Final version of the patch that adds support for RS485 communications to the atmel_serial driver.
The patch has been already sent and discussed on both linux-kernel and linux-arm-kernel mailing lists several times.
Many people collaborated to improve and test the code:
Tested-by: Sebastian Heutling <Sebastian.Heutling@who-ing.de>
Tested-by: Bernhard Roth <br@pwrnet.de>
Reviewed-by: Ryan Mallon <ryan@bluewatersys.com>
Signed-off-by: Claudio Scordino <claudio@evidence.eu.com>
Signed-off-by: Michael Trimarchi <michael@evidence.eu.com>
Signed-off-by: Rick Bronson <rick@efn.org>
Signed-off-by: Sebastian Heutling <Sebastian.Heutling@who-ing.de>
Disable the processor clock when the CPU is idle.
This saves much more power than merely entering 'Wait for Interrupt' mode.
Since JTAG-debugging doesn't work when the processor clock is switched off,
make it conditional on CONFIG_DEBUG_KERNEL.
Signed-off-by: Anders Larsen <al@alarsen.net>
Acked-by: Andrew Victor <avictor.za@gmail.com>
A bit in the at91sam9g10 identification number changed between Engineering
Sample and final product. This patch will identify both as being at91sam9g10.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Andrew Victor <linux@maxim.org.za>
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
arch/arm/Kconfig
arch/arm/mach-ux500/include/mach/debug-macro.S
Otherwise more complicated uart configuration won't be possible.
We can use r1 for tmp register for both head.S and debug.S.
NOTE: This patch depends on another patch to add the the tmp register
into all debug-macro.S files. That can be done with:
$ sed -i -e "s/addruart,rx|addruart, rx/addruart, rx, tmp/"
arch/arm/*/include/*/debug-macro.S
Some misspelled occurences of 'octet' and some comments were also fixed
as I was on it.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Jiri Kosina <trivial@kernel.org>
Cc: Joe Perches <joe@perches.com>
Cc: Junio C Hamano <gitster@pobox.com>
Add support for the Atmel AT572D940HF processor (DIOPSIS range).
This processor integrates an ARM926 core, a DSP and the SoC
peripherals usually found on an AT91 processor (USART, SSC, SPI, TWI,
CAN, etc)
Signed-off-by: Antonio R. Costa <costa.antonior@gmail.com>
Signed-off-by: Andrew Victor <linux@maxim.org.za>
Allow the use of another DMA controller driver in atmel-mci sd/mmc driver.
This adds a generic dma_slave pointer to the mci platform structure where
we can store DMA controller information. In atmel-mci we use information
provided by this structure to initialize the driver (with new helper
functions that are architecture dependant).
This also adds at32/avr32 chip modifications to cope with this new access
method.
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: <linux-mmc@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (51 commits)
Input: appletouch - give up maintainership
Input: dm355evm_kbd - switch to using sparse keymap library
Input: wistron_btns - switch to using sparse keymap library
Input: add generic support for sparse keymaps
Input: fix memory leak in force feedback core
Input: wistron - remove identification strings from DMI table
Input: psmouse - remove identification strings from DMI tables
Input: atkbd - remove identification strings from DMI table
Input: i8042 - remove identification strings from DMI tables
DMI: allow omitting ident strings in DMI tables
Input: psmouse - do not carry DMI data around
Input: matrix-keypad - switch to using dev_pm_ops
Input: keyboard - fix lack of locking when traversing handler->h_list
Input: gpio_keys - scan gpio state at probe and resume time
Input: keyboard - add locking around event handling
Input: usbtouchscreen - add support for ET&T TC5UH touchscreen controller
Input: xpad - add two new Xbox 360 devices
Input: polled device - do not start polling if interval is zero
Input: polled device - schedule first poll immediately
Input: add S3C24XX touchscreen driver
into devel
Setup platform parameters in at91sam9rl-ek board to be passed to
atmel_tsadcc touchscreen.
cpu_is_xxx() macros are identifying generic at91sam9g45 chip. This patch adds
the capacity to differentiate Engineering Samples and final lots through the
inclusion of at91_cpu_fully_identify() and the related chip IDs with chip
version field preserved.
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
This is the at91 specific part of USB host integration. The EHCI high speed
controller has a companion OHCI controller to manage USB full and low speed.
