path: root/arch/arm/mach-ixp4xx
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-28[ARM] 3856/1: Add clocksource for Intel IXP4xx platformsKevin Hilman
Enables the ixp4xx platforms to use Generic time-of-day. Signed-off-by: Kevin Hilman <khilman@mvista.com> Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-06[ARM] 3772/1: Fix compilation error in mach-ixp4xx/nslu2*Martin Michlmayr
Patch from Martin Michlmayr Include linux/irq.h in the nslu2 code in order to avoid the following compiler error: CC arch/arm/mach-ixp4xx/nslu2-power.o arch/arm/mach-ixp4xx/nslu2-power.c: In function 'nslu2_power_init': arch/arm/mach-ixp4xx/nslu2-power.c:53: warning: implicit declaration of function 'set_irq_type' arch/arm/mach-ixp4xx/nslu2-power.c:53: error: 'IRQ_TYPE_LEVEL_LOW' undeclared (first use in this function) arch/arm/mach-ixp4xx/nslu2-power.c:53: error: (Each undeclared identifier is reported only once arch/arm/mach-ixp4xx/nslu2-power.c:53: error: for each function it appears in.) arch/arm/mach-ixp4xx/nslu2-power.c:54: error: 'IRQ_TYPE_LEVEL_HIGH' undeclared (first use in this function) make[5]: *** [arch/arm/mach-ixp4xx/nslu2-power.o] Error 1 Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-08-06[ARM] Fix pci export warningsRussell King
Remove duplicate PCI exports from ixp4xx machine class. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-08-06[ARM] 3747/1: Fix compilation error in mach-ixp4xx/gtwx5715-setup.cMartin Michlmayr
Patch from Martin Michlmayr Fix the following compilation error in arm/mach-ixp4xx/gtwx5715-setup: CC arch/arm/mach-ixp4xx/gtwx5715-setup.o arch/arm/mach-ixp4xx/gtwx5715-setup.c:110: error: expected identifier or '(' before ‘=’ token arch/arm/mach-ixp4xx/gtwx5715-setup.c:121: error: 'gtwx5715_flash_resource' undeclared here (not in a function) arch/arm/mach-ixp4xx/gtwx5715-setup.c: In function 'gtwx5715_init': arch/arm/mach-ixp4xx/gtwx5715-setup.c:133: error: 'flash_resource' undeclared (first use in this function) arch/arm/mach-ixp4xx/gtwx5715-setup.c:133: error: (Each undeclared identifier is reported only once arch/arm/mach-ixp4xx/gtwx5715-setup.c:133: error: for each function it appears in.) make[1]: *** [arch/arm/mach-ixp4xx/gtwx5715-setup.o] Error 1 Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[PATCH] ARM: fixup irqflags breakage after ARM genirq mergeThomas Gleixner
The irgflags consolidation did conflict with the ARM to generic IRQ conversion and was not applied for ARM. Fix it up. Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[ARM] 3682/2: ARM: Convert ixp4xx to generic irq handlingThomas Gleixner
Patch from Thomas Gleixner From: Thomas Gleixner <tglx@linutronix.de> Fixup the conversion to generic irq subsystem. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-26Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 3657/1: S3C24XX: Documentation update of Overview.txt [ARM] Update mach-types [ARM] 3656/1: S3C2412: Add S3C2412 and S3C2413 documenation [ARM] 3654/1: add ajeco 1arm sbc support [ARM] fix drivers/mfd/ucb1x00-core.c IRQ probing bug [ARM] 3651/1: S3C24XX: Make arch list more detailed [ARM] 3650/1: S3C2412: Update s3c2410_defconfig [ARM] 3649/1: S3C24XX: Fix capitalisation of CPU on SMDK2440 [ARM] 3612/1: make pci bus optional for ixp4xx platform [ARM] Remove MODE_(SVC|IRQ|FIQ|USR) and DEFAULT_FIQ [ARM] Remove save_lr/restore_pc macros [ARM] Remove partial non-v6 binutils compatibility [ARM] Remove LOADREGS macro [ARM] Remove RETINSTR macro
2006-06-25[ARM] 3612/1: make pci bus optional for ixp4xx platformMilan Svoboda
Patch from Milan Svoboda IXP4XX platform can happily live without pci bus. This patch modifies Kconfig to support this option and modifies Makefile so pci only files are compiled only when pci is really selected. Patch is tested and ixdp465 runs fine with or without the pci bus.-- Signed-off-by: Milan Svoboda <msvoboda@ra.rockwell.com>Signed-off-by: Deepak Saxena <dsaxena@plexity.net>Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-25[PATCH] kernel/sys.c: cleanupsAdrian Bunk
