Pull more ARM updates from Russell King.
This got a fair number of conflicts with the <asm/system.h> split, but
also with some other sparse-irq and header file include cleanups. They
all looked pretty trivial, though.
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (59 commits)
ARM: fix Kconfig warning for HAVE_BPF_JIT
ARM: 7361/1: provide XIP_VIRT_ADDR for no-MMU builds
ARM: 7349/1: integrator: convert to sparse irqs
ARM: 7259/3: net: JIT compiler for packet filters
ARM: 7334/1: add jump label support
ARM: 7333/2: jump label: detect %c support for ARM
ARM: 7338/1: add support for early console output via semihosting
ARM: use set_current_blocked() and block_sigmask()
ARM: exec: remove redundant set_fs(USER_DS)
ARM: 7332/1: extract out code patch function from kprobes
ARM: 7331/1: extract out insn generation code from ftrace
ARM: 7330/1: ftrace: use canonical Thumb-2 wide instruction format
ARM: 7351/1: ftrace: remove useless memory checks
ARM: 7316/1: kexec: EOI active and mask all interrupts in kexec crash path
ARM: Versatile Express: add NO_IOPORT
ARM: get rid of asm/irq.h in asm/prom.h
ARM: 7319/1: Print debug info for SIGBUS in user faults
ARM: 7318/1: gic: refactor irq_start assignment
ARM: 7317/1: irq: avoid NULL check in for_each_irq_desc loop
ARM: 7315/1: perf: add support for the Cortex-A7 PMU
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system
Pull "Disintegrate and delete asm/system.h" from David Howells:
"Here are a bunch of patches to disintegrate asm/system.h into a set of
separate bits to relieve the problem of circular inclusion
dependencies.
I've built all the working defconfigs from all the arches that I can
and made sure that they don't break.
The reason for these patches is that I recently encountered a circular
dependency problem that came about when I produced some patches to
optimise get_order() by rewriting it to use ilog2().
This uses bitops - and on the SH arch asm/bitops.h drags in
asm-generic/get_order.h by a circuituous route involving asm/system.h.
The main difficulty seems to be asm/system.h. It holds a number of
low level bits with no/few dependencies that are commonly used (eg.
memory barriers) and a number of bits with more dependencies that
aren't used in many places (eg. switch_to()).
These patches break asm/system.h up into the following core pieces:
(1) asm/barrier.h
Move memory barriers here. This already done for MIPS and Alpha.
(2) asm/switch_to.h
Move switch_to() and related stuff here.
(3) asm/exec.h
Move arch_align_stack() here. Other process execution related bits
could perhaps go here from asm/processor.h.
(4) asm/cmpxchg.h
Move xchg() and cmpxchg() here as they're full word atomic ops and
frequently used by atomic_xchg() and atomic_cmpxchg().
(5) asm/bug.h
Move die() and related bits.
(6) asm/auxvec.h
Move AT_VECTOR_SIZE_ARCH here.
Other arch headers are created as needed on a per-arch basis."
Fixed up some conflicts from other header file cleanups and moving code
around that has happened in the meantime, so David's testing is somewhat
weakened by that. We'll find out anything that got broken and fix it..
* tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits)
Delete all instances of asm/system.h
Remove all #inclusions of asm/system.h
Add #includes needed to permit the removal of asm/system.h
Move all declarations of free_initmem() to linux/mm.h
Disintegrate asm/system.h for OpenRISC
Split arch_align_stack() out from asm-generic/system.h
Split the switch_to() wrapper out of asm-generic/system.h
Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h
Create asm-generic/barrier.h
Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h
Disintegrate asm/system.h for Xtensa
Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt]
Disintegrate asm/system.h for Tile
Disintegrate asm/system.h for Sparc
Disintegrate asm/system.h for SH
Disintegrate asm/system.h for Score
Disintegrate asm/system.h for S390
Disintegrate asm/system.h for PowerPC
Disintegrate asm/system.h for PA-RISC
Disintegrate asm/system.h for MN10300
Pull "ARM: More SoC driver updates" from Olof Johansson:
"This branch contains a handful of driver updates, mostly to the
LPC32xx platform but also for Samsung EXYNOS and Davinci.
