Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
gpio-ep93xx.h, hardware.h, and platform.h are only used in
arch/arm/mach-ep93xx, so we can move them one there and no
longer expose them to device drivers.
Acked-by: Alexander Sverdlin <alexander.sverdlin@gmail.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
into next/cleanup
From Rob Herring:
Initial irqchip init infrastructure and GIC and VIC clean-ups
This creates irqchip initialization infrastructure from Thomas
Petazzoni. The VIC and GIC irqchip code is moved to drivers/irqchips
and adapted to use the new infrastructure. All DT enabled platforms
using GIC and VIC are converted over to use the new irqchip_init.
* tag 'gic-vic-to-irqchip' of git://sources.calxeda.com/kernel/linux:
irqchip: Move ARM vic.h to include/linux/irqchip/arm-vic.h
ARM: picoxcell: use common irqchip_init function
ARM: spear: use common irqchip_init function
irqchip: Move ARM VIC to drivers/irqchip
ARM: samsung: remove unused tick.h
ARM: remove unneeded vic.h includes
ARM: remove mach .handle_irq for VIC users
ARM: VIC: set handle_arch_irq in VIC initialization
ARM: VIC: shrink down vic.h
irqchip: Move ARM gic.h to include/linux/irqchip/arm-gic.h
ARM: use common irqchip_init for GIC init
irqchip: Move ARM GIC to drivers/irqchip
ARM: remove mach .handle_irq for GIC users
ARM: GIC: set handle_arch_irq in GIC initialization
ARM: GIC: remove direct use of gic_raise_softirq
ARM: GIC: remove assembly ifdefs from gic.h
ARM: mach-ux500: use SGI0 to wake up the other core
arm: add set_handle_irq() to register the parent IRQ controller handler function
irqchip: add basic infrastructure
irqchip: add to the directories part of the IRQ subsystem in MAINTAINERS
Fixed up massive merge conflicts with the timer cleanup due to adjacent changes:
arch/arm/mach-bcm/board_bcm.c
arch/arm/mach-cns3xxx/cns3420vb.c
arch/arm/mach-ep93xx/adssphere.c
arch/arm/mach-ep93xx/edb93xx.c
arch/arm/mach-ep93xx/gesbc9312.c
arch/arm/mach-ep93xx/micro9.c
arch/arm/mach-ep93xx/simone.c
arch/arm/mach-ep93xx/snappercl15.c
arch/arm/mach-ep93xx/ts72xx.c
arch/arm/mach-ep93xx/vision_ep9307.c
arch/arm/mach-highbank/highbank.c
arch/arm/mach-imx/mach-imx6q.c
arch/arm/mach-msm/board-dt-8960.c
arch/arm/mach-netx/nxdb500.c
arch/arm/mach-netx/nxdkn.c
arch/arm/mach-netx/nxeb500hmi.c
arch/arm/mach-nomadik/board-nhk8815.c
arch/arm/mach-picoxcell/common.c
arch/arm/mach-realview/realview_eb.c
arch/arm/mach-realview/realview_pb1176.c
arch/arm/mach-realview/realview_pb11mp.c
arch/arm/mach-realview/realview_pba8.c
arch/arm/mach-realview/realview_pbx.c
arch/arm/mach-socfpga/socfpga.c
arch/arm/mach-spear13xx/spear1310.c
arch/arm/mach-spear13xx/spear1340.c
arch/arm/mach-spear13xx/spear13xx.c
arch/arm/mach-spear3xx/spear300.c
arch/arm/mach-spear3xx/spear310.c
arch/arm/mach-spear3xx/spear320.c
arch/arm/mach-spear3xx/spear3xx.c
arch/arm/mach-spear6xx/spear6xx.c
arch/arm/mach-tegra/board-dt-tegra20.c
arch/arm/mach-tegra/board-dt-tegra30.c
arch/arm/mach-u300/core.c
arch/arm/mach-ux500/board-mop500.c
arch/arm/mach-ux500/cpu-db8500.c
arch/arm/mach-versatile/versatile_ab.c
arch/arm/mach-versatile/versatile_dt.c
arch/arm/mach-versatile/versatile_pb.c
arch/arm/mach-vexpress/v2m.c
include/asm-generic/vmlinux.lds.h
Numerous includes of asm/hardware/vic.h aren't needed, so remove them.
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Hubert Feurstein <hubert.feurstein@contec.at>
Cc: Alessandro Rubini <rubini@unipv.it>
Cc: STEricsson <STEricsson_nomadik_linux@list.st.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Acked-By: Maxime Ripard <maxime.ripard@free-electrons.com>
Cc: linux-samsung-soc@vger.kernel.org
Cc: patches@opensource.wolfsonmicro.com
Now that the VIC initialization sets up the handle_arch_irq pointer, we
can remove it for all machines and make it static. Move vic_handle_irq
to avoid a forward declaration.
Cc: Shiraz Hashim <shiraz.hashim@st.com>
Cc: Rajeev Kumar <rajeev-dlh.kumar@st.com>
Acked-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Acked-by: Olof Johansson <olof@lixom.net>
Now that the only field in struct sys_timer is .init, delete the struct,
and replace the machine descriptor .timer field with the initialization
function itself.
