path: root/arch/arm/mach-imx/Kconfig
2012-07-23Merge tag 'irq' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc sparse IRQ conversion from Arnd Bergmann: "The I.MX platform is getting converted to use sparse IRQs. We are doing this for all platforms over time, because this is one of the requirements for building a multiplatform kernel, and generally a good idea." * tag 'irq' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: imx: select USE_OF ARM: imx: Fix build error due to missing irqs.h include ARM: imx: enable SPARSE_IRQ for imx platform ARM: fiq: change FIQ_START to a variable tty: serial: imx: remove the use of MXC_INTERNAL_IRQS ARM: imx: remove unneeded mach/irq.h inclusion i2c: imx: remove unneeded mach/irqs.h inclusion ARM: imx: add a legacy irqdomain for mx31ads ARM: imx: add a legacy irqdomain for 3ds_debugboard ARM: imx: pass gpio than irq number into mxc_expio_init ARM: imx: leave irq_base of wm8350_platform_data uninitialized dma: ipu: remove the use of ipu_platform_data ARM: imx: move irq_domain_add_legacy call into avic driver ARM: imx: move irq_domain_add_legacy call into tzic driver gpio/mxc: move irq_domain_add_legacy call into gpio driver ARM: imx: eliminate macro IRQ_GPIOx() ARM: imx: eliminate macro IOMUX_TO_IRQ() ARM: imx: eliminate macro IMX_GPIO_TO_IRQ()
2012-07-23Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc device tree description updates from Arnd Bergmann: "This branch contains two kinds of updates: Some platforms in the process of getting converted to device tree based booting, and the platform specific patches necessary for that are included here. Other platforms are already converted, so we just need to update the actual device tree source files and the binding documents to add support for new board and new drivers. In the future we will probably separate those into two branches, and in the long run, the plan is to move the device tree source files out of the kernel repository, but that has to wait until we have completed a much larger portion of the binding documents." Fix up trivial conflicts in arch/arm/mach-imx/clk-imx6q.c due to newly added clkdev registers next to a few removed unnecessary ones. * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (119 commits) ARM: LPC32xx: Add PWM to base dts file ARM: EXYNOS: mark the DMA channel binding for SPI as preliminary ARM: dts: Add nodes for spi controllers for SAMSUNG EXYNOS5 platforms ARM: EXYNOS: Enable platform support for SPI controllers for EXYNOS5 ARM: EXYNOS: Add spi clock support for EXYNOS5 ARM: dts: Add nodes for spi controllers for SAMSUNG EXYNOS4 platforms ARM: EXYNOS: Enable platform support for SPI controllers for EXYNOX4 ARM: EXYNOS: Fix the incorrect hierarchy of spi controller bus clock ARM: ux500: Remove PMU platform registration when booting with DT ARM: ux500: Remove temporary snowball_of_platform_devs enablement structure ARM: ux500: Ensure vendor specific properties have the vendor's identifier pinctrl: pinctrl-nomadik: Append sleepmode property with vendor specific prefixes ARM: ux500: Move rtc-pl031 registration to Device Tree when enabled ARM: ux500: Enable the AB8500 RTC for all DT:ed DB8500 based devices ARM: ux500: Correctly reference IRQs supplied by the AB8500 from Device Tree ARM: ux500: Apply ab8500-debug node do the db8500 DT structure ARM: ux500: Add a ab8500-usb Device Tree node for db8500 based devices ARM: ux500: Add db8500 Device Tree node for misc/ab8500-pwm ARM: ux500: Add db8500 Device Tree node for ab8500-sysctrl ARM: ux500: Enable LED heartbeat functionality on Snowbal via DT ...
