Booting 4.20 on a TheCUS N2100 results in a kernel oops while probing
PCI, due to n2100_pci_map_irq() having been discarded during boot.
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Cc: stable@vger.kernel.org # 2.6.18+
This converts all remaining cases of the old setup_timer() API into using
timer_setup(), where the callback argument is the structure already
holding the struct timer_list. These should have no behavioral changes,
since they just change which pointer is passed into the callback with
the same available pointers after conversion. It handles the following
examples, in addition to some other variations.
Casting from unsigned long:
void my_callback(unsigned long data)
struct something *ptr = (struct something *)data;
setup_timer(&ptr->my_timer, my_callback, ptr);
and forced object casts:
void my_callback(struct something *ptr)
setup_timer(&ptr->my_timer, my_callback, (unsigned long)ptr);
become:
void my_callback(struct timer_list *t)
struct something *ptr = from_timer(ptr, t, my_timer);
timer_setup(&ptr->my_timer, my_callback, 0);
Direct function assignments:
ptr->my_timer.function = my_callback;
have a temporary cast added, along with converting the args:
ptr->my_timer.function = (TIMER_FUNC_TYPE)my_callback;
And finally, callbacks without a data assignment:
setup_timer(&ptr->my_timer, my_callback, 0);
have their argument renamed to verify they're unused during conversion:
void my_callback(struct timer_list *unused)
The conversion is done with the following Coccinelle script:
spatch --very-quiet --all-includes --include-headers \
-I ./arch/x86/include -I ./arch/x86/include/generated \
-I ./include -I ./arch/x86/include/uapi \
-I ./arch/x86/include/generated/uapi -I ./include/uapi \
-I ./include/generated/uapi --include ./include/linux/kconfig.h \
--dir . \
--cocci-file ~/src/data/timer_setup.cocci
@fix_address_of@
expression e;
setup_timer(
-&(e)
+&e
// Update any raw setup_timer() usages that have a NULL callback, but
// would otherwise match change_timer_function_usage, since the latter
// will update all function assignments done in the face of a NULL
// function initialization in setup_timer().
@change_timer_function_usage_NULL@
expression _E;
identifier _timer;
type _cast_data;
-setup_timer(&_E->_timer, NULL, _E);
+timer_setup(&_E->_timer, NULL, 0);
-setup_timer(&_E->_timer, NULL, (_cast_data)_E);
-setup_timer(&_E._timer, NULL, &_E);
+timer_setup(&_E._timer, NULL, 0);
-setup_timer(&_E._timer, NULL, (_cast_data)&_E);
@change_timer_function_usage@
expression _E;
identifier _timer;
struct timer_list _stl;
identifier _callback;
type _cast_func, _cast_data;
-setup_timer(&_E->_timer, _callback, _E);
+timer_setup(&_E->_timer, _callback, 0);
-setup_timer(&_E->_timer, &_callback, _E);
-setup_timer(&_E->_timer, _callback, (_cast_data)_E);
-setup_timer(&_E->_timer, &_callback, (_cast_data)_E);
-setup_timer(&_E->_timer, (_cast_func)_callback, _E);
-setup_timer(&_E->_timer, (_cast_func)&_callback, _E);
-setup_timer(&_E->_timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E->_timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._timer, _callback, (_cast_data)_E);
+timer_setup(&_E._timer, _callback, 0);
-setup_timer(&_E._timer, _callback, (_cast_data)&_E);
-setup_timer(&_E._timer, &_callback, (_cast_data)_E);
-setup_timer(&_E._timer, &_callback, (_cast_data)&_E);
-setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)_E);
