path: root/arch/arm/mach-lpc32xx/timer.c
2016-02-11arm: lpc32xx: switch to common clock frameworkVladimir Zapolskiy
The change switches NXP LPC32xx platforms to LPC32xx clock driver powered by common clock framework, this obsoletes mach-lpc32xx/clock.o legacy clock driver and thus it is removed. Legacy timer driver mach-lpc32xx/timer.o strictly depends on legacy clock support, but fortunately an existing LPC32xx clock source and clock event driver completely replaces it, and thus it can be removed as well. Noticeably platform UART driver directly operates on LPC32xx source control block registers, remove this dependency to avoid overlapping with common clock framework driver, also this guarantees that UART is working expectedly. Tested-by: Sylvain Lemieux <slemieux@tycoint.com> Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2015-07-17ARM/lpc32xx/timer: Migrate to new 'set-state' interfaceViresh Kumar
Migrate lpc32xx driver to the new 'set-state' interface provided by clockevents core, the earlier 'set-mode' interface is marked obsolete now. This also enables us to implement callbacks for new states of clockevent devices, for example: ONESHOT_STOPPED. Cc: Roland Stigge <stigge@antcom.de> Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
2014-03-12ARM: 7999/1: arch/arm/mach-lpc32xx-remove-irqf-disabledMichael Opdenacker
This patch removes the use of the IRQF_DISABLED flag from arch/arm/mach-lpc32xx/timer.c It's a NOOP since 2.6.35 and it will be removed one day. Signed-off-by: Michael Opdenacker <michael.opdenacker@free-electrons.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2013-01-14Merge branch 'clocksource/cleanup' into next/cleanupOlof Johansson
Clockevent cleanup series from Shawn Guo. Resolved move/change conflict in mach-pxa/time.c due to the sys_timer cleanup. * clocksource/cleanup: clocksource: use clockevents_config_and_register() where possible ARM: use clockevents_config_and_register() where possible clockevents: export clockevents_config_and_register for module use + sync to Linux 3.8-rc3 Signed-off-by: Olof Johansson <olof@lixom.net> Conflicts: arch/arm/mach-pxa/time.c
2013-01-14ARM: use clockevents_config_and_register() where possibleShawn Guo
The clockevent core is able to figure out the best mult and shift, calculate min_delta_ns and max_delta_ns, with the necessary info passed into clockevents_config_and_register(). Use this combined configure and register function where possible to make the codes less error prone and gain some positive diff stat. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Reviewed-by: Anton Vorontsov <cbouatmailru@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Jason Cooper <jason@lakedaemon.net> Tested-by: Roland Stigge <stigge@antcom.de> Acked-by: Eric Miao <eric.y.miao@gmail.com> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: David Brown <davidb@codeaurora.org> Tested-by: Tony Lindgren <tony@atomide.com> Acked-by: Barry Song <baohua.song@csr.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Tony Prisk <linux@prisktech.co.nz> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Jason Cooper <jason@lakedaemon.net> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-02-27ARM: LPC32xx: Fix missing and bad LPC32XX macrosRoland Stigge
Some of the LPC32XX_* macros were typed ("LCP32XX_*"), which is fixed by this patch. (Besides another LCP doc typo.) Further, the LPC32XX_GPIO_P2_MUX_SET/CLR/STATE macros were missing. Signed-off-by: Roland Stigge <stigge@antcom.de>
2011-05-23clocksource: convert ARM 32-bit up counting clocksourcesRussell King
Convert ixp4xx, lpc32xx, mxc, netx, pxa, sa1100, tcc8k, tegra and u300 to use the generic mmio clocksource recently introduced. Cc: Imre Kaloz <kaloz@openwrt.org> Cc: Krzysztof Halasa <khc@pm.waw.pl> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: "Hans J. Koch" <hjk@hansjkoch.de> Acked-by: Colin Cross <ccross@android.com> Cc: Erik Gilling <konkers@android.com> Cc: Olof Johansson <olof@lixom.net> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-12-22ARM: lpc32xx: update clock source registrationRussell King
In d7e81c2 (clocksource: Add clocksource_register_hz/khz interface) new interfaces were added which simplify (and optimize) the selection of the divisor shift/mult constants. Switch over to using this new interface. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-27ARM: LPC32XX: GPIO, timer, and IRQ driversKevin Wells
Common drivers for the LPC32XX used on all platforms Signed-off-by: Kevin Wells <wellsk40@gmail.com> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
