path: root/arch/arm/mach-footbridge/dc21285-timer.c
2009-12-24ARM: footbridge: trim down old ISA rtc setupRussell King
This fixes a "start_kernel(): bug: interrupts were enabled early". rtc_cmos now takes care of initializing the ISA RTC and reading the current time and date from it; there's no need to repeat that here, thereby causing interrupts to be enabled too early. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-13[ARM] netwinder: clean up GPIO namingRussell King
Netwinder was using gpio_xxx names which could clash with the GPIO layer. Add a 'nw_' prefix to ensure that these remain separate. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-28[ARM] Fix timer damage from d3d74453c34f8fd87674a8cf5b8a327c68f22e99Russell King
Move the xtime write mode seqlock into timer_tick(), so it only surrounds the call to do_timer(). This avoids a deadlock in update_process_times() ... hrtimer_get_softirq_time() which tries to get a read mode seqlock on xtime, thereby preventing booting. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08Add IRQF_IRQPOLL flag on armBernhard Walle
Add IRQF_IRQPOLL for each timer interrupt. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] ARM: fixup irqflags breakage after ARM genirq mergeThomas Gleixner
The irgflags consolidation did conflict with the ARM to generic IRQ conversion and was not applied for ARM. Fix it up. Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[ARM] 3680/1: ARM: Convert footbridge to generic irq handlingThomas Gleixner
Patch from Thomas Gleixner From: Thomas Gleixner <tglx@linutronix.de> Fixup the conversion to generic irq subsystem. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-26[PATCH] ARM: Add SA_TIMER flag to timer interruptsRussell King
VST needs to know which timer handler is for the timer interrupt. Mark all timer interrupts with the SA_TIMER flag. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-04-17[PATCH] ARM: footbridge rtc initRussell King
The footbridge ISA RTC was being initialised before we had setup the kernel timer. This caused a divide by zero error when the current time of day is set. Resolve this by initialising the RTC after the kernel timer has been initialised. Signed-off-by: Russell King <rmk@arm.linux.org.uk>