- proper prototypes for the following functions: - ctrl_alt_del() (in include/linux/reboot.h) - getrusage() (in include/linux/resource.h) - make the following needlessly global functions static: - kernel_restart_prepare() - kernel_kexec() [akpm@osdl.org: compile fix] Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[ARM] 3597/1: ixp4xx/nslu2: Board support for new LED subsystemRod Whitby
Patch from Rod Whitby This patch implements NEW_LEDS support for the Linksys NSLU2. The NSLU2 has four LED indicators, which are the only form of output for an unmodified device - there is no keyboard or display on an NSLU2. For an NSLU2 which has been modified to bring out the serial port console, it is important to register that device first separately, to enable debugging of other device support. Signed-off-by: John Bowler <jbowler@acm.org> Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-22[ARM] 3595/1: ixp4xx/nas100d: Board support for new LED subsystemRod Whitby
Patch from Rod Whitby This patch implements NEW_LEDS support for the IOMega NAS100d. The NAS100d has three LED indicators, which are the only form of output for an unmodified device - there is no keyboard or display on an NAS100d. For an NAS100d which has been modified to bring out the serial port console, it is important to register that device first separately, to enable debugging of other device support. Signed-off-by: John Bowler <jbowler@acm.org> Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-22[ARM] 3616/1: fix timer handler wrap logic for a number of platformsLennert Buytenhek
Patch from Lennert Buytenhek A couple of platforms aren't using the right comparison type in their timer interrupt handlers (as we're comparing two wrapping timestamps, we need a bmi/bpl-type comparison, not an unsigned comparison) -- this patch fixes them up. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-04[ARM] Trivial typo fixesEgry Gabor
Trivial typo fixes in Kconfig files (ARM). Signed-off-by: Egry Gabor <gaboregry@t-online.hu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-30[ARM] 3487/1: IXP4xx: Support non-PCI systemsDeepak Saxena
Patch from Deepak Saxena This patch allows for the addition of IXP4xx systems that do not make use of the PCI interface by moving the CONFIG_PCI symbol selection to be platform-specific instead of for all of IXP4xx. If at least one machine with PCI support is built, the PCI code will be compiled in, but when building !PCI, this will drastically shrink the kernel size. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-20[ARM] 3480/1: ixp4xx: fix irq2gpio array typeLennert Buytenhek
Patch from Lennert Buytenhek The irq2gpio array was recently converted from an array of ints to an array of chars (by patch 3368/1.) However, this array contains elements that are -1, and on ARM, the char type is unsigned by default, so this patch broke the GPIO check in ixp4xx_set_irq_type. Change the 'char' to be a 'signed char' to fix this. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Convert kmalloc+memset to kzallocRussell King
Convert all uses of kmalloc followed by memset to use kzalloc instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] 3368/1: ixp4xx: set gpio direction in ixp4xx_config_irqAlessandro Zummo
Patch from Alessandro Zummo ixp4xx_config_irq did not configure the gpio line as an input. As an added bonus, the irq2gpio array has been converted from int to char. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-08[ARM] 3355/1: NSLU2: remove propmt dependsAlessandro Zummo
Patch from Alessandro Zummo The patch that would have made the NSLU2 kernel non compatible with other ixp4xx machs never entered the kernel. So it is actually safe to remove the prompt dependencies. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-08[ARM] 3354/1: NAS100d: fix power led handlingAlessandro Zummo
Patch from Alessandro Zummo Disable GPIO clocks to allow the power led to work properly. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-07[ARM] 3353/1: NAS100d: protect nas100d_power_exit() with machine_is_nas100d()Alessandro Zummo
Patch from Alessandro Zummo nas100d_power_exit(void) gets some protection to avoid freeing an irq when it is not appropriate to do so. Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-22[ARM] 3347/1: Bugfix for ixp4xx_set_irq_type()Mårten Wikström