-setup_timer(&_E._timer, (_cast_func)_callback, (_cast_data)&_E);
-setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)_E);
-setup_timer(&_E._timer, (_cast_func)&_callback, (_cast_data)&_E);
_E->_timer@_stl.function = _callback;
_E->_timer@_stl.function = &_callback;
_E->_timer@_stl.function = (_cast_func)_callback;
_E->_timer@_stl.function = (_cast_func)&_callback;
_E._timer@_stl.function = _callback;
_E._timer@_stl.function = &_callback;
_E._timer@_stl.function = (_cast_func)_callback;
_E._timer@_stl.function = (_cast_func)&_callback;
// callback(unsigned long arg)
@change_callback_handle_cast
depends on change_timer_function_usage@
identifier change_timer_function_usage._callback;
identifier change_timer_function_usage._timer;
type _origtype;
identifier _origarg;
type _handletype;
identifier _handle;
void _callback(
-_origtype _origarg
+struct timer_list *t
... when != _origarg
_handletype *_handle =
-(_handletype *)_origarg;
+from_timer(_handle, t, _timer);
-(void *)_origarg;
_handletype *_handle;
... when != _handle
_handle =
... when != _handle
_handle =
-(void *)_origarg;
// callback(unsigned long arg) without existing variable
@change_callback_handle_cast_no_arg
depends on change_timer_function_usage &&
!change_callback_handle_cast@
type _origtype;
type _handletype;
void _callback(
-_origtype _origarg
+ _handletype *_origarg = from_timer(_origarg, t, _timer);
- (_handletype *)_origarg
+ _origarg
// Avoid already converted callbacks.
@match_callback_converted
!change_callback_handle_cast &&
!change_callback_handle_cast_no_arg@
identifier t;
void _callback(struct timer_list *t)
// callback(struct something *handle)
@change_callback_handle_arg
!match_callback_converted &&
type _handletype;
identifier _handle;
void _callback(
-_handletype *_handle
+ _handletype *_handle = from_timer(_handle, t, _timer);
// If change_callback_handle_arg ran on an empty function, remove
// the added handler.
@unchange_callback_handle_arg
change_callback_handle_arg@
type _handletype;
identifier _handle;
identifier t;
- _handletype *_handle = from_timer(_handle, t, _timer);
// We only want to refactor the setup_timer() data argument if we've found
// the matching callback. This undoes changes in change_timer_function_usage.
@unchange_timer_function_usage
!change_callback_handle_cast_no_arg &&
!change_callback_handle_arg@
expression change_timer_function_usage._E;
type change_timer_function_usage._cast_data;
-timer_setup(&_E->_timer, _callback, 0);
+setup_timer(&_E->_timer, _callback, (_cast_data)_E);
-timer_setup(&_E._timer, _callback, 0);
+setup_timer(&_E._timer, _callback, (_cast_data)&_E);
// If we fixed a callback from a .function assignment, fix the
// assignment cast now.
@change_timer_function_assignment
(change_callback_handle_cast ||
change_callback_handle_cast_no_arg ||
change_callback_handle_arg)@
type _cast_func;
typedef TIMER_FUNC_TYPE;
_E->_timer.function =
-_callback
+(TIMER_FUNC_TYPE)_callback
-&_callback
-(_cast_func)_callback;
-(_cast_func)&_callback
_E._timer.function =
-_callback
-&_callback;
// Sometimes timer functions are called directly. Replace matched args.
@change_timer_function_calls
expression _E;
type _cast_data;
_callback(
-(_cast_data)_E
+&_E->_timer
-(_cast_data)&_E
+&_E._timer
-_E
+&_E->_timer
// If a timer has been configured without a data argument, it can be
// converted without regard to the callback argument, since it is unused.
