we do not change the clock naming convention so does not need to switch
the AVR32 yet
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
specify the port num via platform_data this will allow to match the clock
with the plaform_dev staticaly
Acked-by: Alan Cox <alan@linux.intel.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Setup platform parameters in at91sam9rl-ek board to be passed to
atmel_tsadcc touchscreen.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Acked-by: Andrew Victor <linux@maxim.org.za>
Add the support of AC97 on the at91sam9rl chip and -ek board.
It will share the code with AVR32 ac97c alsa driver "atmel_ac97c".
This is the integration of DMA engine driver into at91sam9rl device file. The
associated driver is at_hdmac.
The recently merged AT91SAM9 watchdog driver uses the
AT91SAM9X_WATCHDOG config variable, whereas the original version of
the driver (and the platform support code) used AT91SAM9_WATCHDOG.
This causes the watchdog platform_device to never be registered, and
therefore the driver not to be initialized.
This patch:
- updates the platform support code to use AT91SAM9X_WATCHDOG.
- includes <linux/io.h> to fix compile error (same fix as was applied
to at91rm9200_wdt.c)
- fixes comment regarding watchdog clock-rates in at91rm9200.
Signed-off-by: Andrew Victor <linux@maxim.org.za>
In at91_add_device_nand(), do not configure the Static Memory
controller with specific timing values.
The *_devices.c files are board independent, and the SMC timing values
are specific to the NAND devices that are installed on the board.
The board-specific files are now responsible for configuring the
Static Memory controller (if the don't want to leave it up to a
bootloader).
This patch adds initialization of the Touchscreen controller for the
AT91SAM9RL processor.
Signed-off-by: Justin Waters <justin.waters@timesys.com>
Signed-off-by: Dan Liang <dan.liang@atmel.com>
Add platform_devices and configuration of the PWM controller found on
Atmel AT91CAP9, SAM9263 and SAM9RL processors.
SAM9263 support by Sedji Gaouaou.
This just leaves include/asm-arm/plat-* to deal with.
Structs called at91_nand_data where renamed to atmel_nand_data
and configs called *MTD_NAND_AT91* where renamed to
*MTD_NAND_ATMEL*. This was unfortunately not done consistently,
causing NAND chips not being initialised on several ARM boards.
I am aware that the author of the original change did not rename
MTD_NAND_AT91_BUSWIDTH to MTD_NAND_ATMEL_BUSWIDTH, for example.
All *MTD_NAND_AT91* where renamed to *MTD_NAND_ATMEL* in order
to keep naming consistency.
This patch was only tested on a MACH_SAM9_L9260, as this is the
only ARM board I have to my disposal.
Before this patch:
$ git-ls-files |xargs grep atmel_nand |wc -l
105
$ git-ls-files |xargs grep at91_nand |wc -l
4
$ git-ls-files |xargs grep MTD_NAND_ATMEL |wc -l
8
$ git-ls-files |xargs grep MTD_NAND_AT91 |wc -l
47
After this patch:
109
0
55
0
Signed-off-by: Pieter du Preez <pdupreez@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
New timings are based on application note
"NAND Flash Support on AT91SAM9 Microcontrollers" available at
http://atmel.com/dyn/resources/prod_documents/doc6255.pdf).
Signed-off-by: Patrice Vilchez <patrice.vilchez@atmel.com>
This is basically s/at91_nand/atmel_nand/g with some manual inspection.
Signed-off-by: Håvard Skinnemoen <haavard.skinnemoen@atmel.com>
Adds support for the USB High Speed Device Port on the AT91SAM9RL
system on chip. The AT91SAM9RL uses the same UDPHS IP as the AVR32 and
the AT91CAP9 (atmel_usba_udc driver).
Fix initialization of framebuffer not calling ioremap_writecombine() function
and not using internal SRAM for at91sam9rl.
This is a little rework of the "Don't initialize a pre-allocated framebuffer"
patch that corrects the call to ioremap_writecombine() function.
It also cuts the use of internal SRAM for at91sam9rl : it is a bit small
for a framebuffer.