Patch from Mårten Wikström This patch fixes a bug in ixp4xx_set_irq_type() which leads to GPIO being incorrectly set to both edge triggered for raising as well as falling edge interrupt types. See the previous discussion on patch 3312/1. Signed-off-by: Mårten Wikström <marten.wikstrom@passito.se> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-22[ARM] 3344/1: NSLU2: beeper supportAlessandro Zummo
Patch from Alessandro Zummo This patch adds support for the beeper embedded in the NSLU2 to the machine setup code. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-22[ARM] 3342/1: NSLU2: Protect power button init routine with machine_is_nslu2()Alessandro Zummo
Patch from Alessandro Zummo The power button exit routine for the Linksys NSLU2 was not protected by a machine_is_nslu2(). This patch fixes it. Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-02-16[ARM] 3337/1: Fix NSLU2 flash support according to window size configuration ↵Martin Michlmayr
patch Patch from Martin Michlmayr ARM patch 3226/1 (IXP4xx runtime expansion bus window size configuration) forgot to update mach-ixp4xx/nslu2-setup.c which leads to the following compilation error. Update NSLU2 flash support following patch 3226/1. CC arch/arm/mach-ixp4xx/nslu2-setup.o arch/arm/mach-ixp4xx/nslu2-setup.c:30: error: ‘NSLU2_FLASH_BASE’ undeclared here (not in a function) arch/arm/mach-ixp4xx/nslu2-setup.c:31: error: ‘NSLU2_FLASH_SIZE’ undeclared here (not in a function) make[1]: *** [arch/arm/mach-ixp4xx/nslu2-setup.o] Error 1 make: *** [arch/arm/mach-ixp4xx] Error 2 Signed-off-by: Martin Michlmayr <tbm@cyrius.com> --- nslu2-setup.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-) Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-18[ARM] 3281/1: ixp4xx: export ixp4xx_exp_bus_size for modulesDavid Vrabel
Patch from David Vrabel Export ixp4xx_exp_bus_size so modules can use the IXP4XX_EXP_BUS_BASE(n) macro. Also, fix a printk format warning. Signed-off-by: David Vrabel <dvrabel@arcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[ARM] 3260/1: remove phys_ram from struct machine_desc (part 2)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. Now that no code uses it anymore, mark it deprecated and remove all initializations from the tree. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-05[ARM] 3226/1: IXP4xx runtime expansion bus window size configurationDeepak Saxena
Patch from Deepak Saxena The expansion bus on the IXP46x NPU can be configured for either 32MiB or 16MiB windows and changing the configuration causes the base address for each chip select for each region to change. Because of this, we cannot hardcode the physical base as we currently do. This patch checks the expansion bus configuration registers at runtime to determine the appropriate window size. Note that this requires that the bootloader already configured the device sizes appropriately, but I feel that is valid assumption to make as the bootloader must configure and access the flash window, the output display (LCD, LEDs, etc) window, and other expansion bus devices. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-04[ARM] 3218/1: PAGE_SHIFT undeclared in arch-ixp4xx/memory.h (adjust_zones ↵Rod Whitby
moved out of line) Patch from Rod Whitby PAGE_SHIFT is undeclared in include/asm-arm/arch-ixp4xx/memory.h, identified by the following kernel compilation error: CC [M] sound/core/memory.o In file included from include/asm/memory.h:27, from include/asm/io.h:28, from sound/core/memory.c:24: include/asm/arch/memory.h: In function `__arch_adjust_zones': include/asm/arch/memory.h:28: error: `PAGE_SHIFT' undeclared (first use in this function) This patch replaces my previous attempt at fixing this problem (Patch 3214/1) and is based on the following feedback: Russell King wrote: > The error you see came up on SA1100. The best solution was to move > the __arch_adjust_zones() function out of line. I suggest ixp4xx > does the same. I have moved the function out of line into arch/arm/mach-ixp4xx/common-pci.c as suggested. Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-04[ARM] 3220/1: Remove gpio_isr_line_clear() from NAS 100dDeepak Saxena