It had a few context conflicts against patches already merged through
fixes-non-critical. We should have resolved this early during the
development cycle by pulling them in as a dependency, instead I did it
after the fact this time."
* tag 'drivers2' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
gpio/samsung: use ioremap() for EXYNOS4 GPIOlib
gpio/samsung: add support GPIOlib for EXYNOS5250
ARM: EXYNOS: add support GPIO for EXYNOS5250
ARM: LPC32xx: Ethernet support
ARM: LPC32xx: USB Support
ARM: davinci: dm644x evm: add support for VPBE display
ARM: davinci: dm644x: add support for v4l2 video display
ARM: EXYNOS: Hook up JPEG PD to generic PD infrastructure
ARM: EXYNOS: Hook up G2D PD to generic PD infrastructure
arm: lpc32xx: phy3250: add rtc & touch device
ARM: LPC32xx: clock.c: Clock registration fixes
ARM: LPC32xx: clock.c: jiffies wrapping
ARM: LPC32xx: clock.c: Missing header file
ARM: LPC32XX: Remove broken non-static declaration
ARM: LPC32xx: clock.c: Fix mutex lock issues
ARM: LPC32xx: clock.c: warning fix
ARM: LPC32xx: Added lpc32xx_defconfig
Disintegrate asm/system.h for ARM.
cc: Russell King <linux@arm.linux.org.uk>
cc: linux-arm-kernel@lists.infradead.org
fixes-non-critical has already been merged upstream, and there are a
handful of annoying context conflicts that it makes sense to resolve
before sending up. Part of this is because there was parallel development
going on between more urgent fixes and general driver fixups, it should
settle down once the lpc32xx platform reaches a more steady state.
arch/arm/mach-lpc32xx/clock.c
arch/arm/mach-lpc32xx/common.h
Pull "ARM: global cleanups" from Arnd Bergmann:
"Quite a bit of code gets removed, and some stuff moved around, mostly
the old samsung s3c24xx stuff. There should be no functional changes
in this series otherwise. Some cleanups have dependencies on other
arm-soc branches and will be sent in the second round.
Signed-off-by: Arnd Bergmann <arnd@arndb.de>"
Fixed up trivial conflicts mainly due to #include's being changes on
both sides.
* tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (121 commits)
ep93xx: Remove unnecessary includes of ep93xx-regs.h
ep93xx: Move EP93XX_SYSCON defines to SoC private header
ep93xx: Move crunch code to mach-ep93xx directory
ep93xx: Make syscon access functions private to SoC
ep93xx: Configure GPIO ports in core code
ep93xx: Move peripheral defines to local SoC header
ep93xx: Convert the watchdog driver into a platform device.
ep93xx: Use ioremap for backlight driver
ep93xx: Move GPIO defines to gpio-ep93xx.h
ep93xx: Don't use system controller defines in audio drivers
ep93xx: Move PHYS_BASE defines to local SoC header file
ARM: EXYNOS: Add clock register addresses for EXYNOS4X12 bus devfreq driver
ARM: EXYNOS: add clock registers for exynos4x12-cpufreq
PM / devfreq: update the name of EXYNOS clock registers that were omitted
ARM: EXYNOS: change the prefix S5P_ to EXYNOS4_ for clock
ARM: EXYNOS: use static declaration on regarding clock
ARM: EXYNOS: replace clock.c for other new EXYNOS SoCs
ARM: OMAP2+: Fix build error after merge
ARM: S3C24XX: remove call to s3c24xx_setup_clocks
Pull "ARM: Non-critical bug fixes" from Ardn Bergmann:
"Simple bug fixes that were not considered important enough for
inclusion into 3.3. One bug fix was originally intended for 3.3 but
accidentally got missed, but is not marked stable because it should
only get backported once later fixes also make it into v3.4.
