path: root/arch/arm/mach-davinci/clock.h
2011-07-26Merge branch 'next/devel' of ↵Linus Torvalds
ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/devel' of ssh://master.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: (128 commits) ARM: S5P64X0: External Interrupt Support ARM: EXYNOS4: Enable MFC on Samsung NURI ARM: EXYNOS4: Enable MFC on universal_c210 ARM: S5PV210: Enable MFC on Goni ARM: S5P: Add support for MFC device ARM: EXYNOS4: Add support FIMD on SMDKC210 ARM: EXYNOS4: Add platform device and helper functions for FIMD ARM: EXYNOS4: Add resource definition for FIMD ARM: EXYNOS4: Change devname for FIMD clkdev ARM: SAMSUNG: Add IRQ_I2S0 definition ARM: SAMSUNG: Add platform device for idma ARM: EXYNOS4: Add more registers to be saved and restored for PM ARM: EXYNOS4: Add more register addresses of CMU ARM: EXYNOS4: Add platform device for dwmci driver ARM: EXYNOS4: configure rtc-s3c on NURI ARM: EXYNOS4: configure MAX8903 secondary charger on NURI ARM: EXYNOS4: configure ADC on NURI ARM: EXYNOS4: configure MAX17042 fuel gauge on NURI ARM: EXYNOS4: configure regulators and PMIC(MAX8997) on NURI ARM: EXYNOS4: Increase NR_IRQS for devices with more IRQs ... Fix up tons of silly conflicts: - arch/arm/mach-davinci/include/mach/psc.h - arch/arm/mach-exynos4/Kconfig - arch/arm/mach-exynos4/mach-smdkc210.c - arch/arm/mach-exynos4/pm.c - arch/arm/mach-imx/mm-imx1.c - arch/arm/mach-imx/mm-imx21.c - arch/arm/mach-imx/mm-imx25.c - arch/arm/mach-imx/mm-imx27.c - arch/arm/mach-imx/mm-imx31.c - arch/arm/mach-imx/mm-imx35.c - arch/arm/mach-mx5/mm.c - arch/arm/mach-s5pv210/mach-goni.c - arch/arm/mm/Kconfig
2011-07-08davinci: enable forced transitions on PSCSekhar Nori
Some DaVinci modules like the SATA on DA850 need forced module state transitions. Define a "force" flag which can be passed to the PSC config function to enable it to make forced transitions. Forced transitions shouldn't normally be attempted, unless the TRM explicitly specifies its usage. ChangeLog: v2: Modified to take care of the fact that davinci_psc_config() now takes the flags directly. Signed-off-by: Sekhar Nori <nsekhar@ti.com>
2011-07-06davinci: dm6467/T EVM: fix setting up of reference clock rateSekhar Nori
The DM6467 and DM6467T EVMs use different reference clock frequencies. This difference is currently supported by having the SoC code call a public board routine which sets up the reference clock frequency. This does not scale as more boards are added. Instead, use the clk_set_rate() API to setup the reference clock frequency to a different value from the board file. Suggested-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Sekhar Nori <nsekhar@ti.com> Acked-by: Kevin Hilman <khilman@ti.com>
2010-11-26ARM: 6483/1: arm & sh: factorised duplicated clkdev.cJean-Christop PLAGNIOL-VILLARD
factorise some generic infrastructure to assist looking up struct clks for the ARM & SH architecture. as the code is identical at 99% put the arch specific code for allocation as example in asm/clkdev.h Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-09-24davinci: clock: add support for setting sysclk rateSekhar Nori
Setting sysclk rate will be useful in cases where the sysclk is not at a fixed ratio to the PLL output but can asynchronously be changed. This support forms the basis of attempt to keep the AEMIF clock constant on OMAP-L138 even as PLL0 output changes as ARM clock is changed to save power. This patch has been tested on OMAP-L138. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-05-06Davinci: watchdog reset separation across socsCyril Chemparathy
The earlier watchdog reset mechanism had a couple of limitations. First, it embedded a reference to "davinci_wdt_device" inside common code. This forced all derived platforms (da8xx and tnetv107x) to define such a device. This also would have caused problems in including multiple socs in a single build due to symbol redefinition. With this patch, davinci_watchdog_reset() now takes the platform device as an argument. The davinci_soc_info struct has been extended to include a reset function and a watchdog platform_device. arch_reset() then uses these elements to reset the system in a SoC specific fashion. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Tested-by: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-05-06Davinci: configurable pll divider maskCyril Chemparathy
This patch allows socs to override the divider ratio mask by setting an optional field (div_ratio_mask) in the pll_data structure. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Tested-by: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-05-06Davinci: support LPSC SwRstDisable stateCyril Chemparathy
