path: root/arch/arm/mach-msm/headsmp.S
2012-01-16ARM: msm: Add missing ENDPROC to headsmp.SRob Herring
Once the ENDPROC is in place, BSYM() in not longer necessary to get correct pointer to msm_secondary_startup(). Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: David Brown <davidb@codeaurora.org> Cc: Daniel Walker <dwalker@fifo99.com>
2011-02-28msm: headsmp.S: Fix section mismatchStephen Boyd
WARNING: vmlinux.o(.cpuinit.text+0xc80): Section mismatch in reference from the function boot_secondary() to the variable .init.text:msm_secondary_startup The function __cpuinit boot_secondary() references a variable __init msm_secondary_startup. If msm_secondary_startup is only used by boot_secondary then annotate msm_secondary_startup with a matching annotation. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2011-01-07msm: add SMP support for msmJeff Ohlstein
Signed-off-by: Jeff Ohlstein <johlstei@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
