path: root/arch/arm/mach-ep93xx
2007-05-08Add IRQF_IRQPOLL flag on armBernhard Walle
Add IRQF_IRQPOLL for each timer interrupt. Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-22[ARM] Convert AMBA PL010 driver to use the clk infrastructureRussell King
Convert the AMBA PL010 serial driver to use the clock infrastructure to allow EP93xx platforms to properly gate the clock to the UARTs. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-08[ARM] 4142/1: ep93xx: handle IRQT_NOEDGELennert Buytenhek
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-08[ARM] 4122/1: ep93xx: add support for GPIO port F interruptsLennert Buytenhek
2007-02-08[ARM] 4121/1: ep93xx: move setting of HWCAP_CRUNCHLennert Buytenhek
Move the setting of HWCAP_CRUNCH to kernel/crunch.c, where it belongs. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-08[ARM] 4120/1: ep93xx: make clock init an arch_initcall()Lennert Buytenhek
2007-02-06[ARM] 4047/1: Add initial board support for Contec Hypercontrol Micro9 boards.Manfred Gruber
Contec Micro9 (H/M/L) boards based on Cirrus Logic ep93xx (ep9315/ep9307/ep9302). Signed-off-by: Manfred Gruber <m.gruber@tirol.com> Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-18[ARM] 4054/1: ep93xx: add HWCAP_CRUNCHLennert Buytenhek
Add HWCAP_CRUNCH so that the dynamic linker knows whether it can use Crunch-optimised libraries or not. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-07[ARM] Merge individual ARM sub-treesRussell King
Merge: Atmel AT91RM9200 and AT91SAM9260 changes General ARM developments Disconfiguous memory cleanups 64-bit/32-bit division and sched_clock extension patches EP93xx support changes IOP support changes Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-07[ARM] 3993/1: ep93xx: add cirrus logic edb9302a supportLennert Buytenhek
Add support for the Cirrus Logic EDB9302A Evaluation Board. Confirmed to work by Chase Douglas. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-01[ARM] 3964/1: ep93xx: add ads sphere supportLennert Buytenhek
Add initial board support for the ADS Sphere board. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-11-30[ARM] Remove compatibility layer for ARM irqsRussell King
set_irq_chipdata -> set_irq_chip_data get_irq_chipdata -> get_irq_chip_data do_level_IRQ -> handle_level_irq do_edge_IRQ -> handle_edge_irq do_simple_IRQ -> handle_simple_irq irqdesc -> irq_desc irqchip -> irq_chip Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-09-30[ARM] 3879/1: ep93xx: instantiate platform devices for ep93xx ethernetLennert Buytenhek
Instantiate platform devices for the ep93xx ethernet driver in a couple of ep93xx board support files. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3811/1: ep93xx: add cirrus logic edb9312 supportLennert Buytenhek
Add Cirrus Logic EDB9312 support. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-02[PATCH] ARM: fixup irqflags breakage after ARM genirq mergeThomas Gleixner
The irgflags consolidation did conflict with the ARM to generic IRQ conversion and was not applied for ARM. Fix it up. Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (44 commits) [ARM] 3541/2: workaround for PXA27x erratum E7 [ARM] nommu: provide a way for correct control register value selection [ARM] 3705/1: add supersection support to ioremap() [ARM] 3707/1: iwmmxt: use the generic thread notifier infrastructure [ARM] 3706/2: ep93xx: add cirrus logic edb9315a support [ARM] 3704/1: format IOP Kconfig with tabs, create more consistency [ARM] 3703/1: Add help description for ARCH_EP80219 [ARM] 3678/1: MMC: Make OMAP MMC work [ARM] 3677/1: OMAP: Update H2 defconfig [ARM] 3676/1: ARM: OMAP: Fix dmtimers and timer32k to compile on OMAP1 [ARM] Add section support to ioremap [ARM] Fix sa11x0 SDRAM selection [ARM] Set bit 4 on section mappings correctly depending on CPU [ARM] 3666/1: TRIZEPS4 [1/5] core ARM: OMAP: Multiplexing for 24xx GPMC wait pin monitoring ARM: OMAP: Fix SRAM to use MT_MEMORY instead of MT_DEVICE ARM: OMAP: Update dmtimers ARM: OMAP: Make clock variables static ARM: OMAP: Fix GPMC compilation when DEBUG is defined ARM: OMAP: Mux updates for external DMA and GPIO ...
