Convert everyone who uses platform_bus_type to include
linux/platform_device.h.
Patch from Deepak Saxena
IXP2000 map_desc.pfn conversion
Signed-off-by: Deepak Saxena <dsaxena@plexity.net>
Serial port only needs 32 bytes of resource space but we are currently
asking for 64K.
[ diff went missing first time due to corrupted patch ]
It's pointless to include mach-types.h if you're not going to use
anything from it. These references were removed as a result of:
grep -lr 'asm/mach-types\.h' . | xargs grep -L 'machine_is_\|MACH_TYPE_\|MACHINE_START\|machine_type'
Rather than hard-coding the platform device IDs, enumerate them.
We don't particularly care about the actual ID we get, just as
long as they're unique.
Fix the broken initialisers missed by the recent IRQ patch.
This is part of Thomas Gleixner's generic IRQ patch, which converts
ARM to use the generic IRQ subsystem. Here, we wrap calls to
desc->handler() in an inline function, desc_handle_irq(). This
reduces the size of Thomas' patch since the changes become more
localised.
ARM to use the generic IRQ subsystem. Here, we rename two of the
irq_chip methods - wake becomes set_wake, and type becomes set_type.
Patch from Lennert Buytenhek
This patch converts the ixp2000 serial port over to a platform
serial device.
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
Remove the pointless machine description macros, favouring C99
initialisers instead.
Compiling one kernel that supports both ixdp2400 and ixdp2800 gives
an error, as a copy of the ixdp2400 irq init routing accidentally
ended up in ixdp2800.c somehow.
Add a mapping for the ixp2400 and ixp2800 msf unit. The msf is the
ixp2000's 'media and switch fabric' unit, which handles the networking
part of the chip.
VST needs to know which timer handler is for the timer interrupt.
Mark all timer interrupts with the SA_TIMER flag.
that don't need it
The later ixp2000 models don't need the PCI I/O workaround that we
currently perform. Add a config option to disable the workaround,
and panic on boot if a kernel without the workaround is booted on a
buggy chip. As only pre-production ixp2000s need the workaround,
the default is for it not to be configured in.
The ixp2000 gpio cleanup broke the ixdp2800 build as it moved some
gpio-related functions from arch/platform.h to arch/gpio.h and the
ixdp2x00 support code used those functions but didn't include the
latter header file.
On the enp2611, GPIO 7 and 6 are connected to an on-board i2c bus that
attaches to the SODIMM module slot (for SPD) and an LM84 temperature
sensor. Add a platform device for this i2c bus.
This patch cleans up the ixp2000 gpio irq code and implements the
set_irq_type method for gpio irqs so that users can select for which
events (falling edge/rising edge/level low/level high) on the gpio
pin they want the corresponding gpio irq to be triggered.
The IXP2000 has four timers, but if we're on an A-step IXP2800, timer
2 and 3 don't work. We need two timers for timekeeping (one for the
timer interrupt and one for tracking missed jiffies), so on early
IXP2800s we have no other choice but to use timer 1 and 4 for that,
but on all other IXP2000s we'd rather leave timer 4 free since that's
the only timer we can use for the watchdog.
So, on buggy IXP2000s (i.e. the A-step IXP2800) we use timer 4 for
tracking missed jiffies, and on all all non-buggy IXP2000s (i.e.
everything but the A-step IXP2800) we use timer 2.
On a pre-production IXP2800, this patch should print these messages
on boot:
Enabling IXP2800 erratum #25 workaround
Unable to use IXP2000 watchdog due to IXP2800 erratum #25
On any non-buggy IXP2800 (as well as on IXP2400s) you shouldn't see
anything at all, and the watchdog should be usable again.
The IXDP2800 is an evalution platform for the IXP2800 processor that
has two IXP2800s connected to the same PCI bus. This is problematic
as both CPUs will try to configure the PCI bus as they boot linux.
Contrary to on the other IXP2000 platforms, the boot loader on the
IXDP2800 doesn't configure the PCI bus properly, so we do want the
linux instance on one of the CPUs to do that.
Making one of the CPUs ignore the PCI bus (and thus act like a pure
PCI slave device) is not an option because there is a 82559 NIC on
the PCI bus for each of the CPUs.
The chosen solution is to have the master CPU configure the PCI bus
while the slave is kept in a quiescent state, and then to have the
slave CPU scan the PCI bus (without assigning resources) while the
master is kept in a quiescent state. After this ritual, the master
deletes the slave NIC from its PCI device list, the slave deletes
the master NIC from its device list, and (almost) all is well.
There's still one little problem: each of the CPUs has a 1G SDRAM
BAR, but the IXP2000 only has 512M of outbound PCI memory window.
We solve this by hand-assigning the master and slave SDRAM BARs to
a location outside each of the IXP's outbound PCI windows, and by
having the rest of the BARs autoconfigured in the outbound PCI
windows, in the range [e0000000..ffffffff], so that there is a 1:1
pci:phys mapping between them.
Even with this patch, a number of issues still remain -- just imagine
what happens if one of the CPUs is rebooted, by watchdog or by hand,
but the other one isn't. But those issues are not easily fixable
given the strange PCI layout of this board and the behavior of the
boot loader shipped with the platform.
Assigning the address zero to a PCI device BAR causes some part of the
PCI subsystem to believe that resource allocation for that BAR failed
due to resource conflicts, which will make attempts to enable the
device fail. Work around this by assigning I/O addresses starting
from 00010000.
While we're at it, make the PCI I/O resource end at 0001ffff, since we
only have 64k of outbound I/O window on the IXP2000, and we don't do
bank switching.
On the IXDP2800, the bootloader does an awful job of configuring
the PCI bus, so we make linux reconfigure everything. Having a 1:1
pci:phys address mapping generally simplifies everything, so try to
allocate PCI addresses from the [e0000000..ffffffff] range, which is
the physical address range of the outbound PCI window on the IXP2000.
This does not affect any of the other IXP2000 platforms since they
all use their bootloader's PCI resource assignment.
Export ixp2000_pci_config_addr, to be used by the IXDP2800 platform
setup code to coordinate booting the master and slave NPU.
infrastructure for it.
Let it rip!
