path: root/arch/arm/kvm/mmio.c
2016-09-08arm/arm64: KVM: Remove external abort test from MMIO handlingMarc Zyngier
As we know handle external aborts pretty early, we can get rid of its handling in the MMIO code (which was a bit odd to begin with...). Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2016-05-20KVM: arm/arm64: Export mmio_read/write_busChristoffer Dall
Rename mmio_{read,write}_bus to kvm_mmio_{read,write}_bus and export them out of mmio.c. This will be needed later for the new VGIC implementation. Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Reviewed-by: Andre Przywara <andre.przywara@arm.com>
2016-05-20KVM: arm/arm64: Fix MMIO emulation data handlingChristoffer Dall
When the kernel was handling a guest MMIO read access internally, we need to copy the emulation result into the run->mmio structure in order for the kvm_handle_mmio_return() function to pick it up and inject the result back into the guest. Currently the only user of kvm_io_bus for ARM is the VGIC, which did this copying itself, so this was not causing issues so far. But with the upcoming new vgic implementation we need this done properly. Update the kvm_handle_mmio_return description and cleanup the code to only perform a single copying when needed. Code and commit message inspired by Andre Przywara. Reported-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Reviewed-by: Andre Przywara <andre.przywara@arm.com>
2016-02-24arm/arm64: KVM: Feed initialized memory to MMIO accessesMarc Zyngier
On an MMIO access, we always copy the on-stack buffer info the shared "run" structure, even if this is a read access. This ends up leaking up to 8 bytes of uninitialized memory into userspace, depending on the size of the access. An obvious fix for this one is to only perform the copy if this is an actual write. Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-12-14KVM: arm/arm64: Count guest exit due to various reasonsAmit Tomar
It would add guest exit statistics to debugfs, this can be helpful while measuring KVM performance. [ Renamed some of the field names - Christoffer ] Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-12-04arm64: KVM: Correctly handle zero register during MMIOPavel Fedin
On ARM64 register index of 31 corresponds to both zero register and SP. However, all memory access instructions, use ZR as transfer register. SP is used only as a base register in indirect memory addressing, or by register-register arithmetics, which cannot be trapped here. Correct emulation is achieved by introducing new register accessor functions, which can do special handling for reg_num == 31. These new accessors intentionally do not rely on old vcpu_reg() on ARM64, because it is to be removed. Since the affected code is shared by both ARM flavours, implementations of these accessors are also added to ARM32 code. This patch fixes setting MMIO register to a random value (actually SP) instead of zero by something like: *((volatile int *)reg) = 0; compilers tend to generate "str wzr, [xx]" here [Marc: Fixed 32bit splat] Signed-off-by: Pavel Fedin <p.fedin@samsung.com> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-03-30KVM: arm/arm64: rework MMIO abort handling to use KVM MMIO busAndre Przywara
Currently we have struct kvm_exit_mmio for encapsulating MMIO abort data to be passed on from syndrome decoding all the way down to the VGIC register handlers. Now as we switch the MMIO handling to be routed through the KVM MMIO bus, it does not make sense anymore to use that structure already from the beginning. So we keep the data in local variables until we put them into the kvm_io_bus framework. Then we fill kvm_exit_mmio in the VGIC only, making it a VGIC private structure. On that way we replace the data buffer in that structure with a pointer pointing to a single location in a local variable, so we get rid of some copying on the way. With all of the virtual GIC emulation code now being registered with the kvm_io_bus, we can remove all of the old MMIO handling code and its dispatching functionality. I didn't bother to rename kvm_exit_mmio (to vgic_mmio or something), because that touches a lot of code lines without any good reason. This is based on an original patch by Nikolay. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Cc: Nikolay Nikolaev <n.nikolaev@virtualopensystems.com> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2014-11-25arm/arm64: KVM: avoid unnecessary guest register mangling on MMIO readAndre Przywara
Currently we mangle the endianness of the guest's register even on an MMIO _read_, where it is completely useless, because we will not use the value of that register. Rework the io_mem_abort() function to clearly separate between reads and writes and only do the endianness mangling on MMIO writes. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2013-11-07arm/arm64: KVM: MMIO support for BE guestMarc Zyngier
Do the necessary byteswap when host and guest have different views of the universe. Actually, the only case we need to take care of is when the guest is BE. All the other cases are naturally handled. Also be careful about endianness when the data is being memcopy-ed from/to the run buffer. Acked-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2013-08-11KVM: ARM: Squash len warningChristoffer Dall
The 'len' variable was declared an unsigned and then checked for less than 0, which results in warnings on some compilers. Since len is assigned an int, make it an int. Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-06-26ARM: KVM: don't special case PC when doing an MMIOMarc Zyngier
Admitedly, reading a MMIO register to load PC is very weird. Writing PC to a MMIO register is probably even worse. But the architecture doesn't forbid any of these, and injecting a Prefetch Abort is the wrong thing to do anyway. Remove this check altogether, and let the adventurous guest wander into LaLaLand if they feel compelled to do so. Reported-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <cdall@cs.columbia.edu>
2013-03-06ARM: KVM: Fix length of mmio accessMarc Zyngier
Instead of hardcoding the maximum MMIO access to be 4 bytes, compare it to sizeof(unsigned long), which will do the right thing on both 32 and 64bit systems. Same thing for sign extention. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <cdall@cs.columbia.edu>
2013-03-06ARM: KVM: abstract IL decoding awayMarc Zyngier
2013-03-06ARM: KVM: abstract SAS decoding awayMarc Zyngier
2013-03-06ARM: KVM: abstract S1TW abort detection awayMarc Zyngier
2013-03-06ARM: KVM: abstract (and fix) external abort detection awayMarc Zyngier
Bit 8 is cache maintenance, bit 9 is external abort. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <cdall@cs.columbia.edu>
2013-03-06ARM: KVM: abstract HSR_SRT_{MASK,SHIFT} awayMarc Zyngier
2013-03-06ARM: KVM: abstract HSR_SSE awayMarc Zyngier
2013-03-06ARM: KVM: abstract HSR_WNR awayMarc Zyngier
2013-03-06ARM: KVM: abstract HSR_ISV awayMarc Zyngier
2013-03-06ARM: KVM: abstract fault register accessesMarc Zyngier
Instead of directly accessing the fault registers, use proper accessors so the core code can be shared. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2013-03-06ARM: KVM: convert GP registers from u32 to unsigned longMarc Zyngier
On 32bit ARM, unsigned long is guaranteed to be a 32bit quantity. On 64bit ARM, it is a 64bit quantity. In order to be able to share code between the two architectures, convert the registers to be unsigned long, so the core code can be oblivious of the change. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2013-02-11ARM: KVM: Initial VGIC infrastructure codeMarc Zyngier
Wire the basic framework code for VGIC support and the initial in-kernel MMIO support code for the VGIC, used for the distributor emulation. Reviewed-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Christoffer Dall <c.dall@virtualopensystems.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2013-01-23KVM: ARM: Handle I/O abortsChristoffer Dall
When the guest accesses I/O memory this will create data abort exceptions and they are handled by decoding the HSR information (physical address, read/write, length, register) and forwarding reads and writes to QEMU which performs the device emulation. Certain classes of load/store operations do not support the syndrome information provided in the HSR. We don't support decoding these (patches are available elsewhere), so we report an error to user space in this case. This requires changing the general flow somewhat since new calls to run the VCPU must check if there's a pending MMIO load and perform the write after userspace has made the data available. Reviewed-by: Will Deacon <will.deacon@arm.com> Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <c.dall@virtualopensystems.com>