2006-07-01[ARM] 3706/2: ep93xx: add cirrus logic edb9315a supportLennert Buytenhek
Patch from Lennert Buytenhek This patch adds support for the Cirrus Logic EDB9315A, an evaluation board based on the Cirrus Logic EP9315 SoC, with 64M RAM, two USB host ports, audio in/out, three serial ports, 10/100 ethernet, and IDE, VGA, and LCD interfaces. The EDB9315A is a low-cost version of the EDB9315, and has only 16M of NOR flash, while the EDB9315 has 32M. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-29[ARM] 3674/1: ep93xx: add cirrus logic edb9302 supportLennert Buytenhek
Patch from Lennert Buytenhek This patch adds support for the Cirrus Logic EDB9302, an evaluation board based on the Cirrus Logic EP9302 SoC, with 32M RAM, one USB host port, audio in/out, two serial ports and a 10/100 ethernet interface. George Kashperko submitted the original patch, this patch is a rewrite using the newer physmap platform driver. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-28[ARM] 3671/1: ep93xx: add cirrus logic edb9315 supportLennert Buytenhek
Patch from Lennert Buytenhek This patch adds support for the Cirrus Logic EDB9315, an evaluation board based on the Cirrus Logic EP9315 SoC, with 64M RAM, two USB host ports, audio in/out, three serial ports, 10/100 ethernet, and IDE, VGA, and LCD interfaces. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-28[ARM] 3370/2: ep93xx: add crunch supportLennert Buytenhek
Patch from Lennert Buytenhek Add the necessary kernel bits for crunch task switching. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-28[ARM] 3663/1: fix resource->end off-by-one thinko during physmap conversionLennert Buytenhek
Patch from Lennert Buytenhek Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-24[ARM] 3646/1: ep93xx: instantiate ep93xx-ohci platform deviceLennert Buytenhek
Patch from Lennert Buytenhek The ep93xx ohci bits have been merged into the gregkh-2.6 tree, which means that they will probably go upstream soon, so make the core ep93xx code instantiate an appropriate ep93xx-ohci platform device. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-24[ARM] 3634/1: ep93xx: initial implementation of the clk_* APILennert Buytenhek
Patch from Lennert Buytenhek Add an initial implementation of the clk_* API for the cirrus ep93xx to the tree. The initial implementation is somewhat minimal, with the intention of extending it as we go along. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-22[ARM] 3617/1: ep93xx: fix slightly incorrect timer tick rateLennert Buytenhek
Patch from Lennert Buytenhek The tick rate of timers 1-3 isn't exactly 508 kHz as some parts of the relevant documentation claim, but more like 508.469 kHz (14.7456 MHz divided by 29.) Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-22[ARM] 3616/1: fix timer handler wrap logic for a number of platformsLennert Buytenhek
Patch from Lennert Buytenhek A couple of platforms aren't using the right comparison type in their timer interrupt handlers (as we're comparing two wrapping timestamps, we need a bmi/bpl-type comparison, not an unsigned comparison) -- this patch fixes them up. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-22[ARM] 3614/1: ep93xx: use platform devices for physmap flashLennert Buytenhek
Patch from Lennert Buytenhek Now that the physmap platform device rewrite is in, make the ep93xx boards use platform devices for physmap flash. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-08[PATCH] ep93xx build fixLennert Buytenhek
From: Lennert Buytenhek <buytenh@wantstofly.org> The recent renaming of m48t86's ->readb() and ->writeb() platform driver methods (2d7b20c1884777e66009be1a533641c19c4705f6) to ->readbyte() and ->writebyte() to fix the ia64 build broke the build of the cirrus ep93xx ARM platform. This patch fixes it up. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-02[ARM] 3451/1: ep93xx: use the m48t86 rtc driver on the ts72xx platformLennert Buytenhek
Patch from Lennert Buytenhek Instantiate the recently merged m48t86 rtc driver in the ts72xx code. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-02[ARM] 3450/1: ep93xx: use the ep93xx rtc driverLennert Buytenhek
Patch from Lennert Buytenhek Instantiate the recently merged ep93xx rtc driver in the ep93xx code. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-26[SERIAL] Provide Cirrus EP93xx AMBA PL010 serial support.Lennert Buytenhek
2006-03-21[ARM] 3374/1: ep93xx: gpio interrupt supportLennert Buytenhek
Patch from Lennert Buytenhek Add GPIO interrupt support for the first 16 GPIO lines (port A and B.) Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] 3371/1: ep93xx: gpio supportLennert Buytenhek
Patch from Lennert Buytenhek Add support for setting the direction of and getting/setting the value of the 64 GPIO lines. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] 3369/1: ep93xx: add core cirrus ep93xx supportLennert Buytenhek
Patch from Lennert Buytenhek This patch adds support for the Cirrus ep93xx series of CPUs. The ep93xx is an ARM920T based CPU with two VICs, PL010 based UARTs, IrDA, MaverickCrunch floating point coprocessor, between 24 and 64 GPIOs, ethernet, OHCI USB and, depending on the model, pcmcia, raster engine, graphics accelerator, IDE controller and a bunch of other stuff. This patch adds the core ep93xx support code, and support for the Glomation GESBC-9312-sx and the Technologic Systems TS-72xx SBCs. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