2012-07-23Merge tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm soc-specific updates from Arnd Bergmann: "This is stuff that does not fit well into another category and in particular is not related to a particular board. The largest part in here is extending the am33xx support in the omap platform." Fix up trivial conflicts in arch/arm/mach-{imx/mach-mx35_3ds.c, tegra/Makefile} * tag 'soc' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (74 commits) ARM: LPC32xx: Add PWM support ARM: LPC32xx: Add PWM clock ARM: LPC32xx: Set system serial based on cpu unique id ARM: vexpress: Config option for early printk console ARM: vexpress: Add Device Tree for V2P-CA15_CA7 core tile ARM: vexpress: Convert V2P-CA15 Device Tree to 64 bit addresses ARM: vexpress: Add fixed regulator for SMSC ARM: vexpress: Add missing SP804 interrupt in motherboard's DTS files ARM: vexpress: Initial common clock support ARM: SAMSUNG: Introduce Kconfig variable for Samsung custom clk API ARM: EXYNOS: Add missing static storage class specifier in pmu.c file ARM: EXYNOS: Make combiner_init function static ARM: EXYNOS: Update HSOTG PHY clock setting for EXYNOS4X12 ARM: versatile: Make plat-versatile clock optional ARM: vexpress: Check master site in daughterboard's sysctl operations ARM: vexpress: remove automatic errata workaround selection ARM: LPC32xx: Adjust to pl08x DMA interface changes ARM: EXYNOS: Clear SYS_WDTRESET bit to use watchdog reset ARM: imx: fix mx51 ehci setup errors ARM: imx: make ehci power/oc polarities configurable ...
2012-07-12Merge branch 'imx/dt-for-3.6' of ↵Arnd Bergmann
git://git.linaro.org/people/shawnguo/linux-2.6 into next/dt From Shawn Guo <shawn.guo@linaro.org>: Here is the second (last) batch of imx device tree changes for 3.6. * 'imx/dt-for-3.6' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: imx6q: ensure ANATOP controller is available ARM: dts: imx6q-sabrelite: add ecspi1 pinctrl support ARM: dts: imx6q-sabrelite: add usb devices ARM: imx6q: disable usb charger detector ARM: imx6q: add usbphy clocks ARM: imx6q: add usb controller clock lookups ARM: dts: imx: update #interrupt-cells for gpio nodes bindings: update imx and mxs #gpio-cells Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-07-12Merge tag 'imx-dt' of git://git.pengutronix.de/git/imx/linux-2.6 into next/dtArnd Bergmann
From Sascha Hauer <s.hauer@pengutronix.de>: ARM i.MX dt updates for v3.6 * tag 'imx-dt' of git://git.pengutronix.de/git/imx/linux-2.6: arm/dts: Add support for i.MX31 bug 1.x board from buglabs. ARM i.MX31: Add devicetree support ARM: dts: Add basic support for mx27_3ds board Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-07-12ARM: imx6q: ensure ANATOP controller is availableOtavio Salvador
During imx6q initialization the usb charger detector is disabled but for it, ANATOP controller symbols need to be available. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Cc: Richard Zhao <richard.zhao@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-07-10ARM i.MX31: Add devicetree supportDenis 'GNUtoo' Carikli
This patch adds basic devicetree support for i.MX31 based SoCs. Only the UART and interrupts bindings are added. Signed-off-by: Denis 'GNUtoo' Carikli <GNUtoo@no-log.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-07-09ARM: imx: add rtc support to mx35_3dsBenoît Thébaudeau
Now that RTC support has been enabled for i.MX35, add RTC to the mx35_3ds board. Cc: Sascha Hauer <kernel@pengutronix.de> Cc: <linux-arm-kernel@lists.infradead.org> Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-07-09ARM: imx: fix i.MX35 CPU architectureBenoît Thébaudeau
The data sheet of the i.MX35 says it is an ARM1136JF-S processor, version r1p3, which, according to section "B.1. New instructions" of the ARM1136JF-S and ARM1136J-S Technical Reference Manual, makes the i.MX35 CPU architecture not only ARMv6, but ARMv6k. Cc: Sascha Hauer <kernel@pengutronix.de> Cc: <linux-arm-kernel@lists.infradead.org> Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-07-06Merge tag 'imx-cleanup' of git://git.pengutronix.de/git/imx/linux-2.6 into ↵Arnd Bergmann
