http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm
* 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits)
ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET
ARM: gic, local timers: use the request_percpu_irq() interface
ARM: gic: consolidate PPI handling
ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H
ARM: mach-s5p64x0: remove mach/memory.h
ARM: mach-s3c64xx: remove mach/memory.h
ARM: plat-mxc: remove mach/memory.h
ARM: mach-prima2: remove mach/memory.h
ARM: mach-zynq: remove mach/memory.h
ARM: mach-bcmring: remove mach/memory.h
ARM: mach-davinci: remove mach/memory.h
ARM: mach-pxa: remove mach/memory.h
ARM: mach-ixp4xx: remove mach/memory.h
ARM: mach-h720x: remove mach/memory.h
ARM: mach-vt8500: remove mach/memory.h
ARM: mach-s5pc100: remove mach/memory.h
ARM: mach-tegra: remove mach/memory.h
ARM: plat-tcc: remove mach/memory.h
ARM: mach-mmp: remove mach/memory.h
ARM: mach-cns3xxx: remove mach/memory.h
Fix up mostly pretty trivial conflicts in:
- arch/arm/Kconfig
- arch/arm/include/asm/localtimer.h
- arch/arm/kernel/Makefile
- arch/arm/mach-shmobile/board-ap4evb.c
- arch/arm/mach-u300/core.c
- arch/arm/mm/dma-mapping.c
- arch/arm/mm/proc-v7.S
- arch/arm/plat-omap/Kconfig
largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP ->
CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and
addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
The <mach/gpio.h> file is included from upper directories
and deal with generic GPIO and gpiolib stuff. Break out the
platform and driver specific defines and functions into its own
header file.
Cc: zeal <zealcook@gmail.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Acked-by: Daniel Silverstone <dsilvers@simtec.co.uk>
Acked-by: Simtec Linux Team <linux@simtec.co.uk>
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Convert arch/arm includes of mach/gpio.h and asm/gpio.h to linux/gpio.h
before we start consolidating the individual platform implementations
of the gpio header files.
Aside of the usual motivation for constification, this function has a
history of being abused a hook for interrupt and other fixups so I turned
this function const ages ago in the MIPS code but it should be done
treewide.
Due to function pointer passing in varous places a few other functions
had to be constified as well.
To: Anton Vorontsov <avorontsov@mvista.com>
To: Chris Metcalf <cmetcalf@tilera.com>
To: Colin Cross <ccross@android.com>
Acked-by: "David S. Miller" <davem@davemloft.net>
To: Eric Miao <eric.y.miao@gmail.com>
To: Erik Gilling <konkers@android.com>
Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
To: "H. Peter Anvin" <hpa@zytor.com>
To: Imre Kaloz <kaloz@openwrt.org>
To: Ingo Molnar <mingo@redhat.com>
To: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
To: Jesse Barnes <jbarnes@virtuousgeek.org>
To: Krzysztof Halasa <khc@pm.waw.pl>
To: Lennert Buytenhek <kernel@wantstofly.org>
To: Matt Turner <mattst88@gmail.com>
To: Nicolas Pitre <nico@fluxnic.net>
To: Olof Johansson <olof@lixom.net>
Acked-by: Paul Mundt <lethal@linux-sh.org>
To: Richard Henderson <rth@twiddle.net>
To: Russell King <linux@arm.linux.org.uk>
To: Thomas Gleixner <tglx@linutronix.de>
Cc: linux-alpha@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: linux-pci@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: linux-tegra@vger.kernel.org
Cc: sparclinux@vger.kernel.org
Cc: x86@kernel.org
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Acked-by: Eric Miao <eric.miao at canonical.com>
Add support for the D-Link DSM-320 Wireless Media Player which is
based on the Micrel KS8695 SoC.
Signed-off-by: Daniel Silverstone <dsilvers@simtec.co.uk>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
