path: root/arch/arm/mach-msm/board-sapphire.c
2015-03-27ARM: Remove mach-msm and associated ARM architecture codeStephen Boyd
The maintainers for mach-msm no longer have any plans to support or test the platforms supported by this architecture[1]. Most likely there aren't any active users of this code anyway, so let's delete it. [1] http://lkml.kernel.org/r/20150307031212.GA8434@fifo99.com Cc: David Brown <davidb@codeaurora.org> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: Daniel Walker <dwalker@fifo99.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Kumar Gala <galak@codeaurora.org>
2014-06-01ARM: 8025/1: Get rid of meminfoLaura Abbott
memblock is now fully integrated into the kernel and is the prefered method for tracking memory. Rather than reinvent the wheel with meminfo, migrate to using memblock directly instead of meminfo as an intermediate. Acked-by: Jason Cooper <jason@lakedaemon.net> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Tested-by: Marek Szyprowski <m.szyprowski@samsung.com> Tested-by: Leif Lindholm <leif.lindholm@linaro.org> Signed-off-by: Laura Abbott <lauraa@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-08-06ARM: msm: Move mach/board.h contents to common.hStephen Boyd
The contents of mach/board.h are only used by files within mach-msm so there is no need to export this file outside of the mach-msm directory. Move the contents of the file to common.h to allow us to compile MSM in the multi-platform kernel. Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Signed-off-by: David Brown <davidb@codeaurora.org>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-09-13ARM: msm: Remove msm_hw_reset_hookStephen Boyd
This reset hook is never assigned and is dead code. Remove it so we have one less header file in the mach directory. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2012-05-08ARM: msm: use machine specific hook for late initShawn Guo
Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: David Brown <davidb@codeaurora.org>
2012-03-28Disintegrate asm/system.h for ARMDavid Howells
Disintegrate asm/system.h for ARM. Signed-off-by: David Howells <dhowells@redhat.com> cc: Russell King <linux@arm.linux.org.uk> cc: linux-arm-kernel@lists.infradead.org
2011-12-21driver-core: remove sysdev.h usage.Kay Sievers
The sysdev.h file should not be needed by any in-kernel code, so remove the .h file from these random files that seem to still want to include it. The sysdev code will be going away soon, so this include needs to be removed no matter what. Cc: Jiandong Zheng <jdzheng@broadcom.com> Cc: Scott Branden <sbranden@broadcom.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Kukjin Kim <kgene.kim@samsung.com> Cc: David Brown <davidb@codeaurora.org> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: "Venkatesh Pallipadi Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
2011-10-28Merge branch 'devel-stable' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits) ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET ARM: gic, local timers: use the request_percpu_irq() interface ARM: gic: consolidate PPI handling ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H ARM: mach-s5p64x0: remove mach/memory.h ARM: mach-s3c64xx: remove mach/memory.h ARM: plat-mxc: remove mach/memory.h ARM: mach-prima2: remove mach/memory.h ARM: mach-zynq: remove mach/memory.h ARM: mach-bcmring: remove mach/memory.h ARM: mach-davinci: remove mach/memory.h ARM: mach-pxa: remove mach/memory.h ARM: mach-ixp4xx: remove mach/memory.h ARM: mach-h720x: remove mach/memory.h ARM: mach-vt8500: remove mach/memory.h ARM: mach-s5pc100: remove mach/memory.h ARM: mach-tegra: remove mach/memory.h ARM: plat-tcc: remove mach/memory.h ARM: mach-mmp: remove mach/memory.h ARM: mach-cns3xxx: remove mach/memory.h ... Fix up mostly pretty trivial conflicts in: - arch/arm/Kconfig - arch/arm/include/asm/localtimer.h - arch/arm/kernel/Makefile - arch/arm/mach-shmobile/board-ap4evb.c - arch/arm/mach-u300/core.c - arch/arm/mm/dma-mapping.c - arch/arm/mm/proc-v7.S - arch/arm/plat-omap/Kconfig largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP -> CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
