path: root/arch/arm/mach-ixp4xx/ixdp425-setup.c
2006-01-13[ARM] 3260/1: remove phys_ram from struct machine_desc (part 2)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. Now that no code uses it anymore, mark it deprecated and remove all initializations from the tree. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-05[ARM] 3226/1: IXP4xx runtime expansion bus window size configurationDeepak Saxena
Patch from Deepak Saxena The expansion bus on the IXP46x NPU can be configured for either 32MiB or 16MiB windows and changing the configuration causes the base address for each chip select for each region to change. Because of this, we cannot hardcode the physical base as we currently do. This patch checks the expansion bus configuration registers at runtime to determine the appropriate window size. Note that this requires that the bootloader already configured the device sizes appropriately, but I feel that is valid assumption to make as the bootloader must configure and access the flash window, the output display (LCD, LEDs, etc) window, and other expansion bus devices. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-12-01[ARM] Fix IXDP425 setup bugJeff Hansen
There is a typo in the ARM IXDP425 setup definition that mistakenly tries to use UART1's IRQ for UART2's traffic. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-29[PATCH] Fix thinko in previous ARM 2917/1 patchDeepak Saxena
Previous patch accidently add IXDP425 mach entry when IXDP465 is configured. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-18[ARM] 2917/1: Make IXP4xx mach_desc's depend on config optionsDeepak Saxena
Patch from Deepak Saxena Building a kernel for IXDP425 currently includes the machine descriptors for IXDP465 and PRPMC1100 even if those machines are not configured. This means we can build a kernel that boots on those machines even though the machine_is_xxx() macro will always return 0 and other bits such as PCI won't be compiled in. This can lead to many wasted hours wondering what you have done to your kernel to make it randomly crash thus requireing large quantities of beer to be consumed. While I am all for consumption of large quantities of beer, there are better reasons to do so then stupid kernel bugs. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-08[SERIAL] Use an enum for serial8250 platform device IDsRussell King
Rather than hard-coding the platform device IDs, enumerate them. We don't particularly care about the actual ID we get, just as long as they're unique. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-29[ARM] 2834/1: Remove IXP4xx board-specific map_io routinesDeepak Saxena
Patch from Deepak Saxena None of the board-specific map_io routines do anything, so kill them. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-08-26[PATCH] arm: fix IXP4xx flash resource rangeDeepak Saxena
We are currently reserving one byte more than actually needed by the flash device and overlapping into the next I/O expansion bus window. This a) causes us to allocate an extra page of VM due to ARM ioremap() alignment code and b) could cause problems if another driver tries to request the next expansion bus window. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-03[PATCH] ARM: 2835/1: Add UPF_SKIP_TEST to IXP4xx serial portsDeepak Saxena
Patch from Deepak Saxena This allows the serial driver autconf to work properly on all the IXP serial ports. W/o it we basically put the serial port in an unrecoverable state and lose console. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-06[PATCH] ARM: 2790/1: Properly terminate plat_serial8250_port arrays on ↵Stefan Sorensen
ixdp425 and coyote Patch from Stefan Sorensen On the ixdp425 and coyote platforms, the plat_serial8250_port arrays are missing the terminating entry required by serial8250_probe. Signed-off-by: Stefan Sorensen <ssoe@kirktelecom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-03[PATCH] ARM: Remove machine description macrosRussell King
Remove the pointless machine description macros, favouring C99 initialisers instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
