git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc
* 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc:
ARM: Consolidate the clkdev header files
ARM: set vga memory base at run-time
ARM: convert PCI defines to variables
ARM: pci: make pcibios_assign_all_busses use pci_has_flag
ARM: remove unnecessary mach/hardware.h includes
pci: move microblaze and powerpc pci flag functions into asm-generic
powerpc: rename ppc_pci_*_flags to pci_*_flags
Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
* 'next/fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (35 commits)
ARM: msm: platsmp: determine number of CPU cores at boot time
ARM: Tegra: Seaboard: Fix I2C bus numbering for ADT7461
ARM: Tegra: Trimslice: Tri-state DAP3 pinmux
ARM: orion5x: fixup 5181 MPP mask check
ARM: mxs-dma: include <linux/dmaengine.h>
ARM: i.MX53: consistently use MX53_UART_PAD_CTRL for uart txd/rxd/rts/cts
ARM: i.MX53: UARTn_CTS pin should not change RTS input select
ARM: i.MX53: UARTn_TXD pin should not change RXD input select
ARM: mx25: Fix typo on CAN1_RX pad setting
iomux-mx53: add missing 'IOMUX_CONFIG_SION' for some I2C pad definitions
ARM: NUC93X: add UL suffix to VMALLOC_END to ensure it is properly typed
ARM: LPC32XXX: add UL suffix to VMALLOC_END to ensure it is properly typed
ARM: CNS3XXX: add UL suffix to VMALLOC_END to ensure it is properly typed
ARM: i.MX53: Fix IOMUX type o's
ARM i.MX dma: Fix burstsize settings
mach-mx5: fix the I2C clock parents
ARM: mxs/tx28: according to the TX28's datasheet D4-D7 are not used for MMC0
ARM i.MX23/28: platform-mxsfb: Add missing include of linux/dma-mapping.h
ARM: mx53: Fix some interrupts marked as reserved.
MXC: iomux-v3: correct NO_PAD_CTRL definition
Fix up trivial conflict in arch/arm/mach-imx/mach-mx31_3ds.c
Now most of ARM machines has the alsmot same __clk_get/put() macro
So place it at the arch/arm/include/asm/clkdev.h and remove the reduntant header files
But some machines don't have the same form as above. It can use the machince specific clkdev file by HAVE_MACH_CLKDEV config
Now there are only 3 caese.
1) define the clk structure with clkdev macro => Need to move clk structure to proper header file
arch/arm/mach-versatile/include/mach/clkdev.h
arch/arm/mach-realview/include/mach/clkdev.h
arch/arm/mach-vexpress/include/mach/clkdev.h
arch/arm/mach-integrator/include/mach/clkdev.h
2) export the __clk_get/put function at clock.c
arch/arm/mach-shmobile/include/mach/clkdev.h
3) demuxing the clk source
arch/arm/mach-u300/include/mach/clkdev.h
Acked-by: Viresh Kumar <viresh.kumar@st.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Signed-off-by: Barry Song <baohua.song@csr.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Platforms provide an empty irq_prio_table macro, and as nothing uses
this macro, it can simply be removed.
This uncouple PHYS_OFFSET from the platform definitions, thereby
facilitating run-time computation of the physical memory offset.
Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-by: Magnus Damm <damm@opensource.se>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Eric Miao <eric.y.miao@gmail.com>
Acked-by: Jiandong Zheng <jdzheng@broadcom.com>
Rather than checking the MMU status in every instance of addruart, do it
once in kernel/debug.S, and change the existing addruart macros to
return both physical and virtual addresses. The main debug code can then
select the appropriate address to use.
This will also allow us to retreive the address of a uart for the MMU
state that we're not current in.
Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com>
and Tony Lindgren <tony@atomide.com>, and fix for versatile express from
Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>.
Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Jason Wang <jason77.wang@gmail.com>
Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
Debug (printascii) and IRQ handler macros for the LPC32XX
arch
Signed-off-by: Kevin Wells <wellsk40@gmail.com>
Header files for the LPC32xx arch