next/cleanup From Sascha Hauer <s.hauer@pengutronix.de>: ARM i.MX cleanups for v3.6 * tag 'imx-cleanup' of git://git.pengutronix.de/git/imx/linux-2.6: ARM: imx: remove unused pdata from device macros ARM: imx: Kconfig: Remove IMX_HAVE_PLATFORM_IMX_SSI from MACH_MX25_3DS ARM: imx27/dt: make dt_compat entry const ARM: imx: cleanup otg_mode Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-07-06Merge branch 'imx/sparse-irq' of ↵Arnd Bergmann
git://git.linaro.org/people/shawnguo/linux-2.6 into next/irq Two bug fixes for the previous state of the imx sparse irq changes. * 'imx/sparse-irq' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: imx: select USE_OF ARM: imx: Fix build error due to missing irqs.h include Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-07-06ARM: imx: select USE_OFUwe Kleine-König
Commit 544496a (ARM: imx: move irq_domain_add_legacy call into avic driver) introduced unconditional calls to irq_find_mapping and irq_domain_add_legacy, but it's still possible to have a .config without CONFIG_IRQ_DOMAIN=y resulting in CC arch/arm/plat-mxc/avic.o arch/arm/plat-mxc/avic.c: In function 'avic_handle_irq': arch/arm/plat-mxc/avic.c:172: error: implicit declaration of function 'irq_find_mapping' arch/arm/plat-mxc/avic.c: In function 'mxc_init_irq': arch/arm/plat-mxc/avic.c:207: error: implicit declaration of function 'irq_domain_add_legacy' arch/arm/plat-mxc/avic.c:208: error: 'irq_domain_simple_ops' undeclared (first use in this function) arch/arm/plat-mxc/avic.c:208: error: (Each undeclared identifier is reported only once arch/arm/plat-mxc/avic.c:208: error: for each function it appears in.) arch/arm/plat-mxc/avic.c:208: warning: assignment makes pointer from integer without a cast make[3]: *** [arch/arm/plat-mxc/avic.o] Error 1 make[2]: *** [arch/arm/plat-mxc/avic.o] Error 2 make[1]: *** [sub-make] Error 2 make: *** [all] Error 2 While selecting CONFIG_IRQ_DOMAIN would be enough, USE_OF is the future and implies CONFIG_IRQ_DOMAIN. So select USE_OF for ARCH_MXC and drop other explicit selects that are superflous now. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-07-05ARM: imx: Kconfig: Remove IMX_HAVE_PLATFORM_IMX_SSI from MACH_MX25_3DSFabio Estevam
commit 5fb86e5d4 (ARM: mx31_3ds: Add sound support) added audio support for mx31pdk, but touched MACH_MX25_3DS Kconfig by mistake. Remove IMX_HAVE_PLATFORM_IMX_SSI from MACH_MX25_3DS configuration. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-07-03ARM: imx: enable flexcan on imx25, imx35, imx53, imx6qMarc Kleine-Budde
Aas the flexcan driver has DT binding for some time now. This patch makes the flexcan driver available in the can drivers menu if a SOC with flexcan is enabled. Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-06-07Merge branch 'imx/fixes' of git://git.pengutronix.de/git/imx/linux-2.6 into ↵Olof Johansson
fixes * 'imx/fixes' of git://git.pengutronix.de/git/imx/linux-2.6: ARM i.MX imx21ads: Fix overlapping static i/o mappings ARM i.MX27 Visstrim M10: fix gpio handling. ARM: imx: only call l2x0_init if it's available ARM: imx: only specify i2c device type once ARM: mx31_3ds: Fix build due to missing IMX_HAVE_PLATFORM_IMX_SSI
2012-05-29ARM: mx31_3ds: Fix build due to missing IMX_HAVE_PLATFORM_IMX_SSIFabio Estevam
commit 5fb86e5 (ARM: mx31_3ds: Add sound support) missed to select IMX_HAVE_PLATFORM_IMX_SSI, which causes the following build error when only mx31_3ds is selected: arch/arm/mach-imx/built-in.o: In function `mx31_3ds_init': mach-mx31_3ds.c:(.init.text+0x15dc): undefined reference to `imx_add_imx_ssi' mach-mx31_3ds.c:(.init.text+0x16b8): undefined reference to `imx31_imx_ssi_data' Select IMX_HAVE_PLATFORM_IMX_SSI to fix it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-05-26Merge tag 'clock' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc clock driver changes from Olof Johansson: "The new clock subsystem was merged in linux-3.4 without any users, this now moves the first three platforms over to it: imx, mxs and spear. The series also contains the changes for the clock subsystem