* tag 'fixes-non-critical' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (66 commits)
iomux-mx25.h slew rate adjusted for LCD __LD pins
ARM: davinci: DA850: move da850_register_pm to .init.text
ARM: davinci: cpufreq: fix compiler warning
ARM: OMAP2+: Fix build for omap4 only builds with missing include of linux/bug.h
ARM: OMAP2+: Fix section warnings for hsmmc_init_one
ARM: OMAP2+: Fix build issues with missing include of linux/bug.h
ARM: OMAP2+: gpmc-smsc911x: only register regulator for first instance
ARM: OMAP3+: PM: VP: fix integer truncation error
ARM: OMAP2+: PM: fix wakeupgen warning when hotplug disabled
ARM: OMAP2+: PM: fix section mismatch with omap2_init_processor_devices()
ARM: OMAP2: Fix section warning for n8x0 when CONFIG_MMC_OMAP is not set
ARM: OMAP2+: Fix omap24xx_io_desc warning if SoC subtypes are not selected
ARM: OMAP1: Fix section mismatch for omap1_init_early()
ARM: OMAP1: Fix typo in lcd_dma.c
ARM: OMAP: mailbox: trivial whitespace fix
ARM: OMAP: Remove definition cpu_is_omap4430()
ARM: OMAP2+: included some headers twice
ARM: OMAP: clock.c: included linux/debugfs.h twice
ARM: OMAP: don't build hwspinlock in vain
ARM: OMAP2+: ads7846_init: put gpio_pendown into pdata if it's provided
git://gitorious.org/linux-davinci/linux-davinci into next/drivers
* 'v3.4/features' of git://gitorious.org/linux-davinci/linux-davinci:
* included from the davinci/cleanup branch:
ARM: davinci: dm644x: don't force vpfe registeration on all boards
ARM: davinci: dm644x: fix inconsistent variable naming
ARM: davinci: dm644x: improve readability using macro
ARM: davinci: streamline sysmod access
ARM: davinci: create new common platform header for davinci
ARM: davinci: dm646x: move private definitions to C file
ARM: davinci: dm365: move private definitions to C file
ARM: davinci: dm644x: move private definitions to C file
arch/arm/mach-davinci/board-dm644x-evm.c
arch/arm/mach-davinci/board-neuros-osd2.c
arch/arm/mach-davinci/board-sffsdr.c
next/fixes-non-critical
* 'fixes' of git://gitorious.org/linux-davinci/linux-davinci: (2 commits)
(update to v3.3-rc7)
All callers (board-mityomapl138.c and board-da850-evm.c) use it in
__init functions only.
This fixes:
WARNING: vmlinux.o(.text+0xd664): Section mismatch in reference from the function da850_register_pm() to the function .init.text:da8xx_get_mem_ctlr()
The function da850_register_pm() references
the function __init da8xx_get_mem_ctlr().
This is often because da850_register_pm lacks a __init
annotation or the annotation of da8xx_get_mem_ctlr is wrong.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
This fixes:
arch/arm/mach-davinci/cpufreq.c: In function davinci_target:
arch/arm/mach-davinci/cpufreq.c:98: warning: passing argument 2 of dev_printk from incompatible pointer type
This patch adds support for V4L2 video display to DM6446 EVM.
Support for SD and ED modes is provided, along with composite
and component outputs.
Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com>
Add functions to register various video devices like venc, osd,
vpbe and the v4l2 display driver for dm644x.
Change dm644x_init_video() to make room for display related
configuration. Register the vpfe or vpbe devices only if valid
display configuration is provided to make sure boards without
video support dont erroneously register video devices.
