path: root/arch/arm/mach-imx/mach-scb9328.c
2012-12-24ARM: delete struct sys_timerStephen Warren
Now that the only field in struct sys_timer is .init, delete the struct, and replace the machine descriptor .timer field with the initialization function itself. This will enable moving timer drivers into drivers/clocksource without having to place a public prototype of each struct sys_timer object into include/linux; the intent is to create a single of_clocksource_init() function that determines which timer driver to initialize by scanning the device dtree, much like the proposed irqchip_init() at: http://www.spinics.net/lists/arm-kernel/msg203686.html Includes mach-omap2 fixes from Igor Grinberg. Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2012-10-15ARM: imx: include hardware.h rather than mach/hardware.hShawn Guo
It moves a bunch of header files included in hardware.h and itself from mach-imx/include/mach to mach-imx, and updates users to include hardware.h rather than mach/hardware.h. The files in mach-imx/devices will need to include "../hardware.h". Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-10-15ARM: imx: include common.h rather than mach/common.hShawn Guo
Rename mach-imx/include/mach/common.h to mach-imx/common.h and update all users to include common.h rather than mach/common.h. It also removes an unneeded inclusion to common.h in mach-imx/devices/devices.c. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-10-15ARM: imx: move iomux drivers and headers into mach-imxShawn Guo
The board files in mach-imx are the only users of iomux drivers and headers. Move them into mach-imx from plat-mxc. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de>
2012-07-01ARM: imx: remove unneeded mach/irq.h inclusionShawn Guo
Remove unneeded mach/irq.h inclusion from imx platform code. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
2012-07-01ARM: imx: eliminate macro IRQ_GPIOx()Shawn Guo
This patch changes all the static gpio irq number assigning with IRQ_GPIOA() ... IRQ_GPIOF() to run-time assigning with gpio_to_irq call, and in turn eliminates these macros. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Dong Aisheng <dong.aisheng@linaro.org>
2012-01-05ARM: restart: mxc: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-11-01Merge branch 'next/devel' of git://git.linaro.org/people/arnd/arm-socLinus Torvalds
* 'next/devel' of git://git.linaro.org/people/arnd/arm-soc: (50 commits) ARM: tegra: update defconfig arm/tegra: Harmony: Configure PMC for low-level interrupts arm/tegra: device tree support for ventana board arm/tegra: add support for ventana pinmuxing arm/tegra: prepare Seaboard pinmux code for derived boards arm/tegra: pinmux: ioremap registers gpio/tegra: Convert to a platform device arm/tegra: Convert pinmux driver to a platform device arm/dt: Tegra: Add pinmux node to tegra20.dtsi arm/tegra: Prep boards for gpio/pinmux conversion to pdevs ARM: mx5: fix clock usage for suspend ARM i.MX entry-macro.S: remove now unused code ARM i.MX boards: use CONFIG_MULTI_IRQ_HANDLER ARM i.MX tzic: add handle_irq function ARM i.MX avic: add handle_irq function ARM: mx25: Add the missing IIM base definition ARM i.MX avic: convert to use generic irq chip mx31moboard: Add poweroff support ARM: mach-qong: Add watchdog support ARM: davinci: AM18x: Add wl1271/wlan support ... Fix up conflicts in: arch/arm/mach-at91/at91sam9g45.c arch/arm/mach-mx5/devices-imx53.h arch/arm/plat-mxc/include/mach/memory.h
2011-09-26ARM i.MX boards: use CONFIG_MULTI_IRQ_HANDLERSascha Hauer
Also, add handle_irq callbacks to machine descriptors. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-08-21ARM: mach-imx: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-07-25Merge branch 'next/cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (133 commits) ARM: EXYNOS4: Change devname for FIMD clkdev ARM: S3C64XX: Cleanup mach/regs-fb.h from mach-s3c64xx ARM: S5PV210: Cleanup mach/regs-fb.h from mach-s5pv210 ARM: S5PC100: Cleanup mach/regs-fb.h from mach-s5pc100 ARM: S3C24XX: Use generic s3c_set_platdata for devices ARM: S3C64XX: Use generic s3c_set_platdata for OneNAND ARM: SAMSUNG: Use generic s3c_set_platdata for NAND ARM: SAMSUNG: Use generic s3c_set_platdata for USB OHCI ARM: SAMSUNG: Use generic s3c_set_platdata for HWMON ARM: SAMSUNG: Use generic s3c_set_platdata for FB ARM: SAMSUNG: Use generic s3c_set_platdata for TS ARM: S3C64XX: Add PWM backlight support on SMDK6410 ARM: S5P64X0: Add PWM backlight support on SMDK6450 ARM: S5P64X0: Add PWM backlight support on SMDK6440 ARM: S5PC100: Add PWM backlight support on SMDKC100 ARM: S5PV210: Add PWM backlight support on SMDKV210 ARM: EXYNOS4: Add PWM backlight support on SMDKC210 ARM: EXYNOS4: Add PWM backlight support on SMDKV310 ARM: SAMSUNG: Create a common infrastructure for PWM backlight support clocksource: convert 32-bit down counting clocksource on S5PV210/S5P64X0 ... Fix up trivial conflict in arch/arm/mach-imx/mach-scb9328.c
2011-07-07ARM: mach-imx/scb9328: Make the UART gpio setup simplerFabio Estevam
Place the UART gpio initialization inside the scb9328_init function as it is done on other i.MX boards. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2011-06-06gpio/mxc: Change gpio-mxc into an upstanding gpio driverShawn Guo
The patch makes necessary changes on gpio-mxc as below to turn it into an upstanding gpio driver. * Add a list to save all mx2 ports references, so that mx2_gpio_irq_handler can walk through all interrupt status registers * Use readl/writel to replace mach-specific accessors __raw_readl/__raw_writel * Change mxc_gpio_init into mxc_gpio_probe function * Move "struct mxc_gpio_port" into gpio-mxc.c, as it needs not to be public at all, and also make some other cleanup on plat-mxc/include/mach/gpio.h at the same time And the patch then migrates mach-imx and mach-mx5 to the updated driver by adding corresponding platform devices. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-10ARM: imx: use .init_early to initialize cpu type and reset addressUwe Kleine-König
This used to be done in .map_io which is supposed to only setup the memory mapping. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-11-17ARM: imx: remove now empty devices.hUwe Kleine-König
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-01ARM: imx: make all pin lists const and signed, move to .init where possibleUwe Kleine-König
Making the lists signed fixes sparse warnings like: arch/arm/mach-imx/mach-mx27_3ds.c:94:31: warning: incorrect type in argument 1 (different signedness) arch/arm/mach-imx/mach-mx27_3ds.c:94:31: expected int const *pin_list arch/arm/mach-imx/mach-mx27_3ds.c:94:31: got unsigned int static [toplevel] *<noident> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2010-06-30ARM: imx: dynamically register imx-uart devices (imx1)Uwe Kleine-König
2010-06-30ARM: imx: move mx1 support to mach-imxUwe Kleine-König