@match_timer_function_unused_data@
expression _E;
identifier _timer;
-setup_timer(&_E->_timer, _callback, 0);
-setup_timer(&_E->_timer, _callback, 0L);
-setup_timer(&_E->_timer, _callback, 0UL);
-setup_timer(&_E._timer, _callback, 0);
-setup_timer(&_E._timer, _callback, 0L);
-setup_timer(&_E._timer, _callback, 0UL);
-setup_timer(&_timer, _callback, 0);
+timer_setup(&_timer, _callback, 0);
-setup_timer(&_timer, _callback, 0L);
-setup_timer(&_timer, _callback, 0UL);
-setup_timer(_timer, _callback, 0);
+timer_setup(_timer, _callback, 0);
-setup_timer(_timer, _callback, 0L);
-setup_timer(_timer, _callback, 0UL);
@change_callback_unused_data
depends on match_timer_function_unused_data@
identifier match_timer_function_unused_data._callback;
type _origtype;
void _callback(
-_origtype _origarg
+struct timer_list *unused
This mechanically converts all remaining cases of ancient open-coded timer
setup with the old setup_timer() API, which is the first step in timer
conversions. This has no behavioral changes, since it ultimately just
changes the order of assignment to fields of struct timer_list when
finding variations of:
init_timer(&t);
f.function = timer_callback;
t.data = timer_callback_arg;
to be converted into:
setup_timer(&t, timer_callback, timer_callback_arg);
The conversion is done with the following Coccinelle script, which
is an improved version of scripts/cocci/api/setup_timer.cocci, in the
following ways:
- assignments-before-init_timer() cases
- limit the .data case removal to the specific struct timer_list instance
- handling calls by dereference (timer->field vs timer.field)
--dir . \
--cocci-file ~/src/data/setup_timer.cocci
@fix_address_of@
expression e;
init_timer(
-&(e)
+&e
// Match the common cases first to avoid Coccinelle parsing loops with
// "... when" clauses.
@match_immediate_function_data_after_init_timer@
expression e, func, da;
-init_timer
+setup_timer
( \(&e\|e\)
+, func, da
-\(e.function\|e->function\) = func;
-\(e.data\|e->data\) = da;
@match_immediate_function_data_before_init_timer@
-init_timer
+setup_timer
( \(&e\|e\)
+, func, da
@match_function_and_data_after_init_timer@
expression e, e2, e3, e4, e5, func, da;
-init_timer
+setup_timer
( \(&e\|e\)
+, func, da
... when != func = e2
when != da = e3
-e.function = func;
... when != da = e4
-e.data = da;
-e->function = func;
... when != da = e4
-e->data = da;
-e.data = da;
... when != func = e5
-e.function = func;
-e->data = da;
@match_function_and_data_before_init_timer@
-e.function = func;
... when != da = e4
-e.data = da;
... when != da = e4
-e->data = da;
-e.data = da;
-e.function = func;
-e->data = da;
when != da = e3
-init_timer
+setup_timer
( \(&e\|e\)
+, func, da
@r1 exists@
expression t;
identifier f;
position p;
f(...) { ... when any
init_timer@p(\(&t\|t\))
... when any
@r2 exists@
expression r1.t;
identifier g != r1.f;
expression e8;
g(...) { ... when any
\(t.data\|t->data\) = e8
... when any
// It is dangerous to use setup_timer if data field is initialized
// in another function.
@script:python depends on r2@
p << r1.p;
cocci.include_match(False)
@r3@
expression r1.t, func, e7;
position r1.p;
-init_timer@p(&t);
+setup_timer(&t, func, 0UL);
... when != func = e7
-t.function = func;
-t.function = func;
-init_timer@p(&t);
-init_timer@p(t);
+setup_timer(t, func, 0UL);
-t->function = func;
-init_timer@p(t);
This converts the IOP32x and IOP33x platforms to pass their
base address offset by a resource attached to a platform device
instead of using static offset macros implicitly passed
through <linux/gpio.h> including <mach/gpio.h>. Delete the
local <mach/gpio.h> and <asm/hardware/iop3xx-gpio.h> headers
and remove the selection of NEED_MACH_GPIO_H.
Pass the virtual address as a resource in the platform device
at this point for bisectability, next patch will pass the
physical address as is custom.
