The maintainers for mach-msm no longer have any plans to support
or test the platforms supported by this architecture[1]. Most likely
there aren't any active users of this code anyway, so let's
delete it.
[1] http://lkml.kernel.org/r/20150307031212.GA8434@fifo99.com
Cc: David Brown <davidb@codeaurora.org>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Daniel Walker <dwalker@fifo99.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Kumar Gala <galak@codeaurora.org>
This is a dangling symbol in the kernel: there is no config option
for the MSM_SERIAL_DEBUGGER anywhere in the kernel.
Pull ARM updates from Russell King:
- Major clean-up of the L2 cache support code. The existing mess was
becoming rather unmaintainable through all the additions that others
have done over time. This turns it into a much nicer structure, and
implements a few performance improvements as well.
- Clean up some of the CP15 control register tweaks for alignment
support, moving some code and data into alignment.c
- DMA properties for ARM, from Santosh and reviewed by DT people. This
adds DT properties to specify bus translations we can't discover
automatically, and to indicate whether devices are coherent.
- Hibernation support for ARM
- Make ftrace work with read-only text in modules
- add suspend support for PJ4B CPUs
- rework interrupt masking for undefined instruction handling, which
allows us to enable interrupts earlier in the handling of these
exceptions.
- support for big endian page tables
- fix stacktrace support to exclude stacktrace functions from the
trace, and add save_stack_trace_regs() implementation so that kprobes
can record stack traces.
- Add support for the Cortex-A17 CPU.
- Remove last vestiges of ARM710 support.
- Removal of ARM "meminfo" structure, finally converting us solely to
memblock to handle the early memory initialisation.
* 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (142 commits)
ARM: ensure C page table setup code follows assembly code (part II)
ARM: consolidate last remaining open-coded alignment trap enable
ARM: remove global cr_no_alignment
ARM: remove CPU_CP15 conditional from alignment.c
ARM: remove unused adjust_cr() function
ARM: move "noalign" command line option to alignment.c
ARM: provide common method to clear bits in CPU control register
ARM: 8025/1: Get rid of meminfo
ARM: 8060/1: mm: allow sub-architectures to override PCI I/O memory type
ARM: 8066/1: correction for ARM patch 8031/2
ARM: 8049/1: ftrace/add save_stack_trace_regs() implementation
ARM: 8065/1: remove last use of CONFIG_CPU_ARM710
ARM: 8062/1: Modify ldrt fixup handler to re-execute the userspace instruction
ARM: 8047/1: rwsem: use asm-generic rwsem implementation
ARM: l2c: trial at enabling some Cortex-A9 optimisations
ARM: l2c: add warnings for stuff modifying aux_ctrl register values
ARM: l2c: print a warning with L2C-310 caches if the cache size is modified
ARM: l2c: remove old .set_debug method
ARM: l2c: kill L2X0_AUX_CTRL_MASK before anyone else makes use of this
memblock is now fully integrated into the kernel and is the prefered
method for tracking memory. Rather than reinvent the wheel with
meminfo, migrate to using memblock directly instead of meminfo as
an intermediate.
Acked-by: Jason Cooper <jason@lakedaemon.net>
Acked-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Tested-by: Marek Szyprowski <m.szyprowski@samsung.com>
Tested-by: Leif Lindholm <leif.lindholm@linaro.org>
Signed-off-by: Laura Abbott <lauraa@codeaurora.org>
Use enum usb_dr_mode and drop default usb_dr_mode from platform data.
USB DT bindings states: dr_mode: "...In case this attribute isn't
passed via DT, USB DRD controllers should default to OTG...",
so remove redundand field.
Signed-off-by: Ivan T. Ivanov <iivanov@mm-sol.com>
Acked-by: David Brown <davidb@codeaurora.org>
Signed-off-by: Felipe Balbi <balbi@ti.com>
This patch fix compilation error when driver is compiled
in multi-platform builds.
drivers/built-in.o: In function `msm_otg_link_clk_reset':
./drivers/usb/phy/phy-msm-usb.c:314: undefined reference to `clk_reset'
./drivers/usb/phy/phy-msm-usb.c:318: undefined reference to `clk_reset'
Use platform data supplied reset handlers and adjust error
messages reported when reset sequence fail.
