path: root/arch/arm/mach-ixp2000/ixdp2x00.c
2007-05-30[ARM] Fix some section mismatch warningsRussell King
The following patch fixes these section mismatch warnings: WARNING: arch/arm/mach-at91/built-in.o(.text+0xdf4): Section mismatch: reference to .init.data:dk_nand_partition (between 'nand_partitions' and 'at91_leds_event') WARNING: arch/arm/mach-at91/built-in.o(.text+0xbdc): Section mismatch: reference to .init.data:ek_nand_partition (after 'nand_partitions') WARNING: arch/arm/mach-at91/built-in.o(.text+0xbdc): Section mismatch: reference to .init.data:ek_nand_partition (between 'nand_partitions' and 'ads7843_pendown_state') WARNING: arch/arm/mach-at91/built-in.o(.text+0xbdc): Section mismatch: reference to .init.data:ek_nand_partition (after 'nand_partitions') WARNING: arch/arm/mach-at91/built-in.o(.text+0xc28): Section mismatch: reference to .init.data:kb9202_nand_partition (after 'nand_partitions') WARNING: arch/arm/mach-footbridge/built-in.o(.text+0xaa4): Section mismatch: reference to .init.data:cats_pci (between 'cats_pci_init' and 'ebsa285_leds_event')WARNING: arch/arm/mach-ixp2000/built-in.o(.text+0xb54): Section mismatch: reference to .init.text:ixp2000_init_irq (between 'ixdp2x00_init_irq' and 'ixdp2x00_irq_handler') WARNING: arch/arm/mach-ixp23xx/built-in.o(.text+0x670): Section mismatch: reference to .init.text:ixp23xx_pci_common_init (between 'ixp23xx_pci_slave_init' and 'ixp23xx_pci_scan_bus') WARNING: arch/arm/mach-ixp23xx/built-in.o(.text+0x890): Section mismatch: reference to .init.text:ixp23xx_init_irq (between 'ixdp2351_init_irq' and 'roadrunner_pci_preinit') WARNING: arch/arm/mach-ixp23xx/built-in.o(.text+0x9a8): Section mismatch: reference to .init.text:ixp23xx_pci_preinit (after 'roadrunner_pci_preinit') WARNING: arch/arm/mach-imx/built-in.o(__ksymtab+0x80): Section mismatch: reference to .init.text:imx_set_mmc_info (between '__ksymtab_imx_set_mmc_info' and '__ksymtab_set_imx_fb_info') WARNING: arch/arm/mach-imx/built-in.o(__ksymtab+0x88): Section mismatch: reference to .init.text:set_imx_fb_info (after '__ksymtab_set_imx_fb_info') WARNING: arch/arm/mach-sa1100/built-in.o(.text+0x1930): Section mismatch: reference to .init.data:neponset_port_fns (between 'neponset_probe' and 'assabet_leds_event') WARNING: drivers/built-in.o(.text+0x3f100): Section mismatch: reference to .init.text:ps2_clear_input (between 'ps2_probe' and 'ps2_cmd_aborted') WARNING: drivers/built-in.o(.text+0x3f1c8): Section mismatch: reference to .init.text:ps2_clear_input (between 'ps2_probe' and 'ps2_cmd_aborted') WARNING: drivers/built-in.o(.text+0x4f988): Section mismatch: reference to .init.text:ps2_clear_input (between 'ps2_probe' and 'ps2_cmd_aborted') WARNING: drivers/built-in.o(.text+0x4fa50): Section mismatch: reference to .init.text:ps2_clear_input (between 'ps2_probe' and 'ps2_cmd_aborted') Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-20[ARM] spelling fixesSimon Arlott
Spelling fixes in arch/arm/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Remove compatibility layer for ARM irqsRussell King
set_irq_chipdata -> set_irq_chip_data get_irq_chipdata -> get_irq_chip_data do_level_IRQ -> handle_level_irq do_edge_IRQ -> handle_edge_irq do_simple_IRQ -> handle_simple_irq irqdesc -> irq_desc irqchip -> irq_chip Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-17[ARM] switch to new pci_get_bus_and_slot APIAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[ARM] 3681/1: ARM: Convert ixp2000 to generic irq handlingThomas Gleixner
Patch from Thomas Gleixner From: Thomas Gleixner <tglx@linutronix.de> Fixup the conversion to generic irq subsystem. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-01Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-11-01[ARM] 3064/1: start using ixp2000_reg_wrbLennert Buytenhek
Patch from Lennert Buytenhek Switch the users of ixp2000_reg_write that depend on writes being flushed out of the write buffer by the time that function returns over to ixp2000_reg_wrb. When using XCB=101, writes to the same functional unit are still guaranteed to complete in order, so we only need to protect against: - reordering of writes to different functional units - masking an interrupt and then reenabling the IRQ bit in CPSR Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[ARM] 2984/1: Replace map_desc.physical with map_desc.pfn: IXP2000Deepak Saxena
Patch from Deepak Saxena IXP2000 map_desc.pfn conversion Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-04[ARM] Wrap calls to descriptor handlersRussell King
This is part of Thomas Gleixner's generic IRQ patch, which converts ARM to use the generic IRQ subsystem. Here, we wrap calls to desc->handler() in an inline function, desc_handle_irq(). This reduces the size of Thomas' patch since the changes become more localised. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-10[PATCH] ARM: 2793/1: platform serial support for ixp2000Lennert Buytenhek
Patch from Lennert Buytenhek This patch converts the ixp2000 serial port over to a platform serial device. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-25[PATCH] ARM: 2751/1: ixp2000 gpio cleanup broke ixdp2800 buildLennert Buytenhek
Patch from Lennert Buytenhek The ixp2000 gpio cleanup broke the ixdp2800 build as it moved some gpio-related functions from arch/platform.h to arch/gpio.h and the ixdp2x00 support code used those functions but didn't include the latter header file. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