itself, since Mike preferred to have it together with the platforms that require these changes, in order to avoid interdependencies and conflicts." Fix up trivial conflicts in arch/arm/mach-kirkwood/common.c (code removed in one branch, added OF support in another) and drivers/dma/imx-sdma.c (independent changes next to each other). * tag 'clock' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (97 commits) clk: Fix CLK_SET_RATE_GATE flag validation in clk_set_rate(). clk: Provide dummy clk_unregister() SPEAr: Update defconfigs SPEAr: Add SMI NOR partition info in dts files SPEAr: Switch to common clock framework SPEAr: Call clk_prepare() before calling clk_enable SPEAr: clk: Add General Purpose Timer Synthesizer clock SPEAr: clk: Add Fractional Synthesizer clock SPEAr: clk: Add Auxiliary Synthesizer clock SPEAr: clk: Add VCO-PLL Synthesizer clock SPEAr: Add DT bindings for SPEAr's timer ARM i.MX: remove now unused clock files ARM: i.MX6: implement clocks using common clock framework ARM i.MX35: implement clocks using common clock framework ARM i.MX5: implement clocks using common clock framework ARM: Kirkwood: Replace clock gating ARM: Orion: Audio: Add clk/clkdev support ARM: Orion: PCIE: Add support for clk ARM: Orion: XOR: Add support for clk ARM: Orion: CESA: Add support for clk ...
2012-05-23Merge tag 'sound-3.5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "This is the first big chunk for 3.5 merges of sound stuff. There are a few big changes in different areas. First off, the streaming logic of USB-audio endpoints has been largely rewritten for the better support of "implicit feedback". If anything about USB got broken, this change has to be checked. For HD-audio, the resume procedure was changed; instead of delaying the resume of the hardware until the first use, now waking up immediately at resume. This is for buggy BIOS. For ASoC, dynamic PCM support and the improved support for digital links between off-SoC devices are major framework changes. Some highlights are below: * HD-audio - Avoid accesses of invalid pin-control bits that may stall the codec - V-ref setup cleanups - Fix the races in power-saving code - Fix the races in codec cache hashes and connection lists - Split some common codes for BIOS auto-parser to hda_auto_parser.c - Changed the PM resume code to wake up immediately for buggy BIOS - Creative SoundCore3D support - Add Conexant CX20751/2/3/4 codec support * ASoC - Dynamic PCM support, allowing support for SoCs with internal routing through components with tight sequencing and formatting constraints within their internal paths or where there are multiple components connected with CPU managed DMA controllers inside the SoC. - Greatly improved support for direct digital links between off-SoC devices, providing a much simpler way of connecting things like digital basebands to CODECs. - Much more fine grained and robust locking, cleaning up some of the confusion that crept in with multi-component. - CPU support for nVidia Tegra 30 I2S and audio hub controllers and ST-Ericsson MSP I2S controolers - New CODEC drivers for Cirrus CS42L52, LAPIS Semiconductor ML26124, Texas Instruments LM49453. - Some regmap changes needed by the Tegra I2S driver. - mc13783 audio support. * Misc - Rewrite with module_pci_driver() - Xonar DGX support for snd-oxygen - Improvement of packet handling in snd-firewire driver - New USB-endpoint streaming logic - Enhanced M-audio FTU quirks and relevant cleanups - Increment the support of OSS devices to 256 - snd-aloop accuracy improvement There are a few more pending changes for 3.5, but they will be sent slightly later as partly depending on the changes of DRM." Fix up conflicts in regmap (due to duplicate patches, with some further updates then having already come in from the regmap tree). Also some fairly trivial context conflicts in the imx and mcx soc drivers. * tag 'sound-3.5' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (280 commits) ALSA: snd-usb: fix stream info output in /proc ALSA: pcm - Add proper state checks to snd_pcm_drain() ALSA: sh: Fix up namespace