path: root/arch/arm/include/asm
2012-06-20Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
* emailed from Andrew Morton <akpm@linux-foundation.org>: (21 patches) mm/memblock: fix overlapping allocation when doubling reserved array c/r: prctl: Move PR_GET_TID_ADDRESS to a proper place pidns: find_new_reaper() can no longer switch to init_pid_ns.child_reaper pidns: guarantee that the pidns init will be the last pidns process reaped fault-inject: avoid call to random32() if fault injection is disabled Viresh has moved get_maintainer: Fix --help warning mm/memory.c: fix kernel-doc warnings mm: fix kernel-doc warnings mm: correctly synchronize rss-counters at exit/exec mm, thp: print useful information when mmap_sem is unlocked in zap_pmd_range h8300: use the declarations provided by <asm/sections.h> h8300: fix use of extinct _sbss and _ebss xtensa: use the declarations provided by <asm/sections.h> xtensa: use "test -e" instead of bashism "test -a" xtensa: replace xtensa-specific _f{data,text} by _s{data,text} memcg: fix use_hierarchy css_is_ancestor oops regression mm, oom: fix and cleanup oom score calculations nilfs2: ensure proper cache clearing for gc-inodes thp: avoid atomic64_read in pmd_read_atomic for 32bit PAE ...
2012-06-20Viresh has movedViresh Kumar
viresh.kumar@st.com email-id doesn't exist anymore as I have left the company. Replace ST's id with viresh.linux@gmail.com. It also updates .mailmap file to fix address for 'git shortlog' Signed-off-by: Viresh Kumar <viresh.linux@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-16ARM: 7425/1: extable: ensure fixup entries are 4-byte alignedWill Deacon
Fixup entries in the kernel exception tables should be 4-byte aligned since we return directly to them when handling a faulting instruction in the kernel. This patch adds the missing align directives to the fixup entries. Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-06-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs changes from Al Viro. "A lot of misc stuff. The obvious groups: * Miklos' atomic_open series; kills the damn abuse of ->d_revalidate() by NFS, which was the major stumbling block for all work in that area. * ripping security_file_mmap() and dealing with deadlocks in the area; sanitizing the neighborhood of vm_mmap()/vm_munmap() in general. * ->encode_fh() switched to saner API; insane fake dentry in mm/cleancache.c gone. * assorted annotations in fs (endianness, __user) * parts of Artem's ->s_dirty work (jff2 and reiserfs parts) * ->update_time() work from Josef. * other bits and pieces all over the place. Normally it would've been in two or three pull requests, but signal.git stuff had eaten a lot of time during this cycle ;-/" Fix up trivial conflicts in Documentation/filesystems/vfs.txt (the 'truncate_range' inode method was removed by the VM changes, the VFS update adds an 'update_time()' method), and in fs/btrfs/ulist.[ch] (due to sparse fix added twice, with other changes nearby). * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (95 commits) nfs: don't open in ->d_revalidate vfs: retry last component if opening stale dentry vfs: nameidata_to_filp(): don't throw away file on error vfs: nameidata_to_filp(): inline __dentry_open() vfs: do_dentry_open(): don't put filp vfs: split __dentry_open() vfs: do_last() common post lookup vfs: do_last(): add audit_inode before open vfs: do_last(): only return EISDIR for O_CREAT vfs: do_last(): check LOOKUP_DIRECTORY vfs: do_last(): make ENOENT exit RCU safe vfs: make follow_link check RCU safe vfs: do_last(): use inode variable vfs: do_last(): inline walk_component() vfs: do_last(): make exit RCU safe vfs: split do_lookup() Btrfs: move over to use ->update_time fs: introduce inode operation ->update_time reiserfs: get rid of resierfs_sync_super reiserfs: mark the superblock as dirty a bit later ...
