path: root/arch/arm/mach-footbridge
2011-10-28Merge branch 'devel-stable' of ↵Linus Torvalds
http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm * 'devel-stable' of http://ftp.arm.linux.org.uk/pub/linux/arm/kernel/git-cur/linux-2.6-arm: (178 commits) ARM: 7139/1: fix compilation with CONFIG_ARM_ATAG_DTB_COMPAT and large TEXT_OFFSET ARM: gic, local timers: use the request_percpu_irq() interface ARM: gic: consolidate PPI handling ARM: switch from NO_MACH_MEMORY_H to NEED_MACH_MEMORY_H ARM: mach-s5p64x0: remove mach/memory.h ARM: mach-s3c64xx: remove mach/memory.h ARM: plat-mxc: remove mach/memory.h ARM: mach-prima2: remove mach/memory.h ARM: mach-zynq: remove mach/memory.h ARM: mach-bcmring: remove mach/memory.h ARM: mach-davinci: remove mach/memory.h ARM: mach-pxa: remove mach/memory.h ARM: mach-ixp4xx: remove mach/memory.h ARM: mach-h720x: remove mach/memory.h ARM: mach-vt8500: remove mach/memory.h ARM: mach-s5pc100: remove mach/memory.h ARM: mach-tegra: remove mach/memory.h ARM: plat-tcc: remove mach/memory.h ARM: mach-mmp: remove mach/memory.h ARM: mach-cns3xxx: remove mach/memory.h ... Fix up mostly pretty trivial conflicts in: - arch/arm/Kconfig - arch/arm/include/asm/localtimer.h - arch/arm/kernel/Makefile - arch/arm/mach-shmobile/board-ap4evb.c - arch/arm/mach-u300/core.c - arch/arm/mm/dma-mapping.c - arch/arm/mm/proc-v7.S - arch/arm/plat-omap/Kconfig largely due to some CONFIG option renaming (ie CONFIG_PM_SLEEP -> CONFIG_ARM_CPU_SUSPEND for the arm-specific suspend code etc) and addition of NEED_MACH_MEMORY_H next to HAVE_IDE.
2011-10-26Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (27 commits) rtmutex: Add missing rcu_read_unlock() in debug_rt_mutex_print_deadlock() lockdep: Comment all warnings lib: atomic64: Change the type of local lock to raw_spinlock_t locking, lib/atomic64: Annotate atomic64_lock::lock as raw locking, x86, iommu: Annotate qi->q_lock as raw locking, x86, iommu: Annotate irq_2_ir_lock as raw locking, x86, iommu: Annotate iommu->register_lock as raw locking, dma, ipu: Annotate bank_lock as raw locking, ARM: Annotate low level hw locks as raw locking, drivers/dca: Annotate dca_lock as raw locking, powerpc: Annotate uic->lock as raw locking, x86: mce: Annotate cmci_discover_lock as raw locking, ACPI: Annotate c3_lock as raw locking, oprofile: Annotate oprofilefs lock as raw locking, video: Annotate vga console lock as raw locking, latencytop: Annotate latency_lock as raw locking, timer_stats: Annotate table_lock as raw locking, rwsem: Annotate inner lock as raw locking, semaphores: Annotate inner lock as raw locking, sched: Annotate thread_group_cputimer as raw ... Fix up conflicts in kernel/posix-cpu-timers.c manually: making cputimer->cputime a raw lock conflicted with the ABBA fix in commit bcd5cff7216f ("cputimer: Cure lock inversion").