collision in sh_dac_audio. ALSA: hda/realtek - Fix unused variable compile warning ASoC: sh: fsi: enable chip specific data transfer mode ASoC: sh: fsi: call fsi_hw_startup/shutdown from fsi_dai_trigger() ASoC: sh: fsi: use same format for IN/OUT ASoC: sh: fsi: add fsi_version() and removed meaningless version check ASoC: sh: fsi: use register field macro name on IN/OUT_DMAC ASoC: tegra: Add machine driver for WM8753 codec ALSA: hda - Fix possible races of accesses to connection list array ASoC: OMAP: HDMI: Introduce codec ARM: mx31_3ds: Add sound support ASoC: imx-mc13783 cleanup mx31moboard: Add sound support ASoC: mc13783 codec cleanups ASoC: add imx-mc13783 sound support ASoC: Add mc13783 codec mfd: mc13xxx: add codec platform data ASoC: don't flip master of DT-instantiated DAI links ...
2012-05-22Merge tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm-soc board specific changes from Olof Johansson: "While we generally attempt to get rid of board specific files and replace them with device tree based descriptions, a lot of platforms have not come that far: In shmobile, we add two new board files because their recently started effort to add DT support has not proceeded enough to use it for all of the important hardware. In Kirkwood, we are adding support for new boards with a combination of DT and board file contents in multiple cases. pxa/mmp and imx are extending support for existing board files but not adding new ones." Fix up trivial conflicts in arch/arm/mach-{mmp/ttc_dkb.c,shmobile/{Kconfig,Makefile}} * tag 'boards' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits) ARM: shmobile: fix smp build ARM: kirkwood: Add support for RaidSonic IB-NAS6210/6220 using devicetree kirkwood: Add iconnect support orion/kirkwood: create a generic function for gpio led blinking kirkwood/orion: fix orion_gpio_set_blink ARM: kirkwood: Define DNS-320/DNS-325 NAND in fdt kirkwood: Allow nand to be configured via. devicetree mtd: Add orion_nand devicetree bindings ARM: kirkwood: Basic support for DNS-320 and DNS-325 ARM: mach-shmobile: Use DT_MACHINE for armadillo 800 eva ARM: mach-shmobile: Use DT_MACHINE for KZM9G ARM: pxa: hx4700: Add Synaptics NavPoint touchpad ARM: pxa: Use REGULATOR_SUPPLY macro ARM: mach-shmobile: kzm9g: enable SMP boot ARM: mach-shmobile: kzm9g: defconfig update ARM: mach-shmobile: kzm9g: add PCF8757 gpio-key ARM: mach-shmobile: kzm9g: add SDHI support ARM: mach-shmobile: kzm9g: add MMCIF support ARM: mach-shmobile: kzm9g: correct screen direction ARM: mach-shmobile: sh73a0.h: add GPIO_NR ...
2012-05-22Merge tag 'pinctrl' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull arm soc-specific pinctrl changes from Olof Johansson: "With this, five platforms are moving to the relatively new pinctrl subsystem for their pin management, replacing the older soc specific in-kernel interfaces with common code. There is quite a bit of net addition of code for each platform being added to the pinctrl subsystem. But the payback comes later when adding new boards can be done by only providing new device trees instead." Fix up trivial conflicts in arch/arm/mach-ux500/{Makefile,board-mop500.c} * tag 'pinctrl' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (61 commits) mtd: nand: gpmi: fix compile error caused by pinctrl call ARM: PRIMA2: select PINCTRL and PINCTRL_SIRF in Kconfig ARM: nomadik: enable PINCTRL_NOMADIK where needed ARM: mxs: enable pinctrl support video: mxsfb: adopt pinctrl support ASoC: mxs-saif: adopt pinctrl support i2c: mxs: adopt pinctrl support mtd: nand: gpmi: adopt pinctrl support mmc: mxs-mmc: adopt pinctrl support serial: mxs-auart: adopt pinctrl support serial: amba-pl011: adopt pinctrl support spi/imx: adopt pinctrl support i2c: imx: adopt pinctrl support can: flexcan: adopt pinctrl support net: fec: adopt pinctrl support ARM: ux500: switch MSP to using pinctrl for pins ARM: ux500: alter MSP registration to return a device pointer ARM: ux500: switch to using pinctrl for uart0 ARM: ux500: delete custom pin control system ARM: ux500: switch over to Nomadik pinctrl driver ...