Cc: Andrew Victor <linux@maxim.org.za>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
If the user specified a fixed framebuffer address on the command line, it may
have been initialized already with a splash image or something, so we
shouldn't clear it.
Therefore, we should only initialize the framebuffer if we allocated it
ourselves. This patch also updates the AVR32 setup code to clear the
framebuffer if it allocated it itself, i.e. the user didn't provide a fixed
address or the reservation failed.
I've updated the at91 platform code as well so that it initializes the
framebuffer if it is located in SRAM, but I haven't tested that it actually
works.
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Cc: Nicolas FERRE <nicolas.ferre@rfo.atmel.com>
Cc: Andrew Victor <andrew@sanpeople.com>
All the SAM9 boards supported by mainline and the AT91 patches have
been converted to the new-style UART initialization. Therefore drop
support for the old at91_init_serial() interface for SAM9.
at91_uarts[] array can also be marked as __initdata.
The warning that no serial-console is defined moved from
at91_set_serial_console() to at91_add_device_serial() since the whole
point is the board-specific file is not calling
at91_set_serial_console().
Register platform_devices for the Timer/Counter Block peripherals
found on the AT91RM9200, SAM9 & CAP9 processors.
Original patch from David Brownell.
The RTT-as-RTC driver will search for the user-specified RTT
peripheral via ID number (0 .. 1).
Therefore if the processor only contains a single RTT peripheral, we
need to set its platform_device.id to "0" instead of "-1".
Also add the missing platform_device resource for the CAP9 processor.
Bug reported by Sedji Gaouaou.
On AT91 processors that include an ECC controller, pass its base
address to the NAND driver via platform_device resources.
The AT91CAP9 processor includes the same Static Memory Controller
(SMC) peripheral as the SAM9 processors, but replaces the SDRAM
Controller with a DDR/SDR Controller (DDRSDRC).
This patch splits the existing
include/asm-arm/arch-at91/at91sam926x_mc.h into at91sam9_sdramc.h and
at91sam9_smc.h.
It also adds an at91cap9_ddrsdr.h for the DDRSDRC controller.
Move the LED initialization code out of the various *_devices.c files,
and into leds.c.
Also add support for NEW_LEDs.
Patch from David Brownell.
Modify the UART initialization to allow the board-initialization code
to specify which pins are connected, and which pins should therefore
be initialized.
The current at91_init_serial() will continue to work as-is, but is
marked as "deprecated" and will be removed once the board-specific
files has been updated to use the new interface.
As in the AVR32 code, we assume that the TX and RX pins will always be
initialized.
Core support of the Atmel SSC library for all Atmel AT91 processors.
Based on David Brownell's initial patch for the AT91RM9200.
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Replace hard-coded DMA mask (0xffffffff) with DMA_BIT_MASK(32) as
defined in dma-mapping.h.
Set "dma_mask" field for the UART platform_devices.
Add platform_device and initialization for the RTT (Real Time Timer)
and WDT (Watchdog) integrated in the Atmel AT91SAM9 processors.
For SAM9263, register both RTT peripherals.
[From: David Brownell <dbrownell@users.sourceforge.net>]
Provide platform_resources for RTT peripherals
Add support for RTC peripheral on AT91SAM9RL (same RTC peripherals as
AT91RM9200)
The AT91 I2C driver is currently marked as "broken" due to hardware
issues. This patch enables AT91-based platforms to also use the
bitbanged GPIO for I2C.
This updates platform setup logic (setting up an i2c-gpio device
using the same pins as the i2c-at91 device, unless only the BROKEN
driver is enabled).
Also make use of the new-style initialization of I2C devices using
i2c_register_board_info().
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Signed-off-by: Andrew Victor <andrew@sanpeople.com>
Define SZ_512, SZ_256 and SZ_16 in asm-arm/sizes.h.
Remove the definitions from the at91*_devices.c files.
(Dependent on ARM patch #4370/2)
Add support for Atmel's new AT91SAM9RL range of processors.
Includes similar peripherals as other AT91SAM9 processors, but with a
High-speed USB controller and various sizes of internal SRAM.
Signed-off-by: Nicolas Ferre <nicolas.ferre@rfo.atmel.com>
