010-06-24ARM: mx3/mx31_3ds: fold board header in its only userUwe Kleine-König
2010-06-24ARM: mx3/qong: get rid of nearly empty headerUwe Kleine-König
board-qong.h only defined a single symbol that was used only once. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2010-06-24ARM: mx3/kzm_arm11_01: fold board header in its only userUwe Kleine-König
2010-06-24ARM: imx: remove empty and unused board headersUwe Kleine-König
2010-06-02ARM: mx3: rename mach-mx35pdk.c to mach-mx35_3ds.c matching its arch numberUwe Kleine-König
Additional document all known names of that machine. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2010-05-26leds: Add mx31moboard MC13783 led supportPhilippe Rétornaz
Add two RGB led on mx31moboard using MC13783 led subsystem Signed-off-by: Philippe Rétornaz <philippe.retornaz@epfl.ch> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2010-05-26ARM: mx3: pcm037: remove unused variableDaniel Mack
CC arch/arm/mach-mx3/mach-pcm037.o arch/arm/mach-mx3/mach-pcm037.c: In function 'mxc_board_init': arch/arm/mach-mx3/mach-pcm037.c:584: warning: unused variable 'tmp' Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-05-25Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (103 commits) ARM: 6141/1: Add audio support part in arch/arm/mach-w90x900 ARM: 5939/1: ARM: Add option CMDLINE_FORCE to force usage of the in-kernel cmdline ARM: 6140/1: silence a bogus sparse warning in unwind.c ARM: mach-at91: duplicated include ARM: arch/arm/nwfpe/fpsr.h: Checkpatch cleanup ARM: arch/arm/mach-shark/pci.c: Checkpatch cleanup ARM: arch/arm/nwfpe/ChangeLog: Checkpatch cleanup ARM: arch/arm/mach-sa1100/leds.c: Checkpatch cleanup ARM: arch/arm/mach-h720x/common.h: Checkpatch cleanup ARM: arch/arm/mach-footbridge/ebsa285-pci.c: Checkpatch cleanup ARM: arch/arm/mach-clps711x/Makefile.boot: Checkpatch cleanup ARM: arch/arm/boot/bootp/bootp.lds: Checkpatch cleanup ARM: SPEAR6xx: remove duplicated #include ARM: s3c6400_defconfig: Add NAND driver ARM: s3c6400_defconfig: enable sound as modules ARM: s3c6400_defconfig: enable power management ARM: s5pv210_defconfig: Update s5pv210_defconfig to v2.6.34 ARM: s5pc110_defconfig: Update s5pc110_defconfig to v2.6.34 ARM: s5p6442_defconfig: Update s5p6442_defconfig to v2.6.34 ARM: s5p6440_defconfig: Update s5p6440_defconfig to v2.6.34 ...
2010-05-19mx31_3ds: Support the keypad situated in the personality boardAlberto Panizzo
Signed-off-by: Alberto Panizzo <maramaopercheseimorto@gmail.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-05-19MX3X: Add Keypad device definition for MX3X archAlberto Panizzo
This patch adds also the pin definition helpers in iomux-mx3.h Signed-off-by: Alberto Panizzo <maramaopercheseimorto@gmail.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-05-17can: sja1000 platform data fixesWolfgang Grandegger
The member "clock" of struct "sja1000_platform_data" is documented as "CAN bus oscillator frequency in Hz" but it's actually used as the CAN clock frequency, which is half of it. To avoid further confusion, this patch fixes it by renaming the member to "osc_freq". That way, also non mainline users will notice the change. The platform code for the relevant boards is updated accordingly. Furthermore, pre-defined values are now used for the members "ocr" and "cdr". Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