2011-10-25Merge branch 'misc' into for-linusRussell King
Conflicts: arch/arm/mach-integrator/integrator_ap.c
2011-10-25Merge branches 'arnd-randcfg-fixes', 'debug', 'io' (early part), 'l2x0', ↵Russell King
'p2v', 'pgt' (early part) and 'smp' into for-linus
2011-10-18Merge branch 'mach_memory_h' of git://git.linaro.org/people/nico/linux into ↵Russell King
devel-stable
2011-10-17ARM: platform fixups: remove mdesc argument to fixup functionRussell King
Get rid of the mdesc pointer in the fixup function call. No one uses the mdesc pointer, it shouldn't be modified anyway, and we can't wrap it, so let's remove it. Platform files found by: $ regexp=$(git grep -h '\.fixup.*=' arch/arm | sed 's!.*= *\([^,]*\),* *!\1!' | sort -u | tr '\n' '|' | sed 's,|$,,;s,|,\\|,g') $ git grep $regexp arch/arm Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-17ARM: 7078/1: Footbridge: Sort KConfig Options alphabeticallyPeter Hüwe
As per request of rmk, the options should be sorted alphabetically. Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-10-17ARM: 7022/1: allow to detect conflicting zreladdrsSascha Hauer
Boards used to specify zreladdr in their Makefile.boot with zreladdr-y := x, so conflicting zreladdrs were silently overwritten. This patch changes this to zreladdr-y += x, so that we end up with multiple words in zreladdr in such a case. We can detect this later and complain if necessary. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-09-26ARM: add an extra temp register to the low level debugging addruart macroNicolas Pitre
Some platforms (like OMAP not to name it) are doing rather complicated hacks just to determine the base UART address to use. Let's give their addruart macro some slack by providing an extra work register which will allow for much needed cleanups. This is basically a no-op as this commit is only adding the extra argument to the macro but no one is using it yet. Signed-off-by: nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-09-16Merge branch 'for-rmk' of git://linux-arm.org/linux-2.6-wd into devel-stableRussell King
Conflicts: arch/arm/mach-imx/mach-cpuimx27.c
2011-09-13locking, ARM: Annotate low level hw locks as rawThomas Gleixner
Annotate the low level hardware locks which must not be preempted. In mainline this change documents the low level nature of the lock - otherwise there's no functional difference. Lockdep and Sparse checking will work as usual. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-08-29Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: pm: avoid writing the auxillary control register for ARMv7 ARM: pm: some ARMv7 requires a dsb in resume to ensure correctness ARM: pm: arm920/926: fix number of registers saved ARM: pm: CPU specific code should not overwrite r1 (v:p offset) ARM: 7066/1: proc-v7: disable SCTLR.TE when disabling MMU ARM: 7065/1: kexec: ensure new kernel is entered in ARM state ARM: 7003/1: vexpress: Add clock definition for the SP805. ARM: 7051/1: cpuimx* boards: fix mach-types errors ARM: 7019/1: Footbridge: select CLKEVT_I8253 for ARCH_NETWINDER ARM: 7015/1: ARM errata: Possible cache data corruption with hit-under-miss enabled ARM: 7014/1: cache-l2x0: Fix L2 Cache size calculation. ARM: 6967/1: ep93xx: ts72xx: fix board model detection ARM: 6965/1: ep93xx: add model detection for ts-7300 and ts-7400 boards ARM: cache: detect VIPT aliasing I-cache on ARMv6 ARM: twd: register clockevents device before enabling PPI ARM: realview: ensure visibility of writes during reset ARM: perf: make name of arm_pmu_type consistent ARM: perf: fix prototype of release_pmu ARM: fix perf build with uclibc toolchains
2011-08-25ARM: mach-footbridge: add missing header file <video/vga.h>Bryan Wu
This patch fixes following building error: -- arch/arm/mach-footbridge/dc21285.c: In function 'dc21285_preinit': arch/arm/mach-footbridge/dc21285.c:299:2: error: 'vga_base' undeclared (first use in this function) arch/arm/mach-footbridge/dc21285.c:299:2: note: each undeclared identifier is reported only once for each function it appears in make[1]: *** [arch/arm/mach-footbridge/dc21285.o] Error 1 -- Signed-off-by: Bryan Wu <bryan.wu@canonical.com> Acked-by: Rob Herring <rob.herring@calxeda.com>
2011-08-21ARM: mach-footbridge: convert boot_params to atag_offsetNicolas Pitre
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de>
2011-08-19ARM: 7019/1: Footbridge: select CLKEVT_I8253 for ARCH_NETWINDERAxel Lin