This will enable moving timer drivers into drivers/clocksource without
having to place a public prototype of each struct sys_timer object into
include/linux; the intent is to create a single of_clocksource_init()
function that determines which timer driver to initialize by scanning
the device dtree, much like the proposed irqchip_init() at:
http://www.spinics.net/lists/arm-kernel/msg203686.html
Includes mach-omap2 fixes from Igor Grinberg.
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
The PHYS_BASE defines in arch/arm/mach-ep93xx/include/mach-ep93xx-regs.h are
only used in the SoC code. Move the defines to a local header file.
Signed-off-by: Ryan Mallon <rmallon@gmail.com>
Reviewed-by: Mika Westerberg <mika.westerberg@iki.fi>
Acked-by: Hartley Sweeten <hsweeten@visionengravers.com>
arch/arm/mach-exynos/cpu.c
The changes to arch/arm/mach-exynos/cpu.c were moved to
mach-exynos/common.c.
Hook these platforms restart code into the new restart hook rather than
using arch_reset().
Now that there is a generic IRQ handler for multiple VIC devices use it
for ep93xx to help building multi platform kernels.
Cc: Hartley Sweeten <hsweeten@visionengravers.com>
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Tested-by: Petr Štetiar <ynezz@true.cz>
Tested-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Since we're now using addruart to establish the debug mapping, we can
remove the io_pg_offst and phys_io members of struct machine_desc.
The various declarations were removed using the following script:
grep -rl MACHINE_START arch/arm | xargs \
sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }'
[ Initial patch was from Jeremy Kerr, example script from Russell King ]
Acked-by: Eric Miao <eric.miao at canonical.com>
Create a core.c __init function to handle the physmap flash
registration for all the ep93xx platforms. Also, modify all
the ep93xx platforms to use this new function.
This simplifies all the ep93xx platform init code and reduces
the size of the kernel when including multiple ep93xx boards.
Acked-by: Ryan Mallon <ryan@bluewatersys.com>
Acked-by: Martin Guy <martinwguy@gmail.com>
Acked-by: Hubert Feurstein <hubert.feurstein@contec.at>
A number of the peripherals for the ep93xx are registered at
startup using platform_data that is passed from the board init
code to the core code. This data is then copied to a local
static variable in the core code. Since the data is copied,
the original data can be marked as __initdata and discarded
after startup is complete.
This adds the __initdata tag to all the appropriate data in
the various ep93xx board init's. Specifically, all the
struct ep93xx_eth_data, struct ep93xxfb_mach_info, and
struct i2c_gpio_platform_data.
Also, document the various registration functions and note
what data should be marked as __initdata.
While here, also cleanup a couple over zealous whitespace tabs.
In particular, several occurances of funny versions of 'success',
'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address',
'beginning', 'desirable', 'separate' and 'necessary' are fixed.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Joe Perches <joe@perches.com>
Cc: Junio C Hamano <gitster@pobox.com>
__raw_readl and IOMEM
Add Contec Micro9-Slim support
Cc: Ryan Mallon <ryan@bluewatersys.com>
Requires: 5750/1
Signed-off-by: Hubert Feurstein <hubert.feurstein@contec.at>
Update Contec Micro9 platform code
Requires: 5749/1
Update Contec Micro9 maintainer and add entry in MAINTAINERS
Requires: 5744/1
Acked-by: Manfred Gruber <m.gruber@tirol.com>
arch/arm/mach-ep93xx/include/mach/hardware.h
1. Properly name the include files so that they are loaded
from the <mach/*> directory and not the local directory.
2. Remove including the ts72xx.h header. This header is not
generic to the ep93xx platform. It should only be included
by the ts72xx specific files that require it. The only
two users in the tree are arch/arm/mach-ep93xx/ts72xx.c
and drivers/mtd/nand/ts7250.c.
arch/arm/mach-ep93xx/include/mach/ts72xx.h
1. <linux/io.h> should already be included by any user of this
header. Doing the include here hides it from being needed
by the calling source file.
arch/arm/mach-ep93xx/core.c
1. Remove unnecessary headers. They were probably included
originally due to cut-and-paste from other files.
2. <linux/io.h> should be included not <mach/gpio.h>
arch/arm/mach-ep93xx/adsphere.c
2. Add platform specific header <mach/ts72xx.h>.
1. <linux/io.h> should be included not <asm/io.h>.
Include <linux/i2c.h> in all ep93xx platforms.
Patch "5311/1: add core support for built in i2c bus" will cause build errors due to the following in
arch/arm/mach-ep93xx/include/mach/platform.h:
+void ep93xx_register_i2c(struct i2c_board_info *devices, int num);
The i2c.h header needs to be included in order to define struct i2c_board_info.
Use EP93XX_*_PHYS_BASE and SZ_* defines in ep93xx platform inits.
The following patch changes the flash memory hard-coded resource
addresses and MACHINE_START boot_params to EP93XX_*_PHYS_BASE and
SZ_* defines to improve readability. Also some minor whitespace
cleanup resulting from previous patches.
'sa1100' into devel
All EP93xx based systems can support Ethernet. This patch moves
the platform_device setup from the various board support files
into the core support file. The Ethernet driver data still remains
in the individual platform setup files to allow specific platform
configuration.
This also adds Ethernet support to the edb9302, edb9312, and
edb9315 platforms.
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
Contec Micro9 (H/M/L) boards based on Cirrus Logic ep93xx (ep9315/ep9307/ep9302).
Signed-off-by: Manfred Gruber <m.gruber@tirol.com>
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
