path: root/arch/arm/mach-davinci
2010-10-25Merge branch 'davinci-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci * 'davinci-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci: (50 commits) davinci: fix remaining board support after io_pgoffst removal davinci: mityomapl138: make file local data static arm/davinci: remove duplicated include davinci: Initial support for Omapl138-Hawkboard davinci: MityDSP-L138/MityARM-1808 read MAC address from I2C Prom davinci: add tnetv107x touchscreen platform device input: add driver for tnetv107x touchscreen controller davinci: add keypad config for tnetv107x evm board davinci: add tnetv107x keypad platform device input: add driver for tnetv107x on-chip keypad controller net: davinci_emac: cleanup unused cpdma code net: davinci_emac: switch to new cpdma layer net: davinci_emac: separate out cpdma code net: davinci_emac: cleanup unused mdio emac code omap: cleanup unused davinci mdio arch code davinci: cleanup mdio arch code and switch to phy_id net: davinci_emac: switch to new mdio omap: add mdio platform devices davinci: add mdio platform devices net: davinci_emac: separate out davinci mdio ... Fix up trivial conflict in drivers/input/keyboard/Kconfig (two entries added next to each other - one from the davinci merge, one from the input merge)
2010-10-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (365 commits) ALSA: hda - Disable sticky PCM stream assignment for AD codecs ALSA: usb - Creative USB X-Fi volume knob support ALSA: ca0106: Use card specific dac id for mute controls. ALSA: ca0106: Allow different sound cards to use different SPI channel mappings. ALSA: ca0106: Create a nice spot for mapping channels to dacs. ALSA: ca0106: Move enabling of front dac out of hardcoded setup sequence. ALSA: ca0106: Pull out dac powering routine into separate function. ALSA: ca0106 - add Sound Blaster 5.1vx info. ASoC: tlv320dac33: Use usleep_range for delays ALSA: usb-audio: add Novation Launchpad support ALSA: hda - Add workarounds for CT-IBG controllers ALSA: hda - Fix wrong TLV mute bit for STAC/IDT codecs ASoC: tpa6130a2: Error handling for broken chip ASoC: max98088: Staticise m98088_eq_band ASoC: soc-core: Fix codec->name memory leak ALSA: hda - Apply ideapad quirk to Acer laptops with Cxt5066 ALSA: hda - Add some workarounds for Creative IBG ALSA: hda - Fix wrong SPDIF NID assignment for CA0110 ALSA: hda - Fix codec rename rules for ALC662-compatible codecs ALSA: hda - Add alc_init_jacks() call to other codecs ...
2010-10-25Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: arch/powerpc/platforms/85xx/p1022_ds.c
2010-10-21davinci: fix remaining board support after io_pgoffst removalKevin Hilman
Some boards that were added after the mass io_pgoffst/io_physio removal, and were not updated in the original patch. Fixup here. c.f. original io_pgoffst/io_physio removal commit 6451d7783ba5ff24eb1a544eaa6665b890f30466 Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-10-21Merge branch 'davinci-next' into davinci-for-linusKevin Hilman
Conflicts: arch/arm/mach-davinci/board-da830-evm.c arch/arm/mach-davinci/board-da850-evm.c
2010-10-20arm: remove machine_desc.io_pg_offst and .phys_ioNicolas Pitre
Since we're now using addruart to establish the debug mapping, we can remove the io_pg_offst and phys_io members of struct machine_desc. The various declarations were removed using the following script: grep -rl MACHINE_START arch/arm | xargs \ sed -i '/MACHINE_START/,/MACHINE_END/ { /\.\(phys_io\|io_pg_offst\)/d }' [ Initial patch was from Jeremy Kerr, example script from Russell King ] Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org> Acked-by: Eric Miao <eric.miao at canonical.com>
2010-10-20arm: return both physical and virtual addresses from addruartJeremy Kerr
Rather than checking the MMU status in every instance of addruart, do it once in kernel/debug.S, and change the existing addruart macros to return both physical and virtual addresses. The main debug code can then select the appropriate address to use. This will also allow us to retreive the address of a uart for the MMU state that we're not current in. Updated with fixes for OMAP from Jason Wang <jason77.wang@gmail.com> and Tony Lindgren <tony@atomide.com>, and fix for versatile express from Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Jason Wang <jason77.wang@gmail.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Tested-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-10-12davinci: mityomapl138: make file local data staticSekhar Nori