Since commit 8560a6cfc9818edde1fd8677961714b264ffa03d "arm: Footbridge: Use common i8253 clockevent", ARCH_NETWINDER needs to select CLKEVT_I8253. This patch fixes below build error with "make netwinder_defconfig". LD .tmp_vmlinux1 arch/arm/mach-footbridge/built-in.o: In function `isa_timer_init': isa-rtc.c:(.init.text+0x12c8): undefined reference to `clockevent_i8253_init' isa-rtc.c:(.init.text+0x12d0): undefined reference to `i8253_clockevent' arch/arm/mach-footbridge/built-in.o:(.data+0x198): undefined reference to `i8253_clockevent' make: *** [.tmp_vmlinux1] Error 1 Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-08-17ARM: io: remove IO_SPACE_LIMIT from platforms with ISA/PCI and 64K windowRussell King
Remove IO_SPACE_LIMIT definitions from platforms which have a well defined ISA or PCI, and has a 64K window. EBSA110 - well defined set of ISA devices. Footbridge, Integrator, IXP4xx, VT8500 - PCI platforms. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-07-29Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: remove printks about disabled bridge windows PCI: fold pci_calc_resource_flags() into decode_bar() PCI: treat mem BAR type "11" (reserved) as 32-bit, not 64-bit, BAR PCI: correct pcie_set_readrq write size PCI: pciehp: change wait time for valid configuration access x86/PCI: Preserve existing pci=bfsort whitelist for Dell systems PCI: ARI is a PCIe v2 feature x86/PCI: quirks: Use pci_dev->revision PCI: Make the struct pci_dev * argument of pci_fixup_irqs const. PCI hotplug: cpqphp: use pci_dev->vendor PCI hotplug: cpqphp: use pci_dev->subsystem_{vendor|device} x86/PCI: config space accessor functions should not ignore the segment argument PCI: Assign values to 'pci_obff_signal_type' enumeration constants x86/PCI: reduce severity of host bridge window conflict warnings PCI: enumerate the PCI device only removed out PCI hieratchy of OS when re-scanning PCI PCI: PCIe AER: add aer_recover_queue x86/PCI: select direct access mode for mmconfig option PCI hotplug: Rename is_ejectable which also exists in dock.c
2011-07-26Merge branch 'next/cross-platform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: Consolidate the clkdev header files ARM: set vga memory base at run-time ARM: convert PCI defines to variables ARM: pci: make pcibios_assign_all_busses use pci_has_flag ARM: remove unnecessary mach/hardware.h includes pci: move microblaze and powerpc pci flag functions into asm-generic powerpc: rename ppc_pci_*_flags to pci_*_flags Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
2011-07-22Merge branch 'timers-cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: mips: Fix i8253 clockevent fallout i8253: Cleanup outb/inb magic arm: Footbridge: Use common i8253 clockevent mips: Use common i8253 clockevent x86: Use common i8253 clockevent i8253: Create common clockevent implementation i8253: Export i8253_lock unconditionally pcpskr: MIPS: Make config dependencies finer grained pcspkr: Cleanup Kconfig dependencies i8253: Move remaining content and delete asm/i8253.h i8253: Consolidate definitions of PIT_LATCH x86: i8253: Consolidate definitions of global_clock_event i8253: Alpha, PowerPC: Remove unused asm/8253pit.h alpha: i8253: Cleanup remaining users of i8253pit.h i8253: Remove I8253_LOCK config i8253: Make pcsp sound driver use the shared i8253_lock i8253: Make pcspkr input driver use the shared i8253_lock i8253: Consolidate all kernel definitions of i8253_lock i8253: Unify all kernel declarations of i8253_lock i8253: Create linux/i8253.h and use it in all 8253 related files
2011-07-22PCI: Make the struct pci_dev * argument of pci_fixup_irqs const.Ralf Baechle
Aside of the usual motivation for constification, this function has a history of being abused a hook for interrupt and other fixups so I turned this function const ages ago in the MIPS code but it should be done treewide. Due to function pointer passing in varous places a few other functions had to be constified as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> To: Anton Vorontsov <avorontsov@mvista.com> To: Chris Metcalf <cmetcalf@tilera.com> To: Colin Cross <ccross@android.com> Acked-by: "David S. Miller" <davem@davemloft.net> To: Eric Miao <eric.y.miao@gmail.com> To: Erik Gilling <konkers@android.com> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> To: "H. Peter Anvin" <hpa@zytor.com> To: Imre Kaloz <kaloz@openwrt.org> To: Ingo Molnar <mingo@redhat.com> To: Ivan Kokshaysky <ink@jurassic.park.msu.ru> To: Jesse Barnes <jbarnes@virtuousgeek.org> To: Krzysztof Halasa <khc@pm.waw.pl> To: Lennert Buytenhek <kernel@wantstofly.org> To: Matt Turner <mattst88@gmail.com> To: Nicolas Pitre <nico@fluxnic.net> To: Olof Johansson <olof@lixom.net> Acked-by: Paul Mundt <lethal@linux-sh.org> To: Richard Henderson <rth@twiddle.net> To: Russell King <linux@arm.linux.org.uk> To: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-alpha@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-pci@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linux-tegra@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: x86@kernel.org Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-07-12ARM: set vga memory base at run-timeRob Herring