They are sharing the same IRQ line and vbus pin.
drivers/staging/Kconfig
drivers/staging/Makefile
drivers/staging/cpc-usb/TODO
drivers/staging/cpc-usb/cpc-usb_drv.c
drivers/staging/cpc-usb/cpc.h
drivers/staging/cpc-usb/cpc_int.h
drivers/staging/cpc-usb/cpcusb.h
Created a modified version of the at91sam9g20 evaluation kit platform
(board-sam9g20ek-2slot-mmc.c) and device support to make use of the
updated atmel-mci driver.
As the use of two slots modify GPIO pin allocation, we create another
board file.
This requires getting the most updated arch/arm/tools/mach-types from
http://www.arm.linux.org.uk/developer/machines/download.php to have the machine
type for the at91sam9g20ek-2slot-mmc board.
[nicolas.ferre@atmel.com: printk, slot_count modification in at91sam9260_devices.c file]
Signed-off-by: Rob Emanuele <rob@emanuele.us>
Cc: Andrew Victor <linux@maxim.org.za>
This patch adds the device definition for the at91_can device to
the generic device definiton file for the at91sam9263.
Signed-off-by: Hans J. Koch <hjk@linutronix.de>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Acked-by: Wolfgang Grandegger <wg@grandegger.com>
MAINTAINERS
arch/arm/mm/fault.c
This patch modifies the support of AC97 on the at91sam9263 ek board, so it would
share the code with AVR32.
Plus it removes a typo in at91sam9263_devices.c.
Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
dmaengine: at_hdmac: add DMA slave transfers
dmaengine: at_hdmac: new driver for the Atmel AHB DMA Controller
dmaengine: dmatest: correct thread_count while using multiple thread per channel
dmaengine: dmatest: add a maximum number of test iterations
drivers/dma: Remove unnecessary semicolons
drivers/dma/fsldma.c: Remove unnecessary semicolons
dmaengine: move HIGHMEM64G restriction to ASYNC_TX_DMA
fsldma: do not clear bandwidth control bits on the 83xx controller
fsldma: enable external start for the 83xx controller
fsldma: use PCI Read Multiple command
It adds DMA peripheral identifiers for hardware handshaking interface. It will
be used in platform code.
This patch for at_hdmac adds the slave transfers capability to the Atmel DMA
controller available on some AT91 SOCs. This allow peripheral to memory and
memory to peripheral transfers with hardware handshaking.
Slave structure for controller specific information is passed through channel
private data. This at_dma_slave structure is defined in at_hdmac.h header file
and relative hardware definition are moved to this file from at_hdmac_regs.h.
Doing this we allow the channel configuration from platform definition code.
This work is intensively based on dw_dmac and several slave implementations.
This AHB DMA Controller (aka HDMA or DMAC on AT91 systems) is availlable on
at91sam9rl chip. It will be used on other products in the future.
This first release covers only the memory-to-memory tranfer type. This is the
only tranfer type supported by this chip. On other products, it will be used
also for peripheral DMA transfer (slave API support to come).
I used dmatest client without problem in different configurations to test it.
Full documentation for this controller can be found in the SAM9RL datasheet:
http://www.atmel.com/dyn/products/product_card.asp?part_id=4243
Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com>
AT91sam9g10 is an ARM 926ej-s SOC. It is an evolution of the at91sam9261 with a
faster clock speed: 266/133MHz.
Here is the basic header file support for this product.
Signed-off-by: Hong Xu <hong.xu@atmel.com>
Here are the at91 specific files dedicated to the at91sam9g45 series. They
mimic the traditional at91 way of managing chips & boards.
The first board that embeds at91sam9g45 chip is the AT91SAM9G45-EKES. In
the future, the main board for this 9g45 series will be the
AT91SAM9M10G45-EK (I choose this last name for the board file).
Simple drivers are enabled in _devices and board- files. Newer peripheral
support will be added in future patches.
Incuded peripherals support (for now):
- USART
- SPI
- Ethernet
- NAND flash
- LCD
- gpio/joystick/buttons
- leds and pwm
AT91sam9g45 series is an ARM 926ej-s SOC family clocked at 400/133MHz.
It embedds USB high speed host and device, LCD, DDR2 RAM, and a full set of
peripherals.
Here is the basic header file support for this product series.
In clock.c file the clock management is grouped by cpu with cpu_is_xxx()
function. This lead to some kind of difficulties to read this file and
maintainability issues as the number of AT91 cpus & PLLs/clocks is growing.
In this patch, I try to group clock functionality together and match cpus with
this functionality set.
An update to at91_pmc.h is needed to cover some new PMC possibilities (and
some update in comments).
The flexible array in the USBH platform data is not safe to copy. The
compiler will not allocate any extra memory for the non-init platform
data structure (in the *_devices.c files) since it isn't given any
defaults at compile time. When the probe function attempts to address
that array, it will actually attempt to access data in an adjacent
structure.
