path: root/arch/arm/mach-kirkwood/openrd-setup.c
2011-08-21ARM: mach-kirkwood: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-03-03ARM: Remove dependency of plat-orion time code on mach directory includes.Lennert Buytenhek
This patch makes the various mach dirs that use the plat-orion time code pass in timer and bridge addresses explicitly, instead of having plat-orion get those values by including a mach dir include file -- the latter mechanism is problematic if you want to support multiple ARM platforms in the same kernel image. Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-11-15ASoC: Add support for OpenRD UltimateArnaud Patard (Rtp)
OpenRD Ultimate & Client are similar machines so enable OpenRD client sound support on Ultimate too Tested-by: Robas Teodor <teodor.robas@gmail.com> Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-09-19[ARM] OpenRD: Enable SD/UART selection for serial port 1Tanmay Upadhyay
This patch enables users to choose either the SDIO interface or UART1 (RS232/RS485). The selection can be done through kernel parameter. By default the port would be used for SDIO interface. Passing the string "kw_openrd_init_uart1=232" or "kw_openrd_init_uart1=485" enables either the RS-232 or RS-485 port respectively; disabling the SDIO interface. Anything else selects the default SDIO interface. "kw_openrd_init_uart1=485" is ignored on OpenRD-Base as it doesn't have RS485 port. Signed-off-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com> Acked-by: Alexander Clouter <alex@digriz.org.uk> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-08-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (214 commits) ALSA: hda - Add pin-fix for HP dc5750 ALSA: als4000: Fix potentially invalid DMA mode setup ALSA: als4000: enable burst mode ALSA: hda - Fix initial capsrc selection in patch_alc269() ASoC: TWL4030: Capture route runtime DAPM ordering fix ALSA: hda - Add PC-beep whitelist for an Intel board ALSA: hda - More relax for pending period handling ALSA: hda - Define AC_FMT_* constants ALSA: hda - Fix beep frequency on IDT 92HD73xx and 92HD71Bxx codecs ALSA: hda - Add support for HDMI HBR passthrough ALSA: hda - Set Stream Type in Stream Format according to AES0 ALSA: hda - Fix Thinkpad X300 so SPDIF is not exposed ALSA: hda - FIX to not expose SPDIF on Thinkpad X301, since it does not have the ability to use SPDIF ASoC: wm9081: fix resource reclaim in wm9081_register error path ASoC: wm8978: fix a memory leak if a wm8978_register fail ASoC: wm8974: fix a memory leak if another WM8974 is registered ASoC: wm8961: fix resource reclaim in wm8961_register error path ASoC: wm8955: fix resource reclaim in wm8955_register error path ASoC: wm8940: fix a memory leak if wm8940_register return error ASoC: wm8904: fix resource reclaim in wm8904_register error path ...
2010-07-16[ARM] Kirkwood: add support for PCIe1Saeed Bishara
This patch extends the kirkwood's PCIe support up to 2 controllers as in the 6282 devices. Signed-off-by: Saeed Bishara <saeed@marvell.com> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-07-16[ARM] Marvell OpenRD-Ultimate machine supportDmytro Milinevskyy
This patch adds support for the OpenRD Ultimate machine (could be found at http://www.arm.linux.org.uk/developer/machines/list.php?id=2884) Signed-off-by: Dmytro Milinevskyy <milinevskyy@gmail.com> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
2010-05-31openrd-client: initialise audioapatard@mandriva.com
This patch is reponsible for enabling audio on the openrd client board Signed-off-by: Arnaud Patard <apatard@mandriva.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-02-05[ARM] kirkwood: combine support for openrd base/client supportAlexander Clouter
Inspired by the mach-ep93xx flattening work, there is really not much difference between the OpenRD base and client board support so they should be merged together. Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Acked-by: Simon Kagstrom <simon.kagstrom@netinsight.net> Signed-off-by: Nicolas Pitre <nico@fluxnic.net>