Convert the incorrectly named PCIMEM_BASE to a variable called vga_base. This removes the dependency on mach/hardware.h. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-12ARM: convert PCI defines to variablesRob Herring
Convert PCIBIOS_MIN_IO and PCIBIOS_MIN_MEM to variables to allow multi-platform builds. This also removes the requirement for a platform to have a mach/hardware.h. The default values for i/o and mem are 0x1000 and 0x01000000, respectively. Per Arnd Bergmann, other values are likely to be incorrect, but this commit does not try to address that issue. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-12ARM: pci: make pcibios_assign_all_busses use pci_has_flagRob Herring
Convert pcibios_assign_all_busses from a define to inline so platforms can control this setting. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2011-07-01arm: Footbridge: Use common i8253 clockeventThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: John Stultz <john.stultz@linaro.org> Link: http://lkml.kernel.org/r/20110609130622.241312122@linutronix.de
2011-06-11ARM: footbridge: fix clock event supportRussell King
4e8d7637 (ARM: footbridge: convert to clockevents/clocksource) did not set the cpumask for the clock event device. This causes boot to fail. Add the necessary initialization. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-11ARM: footbridge: fix debug macrosRussell King
More of the same of 5f2c1b30 (ARM: footbridge: fix debug macros), this time for the DC21285-based debugging code rather than the 8250- based debugging code. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-06-09i8253: Consolidate all kernel definitions of i8253_lockRalf Baechle
Move them to drivers/clocksource/i8253.c and remove the implementations in arch/ [ tglx: Avoid the extra file in lib - folded arch patches in. The export will become conditional in a later step ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Link: http://lkml.kernel.org/r/20110601180610.221426078@duck.linux-mips.net Cc: Russell King <linux@arm.linux.org.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-06-09i8253: Create linux/i8253.h and use it in all 8253 related filesRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Link: http://lkml.kernel.org/r/20110601180610.054254048@duck.linux-mips.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de> arch/arm/mach-footbridge/isa-timer.c | 2 +- arch/mips/cobalt/time.c | 2 +- arch/mips/jazz/irq.c | 2 +- arch/mips/kernel/i8253.c | 2 +- arch/mips/mti-malta/malta-time.c | 2 +- arch/mips/sgi-ip22/ip22-time.c | 2 +- arch/mips/sni/time.c | 2 +- arch/x86/kernel/apic/apic.c | 2 +- arch/x86/kernel/apm_32.c | 2 +- arch/x86/kernel/hpet.c | 2 +- arch/x86/kernel/i8253.c | 2 +- arch/x86/kernel/time.c | 2 +- drivers/block/hd.c | 2 +- drivers/clocksource/i8253.c | 2 +- drivers/input/gameport/gameport.c | 2 +- drivers/input/joystick/analog.c | 2 +- drivers/input/misc/pcspkr.c | 2 +- include/linux/i8253.h | 11 +++++++++++ sound/drivers/pcsp/pcsp.h | 2 +- 19 files changed, 29 insertions(+), 18 deletions(-)
2011-05-14clocksource: convert footbridge to generic i8253 clocksourceRussell King
Convert the footbridge isa-timer code to use generic i8253 clocksource. Acked-by: John Stultz <john.stultz@linaro.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: footbridge: Make cksrc_dc21285_disable() voidThomas Gleixner
This clocksource function needs to be void. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-16Merge branch 'p2v' into develRussell King
Conflicts: arch/arm/kernel/module.c arch/arm/mach-s5pv210/sleep.S
2011-03-16Merge branch 'misc' into develRussell King
Conflicts: arch/arm/Kconfig
2011-03-10ARM: 6796/1: Footbridge: Fix I/O mappings for NOMMU modeStepan Moskovchenko
Use the correct I/O address definitions for Footbridge peripherals when the kernel is compiled without MMU support. Signed-off-by: Stepan Moskovchenko <stepanm@codeaurora.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-17ARM: P2V: separate PHYS_OFFSET from platform definitionsRussell King