2012-05-30bury __kernel_nlink_t, make internal nlink_t consistentAl Viro
2012-05-29Merge branch 'for-linus' of git://git.linaro.org/people/rmk/linux-armLinus Torvalds
Pull arm updates from Russell King: "This contains both some fixes found when trying to get the Assabet+neponset setup as a replacement firewall with a 3c589 PCMCIA card, and a bunch of changes from Al to fix up the ARM signal handling, particularly some of the restart behaviour." * 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: ARM: neponset: make sure neponset_ncr_frob() is exported ARM: fix out[bwl]() arm: don't open-code ptrace_report_syscall() arm: bury unused _TIF_RESTORE_SIGMASK arm: remove unused restart trampoline arm: new way of handling ERESTART_RESTARTBLOCK arm: if we get into work_pending while returning to kernel mode, just go away arm: don't call try_to_freeze() from do_signal() arm: if there's no handler we need to restore sigmask, syscall or no syscall arm: trim _TIF_WORK_MASK, get rid of useless test and branch... arm: missing checks of __get_user()/__put_user() return values
2012-05-29Merge branch 'for-arm' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal.git into for-linus Conflicts: arch/arm/kernel/ptrace.c
2012-05-26Merge tag 'cleanup-initcall' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull sweeping late_initcall cleanup for arm-soc from Olof Johansson: "This is a patch series from Shawn Guo that moves from individual late_initcalls() to using a member in the machine structure to invoke a platform's late initcalls. This cleanup is a step in the move towards multiplatform kernels since it would reduce the need to check for compatible platforms in each and every initcall." Fix up trivial conflicts in arch/arm/mach-{exynos/mach-universal_c210.c, imx/mach-cpuimx51.c, omap2/board-generic.c} due to changes nearby (and, in the case of cpuimx51.c the board support being deleted) * tag 'cleanup-initcall' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: ux500: use machine specific hook for late init ARM: tegra: use machine specific hook for late init ARM: shmobile: use machine specific hook for late init ARM: sa1100: use machine specific hook for late init ARM: s3c64xx: use machine specific hook for late init ARM: prima2: use machine specific hook for late init ARM: pnx4008: use machine specific hook for late init ARM: omap2: use machine specific hook for late init ARM: omap1: use machine specific hook for late init ARM: msm: use machine specific hook for late init ARM: imx: use machine specific hook for late init ARM: exynos: use machine specific hook for late init ARM: ep93xx: use machine specific hook for late init ARM: davinci: use machine specific hook for late init ARM: provide a late_initcall hook for platform initialization
2012-05-25Merge branch 'next' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine updates from Vinod Koul: "Nothing exciting this time, odd fixes in a bunch of drivers" * 'next' of git://git.infradead.org/users/vkoul/slave-dma: dmaengine: at_hdmac: take maxburst from slave configuration dmaengine: at_hdmac: remove ATC_DEFAULT_CTRLA constant dmaengine: at_hdmac: remove some at_dma_slave comments dma: imx-sdma: make channel0 operations atomic dmaengine: Fixup dmaengine_prep_slave_single() to be actually useful dmaengine: Use dma_sg_len(sg) instead of sg->length dmaengine: Use sg_dma_address instead of sg_phys DMA: PL330: Remove duplicate header file inclusion dma: imx-sdma: keep the callbacks invoked in the tasklet dmaengine: dw_dma: add Device Tree probing capability dmaengine: dw_dmac: Add clk_{un}prepare() support dma/amba-pl08x: add support for the Nomadik variant dma/amba-pl08x: check for terminal count status only
2012-05-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.linaro.org/people/mszyprowski/linux-dma-mapping Pull CMA and ARM DMA-mapping updates from Marek Szyprowski: "These patches contain two major updates for DMA mapping subsystem (mainly for ARM architecture). First one is Contiguous Memory Allocator (CMA) which makes it possible for device drivers to allocate big contiguous chunks of memory after the system has booted. The main difference from the similar frameworks is the fact that CMA allows to transparently reuse the memory region reserved for the big chunk allocation as a system memory, so no memory is wasted when no big chunk is allocated. Once the alloc request is issued, the framework migrates system pages to create space for the required big chunk of physically contiguous memory. For more information one can refer to nice LWN articles: - 'A reworked contiguous memory allocator': http://lwn.net/Articles/447405/ - 'CMA and ARM': http://lwn.net/Articles/450286/ - 'A deep dive into CMA': http://lwn.net/Articles/486301/ - and the following thread with the patches and links to all previous versions: https://lkml.org/lkml/2012/4/3/204 The main client for this new framework is ARM DMA-mapping subsystem. The second part provides a complete redesign in ARM DMA-mapping subsystem. The core implementation has been changed to use common struct dma_map_ops based infrastructure with the recent updates for new dma attributes merged in v3.4-rc2. This allows to use more than one implementation of dma-mapping calls and change/select them on the struct device basis. The first client of this new infractructure is dmabounce implementation which has been completely cut out of the core, common code. The last patch of this redesign update introduces a new, experimental implementation of dma-mapping calls on top of generic IOMMU framework. This lets ARM sub-platform to transparently use IOMMU for DMA-mapping calls if one provides required IOMMU hardware. For more information please refer to the following thread: http://www.spinics.net/lists/arm-kernel/msg175729.html