path: root/arch/arm/mach-ixp23xx/Kconfig
2006-03-28[ARM] 3388/1: ixp23xx: add core ixp23xx supportLennert Buytenhek
Patch from Lennert Buytenhek This patch adds support for the Intel ixp23xx series of CPUs. The ixp23xx is an XSC3 based CPU with 512K of L2 cache, a 64bit 66MHz PCI interface, two DDR RAM interfaces, QDR RAM interfaces, two gigabit MACs, two 10/100 MACs, expansion bus, four microengines, a Media and Switch Fabric unit almost identical to the one on the ixp2400, two xscale (8250ish) UARTs and a bunch of other stuff. This patch adds the core ixp23xx support code, and support for the ADI Engineering Roadrunner, Intel IXDP2351, and IP Fabrics Double Espresso platforms. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