This is an intermediate step before adding support for reset
framework and newer targets.
Acked-by: Felipe Balbi <balbi@ti.com>
The contents of mach/board.h are only used by files within
mach-msm so there is no need to export this file outside of the
mach-msm directory. Move the contents of the file to common.h to
allow us to compile MSM in the multi-platform kernel.
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Acked-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Signed-off-by: David Brown <davidb@codeaurora.org>
To move closer to the generic struct clock framework move the
proc_comm based clock code to a platform driver. The data
describing the struct clks still live in the devices-$ARCH file,
but the clock initialization is done at driver binding time.
Cc: Saravana Kannan <skannan@codeaurora.org>
Reviewed-by: Pankaj Jangra <jangra.pankaj9@gmail.com>
Acked-by: Mike Turquette <mturquette@linaro.org>
Doing this removes the dependence of this driver on the
msm_iomap.h and cpu.h mach include headers provied by MSM. This
is necessary to support single zImage work in the future and
allows us to remove cpu.h entirely and brings us closer to
removing msm_iomap.h.
Cc: Grant Likely <grant.likely@secretlab.ca>
Tested-by: Rohit Vaswani <rvaswani@codeaurora.org>
Acked-by: Rohit Vaswani <rvaswani@codeaurora.org>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
The timer code relies on #defines from mach/iomap.h, cpu_is_*()
checks, and a global irq #define. All this makes this file
impossible to compile in a mult-target build. Therefore, make a
sys_timer struct for each SoC so that machine descriptors can
reference the correct timer. Then go through and replace all the
defines with raw values that are passed to a common
initialization function.
This paves the way to adding DT support to this code as well as
allows us to compile this file on multiple targets at the same
time.
Pull sweeping late_initcall cleanup for arm-soc from Olof Johansson:
"This is a patch series from Shawn Guo that moves from individual
late_initcalls() to using a member in the machine structure to invoke
a platform's late initcalls.
This cleanup is a step in the move towards multiplatform kernels since
it would reduce the need to check for compatible platforms in each and
every initcall."
Fix up trivial conflicts in arch/arm/mach-{exynos/mach-universal_c210.c,
imx/mach-cpuimx51.c, omap2/board-generic.c} due to changes nearby (and,
in the case of cpuimx51.c the board support being deleted)
* tag 'cleanup-initcall' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: ux500: use machine specific hook for late init
ARM: tegra: use machine specific hook for late init
ARM: shmobile: use machine specific hook for late init
ARM: sa1100: use machine specific hook for late init
ARM: s3c64xx: use machine specific hook for late init
ARM: prima2: use machine specific hook for late init
ARM: pnx4008: use machine specific hook for late init
ARM: omap2: use machine specific hook for late init
ARM: omap1: use machine specific hook for late init
ARM: msm: use machine specific hook for late init
ARM: imx: use machine specific hook for late init
ARM: exynos: use machine specific hook for late init
ARM: ep93xx: use machine specific hook for late init
ARM: davinci: use machine specific hook for late init
ARM: provide a late_initcall hook for platform initialization
arch/arm/mach-msm/board-msm7x30.c and arch/arm/mach-msm/board-qsd8x50.c
included 'linux/gpio.h' twice, remove the duplicates.
Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de>
After 0744a3ee (ARM: platform fixups: remove mdesc argument to
fixup function, 2010-12-20) the fixup functions introduced in
9e775ad (ARM: 7012/1: Set proper TEXT_OFFSET for newer MSMs,
2011-08-12) cause warnings like:
arch/arm/mach-msm/board-msm8x60.c:85: warning: initialization
from incompatible pointer type
Fix them by removing the machine_desc argument from the fixup
functions.