2011-10-27Merge branch 'gpio' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'gpio' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (43 commits) ARM: 7135/1: ep93xx: bring back missing <mach/gpio.h> ARM: 7104/1: plat-pxa: break out GPIO driver specifics ARM: 7103/1: plat-pxa: move PXA GPIO driver to GPIO subsystem ARM: 7042/3: mach-ep93xx: break out GPIO driver specifics ARM: 7101/1: arm/tegra: Replace <mach/gpio.h> with <mach/gpio-tegra.h> ARM: 7094/1: arm/tegra: Move EN_VDD_1V05_GPIO to board-harmony.h ARM: 7083/1: rewrite U300 GPIO to use gpiolib ARM: 7074/1: gpio: davinci: eliminate unused variable warnings ARM: 7063/1: Orion: gpio: add missing include of linux/types.h ARM: 7055/1: arm/tegra: mach/gpio.h: include linux/types.h to fix build ARM: 7054/1: arm/tegra: Delete custom gpio_to_irq, and irq_to_gpio ARM: 7053/1: gpio/tegra: Implement gpio_chip.to_irq ARM: 7052/1: gpio/tegra: Remove use of irq_to_gpio ARM: 7057/1: mach-pnx4008: rename GPIO header ARM: 7056/1: plat-nomadik: kill off <plat/gpio.h> ARM: 7050/1: mach-sa1100: delete irq_to_gpio() function ARM: 7049/1: mach-sa1100: move SA1100 GPIO driver to GPIO subsystem ARM: 7045/1: mach-lpc32xx: break out GPIO driver specifics ARM: 7044/1: mach-lpc32xx: move LPC32XX GPIO driver to GPIO subsystem ARM: 7043/1: mach-ixp2000: rename GPIO header ... Fix up trivial conflicts in arch/arm/mach-u300/Kconfig manually
2011-10-17ARM: platform fixups: remove mdesc argument to fixup functionRussell King
Get rid of the mdesc pointer in the fixup function call. No one uses the mdesc pointer, it shouldn't be modified anyway, and we can't wrap it, so let's remove it. Platform files found by: $ regexp=$(git grep -h '\.fixup.*=' arch/arm | sed 's!.*= *\([^,]*\),* *!\1!' | sort -u | tr '\n' '|' | sed 's,|$,,;s,|,\\|,g') $ git grep $regexp arch/arm Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-21ARM: mach-msm: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-08-08ARM: gpio: convert includes of mach/gpio.h and asm/gpio.h to linux/gpio.hRussell King
Convert arch/arm includes of mach/gpio.h and asm/gpio.h to linux/gpio.h before we start consolidating the individual platform implementations of the gpio header files. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-03-16Merge remote branch 'rmk/for-linus' into for-linusDavid Brown
* rmk/for-linus: (1557 commits) ARM: 6806/1: irq: introduce entry and exit functions for chained handlers ARM: 6781/1: Thumb-2: Work around buggy Thumb-2 short branch relocations in gas ARM: 6747/1: P2V: Thumb2 support ARM: 6798/1: aout-core: zero thread debug registers in a.out core dump ARM: 6796/1: Footbridge: Fix I/O mappings for NOMMU mode ARM: 6784/1: errata: no automatic Store Buffer drain on Cortex-A9 ARM: 6772/1: errata: possible fault MMU translations following an ASID switch ARM: 6776/1: mach-ux500: activate fix for errata 753970 ARM: 6794/1: SPEAr: Append UL to device address macros. ARM: 6793/1: SPEAr: Remove unused *_SIZE macros from spear*.h files ARM: 6792/1: SPEAr: Replace SIZE macro's with SZ_4K macros ARM: 6791/1: SPEAr3xx: Declare device structures after shirq code ARM: 6790/1: SPEAr: Clock Framework: Rename usbd clock and align apb_clk entry ARM: 6789/1: SPEAr3xx: Rename sdio to sdhci ARM: 6788/1: SPEAr: Include mach/hardware.h instead of mach/spear.h ARM: 6787/1: SPEAr: Reorder #includes in .h & .c files. ARM: 6681/1: SPEAr: add debugfs support to clk API ARM: 6703/1: SPEAr: update clk API support ARM: 6679/1: SPEAr: make clk API functions more generic ARM: 6737/1: SPEAr: formalized timer support ... Conflicts: arch/arm/mach-msm/board-msm7x27.c arch/arm/mach-msm/board-msm7x30.c arch/arm/mach-msm/board-qsd8x50.c arch/arm/mach-msm/board-sapphire.c arch/arm/mach-msm/include/mach/memory.h
2011-02-17ARM: P2V: avoid initializers and assembly using PHYS_OFFSETRussell King
As PHYS_OFFSET will be becoming a variable, we can't have it used in initializers nor assembly code. Replace those in generic code with a run-time initialization. Replace those in platform code using the individual platform specific PLAT_PHYS_OFFSET. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Eric Miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-28msm: Clean up useless ifdefsStepan Moskovchenko
Remove ifdefs that do nothing, either from having the code between them previously removed, or from having been accidentally added to the wrong file. Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org> Signed-off-by: David Brown <davidb@codeaurora.org>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-05-12arm: msm: add board file for the HTC Sapphire deviceDaniel Walker
This adds a basic board file without Kconfig changes. Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