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup
* 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
ARM: OMAP2+: Fix L4_EMU_34XX_BASE error after iomap changes
ARM: OMAP2+: Limit omap_read/write usage to legacy USB drivers
ARM: OMAP: Remove plat/io.h by splitting it into mach/io.h and mach/hardware.h
ARM: OMAP2+: Move most of plat/io.h into local iomap.h
ARM: OMAP1: Move most of plat/io.h into local iomap.h
ARM: OMAP1: Move 16xx GPIO system clock to platform init code
ARM: OMAP: Move omap_init_consistent_dma_size() to local common.h
ARM: OMAP2+: Move SDRC related functions from io.h into local common.h
ARM: OMAP2+: Drop DISPC L3 firewall code
ARM: OMAP2xxx: PM: remove obsolete timer disable code in the suspend path
ARM: OMAP: McSPI: Remove unused flag from struct omap2_mcspi_device_config
(update to latest rmk/for-arm-soc branch)
* davinci/cleanups:
ARM: davinci: add back dummy header files
The mach/dm365.h and mach/dm646xh headers are currently being included
in some device drivers. The removal of those includes is already merged
in some subsystem trees, but adding the dummy files ensures that this
branch can be built standalone.
into next/fixes-non-critical
* 'v3.4/fixes' of git://gitorious.org/linux-davinci/linux-davinci:
ARM: davinci: map default_queue to edma channels
into next/cleanup
* 'imx-cleanup' of git://git.pengutronix.de/git/imx/linux-2.6: (247 commits)
ARM: Remove redundant ';' from avic_irq_set_priority()
ARM: mx3: Let mx31 and mx35 share the same CCM header file
ARM: plat-mxc: audmux-v1: Remove unneeded ifdef's
Update to v3.3-rc3
Move all vpfe platform device registrations to the board specific
file.
This removes registration of vpfe platform devices on boards which
do not use vpfe.
Add dm644x_ prefix to names of v4l2 variables in dm644x.c
Add dm644xevm_ prefix to names of v4l2 variables in board-dm644x-evm.c.
This makes the code consistent with rest of these files.
Replace the VPSS base address "magic number" with the
define "DM644X_VPSS_BASE" to improve readability.
While at it, fix the indentation done using spaces in
this part of code.
There are instances of IO_ADDRESS() being used for system module
(sysmod) register access. Eliminate this in favor of a ioremap()
based access. ioremap() the entire sysmod address space once during
boot-up and provide a helper macro to access specific register
offsets within the address space.
With this, also eliminate ioremap() of specific sysmodule registers
related to VPIF happening in DM646x EVM code.
While at it, also eliminate some duplicate sysmod register offset macros
defined in code and place offset definitions at one place in davinci.h
[nsekhar@ti.com: removed the addition of ifndef __ASSEMBLER__
in davinci.h, eliminate IO_ADDRESS() usage left out in dm646x.c,
cleanup VPIF sysmodule register access as part of this patch and
keep all sysmod offsets in davinci.h Also, convert the WARN_ON()
on failure to setup sysmod base to BUG_ON()]
Remove individual platform header files for dm365, dm355, dm644x
and dm646x and consolidate it into a single and common
header file davinci.h placed in arch/arm/mach-davinci.
This reduces the pollution in the include/mach and is consistent
with Russell's suggestions as part of his "pet peaves" mail.
(See #4 in: http://lists.infradead.org/pipermail/linux-arm-kernel/2011-November/071516.html)
While at it, fix the forward declaration of spi_board_info,
and include the right header file instead.
The further patches in the series take advantage of this consolidation
for easy implementation of IO_ADDRESS elimination.
[nsekhar@ti.com: make davinci.h the first local include file,
fix forward declaration of spi_board_info and add back Deep Root
Systems, LLC copyright]
into for-armsoc
* lpc32xx/drivers: (566 commits)
ARM: LPC32xx: ADC support for mach-lpc32xx
Includes an update to Linux 3.3-rc4
Now that most platforms don't need disable_fiq and arch_ret_to_user
macros, we can remove the empty macros or empty entry-macro.S files.
Acked-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: Nicolas Pitre <nico@linaro.org>
Acked-by: Ryan Mallon <rmallon@gmail.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Davinci has its own sched_clock() implementation, which gets in the
way of a single zImage. Moving to the common sched_clock framework
makes the code slightly cleaner.
Acked-by: Sekhar Nori <nsekhar@ti.com>
Cc: Kevin Hilman <khilman@ti.com>
Rearrange header files to keep related header files
together.
Default queue is expected to be a low-priority queue.
This way, long transfers on the default queue started
by the codec engine will not cause audio defects.
