* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (35 commits)
ARM: Update (and cut down) mach-types
ARM: 6771/1: vexpress: add support for multiple core tiles
ARM: 6797/1: hw_breakpoint: Fix newlines in WARNings
ARM: 6751/1: vexpress: select applicable errata workarounds in Kconfig
ARM: 6753/1: omap4: Enable ARM local timers with OMAP4430 es1.0 exception
ARM: 6759/1: smp: Select local timers vs broadcast timer support runtime
ARM: pgtable: add pud-level code
ARM: 6673/1: LPAE: use phys_addr_t instead of unsigned long for start of membanks
ARM: Use long long format when printing meminfo physical addresses
ARM: integrator: add Integrator/CP sched_clock support
ARM: realview/vexpress: consolidate SMP bringup code
ARM: realview/vexpress: consolidate localtimer support
ARM: integrator/versatile: consolidate FPGA IRQ handling code
ARM: rationalize versatile family Kconfig/Makefile
ARM: realview: remove old AMBA device DMA definitions
ARM: versatile: remove old AMBA device DMA definitions
ARM: vexpress: use new init_early for clock tree and sched_clock init
ARM: realview: use new init_early for clock tree and sched_clock init
ARM: versatile: use new init_early for clock tree and sched_clock init
ARM: integrator: use new init_early for clock tree init
The current code support of dummy timers in absence of local
timer is compile time. This is an attempt to convert it to runtime
so that on few SOC version if the local timers aren't supported
kernel can switch to dummy timers. OMAP4430 ES1.0 does suffer from
this limitation.
This patch should not have any functional impact on affected
files.
Cc: Daniel Walker <dwalker@codeaurora.org>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Tony Lindgren <tony@atomide.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Magnus Damm <magnus.damm@gmail.com>
Cc: Colin Cross <ccross@android.com>
Cc: Erik Gilling <konkers@android.com>
Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Linus Walleij <linus.walleij@stericsson.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: David Brown <davidb@codeaurora.org>
Modify the macros in the MSM timer driver to support the
MSM8960 chip.
Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org>
Signed-off-by: David Brown <davidb@codeaurora.org>
Allow the timer register to be determined dynamically instead of at
compile time. Use common virtual addresses for the registers across
all MSM chips, and select the register mappings based on the detected
CPU.
The msm provides timer hardware that is private to each core. Each
timer has separate counter and match registers, so we create separate
clock_event_devices for each core. For the global clocksource, use
cpu 0's counter.
Signed-off-by: Jeff Ohlstein <johlstei@codeaurora.org>
In d7e81c2 (clocksource: Add clocksource_register_hz/khz interface) new
interfaces were added which simplify (and optimize) the selection of the
divisor shift/mult constants. Switch over to using this new interface.
Tested-By: Jeff Ohlstein <johlstei@codeaurora.org>
The shift of 24 causes the shift and multiply operation to sometimes
overflow, resulting in incorrect timer values and poor performance.
Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
Some SoC need to redefine MSM_DGT_BASE from it's default.
This allows it to be defined in a header to override the
default value.
Pass clocksource pointer to the read() callback for clocksources. This
allows us to share the callback between multiple instances.
[hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods]
[akpm@linux-foundation.org: cleanup]
Signed-off-by: Magnus Damm <damm@igel.co.jp>
Acked-by: John Stultz <johnstul@us.ibm.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Impact: change calling convention of existing clock_event APIs
struct clock_event_timer's cpumask field gets changed to take pointer,
as does the ->broadcast function.
Another single-patch change. For safety, we BUG_ON() in
clockevents_register_device() if it's not set.
- Add some more peripherals (sdcc, etc) to the iomap.
- Remove virtual base addresses for devices that we should be passing
physical addresses to drivers via resources and ioremap()ing.
- don't try to use uarts for ll debug once the mmu is enabled due to
problems with the peripheral window
- make base addresses void __iomem * and fixup irq.c and timer.c
- Remove common.c and bring in devices.c/devices.h similar to
the PXA architecture.
Signed-off-by: Brian Swetland <swetland@google.com>
This just leaves include/asm-arm/plat-* to deal with.
- Vectored Interrupt Controller support
- Timer support using the GPT and DGT timers
