path: root/arch/arm/mach-davinci/board-dm644x-evm.c
2009-09-16davinci: DM644x platform changes for vpfe captureMuralidharan Karicheri
DM644x platform and board setup This adds platform and board setup changes required to support vpfe capture driver on DM644x Tested video capture on DM6446 with tvp514x driver Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Reviewed-by: Laurent Pinchart <laurent.pinchart@skynet.be> Reviewed-by: David Brownell <david-b@pacbell.net> Signed-off-by: Muralidharan Karicheri <m-karicheri2@ti.com> Signed-off-by: Denys Dmytriyenko <denis@denix.org> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-08-26davinci: audio: move tlv320aic33 i2c setup into board filesChaithrika U S
Tested on DM6446, DM355, DM6447, DA850 EVMs. Signed-off-by: Chaithrika U S <chaithrika@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-08-26davinci: audio clocks: use struct device instead of clock namesKevin Hilman
There is no need to pass clock name strings in platform_data. Instead, setup clkdev nodes to have correct ASoC device names. Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-08-26davinci: ASoC: Add the platform devices for ASPChaithrika U S
1) Registers the platform devices for ASP on dm355, dm644x and dm646x so that the machine driver can probe to get ASP related platform data. 2) Move towards definition of the asp clocks using physical name(for dm355 and dm644x) 3) Add platform data to board specific files. Signed-off-by: Naresh Medisetty <naresh@ti.com> Signed-off-by: Chaithrika U S <chaithrika@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-07-25ARM: includecheck fix: board-dm644x-evm.cJaswinder Singh Rajput
fix the following 'make includecheck' warning: arch/arm/mach-davinci/board-dm644x-evm.c: mach/common.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-05-28davinci: Factor out emac mac address handlingMark A. Greer
Factor out the code to extract that mac address from i2c eeprom. Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-05-28davinci: Move emac platform_data to SoC-specific filesMark A. Greer
Since most of the emac platform_data is really SoC specific and not board specific, move it to the SoC-specific files. Put a pointer to the platform_data in the soc_info structure so the board-specific code can set some of the platform_data if it needs to. Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-05-26davinci: Encapsulate SoC-specific data in a structureMark A. Greer
Create a structure to encapsulate SoC-specific information. This will assist in generalizing code so it can be used by different SoCs that have similar hardware but with minor differences such as having a different base address. The idea is that the code for each SoC fills out a structure with the correct information. The board-specific code then calls the SoC init routine which in turn will call a common init routine that makes a copy of the structure, maps in I/O regions, etc. After initialization, code can get a pointer to the structure by calling davinci_get_soc_info(). Eventually, the common init routine will make a copy of all of the data pointed to by the structure so the original data can be made __init_data. That way the data for SoC's that aren't being used won't consume memory for the entire life of the kernel. The structure will be extended in subsequent patches but initially, it holds the map_desc structure for any I/O regions the SoC/board wants statically mapped. Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-05-26davinci: EMAC platform supportKevin Hilman
Add SoC and platform-specific data and init for DaVinci EMAC network driver. Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-05-26davinci: MMC platform supportKevin Hilman
Add SoC and platform-specific data and init for MMC driver. Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-05-07[ARM] 5506/1: davinci: DMA_32BIT_MASK --> DMA_BIT_MASK(32)Kevin Hilman
As per commit 284901a90a9e0b812ca3f5f852cbbfb60d10249d, use DMA_BIT_MASK(n) Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-04-27davinci: DM644x: NAND: update partitioningDavid Brownell
Update NAND partitioning for the dm6446 evm, unmasking the hidden data at the beginning and letting the kernel be updated from Linux. - This is boot-compatible with TI's software (U-Boot 1.20 and both the 2.6.10 and 2.6.18 kernels), in terms of startup and loading kernels from flash. - In the same way, it's also boot-compatible with mainline U-Boot, which stores U-Boot params in block 0 not block 16. - It's not quite compatible with systems that previously used NAND partitions to hold (filesystem) data. The compatibilities are a bit different based on which kernel was used previously + Users of TI/MV kernels no longer see mtd2 "params" (mainline u-boot env is in a different place) * Filesystem is now mtd2 ... vs mtd3 + Users of GIT kernels now see mtd0 and mtd1 partitions * Filesystem partition starts 640 KBytes earlier * Filesystem is now mtd2 ... vs mtd0 * Linux now *uses* the flash-resident BBT * Removes annoying slowdown/hiccup during boot * Potentially ~64KB less space available with TI/MV kernels If you *used* NAND partitions from Linux, there is no solution that's fully compatible with all previous kernels in those respects ... ergo this "best compromise". It'd be good to back back up the filesystem data; or, carry your own backwards-compatibility patch for awhile. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-04-27davinci: update DM644x support in preparation for more SoCsKevin Hilman
Rework DM644x code into SoC specific and board specific parts. This is also to generalize the structure a bit so it's easier to add support for new SoCs in the DaVinci family. Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
2009-04-27davinci: DM644x: rename board fileKevin Hilman
Rename DM6446 EVM board file, no functional changes. Code is updated and reworked in following patch. Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