2012-05-18ARM: mx31_3ds: Add sound supportPhilippe Rétornaz
Signed-off-by: Philippe Rétornaz <philippe.retornaz@epfl.ch> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-05-18mx31moboard: Add sound supportPhilippe Rétornaz
Signed-off-by: Philippe Rétornaz <philippe.retornaz@epfl.ch> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-05-14Merge branch 'imx/pinctrl' into imx/clockArnd Bergmann
Conflicts: drivers/mmc/host/sdhci-esdhc-imx.c drivers/net/ethernet/freescale/fec.c drivers/spi/spi-imx.c drivers/tty/serial/imx.c This resolves dependencies between the pinctrl and clock changes in imx. Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-09ARM: i.MX6: implement clocks using common clock frameworkShawn Guo
Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
2012-05-09ARM i.MX35: implement clocks using common clock frameworkSascha Hauer
This patch also adds the SPDIF baud clock mux and dividers. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
2012-05-09ARM i.MX5: implement clocks using common clock frameworkSascha Hauer
2012-05-08ARM: imx: eukrea_mbimxsd: add audio supportEric Bénard
Signed-off-by: Eric Bénard <eric@eukrea.com> Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-05-08ARM: imx: eukrea_cpuimx51sd: add watchdog supportEric Bénard
2012-05-08ARM: imx: eukrea-cpuimx51: remove boardEric Bénard
this board is not publicly available and is replaced by cpuimx51sd Signed-off-by: Eric Bénard <eric@eukrea.com> Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-05-08ARM: imx: eukrea_mbimxsd35: add spi controler and spidev supportEric Bénard
2012-05-08ARM: imx: eukrea_cpuimx25: add watchdog supportEric Bénard
2012-05-08ARM: imx: eukrea_mbimxsd25: add spi controler and spidev supportEric Bénard
2012-05-08ARM: imx6q: switch to use pinctrl subsystemDong Aisheng
Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2012-05-02ARM i.MX31: implement clocks using common clock frameworkSascha Hauer
2012-05-02ARM i.MX27: implement clocks using common clock frameworkSascha Hauer
2012-05-02ARM i.MX21: implement clocks using common clock frameworkSascha Hauer
2012-05-02ARM i.MX1: implement clocks using common clock frameworkSascha Hauer
This also changes the DMA clkdev lookup to use the imx-dma driver name and "ahb" as connection ID to request the hclk dma clock. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
2012-05-02ARM i.MX25: implement clocks using common clock frameworkSascha Hauer
2012-04-26arm: imx: add missing select IMX_HAVE_PLATFORM for MACH_MX35_3DS in KconfigMarc Kleine-Budde
This patch fixes the following linker error: arch/arm/mach-imx/built-in.o: In function `mx35_3ds_init': mach-mx35_3ds.c:(.init.text+0x4b0): undefined reference to `imx_add_ipu_core' mach-mx35_3ds.c:(.init.text+0x4c4): undefined reference to `imx_alloc_mx3_camera' mach-mx35_3ds.c:(.init.text+0x520): undefined reference to `imx_add_mx3_sdc_fb' mach-mx35_3ds.c:(.init.text+0x590): undefined reference to `imx35_ipu_core_data' Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Cc: Fabio Estevam <festevam@gmail.