Signed-off-by: Juha Kuikka <juha.kuikka@gmail.com>
Reported-by: Juha Kuikka <juha.kuikka@gmail.com>
Acked-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com>
Cc: linux-mmc@vger.kernel.org
Cc: davinci-linux-open-source@linux.davincidsp.com
Cc: Rajashekhara, Sudhakar <sudhakar.raj@ti.com>
Cc: Ido Yariv <ido@wizery.com>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Sergei Shtylyov <sshtylyov@mvista.com>
Commit 5a05a8200a4359ef2bfe9094c137dee35cfdd516 ("davinci_emac:
use an unique MDIO bus name") introduced during the v3.3 merge
window updated the davinci mdio bus name to make it unique.
Update the bus name in board files which use DaVinci MDIO bus
to match the new name. Without this PHY is not detected with
error like:
PHY 0:01 not found
net eth0: could not connect to phy 0:01
Tested on DM365 and DA850 EVMs.
Cc: Florian Fainelli <florian@openwrt.org>
When this is the only content remaining in mach/system.h then the
whole file is removed.
Signed-off-by: Nicolas Pitre <nicolas.pitre@linaro.org>
Acked-and-tested-by: Jamie Iles <jamie@jamieiles.com>
Acked-by: David Brown <davidb@codeaurora.org>
Move register base addresses and offsets used only in dm646x.c
from arch/arm/mach-davinci/include/mach/dm646x.h in to the C
file as these definitions are used only in C file.
This helps reduce code in arch/arm/mach-davinci/include/mach/
which is not really needed by rest of the kernel.
Move register base addresses and offsets used only in dm365.c
from arch/arm/mach-davinci/include/mach/dm365.h in to the C
Move register base addresses and offsets used only by dm644x.c
from arch/arm/mach-davinci/include/mach/dm644x.h to the C file
as these definitions are used only there.
DA850: sysclk4-7 only exist for pll0. for pll1 sysclk1-3 exist.
Remove the non-existing clocks.
Signed-off-by: Bas van den Berg <b.van.den.berg.nl@gmail.com>
MTD pull for 3.3
* tag 'for-linus-3.3' of git://git.infradead.org/mtd-2.6: (113 commits)
mtd: Fix dependency for MTD_DOC200x
mtd: do not use mtd->block_markbad directly
logfs: do not use 'mtd->block_isbad' directly
mtd: introduce mtd_can_have_bb helper
mtd: do not use mtd->suspend and mtd->resume directly
mtd: do not use mtd->lock, unlock and is_locked directly
mtd: do not use mtd->sync directly
mtd: harmonize mtd_writev usage
mtd: do not use mtd->lock_user_prot_reg directly
mtd: mtd->write_user_prot_reg directly
mtd: do not use mtd->read_*_prot_reg directly
mtd: do not use mtd->get_*_prot_info directly
mtd: do not use mtd->read_oob directly
mtd: mtdoops: do not use mtd->panic_write directly
romfs: do not use mtd->get_unmapped_area directly
mtd: do not use mtd->get_unmapped_area directly
mtd: do use mtd->point directly
mtd: introduce mtd_has_oob helper
mtd: mtdcore: export symbols cleanup
mtd: clean-up the default_mtd_writev function
Fix up trivial edit/remove conflict in drivers/staging/spectra/lld_mtd.c
New feature development
This adds support for new features, and contains stuff from most
platforms. A number of these patches could have fit into other
branches, too, but were small enough not to cause too much
confusion here.