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
* 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits)
ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET
ARM: gic, local timers: use the request_percpu_irq() interface
ARM: gic: consolidate PPI handling
ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H
ARM: mach-s5p64x0: remove mach/memory.h
ARM: mach-s3c64xx: remove mach/memory.h
ARM: plat-mxc: remove mach/memory.h
ARM: mach-prima2: remove mach/memory.h
ARM: mach-zynq: remove mach/memory.h
ARM: mach-bcmring: remove mach/memory.h
ARM: mach-davinci: remove mach/memory.h
ARM: mach-pxa: remove mach/memory.h
ARM: mach-ixp4xx: remove mach/memory.h
ARM: mach-h720x: remove mach/memory.h
ARM: mach-vt8500: remove mach/memory.h
ARM: mach-s5pc100: remove mach/memory.h
ARM: mach-tegra: remove mach/memory.h
ARM: plat-tcc: remove mach/memory.h
ARM: mach-mmp: remove mach/memory.h
ARM: mach-cns3xxx: remove mach/memory.h
Fix up mostly pretty trivial conflicts in:
- arch/arm/Kconfig
- arch/arm/include/asm/localtimer.h
- arch/arm/kernel/Makefile
- arch/arm/mach-shmobile/board-ap4evb.c
- arch/arm/mach-u300/core.c
- arch/arm/mm/dma-mapping.c
- arch/arm/mm/proc-v7.S
- arch/arm/plat-omap/Kconfig
largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP ->
CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and
addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
* 'gpio' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (43 commits)
ARM: 7135/1: ep93xx: bring back missing <mach/gpio.h>
ARM: 7104/1: plat-pxa: break out GPIO driver specifics
ARM: 7103/1: plat-pxa: move PXA GPIO driver to GPIO subsystem
ARM: 7042/3: mach-ep93xx: break out GPIO driver specifics
ARM: 7101/1: arm/tegra: Replace <mach/gpio.h> with <mach/gpio-tegra.h>
ARM: 7094/1: arm/tegra: Move EN_VDD_1V05_GPIO to board-harmony.h
ARM: 7083/1: rewrite U300 GPIO to use gpiolib
ARM: 7074/1: gpio: davinci: eliminate unused variable warnings
ARM: 7063/1: Orion: gpio: add missing include of linux/types.h
ARM: 7055/1: arm/tegra: mach/gpio.h: include linux/types.h to fix build
ARM: 7054/1: arm/tegra: Delete custom gpio_to_irq, and irq_to_gpio
ARM: 7053/1: gpio/tegra: Implement gpio_chip.to_irq
ARM: 7052/1: gpio/tegra: Remove use of irq_to_gpio
ARM: 7057/1: mach-pnx4008: rename GPIO header
ARM: 7056/1: plat-nomadik: kill off <plat/gpio.h>
ARM: 7050/1: mach-sa1100: delete irq_to_gpio() function
ARM: 7049/1: mach-sa1100: move SA1100 GPIO driver to GPIO subsystem
ARM: 7045/1: mach-lpc32xx: break out GPIO driver specifics
ARM: 7044/1: mach-lpc32xx: move LPC32XX GPIO driver to GPIO subsystem
ARM: 7043/1: mach-ixp2000: rename GPIO header
Fix up trivial conflicts in arch/arm/mach-u300/Kconfig manually
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
MSMs post 8x50 have 2Mb at the beginning of RAM reserved for
shared memory. Since the kernel hasn't typically been told this
RAM exists, PHYS_OFFSET has been set to 0xN0200000 and the memory
atags passed to the kernel have matched. This doesn't play nicely
with things such as AUTO_ZRELADDR, which doesn't work at all, and
dynamic phys to virt, which requires an MSM specific workaround.
Work around these issues by telling the kernel RAM starts at
0xN0000000 (it actually does) and fixup the atags from the
bootloader (if necessary) to say the same. In addition, make sure
to set TEXT_OFFSET at least 2Mb beyond the start of RAM so that
the kernel doesn't end up being decompressed into shared memory.