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-03-29Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine update from Vinod Koul: "This includes the cookie cleanup by Russell, the addition of context parameter for dmaengine APIs, more arm dmaengine driver cleanup by moving code to dmaengine, this time for imx by Javier and pl330 by Boojin along with the usual driver fixes." Fix up some fairly trivial conflicts with various other cleanups. * 'next' of git://git.infradead.org/users/vkoul/slave-dma: (67 commits) dmaengine: imx: fix the build failure on x86_64 dmaengine: i.MX: Fix merge of cookie branch. dmaengine: i.MX: Add support for interleaved transfers. dmaengine: imx-dma: use 'dev_dbg' and 'dev_warn' for messages. dmaengine: imx-dma: remove 'imx_dmav1_baseaddr' and 'dma_clk'. dmaengine: imx-dma: remove unused arg of imxdma_sg_next. dmaengine: imx-dma: remove internal structure. dmaengine: imx-dma: remove 'resbytes' field of 'internal' structure. dmaengine: imx-dma: remove 'in_use' field of 'internal' structure. dmaengine: imx-dma: remove sg member from internal structure. dmaengine: imx-dma: remove 'imxdma_setup_sg_hw' function. dmaengine: imx-dma: remove 'imxdma_config_channel_hw' function. dmaengine: imx-dma: remove 'imxdma_setup_mem2mem_hw' function. dmaengine: imx-dma: remove dma_mode member of internal structure. dmaengine: imx-dma: remove data member from internal structure. dmaengine: imx-dma: merge old dma-v1.c with imx-dma.c dmaengine: at_hdmac: add slave config operation dmaengine: add context parameter to prep_slave_sg and prep_dma_cyclic dmaengine/dma_slave: introduce inline wrappers dma: imx-sdma: Treat firmware messages as warnings instead of erros ...
2012-03-27Merge tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: device tree work" from Arnd Bergmann: "Most of these patches convert code from using static platform data to describing the hardware in the device tree. This is only the first half of the changes for v3.4 because a lot of patches for this topic came in the last week before the merge window. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fix up trivial conflicts in arch/arm/mach-vexpress/{Kconfig,core.h} * tag 'dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (86 commits) Document: devicetree: add OF documents for arch-mmp ARM: dts: append DTS file of pxa168 ARM: mmp: append OF support on pxa168 ARM: mmp: enable rtc clk in pxa168 i2c: pxa: add OF support serial: pxa: add OF support arm/dts: mt_ventoux: very basic support for TeeJet Mt.Ventoux board ARM: OMAP2+: Remove extra ifdefs for board-generic ARM: OMAP2+: Fix build error when only ARCH_OMAP2/3 or 4 is selected ASoC: DT: Add digital microphone binding to PAZ00 board. ARM: dt: Add ARM PMU to tegra*.dtsi ARM: at91: at91sam9x5cm/dt: add leds support ARM: at91: usb_a9g20/dt: add gpio-keys support ARM: at91: at91sam9m10g45ek/dt: add gpio-keys support ARM: at91: at91sam9m10g45ek/dt: add leds support ARM: at91: usb_a9g20/dt: add leds support ARM: at91/pio: add new PIO3 features ARM: at91: add sam9_smc.o to at91sam9x5 build ARM: at91/tc/clocksource: Add 32 bit variant to Timer Counter ARM: at91/tc: add device tree support to atmel_tclib ...
