Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Reviewed-by: Ryan Mallon <rmallon@gmail.com>
Cc: linux-usb@vger.kernel.org
Add parameter and change existing call in at91sam9263_devices.c.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Since 193ab2a6070039e7ee2b9b9bebea754a7c52fd1b, various AT91 boards don't
register at91_udc anymore due to depending on a now non-existing symbol.
Fix the symbol name.
Signed-off-by: Anders Darander <anders@chargestorm.se>
Cc: stable <stable@vger.kernel.org>
we will select now the DBGU used by the soc at Kconfig level
For the DEBUG_LL and early_printk this will allow to select which DBGU to use
this will also allow to select them when multiple SOC are enabled
switch the watchdog drivers to resource and pass it via platform_device
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Both at91 and avr32 defines its own platform data structure for
the macb driver and both share common structures though at91
includes a currently unused phy_irq_pin. Create a common
macb_platform_data for macb that both at91 and avr32 can use. In
future we can use this to support other architectures that use the
same IP block with the macb driver.
v2: rename eth_platform_data to macb_platform_data and allow at91_ether
to share the platform data with macb.
Signed-off-by: Jamie Iles <jamie@jamieiles.com>
Tested-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
In commit fb149f9e28354 we introduce ioremap support for static map_io, we do
not need this register entry anymore.
arch/arm/mach-mxs/include/mach/gpio.h
arch/arm/plat-mxc/include/mach/gpio.h
As a new overcurrent_pin[] array has been added to the at91_usbh_data
structure, those pins must be muxed to work properly. This commit
implements this muxing for all AT91 SoCs that support the AT91 OHCI.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
[nicolas.ferre@atmel.com: added i variable declaration for the loop]
Convert arch/arm includes of mach/gpio.h and asm/gpio.h to linux/gpio.h
before we start consolidating the individual platform implementations
of the gpio header files.
we do not change the clock naming convention so does not need to switch
the AVR32 yet
Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
specify the port num via platform_data this will allow to match the clock
with the plaform_dev staticaly
Acked-by: Alan Cox <alan@linux.intel.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
drivers/staging/Kconfig
drivers/staging/Makefile
drivers/staging/cpc-usb/TODO
drivers/staging/cpc-usb/cpc-usb_drv.c
drivers/staging/cpc-usb/cpc.h
drivers/staging/cpc-usb/cpc_int.h
drivers/staging/cpc-usb/cpcusb.h
This patch adds the device definition for the at91_can device to
the generic device definiton file for the at91sam9263.
Signed-off-by: Hans J. Koch <hjk@linutronix.de>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Acked-by: Wolfgang Grandegger <wg@grandegger.com>
This patch modifies the support of AC97 on the at91sam9263 ek board, so it would
share the code with AVR32.
Plus it removes a typo in at91sam9263_devices.c.
Signed-off-by: Sedji Gaouaou <sedji.gaouaou@atmel.com>
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
Cc: Andrew Victor <avictor.za@gmail.com>
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Acked-by: Andrew Victor <linux@maxim.org.za>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
The recently merged AT91SAM9 watchdog driver uses the
AT91SAM9X_WATCHDOG config variable, whereas the original version of
the driver (and the platform support code) used AT91SAM9_WATCHDOG.
This causes the watchdog platform_device to never be registered, and
therefore the driver not to be initialized.
This patch:
- updates the platform support code to use AT91SAM9X_WATCHDOG.
- includes <linux/io.h> to fix compile error (same fix as was applied
to at91rm9200_wdt.c)
- fixes comment regarding watchdog clock-rates in at91rm9200.
Signed-off-by: Andrew Victor <linux@maxim.org.za>
In at91_add_device_nand(), do not configure the Static Memory
controller with specific timing values.
The *_devices.c files are board independent, and the SMC timing values
are specific to the NAND devices that are installed on the board.
The board-specific files are now responsible for configuring the
Static Memory controller (if the don't want to leave it up to a
bootloader).
Add platform_devices and configuration of the PWM controller found on
Atmel AT91CAP9, SAM9263 and SAM9RL processors.
SAM9263 support by Sedji Gaouaou.
This just leaves include/asm-arm/plat-* to deal with.
Structs called at91_nand_data where renamed to atmel_nand_data
and configs called *MTD_NAND_AT91* where renamed to
*MTD_NAND_ATMEL*. This was unfortunately not done consistently,
causing NAND chips not being initialised on several ARM boards.
I am aware that the author of the original change did not rename
MTD_NAND_AT91_BUSWIDTH to MTD_NAND_ATMEL_BUSWIDTH, for example.
All *MTD_NAND_AT91* where renamed to *MTD_NAND_ATMEL* in order
to keep naming consistency.
This patch was only tested on a MACH_SAM9_L9260, as this is the
only ARM board I have to my disposal.
