path: root/arch/arm/mach-at91/board-kafa.c
2007-11-26[ARM] 4650/1: AT91: New-style init of I2C, support for i2c-gpioAndrew Victor
The AT91 I2C driver is currently marked as "broken" due to hardware issues. This patch enables AT91-based platforms to also use the bitbanged GPIO for I2C. This updates platform setup logic (setting up an i2c-gpio device using the same pins as the i2c-at91 device, unless only the BROKEN driver is enabled). Also make use of the new-style initialization of I2C devices using i2c_register_board_info(). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-08[ARM] 4124/1: Rename mach-at91rm9200 and arch-at91rm9200 directoriesAndrew Victor
Now that Linux includes support for the Atmel AT91SAM9260 and AT91SAM9261 processors in addition to the original Atmel AT91RM9200 (with support for more AT91 processors pending), the "mach-at91rm9200" and "arch-at91rm9200" directories should be renamed to indicate their more generic nature. The following git commands should be run BEFORE applying this patch: git-mv arch/arm/mach-at91rm9200 arch/arm/mach-at91 git-mv include/asm-arm/arch-at91rm9200 include/asm-arm/arch-at91 Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
