path: root/arch/arm/mach-footbridge
2006-09-20[ARM] 3759/2: Remove uses of %?Daniel Jacobowitz
Patch from Daniel Jacobowitz The ARM kernel has several uses of asm("foo%?"). %? is a GCC internal modifier used to output conditional execution predicates. However, no version of GCC supports conditionalizing asm statements. GCC 4.2 will correctly expand %? to the empty string in user asms. Earlier versions may reuse the condition from the previous instruction. In 'if (foo) asm ("bar%?");' this is somewhat likely to be right... but not reliable. So, the only safe thing to do is to remove the uses of %?. I believe the tlbflush.h occurances were supposed to be removed before, based on the comment about %? not working at the top of that file. Old versions of GCC could omit branches around user asms if the asm didn't mark the condition codes as clobbered. This problem hasn't been seen on any recent (3.x or 4.x) GCC, but it could theoretically happen. So, where %? was removed a cc clobber was added. Signed-off-by: Daniel Jacobowitz <dan@codesourcery.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-08-28[ARM] Move prototype for register_isa_ports to asm/io.hRussell King
2006-07-14[ARM] Fix cats buildRussell King
Fix more fallout from 894673ee6122a3ce1958e1fe096901ba5356a96b. arch/arm/mach-footbridge/cats-hw.c: In function 'fixup_cats': arch/arm/mach-footbridge/cats-hw.c:81: error: 'ORIG_VIDEO_LINES' undeclared (first use in this function) ... Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-03[ARM] Fix ISA IRQ resourcesRussell King
The ISA IRQ code was not using named initialisers, so merging the 64-bit resource code (which re-ordered the struct members) broke this. Fix it up to use named initialisers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[PATCH] ARM: fixup irqflags breakage after ARM genirq mergeThomas Gleixner
The irgflags consolidation did conflict with the ARM to generic IRQ conversion and was not applied for ARM. Fix it up. Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[ARM] 3680/1: ARM: Convert footbridge to generic irq handlingThomas Gleixner
Patch from Thomas Gleixner From: Thomas Gleixner <tglx@linutronix.de> Fixup the conversion to generic irq subsystem. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-28[PATCH] RTC: Remove RTC UIP synchronization on ARMMatt Mackall
Signed-off-by: Matt Mackall <mpm@selenic.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-21[ARM] Convert kmalloc+memset to kzallocRussell King
Convert all uses of kmalloc followed by memset to use kzalloc instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[ARM] 3260/1: remove phys_ram from struct machine_desc (part 2)Nicolas Pitre
Patch from Nicolas Pitre This field is redundent since it must be equal to PHYS_OFFSET anyway. Now that no code uses it anymore, mark it deprecated and remove all initializations from the tree. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-08[PATCH] ARM: Netwinder ds1620 driver needs an export to be built as moduleWoody Suwalski
ds1620 module is using gpio_read symbol, so works only if "built-in" symbol needs to be exported from the kernel image Signed-off-by: Woody Suwalski <woodys@xandros.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[ARM] Cleanup ARM includesRussell King
arch/arm/kernel/entry-armv.S has contained a comment suggesting that asm/hardware.h and asm/arch/irqs.h should be moved into the asm/arch/entry-macro.S include. So move the includes to these two files as required. Add missing includes (asm/hardware.h, asm/io.h) to asm/arch/system.h includes which use those facilities, and remove asm/io.h from kernel/process.c. Remove other unnecessary includes from arch/arm/kernel, arch/arm/mm and arch/arm/mach-footbridge. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-13[ARM] Re-fix footbridgeRussell King
That's __phys_to_pfn, not __phy_to_pfn. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-12[ARM] Fix Footbridge-based machinesRussell King
Unfortunately, all these machines got broken when the PFN memory setup changes happened. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-28[ARM] 2998/1: Replace map_desc.physical with map_desc.pfn: FootbridgeDeepak Saxena
Patch from Deepak Saxena Footbridge map_desc.pfn conversion Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-08[SERIAL] Use an enum for serial8250 platform device IDsRussell King
Rather than hard-coding the platform device IDs, enumerate them. We don't particularly care about the actual ID we get, just as long as they're unique. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-07[PATCH] Kconfig fix (BLK_DEV_FD dependencies)viro@ZenIV.linux.org.uk
Sanitized and fixed floppy dependencies: split the messy dependencies for BLK_DEV_FD by introducing a new symbol (ARCH_MAY_HAVE_PC_FDC), making BLK_DEV_FD depend on that one and taking declarations of ARCH_MAY_HAVE_PC_FDC to arch/*/Kconfig. While we are at it, fixed several obvious cases when BLK_DEV_FD should have been excluded (architectures lacking asm/floppy.h are *not* going to have floppy.c compile, let alone work). If you can come up with better name for that ("this architecture might have working PC-compatible floppy disk controller"), you are more than welcome - just s/ARCH_MAY_HAVE_PC_FDC/your_prefered_name/g in the patch below... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-04[ARM] Wrap calls to descriptor handlersRussell King
This is part of Thomas Gleixner's generic IRQ patch, which converts ARM to use the generic IRQ subsystem. Here, we wrap calls to desc->handler() in an inline function, desc_handle_irq(). This reduces the size of Thomas' patch since the changes become more localised. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-03[PATCH] ARM: Remove machine description macrosRussell King
Remove the pointless machine description macros, favouring C99 initialisers instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-26[PATCH] ARM: Add SA_TIMER flag to timer interruptsRussell King
VST needs to know which timer handler is for the timer interrupt. Mark all timer interrupts with the SA_TIMER flag. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-05-05[PATCH] ARM: select PCI, ISA and ISA_DMARussell King
Rather than using a long "depends on..." and "default y" lines for these options, use select instead. Signed-off-by: Russell King <rmk@arm.linux.org.uk>
2005-04-17[PATCH] ARM: footbridge rtc initRussell King
The footbridge ISA RTC was being initialised before we had setup the kernel timer. This caused a divide by zero error when the current time of day is set. Resolve this by initialising the RTC after the kernel timer has been initialised. Signed-off-by: Russell King <rmk@arm.linux.org.uk>