Most of the regulator data structures are local to the board file, but not made static. Fix this. Also make the nand partition table static. This gets rid of all the sparse warnings for this file. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-10-04arm/davinci: remove duplicated includeNicolas Kaiser
Remove duplicated include. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-25ARM: 6409/1: davinci: map sram using MT_MEMORY_NONCACHED instead of MT_DEVICESantosh Shilimkar
On Davinci SRAM is mapped as MT_DEVICE becasue of the section mapping pre-requisite instead of intended MT_MEMORY_NONCACHED Since the section mapping limitation gets fixed with first patch in this series, the MT_MEMORY_NONCACHED can be used now. Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-24davinci: Initial support for Omapl138-HawkboardVictor Rodriguez
This patch adds initial support for the Hawkboard-L138 system It is under the machine name "omapl138_hawkboard". This system is based on the da850 davinci CPU architecture. Information on these system may be found at http://www.hawkboard.org. Basic support for the UART console is included in this patch. It's tested with latest Angstrom File Systems like ramdisk from http://alturl.com/imb45. Signed-off-by: Victor Rodriguez <victor.rodriguez@sasken.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: MityDSP-L138/MityARM-1808 read MAC address from I2C PromMichael Williamson
For the MityDSP-L138/MityARM-1808 SOMS, read the factory assigned MAC address from the onboard I2C EPROM and assign it to the emac device during platform initialization. Signed-off-by: Michael Williamson <michael.williamson@criticallink.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: add tnetv107x touchscreen platform deviceCyril Chemparathy
This patch adds a platform device definition for tnetv107x's touchscreen controller. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: add keypad config for tnetv107x evm boardCyril Chemparathy
This patch adds evm board specific keymap definitions and controller configuration data for on-chip keypad controller on tnetv107x silicon. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: add tnetv107x keypad platform deviceCyril Chemparathy
This patch adds a platform device definition for tnetv107x's keypad controller. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: cleanup mdio arch code and switch to phy_idCyril Chemparathy
This patch removes davinci architecture code that has now been rendered useless by the previous patches in the MDIO separation series. In addition, the earlier phy_mask definitions have been replaced with corresponding phy_id definitions. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Tested-by: Michael Williamson <michael.williamson@criticallink.com> Tested-by: Caglar Akyuz <caglarakyuz@gmail.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: add mdio platform devicesCyril Chemparathy
This patch adds mdio platform devices on SoCs that have the necessary hardware. Clock lookup entries (aliases) have also been added, so that the MDIO and EMAC drivers can independently enable/disable a shared underlying clock. Further, the EMAC MMR region has been split down into separate MDIO and EMAC regions. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Michael Williamson <michael.williamson@criticallink.com> Tested-by: Caglar Akyuz <caglarakyuz@gmail.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: Add I2C0 devices to MityDSP-L138/MityARM-1808 platformMichael Williamson
This patch adds the i2c0 bus and attached devices to the MityDSP-L138 and MityARM-1808 davinci SoM. Included is a TPS65023 voltage regulator needed for power management and a small 24c02 EPROM that contains factory configuration data. Signed-off-by: Michael Williamson <michael.williamson@criticallink.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: add idcode for tnetv107x rev 1.1/1.2Cyril Chemparathy
This patch adds an entry into the idcode table for tnetv107x silicon revision 1.1 and 1.2 devices. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: Initial support for MityDSP-L138/MityARM-1808Michael Williamson
This patch adds initial support for the MityDSP-L138 and MityDSP-1808 system on Module (SOM) under the machine name "mityomapl138". These SOMs are based on the da850 davinci CPU architecture. Information on these SOMs may be found at http://www.mitydsp.com. Basic support for the console UART, NAND, and EMAC (MII interface) is included in this patch. Signed-off-by: Michael Williamson <michael.williamson@criticallink.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: Add machine checks to DA8XX serial console init routinesMichael Williamson