2012-03-27Merge tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull "ARM: driver specific updates" from Arnd Bergmann: "These are all specific to some driver. They are typically the platform side of a change in the drivers directory, such as adding a new driver or extending the interface to the platform. In cases where there is no maintainer for the driver, or the maintainer prefers to have the platform changes in the same branch as the driver changes, the patches to the drivers are included as well. A much smaller set of driver updates that depend on other branches getting merged first will be sent later. The new export of tegra_chip_uid conflicts with other changes in fuse.c. In rtc-sa1100.c, the global removal of IRQF_DISABLED conflicts with the cleanup of the interrupt handling of that driver. Signed-off-by: Arnd Bergmann <arnd@arndb.de>" Fixed up aforementioned trivial conflicts. * tag 'drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (94 commits) ARM: SAMSUNG: change the name from s3c-sdhci to exynos4-sdhci mmc: sdhci-s3c: add platform data for the second capability ARM: SAMSUNG: support the second capability for samsung-soc ARM: EXYNOS: add support DMA for EXYNOS4X12 SoC ARM: EXYNOS: Add apb_pclk clkdev entry for mdma1 ARM: EXYNOS: Enable MDMA driver regulator: Remove bq24022 regulator driver rtc: sa1100: add OF support pxa: magician/hx4700: Convert to gpio-regulator from bq24022 ARM: OMAP3+: SmartReflex: fix error handling ARM: OMAP3+: SmartReflex: fix the use of debugfs_create_* API ARM: OMAP3+: SmartReflex: micro-optimization for sanity check ARM: OMAP3+: SmartReflex: misc cleanups ARM: OMAP3+: SmartReflex: move late_initcall() closer to its argument ARM: OMAP3+: SmartReflex: add missing platform_set_drvdata() ARM: OMAP3+: hwmod: add SmartReflex IRQs ARM: OMAP3+: SmartReflex: clear ERRCONFIG_VPBOUNDINTST only on a need ARM: OMAP3+: SmartReflex: Fix status masking in ERRCONFIG register ARM: OMAP3+: SmartReflex: Add a shutdown hook ARM: OMAP3+: SmartReflex Class3: disable errorgen before disable VP ... Conflicts: arch/arm/mach-tegra/Makefile arch/arm/mach-tegra/fuse.c drivers/rtc/rtc-sa1100.c
2012-03-27Merge tag 'asoc-3.4' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into next/boards The asoc branch that was already merged into v3.4 contains some board-level changes that conflict with patches we already have here, so pull in that branch to resolve the conflicts. Conflicts: arch/arm/mach-imx/mach-imx27_visstrim_m10.c arch/arm/mach-omap2/board-omap4panda.c Signed-off-by: Arnd Bergmann <arnd@arndb.de> [olof: Amended fix for mismerge as reported by Kevin Hilman] Signed-off-by: Olof Johansson <olof@lixom.net>
2012-03-26dmaengine: imx-dma: merge old dma-v1.c with imx-dma.cJavier Martin
It is mainly a simple merge changing the prefix of some functions to fit the imx-dma namings. As there are no users of the old dma-v1.c api we can safely remove this file. Signed-off-by: Javier Martin <javier.martin@vista-silicon.com> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
2012-03-06ASoC: imx: move audmux driver into sound/soc/imxShawn Guo
As audmux becomes a platform driver and its callers are all ASoC machine drivers, there is no reason to keep it in arch folder, so move it to sound/soc/imx. One bonus point would be those ASoC machine drivers stop including mach/audmux.h, since it's been moved to sound/soc/imx/imx-audmux.h. This should be a move to the right direction in terms of single kernel image goal. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-06ARM: imx: merge audmux-v1 and audmux-v2Shawn Guo
It merges audmux-v1 and audmux-v2 under arch/arm/plat-mxc into one. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-02Merge branch 'features/imx31-moboard' of ↵Arnd Bergmann
git://git.pengutronix.de/git/imx/linux-2.6 into next/boards * 'features/imx31-moboard' of git://git.pengutronix.de/git/imx/linux-2.6: mx31moboard: Add watchdog support mx31moboard: update maintainer
2012-03-02mx31moboard: Add watchdog supportPhilippe Rétornaz
Signed-off-by: Philippe Rétornaz <philippe.retornaz@epfl.ch> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-03-02i.MX27: visstrim_m10: Add led support.Javier Martin
Vista Silicon Visstrim_m10 board has 4 leds to signal several working conditions. Signed-off-by: Javier Martin <javier.martin@vista-silicon.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
2012-03-02i.MX27: visstrim_m10: Add video support.Javier Martin
Vista Silicon Visstrim_m10 board has a tvp5150 video decoder attached to the CSI interface Signed-off-by: Javier Martin <javier.martin@vista-silicon.com> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de>