Before this patch:
$ git-ls-files |xargs grep atmel_nand |wc -l
105
$ git-ls-files |xargs grep at91_nand |wc -l
4
$ git-ls-files |xargs grep MTD_NAND_ATMEL |wc -l
8
$ git-ls-files |xargs grep MTD_NAND_AT91 |wc -l
47
After this patch:
109
0
55
0
Signed-off-by: Pieter du Preez <pdupreez@gmail.com>
New timings are based on application note
"NAND Flash Support on AT91SAM9 Microcontrollers" available at
http://atmel.com/dyn/resources/prod_documents/doc6255.pdf).
Signed-off-by: Patrice Vilchez <patrice.vilchez@atmel.com>
This is basically s/at91_nand/atmel_nand/g with some manual inspection.
Signed-off-by: Håvard Skinnemoen <haavard.skinnemoen@atmel.com>
typo in mci configuration in devices files
All the SAM9 boards supported by mainline and the AT91 patches have
been converted to the new-style UART initialization. Therefore drop
support for the old at91_init_serial() interface for SAM9.
at91_uarts[] array can also be marked as __initdata.
The warning that no serial-console is defined moved from
at91_set_serial_console() to at91_add_device_serial() since the whole
point is the board-specific file is not calling
at91_set_serial_console().
Register platform_devices for the Timer/Counter Block peripherals
found on the AT91RM9200, SAM9 & CAP9 processors.
Original patch from David Brownell.
On AT91 processors that include an ECC controller, pass its base
address to the NAND driver via platform_device resources.
The AT91CAP9 processor includes the same Static Memory Controller
(SMC) peripheral as the SAM9 processors, but replaces the SDRAM
Controller with a DDR/SDR Controller (DDRSDRC).
This patch splits the existing
include/asm-arm/arch-at91/at91sam926x_mc.h into at91sam9_sdramc.h and
at91sam9_smc.h.
It also adds an at91cap9_ddrsdr.h for the DDRSDRC controller.
Move the LED initialization code out of the various *_devices.c files,
and into leds.c.
Also add support for NEW_LEDs.
Patch from David Brownell.
Modify the UART initialization to allow the board-initialization code
to specify which pins are connected, and which pins should therefore
be initialized.
The current at91_init_serial() will continue to work as-is, but is
marked as "deprecated" and will be removed once the board-specific
files has been updated to use the new interface.
As in the AVR32 code, we assume that the TX and RX pins will always be
initialized.
Map the complete memory region (SZ_256M) as is done on the other AT91
processors.
The SMC_SMARTMEDIA bit should be set in the EBI controller to enable
the hardware NAND logic.
(Patch from Sascha Erlacher)
Core support of the Atmel SSC library for all Atmel AT91 processors.
Based on David Brownell's initial patch for the AT91RM9200.
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Replace hard-coded DMA mask (0xffffffff) with DMA_BIT_MASK(32) as
defined in dma-mapping.h.
Set "dma_mask" field for the UART platform_devices.
Add platform_device and initialization for the RTT (Real Time Timer)
and WDT (Watchdog) integrated in the Atmel AT91SAM9 processors.
For SAM9263, register both RTT peripherals.
[From: David Brownell <dbrownell@users.sourceforge.net>]
Provide platform_resources for RTT peripherals
Add support for RTC peripheral on AT91SAM9RL (same RTC peripherals as
AT91RM9200)
Add support for the Image Sensor Interface (ISI) peripheral integrated
in the Atmel AT91SAM9263 processor.
Patch from MaLiK
The AT91 I2C driver is currently marked as "broken" due to hardware
issues. This patch enables AT91-based platforms to also use the
bitbanged GPIO for I2C.
This updates platform setup logic (setting up an i2c-gpio device
using the same pins as the i2c-at91 device, unless only the BROKEN
driver is enabled).
Also make use of the new-style initialization of I2C devices using
i2c_register_board_info().
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Signed-off-by: Andrew Victor <andrew@sanpeople.com>
- Include atmel_lcdc.h in at91sam926{1,3}_devices.c
Signed-off-by: Jan Altenberg <jan.altenberg@linutronix.de>
Define SZ_512, SZ_256 and SZ_16 in asm-arm/sizes.h.
Remove the definitions from the at91*_devices.c files.
(Dependent on ARM patch #4370/2)
Define resources, platform_device and device registration functions for
the LCD and AC97 controllers on the AT91SAM9263.
Also update the AT91SAM9261 to use the common atmel_lcdfb driver.
Signed-off-by: Nicolas Ferre <nicolas.ferre@rfo.atmel.com>
The duplicate file "include/asm-arm/arch-at91rm9200/entry-macro.S" can
be removed - it was already moved to include/asm-arm/arch-at91/.
Fix 3 small typo's - two in comments, and the incorrect clock was
specified for the LCD device.
Add support for the Atmel AT91SAM9263 processor. It is similar to the
AT91SAM9260 but with more integrated peripherals, 5 GPIO banks, etc.
Original patch from Nicolas Ferre.