Cc: Lennert Buytenhek <kernel@wantstofly.org>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Mikael Pettersson <mikpe@it.uu.se>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Refrain from using the custom gpio_line_get() to read the power
key on the N2100, use the gpiolib function gpio_get() instead.
Also request the line in the GPIOs initicall, and move the poll
timer setup to that inicall so the gpio chip is available before
we request this GPIO and start to poll it.
As the IOP GPIO driver supports gpiolib we can use the standard
GPIO calls to issue a reset of the machine instead of using the
custom gpio_line_set/config calls. Also request the GPIO when
initializing the machine.
Preparing to move the parsing of reboot= to generic kernel code forces
the change in reboot_mode handling to use the enum.
[akpm@linux-foundation.org: fix arch/arm/mach-socfpga/socfpga.c]
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Russ Anderson <rja@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
Most PCI implementations perform simple root bus scanning. Rather than
having each group of platforms provide a duplicated bus scan function,
provide the PCI configuration ops structure via the hw_pci structure,
and call the root bus scanning function from core ARM PCI code.
Acked-by: Krzysztof Hałasa <khc@pm.waw.pl>
Most PCI implementations use the standard PCI swizzle function, which
handles the well defined behaviour of PCI-to-PCI bridges which can be
found on cards (eg, four port ethernet cards.)
Rather than having almost every platform specify the standard swizzle
function, make this the default when no swizzle function is supplied.
Therefore, a swizzle function only needs to be provided when there is
something exceptional which needs to be handled.
This gets rid of the swizzle initializer from 47 files, and leaves us
with just two platforms specifying a swizzle function: ARM Integrator
and Chalice CATS.
Hook these platforms restart code into the arm_pm_restart hook rather
than using arch_reset().
In doing so, we split out the n2100 platform specific restart handler
into the n2100 platform file.
Acked-by: Lennert Buytenhek <buytenh@wantstofly.org>
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Aside of the usual motivation for constification, this function has a
history of being abused a hook for interrupt and other fixups so I turned
this function const ages ago in the MIPS code but it should be done
treewide.
Due to function pointer passing in varous places a few other functions
had to be constified as well.
To: Anton Vorontsov <avorontsov@mvista.com>
To: Chris Metcalf <cmetcalf@tilera.com>
To: Colin Cross <ccross@android.com>
Acked-by: "David S. Miller" <davem@davemloft.net>
To: Eric Miao <eric.y.miao@gmail.com>
To: Erik Gilling <konkers@android.com>
Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
To: "H. Peter Anvin" <hpa@zytor.com>
To: Imre Kaloz <kaloz@openwrt.org>
To: Ingo Molnar <mingo@redhat.com>
To: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
To: Jesse Barnes <jbarnes@virtuousgeek.org>
To: Krzysztof Halasa <khc@pm.waw.pl>
To: Lennert Buytenhek <kernel@wantstofly.org>
To: Matt Turner <mattst88@gmail.com>
To: Nicolas Pitre <nico@fluxnic.net>
To: Olof Johansson <olof@lixom.net>
Acked-by: Paul Mundt <lethal@linux-sh.org>
To: Richard Henderson <rth@twiddle.net>
To: Russell King <linux@arm.linux.org.uk>
To: Thomas Gleixner <tglx@linutronix.de>
Cc: linux-alpha@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: linux-pci@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: linux-tegra@vger.kernel.org
Cc: sparclinux@vger.kernel.org
Cc: x86@kernel.org
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Acked-by: Eric Miao <eric.miao at canonical.com>
arch/arm/Kconfig
arch/arm/include/asm/system.h
arch/arm/mm/Kconfig
Thecus N2100 has a jumper (J3/J4) to select whether the XINT1 interrupt
line is connected to the second UHCI controller (position J3) or to
the serial port UART (position J4). Currently, the kernel is hardcoded
to assume the J3 position, and the serial port is always being used in
polling mode.