Patch from Deepak Saxena This patch removes referneces to gpio_isr_line_clear() from the NAS 100d platform implementation. Depends on 3192/1 and 3215/1 Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-04[ARM] 3215/1: Iomega NAS 100d (MACH_NAS100D) machine supportRod Whitby
Patch from Rod Whitby This patch adds support for a new arm/ixp4xx machine - the Iomega NAS 100d network attached storage product. The NAS100D is a consumer device containing a 266MHz Intel IXP420 processor, 16MB of flash, 64MB of RAM, a 160Gb internal IDE hard disk, and 802.11b/g wireless on an Atheros mini-PCI card. Work on porting the latest 2.6.x kernel to this device is being done by the NSLU2-Linux project (the same team who maintains the port to the Linksys NSLU2 device). In particular, the majority of this patch was authored by Alessandro Zummo, based on the work done for MACH_NSLU2 support by the NSLU2-Linux core team of developers. MACH_NAS100D (as implemented by this patch) can be enabled in jumbo ixp4xx kernels without any affect on the other machines supported by that kernel. This patch applies cleanly against 2.6.15-rc7 and should be trivial to apply to later kernel versions. It does not depend upon any other patches. Modified files (and number of lines inserted): arch/arm/mach-ixp4xx/Kconfig | 8 arch/arm/mach-ixp4xx/Makefile | 1 include/asm-arm/arch-ixp4xx/hardware.h | 1 include/asm-arm/arch-ixp4xx/irqs.h | 9 include/asm-arm/arch-ixp4xx/nas100d.h | 75 arch/arm/mach-ixp4xx/nas100d-pci.c | 77 arch/arm/mach-ixp4xx/nas100d-power.c | 69 arch/arm/mach-ixp4xx/nas100d-setup.c | 133 -- Rod Whitby (NSLU2-Linux project lead) Signed-off-by: Rod Whitby <rod@whitby.id.au> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-04[ARM] 3192/1: Remove gpio_isr_line_clear() API from IXP4xxDeepak Saxena
Patch from Deepak Saxena Other than interrupt masking purposes, this API is only used when configuring interrupt lines and this patch moves that functionality directly into the ixp4xx_set_irq_type() implementation as board level PCI code should not need to worry about those details. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-12-01[ARM] Fix IXDP425 setup bugJeff Hansen
There is a typo in the ARM IXDP425 setup definition that mistakenly tries to use UART1's IRQ for UART2's traffic. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-10[ARM] 3140/1: NSLU2 machine supportAlessandro Zummo
Patch from Alessandro Zummo This patch adds support for the LinkSys NSLU2 running with both big and little-endian kernels. The LinkSys NSLU2 is a cost engineered ARM, XScale 420 based system similar to the the Intel IXDP425 evaluation board. It uses the IXP4XX ARCH. While this patch applies independently of other patches the resultant kernel requires further patches to successfully use onboard devices, including the onboard flash. Since these patches are independent of this one they will be submitted separately. A defconfig is not included here because not all of the required drivers are actually in the kernel. We intend to provide one as soon as the patches will be incorporated in mainstream. This patch is the combined work of nslu2-linux.org Signed-off-by: John Bowler <jbowler@acm.org> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-06[ARM] 3089/1: ixp4xx AHB/PCI endianness fixAlessandro Zummo
Patch from Alessandro Zummo This patch fixes AHB/PCI endianness problems when the processor is in little-endian mode. The patch configures the CSR register closely following the directives in [1], paragraph 4.1, page 19. According to the considerations in [1], page 11, while the AHB bus supports both endian modes, on the IXP4XX it always uses big-endian. The PCI bus is connected to the South AHB. A wrong setting in the CSR register will thus cause a malfunctional PCI bus. A schematic diagram of the bus interconnections on the IXP4XX can be found in [1], page 18. The patch has been verified to work on the NSLU2 in both LE and BE modes. The author is Peter Korsgaard. [1] Intel® IXP4XX Product Line of Network Processors and IXC1100 Control Plane Processor: Understanding Big Endian and Little Endian Modes http://www.intel.com/design/network/applnots/25423701.pdf Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[ARM] 2985/1: Replace map_desc.physical with map_desc.pfn: IXP4xxDeepak Saxena