* tag 'devel' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (28 commits)
mfd/db8500-prcmu: remove support for early silicon revisions
ARM: ux500: fix the smp_twd clock calculation
ARM: ux500: remove support for early silicon revisions
ARM: ux500: update register files
ARM: ux500: register DB5500 PMU dynamically
ARM: ux500: update ASIC detection for U5500
ARM: ux500: support DB8520
ARM: picoxcell: implement watchdog restart
ARM: OMAP3+: hwmod data: Add the default clockactivity for I2C
ARM: OMAP3: hwmod data: disable multiblock reads on MMC1/2 on OMAP34xx/35xx <= ES2.1
ARM: OMAP: USB: EHCI and OHCI hwmod structures for OMAP4
ARM: OMAP: USB: EHCI and OHCI hwmod structures for OMAP3
ARM: OMAP: hwmod data: Add support for AM35xx UART4/ttyO3
ARM: Orion: Remove address map info from all platform data structures
ARM: Orion: Get address map from plat-orion instead of via platform_data
ARM: Orion: mbus_dram_info consolidation
ARM: Orion: Consolidate the address map setup
ARM: Kirkwood: Add configuration for MPP12 as GPIO
ARM: Kirkwood: Recognize A1 revision of 6282 chip
ARM: ux500: update the MOP500 GPIO assignments
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
arch/arm/mach-at91/at91cap9.c
arch/arm/mach-at91/at91sam9260.c
arch/arm/mach-at91/at91sam9261.c
arch/arm/mach-at91/at91sam9263.c
arch/arm/mach-at91/at91sam9g45.c
arch/arm/mach-at91/at91sam9rl.c
arch/arm/mach-exynos/cpu.c
arch/arm/mach-shmobile/board-kota2.c
This resolves a bunch of conflicts between the arm-soc tree
and changes from the arm tree that have gone upstream.
Remove the now empty arch_reset() from all the mach/system.h includes,
and remove its callsite. Remove arm_machine_restart() as this function
no longer does anything useful.
For samsung platforms, remove the include of mach/system-reset.h and
plat/system-reset.h from their respective mach/system.h headers as these
just define their arch_reset functions. As a result, the s3c2410 and
plat-samsung system-reset.h files are no longer referenced, so remove
these files entirely.
Rather than using DaVinci specific davinci_soc_info based
restart hook, use the restart hook available in the machine
descriptor instead.
Tested on DM365 and AM18x EVMs.
v2:
Changed to use restart hook in machine descriptor
per Russell's comment.
* picoxcell/cleanup: (4 commits)
MAINTAINERS: add maintainer entry for Picochip picoxcell
ARM: picoxcell: move io mappings to common.c
ARM: picoxcell: don't reserve irq_descs
ARM: picoxcell: remove mach/memory.h
arch/arm/mach-at91/setup.c
* picoxcell/devel: (1 commit)
* davinci/features:
ARM: davinci: add support for multiple power domains
Current partition information maintained in kernel does not match with
u-boot, this leads to corruption of u-boot env when we update uImage
from kernel. Patch fixes it to match with u-boot partition information.
Signed-off-by: Shankarmurthy,Akshay <akshay.s@ti.com>
On OMAP-L138 platform, EDMA event queue 0 should be used for audio
transfers so that they are not starved by video data moving on event queue 1.
Commit 48519f0ae03bc7e86b3dc93e56f1334d53803770 (ASoC: davinci: let platform
data define edma queue numbers) had a side-effect of changing this behavior
by making the driver actually honor the platform data passed.
Fix this now by passing event queue 0 as the queue to be used for audio
transfers.
Signed-off-by: Manjunathappa, Prakash <prakash.pm@ti.com>
Cc: <stable@vger.kernel.org> # v2.6.36.x and above
The function setup_vpif_input_channel_mode() used the VSCLKDIS register
instead of VIDCLKCTL. This meant that when in HD mode videoport channel 0
used a different clock from channel 1.
Clearly a copy-and-paste error.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Manjunath Hadli <manjunath.hadli@ti.com>
Cc: stable@kernel.org
Fix the incorrect classification of DSP clock into a
seperate DSP domain on DM646x.
Per the reference guide (http://www.ti.com/lit/ug/spruep9e/spruep9e.pdf)
there is only one "AlwaysON" power domain on DM6467.
Seperate PDSTAT and PDCTL registers are defined for
domain 0 and domain 1 where as the code always reads
the domain 0 PDSTAT register and domain 1 PDCTL register.
Fix this issue. While at it, introduce usage of macros
for register masks to improve readability.
Reviewed-by: Sergei Shtylyov <sshtylyov@mvista.com>
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