The patch adds the IRQ autodetection flag for the serial port interrupt,
and also marks it as shared (as the driver for the second UHCI controller
will request the interrupt in any case). Now, when the jumper is set to
the J4 position, the serial port will have an interrupt line, resulting
in less CPU overhead and faster throughput.
Tested-by: Mikael Pettersson <mikpe@it.uu.se>
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This updates the IOP platform to use the kernel's generic time
framework. With clockevent support in place, this reduces to
selecting GENERIC_TIME and removing the platform's private timer
->offset() operation (iop_gettimeoffset).
Tested on n2100, compile-tested for all plat-iop machines.
Signed-off-by: Mikael Pettersson <mikpe@it.uu.se>
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
Thecus N2100 has leds and a buzzer attached to a pca9532 controller. Attach
the driver to the i2c bus and define the pca9532 pin coniguration for this
platform in n2100_leds.
With this patch, support for N2100 should be complete in mainline Linux.
Signed-off-by: Riku Voipio <riku.voipio@iki.fi>
Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
Based on earlier work by Jon Smirl and Jochen Friedrich.
Update most new-style i2c drivers to use standard module aliasing
instead of the old driver_name/type driver matching scheme. I've
left the video drivers apart (except for SoC camera drivers) as
they're a bit more diffcult to deal with, they'll have their own
patch later.
Cc: Jon Smirl <jonsmirl@gmail.com>
Cc: Jochen Friedrich <jochen@scram.de>
On thecus n2100, the bootloader does not setup fans to run. In order
to protect the user from frying their gear, start up fans on boot.
Signed-off-by: Riku Voipio <riku.voipio@movial.fi>
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
Use the new i2c framework to load rtc-rs5c372 for the Thecus N2100.
Signed-off-by: Martin Michlmayr <tbm@cyrius.com>
Tested-by: Voipio Riku <Riku.Voipio@movial.fi>
Cc: Lennert Buytenhek <buytenh@wantstofly.org>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: David Brownell <david-b@pacbell.net>
Adds the platform device definitions and the architecture specific support
routines (i.e. register initialization and descriptor formats) for the
iop-adma driver.
Changelog:
* add support for > 1k zero sum buffer sizes
* added dma/aau platform devices to iq80321 and iq80332 setup
* fixed the calculation in iop_desc_is_aligned
* support xor buffer sizes larger than 16MB
* fix places where software descriptors are assumed to be contiguous, only
hardware descriptors are contiguous for up to a PAGE_SIZE buffer size
* convert to async_tx
* add interrupt support
* add platform devices for 80219 boards
* do not call platform register macros in driver code
* remove switch() statements for compatible register offsets/layouts
* change over to bitmap based capabilities
* remove unnecessary ARM assembly statement
* checkpatch.pl fixes
* gpl v2 only correction
* phys move to dma_async_tx_descriptor
WARNING: arch/arm/mach-iop13xx/built-in.o - Section mismatch: reference to
.init.text:iop13xx_pcie_map_irq from .text between 'iop13xx_pci_setup' (at
offset 0x7fc) and 'iop13xx_map_pci_memory'
While fixing this warning I also recalled Adrian Bunk's recommendation to
not use inline in .c files, as 'iop13xx_map_pci_memory' is needlessly
inlined.
Removing 'inline' uncovered some dead code so that is cleaned up as well.
include/asm-arm/arch-at91rm9200/entry-macro.S
On the n2100, both onboard r8169 ports exhibit PCI parity problems.
Set the ->broken_parity_status flag for both ports so that the r8169
drivers knows it should ignore error interrupts.
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
* architecture specific details are handled in asm/arch/time.h
* ARCH_IOP13XX now selects PLAT_IOP
* as suggested by Lennert use ifdef CONFIG_XSCALE to skip the cp_wait on
XSC3
The second ethernet port on the Thecus n2100 was incorrectly assigned
to XINT1 instead of the correct XINT3 (PCI INTB instead of INTD), which
caused that port to be non-functional.
Add support for the Thecus n2100 (80219-based.)