This patch adds machine checks in the serial console init routines for the DA8XX EVM boards. This is needed because there are other DA8XX based machines that use a different UART/tty as the console and may be included in a common kernel build. Signed-off-by: Michael Williamson <michael.williamson@criticallink.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: dm6467t evm: setup NAND flash timingSekhar Nori
Setup NAND flash timing on DM6467T EVM. Without the timing setup, the NAND flash on DM6467T RevC EVM reports a number of random bad blocks because of read errors. Also, with this, copying a 100M file on RevB EVM takes ~35 sec against 1 minute 30 seconds earlier. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: am18x/da850/omap-l138 evm: setup NAND flash timingSekhar Nori
Setup the NAND flash timings for DA850 EVM Before configuring the timing values, throughput calculation using dd command yielded 469 kB/s write and 966 kB/s read speed. After the timing configuration, the throughput was measured to be 2.4 MB/s write and 5 MB/s read. [Mukul Bhatnagar: actual calculation of timing values from the NAND datasheet] Signed-off-by: Sekhar Nori <nsekhar@ti.com> Cc: Mukul Bhatnagar <mbhatnagar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: am17x/da830/omap-l137 evm: setup NAND flash timingSudhakar Rajashekhara
Setup the NAND flash timings for DA830 EVM. Before configuring the timing values, throughput calculation using dd command yielded 477 kB/s write and 970 kB/s read speed. After the timing configuration, the throughput was measured to be 2.5 MB/s write and 5.1 MB/s read. [Mukul Bhatnagar: actual calculation of timing values from the NAND datasheet] Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Mukul Bhatnagar <mbhatnagar@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: dm644x evm: setup NAND flash timingSekhar Nori
The DM644x EVM nand flash timing was earlier being done as a special case in the NAND driver itself. With the NAND driver now capable of progamming the AEMIF interface using timing data passed from the platform, the timing values are being moved into their rightful place in the EVM specific board file. The values being programmed match what was being done earlier and thus do not represent any change in performance/functionality. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24nand: davinci: add support for timing configurationSekhar Nori
This patch modifies the DaVinci NAND driver to use the new AEMIF timing setup API to configure the NAND access timings. Earlier, AEMIF configuration was being done as a special case for DM644x board, but now more boards emerge which have capability to boot for other media (SPI flash, NOR flash) and have the kernel access NAND flash. This means that kernel cannot always depend on the bootloader to setup the NAND. Also, on platforms such as da850/omap-l138, the aemif input frequency changes as cpu frequency changes; necessiating re-calculation of timimg values as part of cpufreq transtitions. This patch forms the basis for adding that support. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2010-09-24davinci: add support for aemif timing configurationSekhar Nori
This patch adds support to configure the AEMIF interface with supplied timing values. Since this capability is useful both from NOR and NAND flashes, it is provided as a new interface and in a file of its own. AEMIF timing configuration is required in cases: 1) Where the AEMIF clock rate can change at runtime (a side affect of cpu frequency change). 2) Where U-Boot does not support NAND/NOR but supports other media like SPI Flash or MMC/SD and thus does not care about setting up the AEMIF timing for kernel to use. 3) Where U-Boot just hasn't configured the timing values and cannot be upgraded because the box is already in the field. Since there is now a header file for AEMIF interface, the common (non-NAND specific) defines for AEMIF registers have been moved from nand.h into the newly created aemif.h Signed-off-by: Sekhar Nori <nsekhar@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: dm365 evm: use EDMAQ_3 as the audio DMA queueSekhar Nori
By default the audio driver uses EDMAQ_0 as the DMA queue, but on DM365 this queue is specially designed for video transfers with a large fifo size. Having both audio and video transfers on the same queue leads to noise on the audio side. This patch changes the audio queue number for DM365 to EDMAQ_3. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24DA850: Add MMCSD1 resources, platform device and convenience registration ↵Juha Kuikka