The current clock control code always gates the clock (PSC state Disable = 2) on clk_disable(). Some on-chip peripherals (e.g. LCD controller on TNETV107X) need to be put into SwRstDisable = 0 on clock disable, to maintain hardware sanity. This patch extends the davinci_psc_config() arguments to pass in the desired module state instead of a boolean enable/disable. Further, clk_disable() now checks for the PSC_SWRSTDISABLE clk flag before selecting the target state. Signed-off-by: Cyril Chemparathy <cyril@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-02-04davinci: clkdev cleanup: remove clk_lookup wrapper, use clkdev_add_table()Kevin Hilman
Remove unneeded 'struct davinci_clk' wrapper around 'struct clk_lookup' and use clkdev_add_table() to add the list of clocks in one go. Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-02-04davinci: make it possible to include clock.h and psc.h in assembly codeSekhar Nori
psc.h contains register defines for PSC module which need to be accessed in assembly code which helps the DA850/OMAP-L138 SoC go to sleep. Shutting down DDR clock using PSC is a part of the sleep procedure. Also, the PLL related hardware definitions in clock.h are needed in assembly code to bypass the DDR2 PLL. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2010-02-04davinci: move PLL wait time values to clock.hSekhar Nori
As suspend support is added, the code supporting the suspend operation needs to bypass PLLs and needs to access the same wait time values as the PLL code in clock.c. To facilitate this, move the PLL wait times to clock.h where they can be accessed by suspend code. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-11-25davinci: DA8xx: rename 'psc_ctlr' field into 'gpsc'Sergei Shtylyov
Replace badly chosen 'psc_ctlr' name of the 'struct clk' field (PSC already means "Power and Sleep Controller", so the '_ctlr' postfix makes the name tautological) with technically correct 'gpsc' (Global PSC -- which contains all the module registers). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-11-25davinci: DA850/OMAP-L138: allow async3 source to be changedSekhar Nori
The patch allows Async3 clock source to be selected between PLL1 SYSCLK2 and PLL0 SYSCLK2. Having Async3 source from PLL1 SYSCLK2 allows peripherals on that domain to remain unaffected by frequency scaling on PLL0. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-11-25davinci: support changing the clock rate in clock frameworkSekhar Nori
clk_round_rate, clk_set_rate have been updated to handle dynamic frequency changes. The motivation behind the changes is to support dynamic CPU frequency change. davinci_set_pllrate() changes the PLL rate of a given PLL. This function has been presented as a generic function though it has been tested only on OMAP-L138 EVM. No other currently available DaVinci device will probably use this function, but any future device specific changes will hopefully be small enough to get taken care using a cpu_is_xxx() macro. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-11-25davinci: make clock rate re-calculation easySekhar Nori
Make clock rate recalculation easy by having a re-calculate function for each clock. The existing functions for calculation of output rates of PLL and PLL-derived sysclks have been convered to the new re-calculate API. A new function is introduced to take care of rate (re)calculation for leaf clocks. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-11-25davinci: enable easy top down traversal of clock treeSekhar Nori
Achieve easy top down traversal of clock tree by keeping track of each clock's list of children. This is useful in supporting DVFS where clock rates of all children need to be updated in an efficient manner. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-05-26davinci: Add support for multiple PSCsMark A. Greer
The current code to support the DaVinci Power and Sleep Controller (PSC) assumes that there is only one controller. This assumption is no longer valid so expand the support to allow greater than one PSC. To accomplish this, put the base addresses for the PSCs in the SoC infrastructure so it can be referenced by the PSC code. This also requires adding an extra parameter to davinci_psc_config() to specify the PSC that is to be enabled/disabled. Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-05-26davinci: add platform support for watchdog timerKevin Hilman
2009-04-23davinci: major rework of clock, PLL, PSC infrastructureKevin Hilman
This is a significant rework of the low-level clock, PLL and Power Sleep Controller (PSC) implementation for the DaVinci family. The primary goal is to have better modeling if the hardware clocks and features with the aim of DVFS functionality. Highlights: - model PLLs and all PLL-derived clocks - model parent/child relationships of PLLs and clocks - convert to new clkdev layer - view clock frequency and refcount via /proc/davinci_clocks Special thanks to significant contributions and testing by David Brownell. Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2007-07-12[ARM] 4430/1: davinci: clock control supportVladimir Barinov
Support clock control driver for TI DaVinci SoC Signed-off-by: Vladimir Barinov <vbarinov@ru.mvista.com> Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