Patch from Deepak Saxena IXP4xx map_desc.pfn conversion Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-29[PATCH] Fix thinko in previous ARM 2917/1 patchDeepak Saxena
Previous patch accidently add IXDP425 mach entry when IXDP465 is configured. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-26[ARM] 2935/1: ixp4xx: fix warnings in ixp4xx_set_irq_typeDavid Vrabel
Patch from David Vrabel Signed-off-by: David Vrabel <dvrabel@arcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-18[ARM] 2917/1: Make IXP4xx mach_desc's depend on config optionsDeepak Saxena
Patch from Deepak Saxena Building a kernel for IXDP425 currently includes the machine descriptors for IXDP465 and PRPMC1100 even if those machines are not configured. This means we can build a kernel that boots on those machines even though the machine_is_xxx() macro will always return 0 and other bits such as PCI won't be compiled in. This can lead to many wasted hours wondering what you have done to your kernel to make it randomly crash thus requireing large quantities of beer to be consumed. While I am all for consumption of large quantities of beer, there are better reasons to do so then stupid kernel bugs. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-08[SERIAL] Use an enum for serial8250 platform device IDsRussell King
Rather than hard-coding the platform device IDs, enumerate them. We don't particularly care about the actual ID we get, just as long as they're unique. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-06[ARM] Fix missed initialisers/missing commaRussell King
Fix the broken initialisers missed by the recent IRQ patch. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-29[ARM] 2836/1: Cleanup IXP4xx GPIO codeDeepak Saxena
Patch from Deepak Saxena This patch implements the set_irq_type() hooks for configuring GPIO IRQ type and updates all the platforms to use it instead of the gpio_line_config() function which is now used to configure input vs. output on the pins. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-29[ARM] 2834/1: Remove IXP4xx board-specific map_io routinesDeepak Saxena
Patch from Deepak Saxena None of the board-specific map_io routines do anything, so kill them. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-26[PATCH] arm: fix IXP4xx flash resource rangeDeepak Saxena
We are currently reserving one byte more than actually needed by the flash device and overlapping into the next I/O expansion bus window. This a) causes us to allocate an extra page of VM due to ARM ioremap() alignment code and b) could cause problems if another driver tries to request the next expansion bus window. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-03[PATCH] ARM: 2835/1: Add UPF_SKIP_TEST to IXP4xx serial portsDeepak Saxena
Patch from Deepak Saxena This allows the serial driver autconf to work properly on all the IXP serial ports. W/o it we basically put the serial port in an unrecoverable state and lose console. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-06[PATCH] ARM: 2792/1: IXP4xx iomap API implementationDeepak Saxena
Patch from Deepak Saxena This patch implements the iomap API for Intel IXP4xx NPU systems. We need to implement our own version of the API functions b/c of the PCI hostbridge does not provide the capability to map PCI I/O space into the CPU's physical memory space. In addition, if a system has more than 64M of PCI memory mapped BARs, PCI memory must also be accessed indirectly. This patch changes the assignment of PCI I/O resources to fall into to 0x0000:0xffff range so that we can trap I/O areas in our ioread/iowrite macros. Signed-off-by: Deepak Saxena Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-06[PATCH] ARM: 2790/1: Properly terminate plat_serial8250_port arrays on ↵Stefan Sorensen
ixdp425 and coyote Patch from Stefan Sorensen On the ixdp425 and coyote platforms, the plat_serial8250_port arrays are missing the terminating entry required by serial8250_probe. Signed-off-by: Stefan Sorensen <ssoe@kirktelecom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