This uncouple PHYS_OFFSET from the platform definitions, thereby facilitating run-time computation of the physical memory offset. Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@st.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Magnus Damm <damm@opensource.se> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Kukjin Kim <kgene.kim@samsung.com> Acked-by: Eric Miao <eric.y.miao@gmail.com> Acked-by: Jiandong Zheng <jdzheng@broadcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-31ARM: footbridge: convert to clockevents/clocksourceRussell King
The Footbridge platforms have some reasonable timers in the host bridge, which we use for most footbridge-based platforms. However, NetWinder's clock these using a spread-spectrum clock which makes them too unstable for time keeping. So we have to rely on the PIT. Convert both Footbridge timers and PIT timers to use the clocksource and clockevent infrastructure. Tested on Netwinder. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-31ARM: footbridge: fix debug macrosRussell King
0ea1293 (arm: return both physical and virtual addresses from addruart) changed the way the 'addruart' worked, making it return both the virt and phys addresses. Unfortunately, for footbridge, these were reversed. Fix that. Tested on Netwinder. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-13ARM: footbridge: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-21ARM: 6484/1: fix compile warning in mm/init.cAnand Gadiyar
Commit 7c63984b86 (ARM: do not define VMALLOC_END relative to PAGE_OFFSET) changed VMALLOC_END to be an explicit value. Before this, it was relative to PAGE_OFFSET and therefore converted to unsigned long as PAGE_OFFSET is an unsigned long. This introduced the following build warning. Fix this by changing the explicit defines of VMALLOC_END to be unsigned long. CC arch/arm/mm/init.o arch/arm/mm/init.c: In function 'mem_init': arch/arm/mm/init.c:606: warning: format '%08lx' expects type 'long unsigned int', but argument 12 has type 'unsigned int' Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Acked-by: Uwe Kleine-K <u.kleine-koenig@pengutronix.dee> Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-10-01ARM: do not define VMALLOC_END relative to PAGE_OFFSETNicolas Pitre
VMALLOC_END is supposed to be an absolute value, while PAGE_OFFSET may vary depending on the selected user:kernel memory split mode through CONFIG_VMSPLIT_*. In fact, the goal of moving PAGE_OFFSET down is to accommodate more directly addressed RAM by the kernel below the vmalloc area, and having VMALLOC_END move along PAGE_OFFSET is rather against the very reason why PAGE_OFFSET can be moved in the first place. Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
2010-07-22ARM: 6233/1: Delete a wrong redundant right parenthesiswanzongshun
Delete a wrong redundant right parenthesis in arch/arm/mach-footbridge/common.c Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-05-24ARM: arch/arm/mach-footbridge/ebsa285-pci.c: Checkpatch cleanupAndrea Gelmini
arch/arm/mach-footbridge/ebsa285-pci.c:22: ERROR: switch and case should be at the same indent Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-25Merge branch 'misc2' into develRussell King
2010-02-15ARM: 5880/1: arm: use generic infrastructure for early paramsJeremy Kerr
The ARM setup code includes its own parser for early params, there's also one in the generic init code. This patch removes __early_init (and related code) from arch/arm/kernel/setup.c, and changes users to the generic early_init macro instead. The generic macro takes a char * argument, rather than char **, so we need to update the parser functions a little. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-12ARM: 5910/1: ARM: Add tmp register for addruart and loadspTony Lindgren
Otherwise more complicated uart configuration won't be possible. We can use r1 for tmp register for both head.S and debug.S. NOTE: This patch depends on another patch to add the the tmp register into all debug-macro.S files. That can be done with: $ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/" arch/arm/*/include/*/debug-macro.S Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-24ARM: footbridge: trim down old ISA rtc setupRussell King
This fixes a "start_kernel(): bug: interrupts were enabled early". rtc_cmos now takes care of initializing the ISA RTC and reading the current time and date from it; there's no need to repeat that here, thereby causing interrupts to be enabled too early. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-13ARM: fix clps711x, footbridge, integrator, ixp2000, ixp2300 and s3c build bugRussell King
Anders Grafström reports that footbridge fails to build after 1c4a4f4. Fix this by adding the necessary definitions for __pfn_to_bus and __bus_to_pfn. Reported-by: Anders Grafström <anders.grafstrom@netinsight.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