function Add resources, platform device and convenience registration function for DA850's second MMC/SD controller (MMCSD1). Signed-off-by: Juha Kuikka <juha.kuikka@elektrobit.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24DA850: Split MMCSD clock into two to support both MMCSD peripheralsJuha Kuikka
Split mmcsd_clk into mmcsd0_clk and mmcsd1_clk and add davinci_mmc.1 in preparation for adding support for MMCSD1 peripheral in DA850. Signed-off-by: Juha Kuikka <juha.kuikka@elektrobit.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24DA850: Add LPSC id for MMCSD1 peripheralJuha Kuikka
Add LPSC id for DA850's MMCSD1 peripheral. Signed-off-by: Juha Kuikka <juha.kuikka@elektrobit.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24arm: mach-davinci: check irq2ctlr() resultKulikov Vasiliy
If irq2ctlr() fails return IRQ_NONE. Also as it can fail make 'ctlr' signed. The semantic patch that finds this problem (many false-positive results): (http://coccinelle.lip6.fr/) // <smpl> @ r1 @ identifier f; @@ int f(...) { ... } @@ identifier r1.f; type T; unsigned T x; @@ *x = f(...) ... *x > 0 Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24DA850: move MII/RMII pin lists to the board fileSergei Shtylyov
The CPGMAC pin list in da850.c was incorrectly split into two MII/RMII mode specific pin lists, while what pin group is used is a function of how the board is wired. Copy the pin lists to board-da850-evm.c, renaming them accordingly, and merge the two lists in da850.c into one, da850_cpgmac_pins[], representing the CPGMAC module as a whole... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Tested-by: Ben Gardiner <bengardiner@nanometrics.ca> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24DA850: move NAND/NOR pin lists to the board fileSergei Shtylyov
The NAND/NOR flash pin lists (da850_nand_pins/da850_nor_pins) are purely board specific and as such shouldn't be in da850.c -- copy them to board-da850-evm.c, renaming to da850_evm_nand_pins/da850_evm_nor_pins respectively, and merge the two lists in da850.c into one, representing the EMIF 2.5 module as a whole, just like we have it in da830.c... While at it, remove the '__init' modifier from da850_evm_setup_nor_nand() as this function is called from non '__init' code... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Tested-by: Ben Gardiner <bengardiner@nanometrics.ca> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24Davinci: tnetv107x: retain psc reg base after initCyril Chemparathy
This is a bugfix for the original tnetv107x submission series. The psc_regs base array was being discarded post-init, and this was causing a crash during post-init clock enable/disable. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: am18x/da850/omap-l138: keep async clock constant with cpufreqSekhar Nori
Keep PLL0 SYSCLK3 at a constant rate of 100MHz. This enables the AEMIF timing to remain valid even as the PLL0 output is changed by cpufreq driver to save power. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: cpufreq: add support for keeping an additional clock constantSekhar Nori
On OMAP-L138 SoC, some of the sysclks need not be at a fixed ratio to CPU clock and can be kept at a relatively constant rate by adjusting the PLLDIVn ratio even as cpufreq goes ahead and changes the CPU clock. This feature can be used to keep the EMIFA (PLL0 SYSCLK3) clock at a constant rate so that the EMIF timings need not be re-programmed whenever the CPU frequency changes. This patch adds the required suppport to cpufreq driver. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: clock: add support for setting sysclk rateSekhar Nori
Setting sysclk rate will be useful in cases where the sysclk is not at a fixed ratio to the PLL output but can asynchronously be changed. This support forms the basis of attempt to keep the AEMIF clock constant on OMAP-L138 even as PLL0 output changes as ARM clock is changed to save power. This patch has been tested on OMAP-L138. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: dm365: disable pulldowns for all MMC/SD1 pins.Sekhar Nori
This patch disables internal pulldowns for all MMC/SD1 pins. Presently only MMCSD1_CMD pin's pull down is disabled, but with this some MMC/SD cards do not get detected on MMC/SD1 slot of the EVM. The problem was reproducible with SanDisk 4GB SDHC card. Reported-by: Stephane Bovagne <s-bovagne@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: am18x/da850/omap-l138: use 'NOM' voltage defined in datasheet as ↵Sekhar Nori
min voltage For each DA850 OPP, the normal ('NOM') voltage defined in the tecnical reference manual (TRM) is actually the minimum voltage the frequency is supported at. The minimum ('MIN') voltage defined in TRM is meant to take care of voltage fluctuations and the device should not be run at this voltage for extended periods of time. Fix the OPP definitions to define the cvdd_min as the normal voltage defined in the datasheet. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: introduce support for AM1x ARM9 microprocessorsSekhar Nori
