path: root/arch/arm/mach-mmp/Makefile
2013-12-11ARM: mmp: build sram driver aloneQiao Zhou
sram driver can be used by many chips besides CPU_MMP2, and so build it alone. Also need to select MMP_SRAM for MMP_TDMA driver. Reported-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Qiao Zhou <zhouqiao@marvell.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2013-08-24irqchip: move mmp irq driverHaojian Zhuang
Move irq-mmp driver from mach-mmp directory into irqchip directory. It's used to support multiple platform. Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-09-08ARM: mmp: move mmp2 clock definition to separated fileChao Xie
move mmp2 clock definition to another file. Then mmp2 can choose common clock framework or private clock framework. Signed-off-by: Chao Xie <xiechao.mail@gmail.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-09-08arm: mmp: move pxa910 clock definition to separated fileChao Xie
move pxa910 clock definition to another file. Then pxa910 can choose common clock framework or private clock framework. Signed-off-by: Chao Xie <xiechao.mail@gmail.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-09-08arm: mmp: move pxa168 clock definition to separated fileChao Xie
move pxa168 clock definition to another file. Then pxa168 can choose common clock framework or private clock framework. Signed-off-by: Chao Xie <xiechao.mail@gmail.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-09-08arm: mmp: make private clock definition exclude from common clockChao Xie
the clock.c is mmp private implementation, make it excluded from common clock framework Signed-off-by: Chao Xie <xiechao.mail@gmail.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-05-07ARM: mmp: add pm support for pxa910Chao Xie
add suspend/resume functionality for pxa910 Signed-off-by: Chao Xie <chao.xie@marvell.com> Signed-off-by: Raul Xiong <xjian@marvell.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-05-07ARM: mmp: add PM support for mmp2Chao Xie
MMP2 can enter system sleep level during suspend. It can be waken up by PMIC interrupt, RTC/ALARM. Signed-off-by: Chao Xie <chao.xie@marvell.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-05-05ARM: mmp: support mmp2 with device treeHaojian Zhuang
Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-05-05ARM: mmp: support DT in irqHaojian Zhuang
Merge irq-pxa168 and irq-mmp2. And support device tree also. Since CONFIG_SPARSE_IRQ is enabled in arch-mmp, base irq starts from NR_IRQS_LEGACY. Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-03-07ARM: mmp: append OF support on pxa168Haojian Zhuang
Enable PXA168 and aspenite support. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-11-05Merge branch 'next/devel2' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/devel2' of git://git.linaro.org/people/arnd/arm-soc: (30 commits) ARM: mmp: register internal sram bank ARM: mmp: register audio sram bank ARM: mmp: add sram allocator gpio/samsung: Complain loudly if we don't know the SoC ARM: S3C64XX: Fix SoC identification for S3C64xx devices ARM: S3C2443: Remove redundant s3c_register_clocks call for init_clocks ARM: S3C24XX: Add devname for hsmmc1 pclk ARM: S3C24XX: use clk_get_rate to init fclk in common_setup_clocks ARM: S3C2443: Accommodate cpufreq frequency scheme in armdiv ARM: S3C2443: handle unset armdiv values gracefully ARM: S3C2443: Add get_rate operation for clk_armdiv ARM: S3C2416: Add comment describing the armdiv/armclk ARM: S3C2443: Move clk_arm and clk_armdiv to common code ARM: S3C24XX: Add infrastructure to transmit armdiv to common code ARM: S3C2416: Add armdiv_mask constant ARM: EXYNOS4: Add support for M-5MOLS camera on Nuri board ARM: EXYNOS4: Enable MFC on ORIGEN ARM: SAMSUNG: Add support s3c2416-adc for S3C2416/S3C2450 ARM: SAMSUNG: Add support s3c2443-adc for S3C2443 ARM: SAMSUNG: Allow overriding of adc device name for S3C24XX ...
2011-10-25ARM: mmp: add sram allocatorLeo Yan
On mmp platform, there have two sram banks: audio sram and internal sram. The audio sram is mainly for audio; the internal sram is for video, wtm and power management. So add the sram allocator using genalloc to manage them. Every sram bank will register its own platform device info, after the sram allocator create the generic pool for the sram bank, the user module can use the pool's name to get the pool handler; then it can use the handler to alloc/free memory with genalloc APIs. Signed-off-by: Leo Yan <leoy@marvell.com> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-10-25ARM: mmp: rename SHEEVAD to GPLUGDEric Miao
GuruPlugD was initially named to be SHEEVAD, and it's causing naming confusion in the mach-types database. Make it consistent by renaming to GPLUGD. Reported-and-Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2011-07-12ARM: pxa168: Add board support for gplugDTanmay Upadhyay
Tested UART console, Ethernet & I2C interfaces Signed-off-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-12-16ARM: mmp: append brownstone supportHaojian Zhuang
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-10-09ARM: pxa168: added support for Teton BGA platformMark F. Brown
Added board defintion, header, and debug UART support. Signed-off-by: Mark F. Brown <mark.brown314@gmail.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-03-02[ARM] mmp: support jasper development boardHaojian Zhuang
2010-03-02[ARM] mmp: add support for Marvell MMP2Haojian Zhuang
Marvell MMP2 (aka ARMADA610) is a SoC based on PJ4 core. It's ARMv6 compatible. Support basic interrupt handler and timer, and basic support for MMP2 based FLINT platform. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2010-03-02[ARM] mmp: rename irq.c to irq-pxa168.c to allow other SoC IRQ chipsEric Miao
2010-03-02[ARM] mmp: avengers lite (pxa168) board bring upHaojian Zhuang
Signed-off-by: Gavin Gu <gavin.gu@marvell.com> Signed-off-by: Jing Xiang <jxiang@marvell.com> Signed-off-by: Jack Ren <jack.ren@marvell.com> Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-03-23[ARM] pxa: add base support for pxa910-based TTC_DKBEric Miao
Signed-off-by: Bin Yang <bin.yang@marvell.com> Signed-off-by: Eric Miao <eric.miao@marvell.com>
2009-03-23[ARM] pxa: add base support for pxa910-based TavorEVBEric Miao
2009-03-23[ARM] pxa: add base support for Marvell PXA910Eric Miao
2009-03-23[ARM] pxa: add base support for Marvell's PXA168 processor lineEric Miao
"""The MarvellĀ® PXA168 processor is the first in a family of application processors targeted at mass market opportunities in computing and consumer devices. It balances high computing and multimedia performance with low power consumption to support extended battery life, and includes a wealth of integrated peripherals to reduce overall BOM cost .... """ See http://www.marvell.com/featured/pxa168.jsp for more information. 1. Marvell Mohawk core is a hybrid of xscale3 and its own ARM core, there are many enhancements like instructions for flushing the whole D-cache, and so on 2. Clock reuses Russell's common clkdev, and added the basic support for UART1/2. 3. Devices are a bit different from the 'mach-pxa' way, the platform devices are now dynamically allocated only when necessary (i.e. when pxa_register_device() is called). Description for each device are stored in an array of 'struct pxa_device_desc'. Now that: a. this array of device description is marked with __initdata and can be freed up system is fully up b. which means board code has to add all needed devices early in his initializing function c. platform specific data can now be marked as __initdata since they are allocated and copied by platform_device_add_data() 4. only the basic UART1/2/3 are added, more devices will come later. Signed-off-by: Jason Chagas <chagas@marvell.com> Signed-off-by: Eric Miao <eric.miao@marvell.com>