Since there are currently no (known) implementations of the at91 USBH
IP with more than 2 vbus pins, I am capping the value at 2. If somebody
tries to assign more, then the compiler will produce a warning.
Signed-off-by: Justin Waters <justin.waters@timesys.com>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
OMAP wishes to pass state to the boot loader upon reboot in order to
instruct it whether to wait for USB-based reflashing or not. There is
already a facility to do this via the reboot() syscall, except we ignore
the string passed to machine_restart().
This patch fixes things to pass this string to arch_reset(). This means
that we keep the reboot mode limited to telling the kernel _how_ to
perform the reboot which should be independent of what we request the
boot loader to do.
arch/arm/mach-at91/gpio.c
This is IDE host driver for AT91 (SAM9, CAP9, AT572D940HF) Static Memory
Controller with Compact Flash True IDE Mode logic.
Driver have to switch 8/16 bit bus width when accessing Task Tile or Data
Register. Moreover some extra things need to be done when setting PIO mode.
Only PIO mode is used, hardware have no DMA support. If interrupt line is
connected through GPIO extra quirk is needed to cope with fake interrupts.
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
Cc: Andrew Victor <avictor.za@gmail.com>
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
controller
Add support for inverted rdy_busy pin for Atmel nand device controller
It will fix building error on NeoCore926 board.
Acked-by: David Woodhouse <David.Woodhouse@intel.com>
Signed-off-by: Gregory CLEMENT <gclement@adeneo.adetelgroup.com>
Add support for gpiolib, including debugfs output, to the AT91 family.
The at91_get/set_gpio_value calls still exist since they are used by the
atmel serial driver.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
The AT91CAP9 revC CPU has a few differences over the previous,
revB CPU which was distributed in small quantities only (revA was
an internal Atmel product only).
This patch adds the detection routines to recognize the different
AT91CAP9 revisions (based on the PMC subsystem version number), and
uses them to:
- activate a workaround for the external interrupts levels
(on revB CPUs)
- set the UDPHS_BYPASS bit (on revB CPUs)
- set AT91_GPBR register address to the correct offset
(0xfffffd50 on revB, 0xfffffd60 on revC)
For debugging usage, the CPU revision can be found in /proc/cpuinfo
on the 'Revision' line.
This patch is extracted from Andrew Victor's -at91 patch (2.6.27-at91.patch)
where it has been tested for the last 6 months.
Signed-off-by: Stelian Pop <stelian@popies.net>
As Al did for Versatile in 2ad4f86b60b649fd7428265c08d73a3bd360c81b,
add a typesafe __io implementation for platforms to use. Convert
platforms to use this new simple typesafe implementation.
When ISA_DMA_API is unset, we're not implementing the ISA DMA API,
so there's no point in publishing the prototypes via asm/dma.h, nor
including the machine dependent parts of that API.
This allows us to remove a lot of mach/dma.h files which don't contain
any useful code. Unfortunately though, some platforms put their own
private non-ISA definitions into mach/dma.h, so we leave these behind
and fix the appropriate #include statments.
Let's provide an overridable default instead of having every machine
class define __virt_to_bus and __bus_to_virt to the same thing. What
most platforms are using is bus_addr == phys_addr so such is the default.
One exception is ebsa110 which has no DMA what so ever, so the actual
definition is not important except only for proper compilation. Also
added a comment about the special footbridge bus translation.
Let's also remove comments alluding to set_dma_addr which is not
(and should not) be commonly used.
Signed-off-by: Nicolas Pitre <nico@marvell.com>
According to the documentation gpio_free should only be called from task
context only. To make this more explicit add a might sleep to all
implementations.
This patch changes the gpio_free implementations for the arm architecture.
DaVinci is skipped on purpose to simplify the merge process for patches
switching it over to use gpiolib as per request by David Brownell.
Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de>
Cc: David Brownell <david-b@pacbell.net>
Add copyright information for some of the AT91 header files.
This patch adds initialization of the Touchscreen controller for the
AT91SAM9RL processor.
Signed-off-by: Dan Liang <dan.liang@atmel.com>
Use the PWM controller and leds-atmel-pwm.c driver to drive a LED on
the Atmel AT91SAM9263-EK board.
Add platform_devices and configuration of the PWM controller found on
Atmel AT91CAP9, SAM9263 and SAM9RL processors.
SAM9263 support by Sedji Gaouaou.
This just leaves include/asm-arm/plat-* to deal with.
