path: root/arch/arm/mach-footbridge/common.c
2012-07-26ARM: footbridge: use fixed PCI i/o mappingRob Herring
Move footbridge PCI to fixed i/o mapping. io.h is still needed for the !MMU case. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Russell King <linux@arm.linux.org.uk> Reviewed-by: Arnd Bergmann <arnd@arndb.de>
2012-03-28Disintegrate asm/system.h for ARMDavid Howells
Disintegrate asm/system.h for ARM. Signed-off-by: David Howells <dhowells@redhat.com> cc: Russell King <linux@arm.linux.org.uk> cc: linux-arm-kernel@lists.infradead.org
2012-01-05ARM: restart: footbridge: use new restart hookRussell King
Hook these platforms restart code into the new restart hook rather than using arch_reset(). Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-03-29arm: Fold irq_set_chip/irq_set_handlerThomas Gleixner
Use irq_set_chip_and_handler() instead. Converted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29arm: Cleanup the irq namespaceThomas Gleixner
Convert to the new function names. Automated with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-13ARM: footbridge: irq_data conversion.Lennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@secretlab.ca> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-22ARM: 6233/1: Delete a wrong redundant right parenthesiswanzongshun
Delete a wrong redundant right parenthesis in arch/arm/mach-footbridge/common.c Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-02-15ARM: 5880/1: arm: use generic infrastructure for early paramsJeremy Kerr
The ARM setup code includes its own parser for early params, there's also one in the generic init code. This patch removes __early_init (and related code) from arch/arm/kernel/setup.c, and changes users to the generic early_init macro instead. The generic macro takes a char * argument, rather than char **, so we need to update the parser functions a little. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-13ARM: fix clps711x, footbridge, integrator, ixp2000, ixp2300 and s3c build bugRussell King
Anders Grafström reports that footbridge fails to build after 1c4a4f4. Fix this by adding the necessary definitions for __pfn_to_bus and __bus_to_pfn. Reported-by: Anders Grafström <anders.grafstrom@netinsight.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-08Merge branch 'devel'Russell King
2009-01-08[ARM] footbridge: add isa_init_irq() to common headerBen Dooks
isa_init_irq() is defined in arch/arm/mach-footbridge/isa-irq.c and used in arch/arm/mach-footbridge/common.c but there is no definition in any header. Move the definition in common.c to common.h to stop the sparse warning: isa-irq.c:118:13: warning: symbol 'isa_init_irq' was not declared. Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2008-12-30[ARM] footbridge: set dc21285 clock rate from command lineRussell King
Allow the footbridge clock rate to be specified on the kernel command line. This allows us to work-around broken Personal Server firmware. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-12-13[ARM] netwinder: clean up GPIO namingRussell King
Netwinder was using gpio_xxx names which could clash with the GPIO layer. Add a 'nw_' prefix to ensure that these remain separate. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-06[ARM] Convert asm/io.h to linux/io.hRussell King
2008-05-02[ARM] 5015/1: arm: remove ARCH_CO285Adrian Bunk
Trying to compile a kerel for ARCH_CO285 fails with the following error: <-- snip --> ... CC arch/arm/mach-footbridge/dc21285.o /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/arm/mach-footbridge/dc21285.c: In function 'dc21285_base_address': /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/arm/mach-footbridge/dc21285.c:54: error: 'PCICFG0_BASE' undeclared (first use in this function) /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/arm/mach-footbridge/dc21285.c:54: error: (Each undeclared identifier is reported only once /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/arm/mach-footbridge/dc21285.c:54: error: for each function it appears in.) /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/arm/mach-footbridge/dc21285.c:57: error: 'PCICFG1_BASE' undeclared (first use in this function) /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/arm/mach-footbridge/dc21285.c: In function 'dc21285_scan_bus': /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/arm/mach-footbridge/dc21285.c:286: error: implicit declaration of function 'pci_scan_bus' ... make[2]: *** [arch/arm/mach-footbridge/dc21285.o] Error 1 <-- snip --> This does not seem to be a recent breakage. The ARCH_CO285 support is old - kernel 2.2.0 contains first traces of it, an it seems to have been pretty complete in later 2.2 kernels. Since it seems to be completely dead code now this patch therefore removes it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Remove compatibility layer for ARM irqsRussell King
set_irq_chipdata -> set_irq_chip_data get_irq_chipdata -> get_irq_chip_data do_level_IRQ -> handle_level_irq do_edge_IRQ -> handle_edge_irq do_simple_IRQ -> handle_simple_irq irqdesc -> irq_desc irqchip -> irq_chip Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-13[ARM] Re-fix footbridgeRussell King
That's __phys_to_pfn, not __phy_to_pfn. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-12[ARM] Fix Footbridge-based machinesRussell King
Unfortunately, all these machines got broken when the PFN memory setup changes happened. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-28[ARM] 2998/1: Replace map_desc.physical with map_desc.pfn: FootbridgeDeepak Saxena
Patch from Deepak Saxena Footbridge map_desc.pfn conversion Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