After doing this, AUTO_ZRELADDR should work on MSM with no
problems and ARM_PATCH_PHYS_VIRT_16BIT should no longer be
necessary.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Convert arch/arm includes of mach/gpio.h and asm/gpio.h to linux/gpio.h
before we start consolidating the individual platform implementations
of the gpio header files.
* rmk/for-linus: (1557 commits)
ARM: 6806/1: irq: introduce entry and exit functions for chained handlers
ARM: 6781/1: Thumb-2: Work around buggy Thumb-2 short branch relocations in gas
ARM: 6747/1: P2V: Thumb2 support
ARM: 6798/1: aout-core: zero thread debug registers in a.out core dump
ARM: 6796/1: Footbridge: Fix I/O mappings for NOMMU mode
ARM: 6784/1: errata: no automatic Store Buffer drain on Cortex-A9
ARM: 6772/1: errata: possible fault MMU translations following an ASID switch
ARM: 6776/1: mach-ux500: activate fix for errata 753970
ARM: 6794/1: SPEAr: Append UL to device address macros.
ARM: 6793/1: SPEAr: Remove unused *_SIZE macros from spear*.h files
ARM: 6792/1: SPEAr: Replace SIZE macro's with SZ_4K macros
ARM: 6791/1: SPEAr3xx: Declare device structures after shirq code
ARM: 6790/1: SPEAr: Clock Framework: Rename usbd clock and align apb_clk entry
ARM: 6789/1: SPEAr3xx: Rename sdio to sdhci
ARM: 6788/1: SPEAr: Include mach/hardware.h instead of mach/spear.h
ARM: 6787/1: SPEAr: Reorder #includes in .h & .c files.
ARM: 6681/1: SPEAr: add debugfs support to clk API
ARM: 6703/1: SPEAr: update clk API support
ARM: 6679/1: SPEAr: make clk API functions more generic
ARM: 6737/1: SPEAr: formalized timer support
arch/arm/mach-msm/board-msm7x27.c
arch/arm/mach-msm/board-sapphire.c
arch/arm/mach-msm/include/mach/memory.h
Migrating to clkdev has several advantages:
* Less code in mach-msm/clock.c
* A more robust clk_get() implementation
* clk_add_alias() support
* clk_get_sys() support
In general, this will help board authors setup clock aliases and
break the dependency on device pointers in the clock tables.
As PHYS_OFFSET will be becoming a variable, we can't have it used in
initializers nor assembly code. Replace those in generic code with
a run-time initialization. Replace those in platform code using the
individual platform specific PLAT_PHYS_OFFSET.
Acked-by: Eric Miao <eric.y.miao@gmail.com>
This uncouple PHYS_OFFSET from the platform definitions, thereby
facilitating run-time computation of the physical memory offset.
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Magnus Damm <damm@opensource.se>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Jiandong Zheng <jdzheng@broadcom.com>
Remove ifdefs that do nothing, either from having the code
between them previously removed, or from having been
accidentally added to the wrong file.
Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org>
This is completely board specific and therefore must be provided
on a per-board basis.
Signed-off-by: Dima Zavin <dima@android.com>
Add USB OTG, peripheral and host devices. This patch also adds
usb_phy_clk which is required for resetting the PHY. VBUS power up
and shutdown routines depends on PMIC module. As PMIC driver is
unavailable, configure USB in peripheral only mode.
Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Acked-by: Eric Miao <eric.miao at canonical.com>
Add msm_smd device in the msm7x30 board file.
Signed-off-by: Niranjana Vishwanathapura <nvishwan@codeaurora.org>
Signed-off-by: Daniel Walker <dwalker@codeaurora.org>
Change deprecated gpio_tlmm_config calls to gpiomux calls.
Signed-off-by: Gregory Bean <gbean@codeaurora.org>
Catch those which have been missed by 6262c92f because they were
submitted via other routes.
Signed-off-by: Abhijeet Dharmapurikar <adharmap@codeaurora.org>
This adds a basic board file without Kconfig changes.