The Sitara AM17x SoCs from TI are an OMAP-L137 pin-to-pin compatible ARM9 microprocessor offering from TI. The Sitara AM18x SoCs from TI are an OMAP-L138 pin-to-pin compatible ARM9 microprocessor offering from TI. More information about these processors available at: www.ti.com/am1x Because of their compatibiliy with OMAP-L1x, the kernel support for OMAP-L1x is fully relevant to AM1x processors. This patch updates the Kconfig prompt and help text to include the AM1x part names to help users select configurations required for these parts easily. Also, the hardware information that shows up in /proc/cpuinfo is updated to show applicability of the respective OMAP-L1x EVMs for AM1x parts. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: clean up inconsistent usage of spaces in KconfigSekhar Nori
In arch/arm/mach-davinci/Kconfig, some of the configuration items are indented with multiple spaces instead of tabs. Also, in couple of places, two spaces are used in the middle of help text where one should do. This patch fixes both issues. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: cpufreq: bailout on regulator errorsSekhar Nori
Current cpufreq code does not consider errors that can occur while changing voltage. Code to increase CPU frequency goes ahead even in the case the regulator has failed to increase the voltage. This leads to hard error since lower voltages cannot support increased frequency. Prevent this by not increasing frequency in case increasing voltage is not successful. Also, do not lower the voltage if changing the cpu frequency has failed for some reason. Note that we do not return error on failure to decrease voltage as that is not a hard error. Build fix for non-cpufreq kernels by Caglar Akyuz. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Cc: Caglar Akyuz <caglar@bilkon-kontrol.com.tr> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: clock: make 'disable unused clocks' printk debug onlyKevin Hilman
The long list of clocks being disabled on boot is noisy and not needed for standard boots. Make this a debug printk instead. Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-09-24davinci: da850 evm: sparse cleanup: make file local variables staticSekhar Nori
Without this cleanup, sparse checker reports warnings of the type: CHECK arch/arm/mach-davinci/board-da850-evm.c arch/arm/mach-davinci/board-da850-evm.c:112:22: warning: symbol 'da850_evm_nandflash_partition' was not declared. Should it be static? The nand flash partitions and regulator supplies are used within the EVM file and so should have been static This patch has been boot tested on DA830 and DA850 EVMs. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-08-16Merge branch 'for-2.6.36' into for-2.6.37Mark Brown
Fairly simple conflicts, the most serious ones are the i.MX ones which I suspect now need another rename. Conflicts: arch/arm/mach-mx2/clock_imx27.c arch/arm/mach-mx2/devices.c arch/arm/mach-omap2/board-rx51-peripherals.c arch/arm/mach-omap2/board-zoom2.c sound/soc/fsl/mpc5200_dma.c sound/soc/fsl/mpc5200_dma.h sound/soc/fsl/mpc8610_hpcd.c sound/soc/pxa/spitz.c
2010-08-12ASoC: multi-component - ASoC Multi-Component SupportLiam Girdwood
This patch extends the ASoC API to allow sound cards to have more than one CODEC and more than one platform DMA controller. This is achieved by dividing some current ASoC structures that contain both driver data and device data into structures that only either contain device data or driver data. i.e. struct snd_soc_codec ---> struct snd_soc_codec (device data) +-> struct snd_soc_codec_driver (driver data) struct snd_soc_platform ---> struct snd_soc_platform (device data) +-> struct snd_soc_platform_driver (driver data) struct snd_soc_dai ---> struct snd_soc_dai (device data) +-> struct snd_soc_dai_driver (driver data) struct snd_soc_device ---> deleted This now allows ASoC to be more tightly aligned with the Linux driver model and also means that every ASoC codec, platform and (platform) DAI is a kernel device. ASoC component private data is now stored as device private data. The ASoC sound card struct snd_soc_card has also been updated to store lists of it's components rather than a pointer to a codec and platform. The PCM runtime struct soc_pcm_runtime now has pointers to all its components. This patch adds DAPM support for ASoC multi-component and removes struct snd_soc_socdev from