commit 0e934e22f3fabb98c41737e2e30bd9db2668e935 upstream.
Since 193ab2a6070039e7ee2b9b9bebea754a7c52fd1b, various AT91 boards don't
register at91_udc anymore due to depending on a now non-existing symbol.
Fix the symbol name.
Signed-off-by: Anders Darander <anders@chargestorm.se>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
we do not change the clock naming convention so does not need to switch
the AVR32 yet
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Patrice Vilchez <patrice.vilchez@atmel.com>
specify the port num via platform_data this will allow to match the clock
with the plaform_dev staticaly
Acked-by: Alan Cox <alan@linux.intel.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Convert the following AT91RM9200-based boards to the new-style UART
initialization:
- Ajeco 1ARM Single Board Computer
- Sperry-Sun KAFA board
- picotux 200
Remove the deprecated at91_init_serial
Signed-off-by: Andrew Victor <linux@maxim.org.za>
This just leaves include/asm-arm/plat-* to deal with.
Structs called at91_nand_data where renamed to atmel_nand_data
and configs called *MTD_NAND_AT91* where renamed to
*MTD_NAND_ATMEL*. This was unfortunately not done consistently,
causing NAND chips not being initialised on several ARM boards.
I am aware that the author of the original change did not rename
MTD_NAND_AT91_BUSWIDTH to MTD_NAND_ATMEL_BUSWIDTH, for example.
All *MTD_NAND_AT91* where renamed to *MTD_NAND_ATMEL* in order
to keep naming consistency.
This patch was only tested on a MACH_SAM9_L9260, as this is the
only ARM board I have to my disposal.
Before this patch:
$ git-ls-files |xargs grep atmel_nand |wc -l
105
$ git-ls-files |xargs grep at91_nand |wc -l
4
$ git-ls-files |xargs grep MTD_NAND_ATMEL |wc -l
8
$ git-ls-files |xargs grep MTD_NAND_AT91 |wc -l
47
After this patch:
109
0
55
0
Signed-off-by: Pieter du Preez <pdupreez@gmail.com>
This is basically s/at91_nand/atmel_nand/g with some manual inspection.
Signed-off-by: Håvard Skinnemoen <haavard.skinnemoen@atmel.com>
All the SAM9 boards supported by mainline and the AT91 patches have
been converted to the new-style UART initialization. Therefore drop
support for the old at91_init_serial() interface for SAM9.
at91_uarts[] array can also be marked as __initdata.
The warning that no serial-console is defined moved from
at91_set_serial_console() to at91_add_device_serial() since the whole
point is the board-specific file is not calling
at91_set_serial_console().
Register platform_devices for the Timer/Counter Block peripherals
found on the AT91RM9200, SAM9 & CAP9 processors.
Original patch from David Brownell.
Due to errata regarding the handling of SPI CS0 on the AT91RM9200, the
atmel_spi driver drives CS0 from the SPI controller and not as a GPIO
pin.
We therefore need to configure CS0 for use by the controller
Move the LED initialization code out of the various *_devices.c files,
and into leds.c.
Also add support for NEW_LEDs.
Patch from David Brownell.
Modify the UART initialization to allow the board-initialization code
to specify which pins are connected, and which pins should therefore
be initialized.
The current at91_init_serial() will continue to work as-is, but is
marked as "deprecated" and will be removed once the board-specific
files has been updated to use the new interface.
As in the AVR32 code, we assume that the TX and RX pins will always be
initialized.
Map the complete memory region (SZ_256M) as is done on the other AT91
processors.
The SMC_SMARTMEDIA bit should be set in the EBI controller to enable
the hardware NAND logic.
(Patch from Sascha Erlacher)
Core support of the Atmel SSC library for all Atmel AT91 processors.
Based on David Brownell's initial patch for the AT91RM9200.
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Replace hard-coded DMA mask (0xffffffff) with DMA_BIT_MASK(32) as
defined in dma-mapping.h.
Set "dma_mask" field for the UART platform_devices.
The AT91 I2C driver is currently marked as "broken" due to hardware
issues. This patch enables AT91-based platforms to also use the
bitbanged GPIO for I2C.
This updates platform setup logic (setting up an i2c-gpio device
using the same pins as the i2c-at91 device, unless only the BROKEN
driver is enabled).
Also make use of the new-style initialization of I2C devices using
i2c_register_board_info().
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Signed-off-by: Andrew Victor <andrew@sanpeople.com>
Convert the AT91RM9200 platform-setup code to use the new atmel_spi
driver (and manually-driven chip-selects), instead of the legacy
AT91-only SPI stack.
The AT91SAM9 processors are already using the atmel_spi driver.
Define SZ_512, SZ_256 and SZ_16 in asm-arm/sizes.h.
Remove the definitions from the at91*_devices.c files.
(Dependent on ARM patch #4370/2)
The GPIO pin setup should be handed by the platform-setup code, and not
directly by the driver.
The Atmel AT91SAM9263 processor includes many more integrated
peripherals than Atmel's previous ARM9-based AT91 processors, so this
has necessitated a few changes to the core AT91 support.
These changes are:
* The system peripheral I/O region we remap has increased from
0xFFFA0000..0xFFFFFFFF to 0xFFF78000..0xFFFFFFFF.
* The increased I/O region forces changes to entry-macro.S and
debug-macro.S due to ARM's limited immediate offset addressing
modes.
* Maximum number of GPIO banks increases to 5.
* 2 MMC controllers so the board-setup code needs to specify which
controller it wishes to use when calling at91_add_device_mmc().
Original patch from Nicolas Ferre.
Now that Linux includes support for the Atmel AT91SAM9260 and
AT91SAM9261 processors in addition to the original Atmel AT91RM9200
(with support for more AT91 processors pending), the "mach-at91rm9200"
and "arch-at91rm9200" directories should be renamed to indicate their
more generic nature.
The following git commands should be run BEFORE applying this patch:
git-mv arch/arm/mach-at91rm9200 arch/arm/mach-at91
git-mv include/asm-arm/arch-at91rm9200 include/asm-arm/arch-at91