DAPM core. All DAPM calls are now made on a card, codec or runtime PCM level basis rather than using snd_soc_socdev. Other notable multi-component changes:- * Stream operations now de-reference less structures. * close_delayed work() now runs on a DAI basis rather than looping all DAIs in a card. * PM suspend()/resume() operations can now handle N CODECs and Platforms per sound card. * Added soc_bind_dai_link() to bind the component devices to the sound card. * Added soc_dai_link_probe() and soc_dai_link_remove() to probe and remove DAI link components. * sysfs entries can now be registered per component per card. * snd_soc_new_pcms() functionailty rolled into dai_link_probe(). * snd_soc_register_codec() now does all the codec list and mutex init. This patch changes the probe() and remove() of the CODEC drivers as follows:- o Make CODEC driver a platform driver o Moved all struct snd_soc_codec list, mutex, etc initialiasation to core. o Removed all static codec pointers (drivers now support > 1 codec dev) o snd_soc_register_pcms() now done by core. o snd_soc_register_dai() folded into snd_soc_register_codec(). CS4270 portions: Acked-by: Timur Tabi <timur@freescale.com> Some TLV320aic23 and Cirrus platform fixes. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> TI CODEC and OMAP fixes Signed-off-by: Peter Ujfalusi <peter.ujfalusi@nokia.com> Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Signed-off-by: Jarkko Nikula <jhnikula@gmail.com> Samsung platform and misc fixes :- Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Jassi Brar <jassi.brar@samsung.com> Signed-off-by: Seungwhan Youn <sw.youn@samsung.com> MPC8610 and PPC fixes. Signed-off-by: Timur Tabi <timur@freescale.com> i.MX fixes and some core fixes. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> J4740 platform fixes:- Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> CC: Tony Lindgren <tony@atomide.com> CC: Nicolas Ferre <nicolas.ferre@atmel.com> CC: Kevin Hilman <khilman@deeprootsystems.com> CC: Sascha Hauer <s.hauer@pengutronix.de> CC: Atsushi Nemoto <anemo@mba.ocn.ne.jp> CC: Kuninori Morimoto <morimoto.kuninori@renesas.com> CC: Daniel Gloeckner <dg@emlix.com> CC: Manuel Lauss <mano@roarinelk.homelinux.net> CC: Mike Frysinger <vapier.adi@gmail.com> CC: Arnaud Patard <apatard@mandriva.com> CC: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-08-08Merge branch 'davinci-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci * 'davinci-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-davinci: davinci: dm646x EVM: Specify reserved EDMA channel/slots davinci: da8xx/omapl EVM: Specify reserved channels/slots davinci: support for EDMA resource sharing davinci: edma: provide ability to detect insufficient CC info data davinci: da8xx: sparse cleanup: remove duplicate entries in irq priorities davinci: DM365: fixed second serial port Davinci: tnetv107x evm board initial support Davinci: tnetv107x initial gpio support Davinci: tnetv107x soc support Davinci: tnetv107x decompresser uart definitions Davinci: generalized debug macros
2010-08-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (214 commits) ALSA: hda - Add pin-fix for HP dc5750 ALSA: als4000: Fix potentially invalid DMA mode setup ALSA: als4000: enable burst mode ALSA: hda - Fix initial capsrc selection in patch_alc269() ASoC: TWL4030: Capture route runtime DAPM ordering fix ALSA: hda - Add PC-beep whitelist for an Intel board ALSA: hda - More relax for pending period handling ALSA: hda - Define AC_FMT_* constants ALSA: hda - Fix beep frequency on IDT 92HD73xx and 92HD71Bxx codecs ALSA: hda - Add support for HDMI HBR passthrough ALSA: hda - Set Stream Type in Stream Format according to AES0 ALSA: hda - Fix Thinkpad X300 so SPDIF is not exposed ALSA: hda - FIX to not expose SPDIF on Thinkpad X301, since it does not have the ability to use SPDIF ASoC: wm9081: fix resource reclaim in wm9081_register error path ASoC: wm8978: fix a memory leak if a wm8978_register fail ASoC: wm8974: fix a memory leak if another WM8974 is registered ASoC: wm8961: fix resource reclaim in wm8961_register error path ASoC: wm8955: fix resource reclaim in wm8955_register error path ASoC: wm8940: fix a memory leak if wm8940_register return error ASoC: wm8904: fix resource reclaim in wm8904_register error path ...
2010-08-05davinci: dm646x EVM: Specify reserved EDMA channel/slotsRajashekhara, Sudhakar
Not all the channels and slots available on the DM646x EVM are used by the devices on the EVM. These resources can be used by the DSP to speed up codec operations. This patch reserves these channels for the DSP. Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