The last patch merges changes from both updates and provides a resolution for the conflicts which cannot be avoided when patches have been applied on the same files (mainly arch/arm/mm/dma-mapping.c)." Acked by Andrew Morton <akpm@linux-foundation.org>: "Yup, this one please. It's had much work, plenty of review and I think even Russell is happy with it." * 'for-linus' of git://git.linaro.org/people/mszyprowski/linux-dma-mapping: (28 commits) ARM: dma-mapping: use PMD size for section unmap cma: fix migration mode ARM: integrate CMA with DMA-mapping subsystem X86: integrate CMA with DMA-mapping subsystem drivers: add Contiguous Memory Allocator mm: trigger page reclaim in alloc_contig_range() to stabilise watermarks mm: extract reclaim code from __alloc_pages_direct_reclaim() mm: Serialize access to min_free_kbytes mm: page_isolation: MIGRATE_CMA isolation functions added mm: mmzone: MIGRATE_CMA migration type added mm: page_alloc: change fallbacks array handling mm: page_alloc: introduce alloc_contig_range() mm: compaction: export some of the functions mm: compaction: introduce isolate_freepages_range() mm: compaction: introduce map_pages() mm: compaction: introduce isolate_migratepages_range() mm: page_alloc: remove trailing whitespace ARM: dma-mapping: add support for IOMMU mapper ARM: dma-mapping: use alloc, mmap, free from dma_ops ARM: dma-mapping: remove redundant code and do the cleanup ... Conflicts: arch/x86/include/asm/dma-mapping.h
2012-05-25ARM: fix out[bwl]()Russell King
out[bwl]() had a side effect that gcc read-back from the register after writing its value. This causes a problem for at least 3c589_cs, which spits out lots of "adapter failure, FIFO diagnostic register 2011." Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-05-24Merge branch 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM changes from Avi Kivity: "Changes include additional instruction emulation, page-crossing MMIO, faster dirty logging, preventing the watchdog from killing a stopped guest, module autoload, a new MSI ABI, and some minor optimizations and fixes. Outside x86 we have a small s390 and a very large ppc update. Regarding the new (for kvm) rebaseless workflow, some of the patches that were merged before we switch trees had to be rebased, while others are true pulls. In either case the signoffs should be correct now." Fix up trivial conflicts in Documentation/feature-removal-schedule.txt arch/powerpc/kvm/book3s_segment.S and arch/x86/include/asm/kvm_para.h. I suspect the kvm_para.h resolution ends up doing the "do I have cpuid" check effectively twice (it was done differently in two different commits), but better safe than sorry ;) * 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (125 commits) KVM: make asm-generic/kvm_para.h have an ifdef __KERNEL__ block KVM: s390: onereg for timer related registers KVM: s390: epoch difference and TOD programmable field KVM: s390: KVM_GET/SET_ONEREG for s390 KVM: s390: add capability indicating COW support KVM: Fix mmu_reload() clash with nested vmx event injection KVM: MMU: Don't use RCU for lockless shadow walking KVM: VMX: Optimize %ds, %es reload KVM: VMX: Fix %ds/%es clobber KVM: x86 emulator: convert bsf/bsr instructions to emulate_2op_SrcV_nobyte() KVM: VMX: unlike vmcs on fail path KVM: PPC: Emulator: clean up SPR reads and writes KVM: PPC: Emulator: clean up instruction parsing kvm/powerpc: Add new ioctl to retreive server MMU infos kvm/book3s: Make kernel emulated H_PUT_TCE available for "PR" KVM KVM: PPC: bookehv: Fix r8/r13 storing in level exception handler KVM: PPC: Book3S: Enable IRQs during exit handling KVM: PPC: Fix PR KVM on POWER7 bare metal KVM: PPC: Fix stbux emulation KVM: PPC: bookehv: Use lwz/stw instead of PPC_LL/PPC_STL for 32-bit fields ...
2012-05-23Merge branch 'x86-fpu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull fpu state cleanups from Ingo Molnar: "This tree streamlines further aspects of FPU handling by eliminating the prepare_to_copy() complication and moving that logic to arch_dup_task_struct(). It also fixes the FPU dumps in threaded core dumps, removes and old (and now invalid) assumption plus micro-optimizes the exit path by avoiding an FPU save for dead tasks." Fixed up trivial add-add conflict in arch/sh/kernel/process.c that came in because we now do the FPU handling in arch_dup_task_struct() rather than the legacy (and now gone) prepare_to_copy(). * 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, fpu: drop the fpu state during thread exit x86, xsave: remove thread_has_fpu() bug check in __sanitize_i387_state() coredump: ensure the fpu state is flushed for proper multi-threaded core dump fork: move the real prepare_to_copy() users to arch_dup_task_struct()
2012-05-22Merge tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-socLinus Torvalds
Pull first batch of arm-soc cleanups from Olof Johansson: "These cleanups are basically all over the place. The idea is to collect changes with minimal impact but large number of changes so we can avoid them from distracting in the diffstat in the other series. A significant number of lines get removed here, in particular because the ixp2000 and ixp23xx platforms get removed. These have never been extremely popular and have fallen into disuse over time with no active maintainer taking care of them. The u5500 soc never made it into a product, so we are removing it from the ux500 platform. Many good cleanups also went into the at91 and omap platforms, as has been the case for a number of releases." Trivial modify-delete conflicts in arch/arm/mach-{ixp2000,ixp23xx} * tag 'cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (152 commits) ARM: clps711x: Cleanup IRQ handling ARM clps711x: Removed unused header mach/time.h ARM: clps711x: Added note about support EP731x CPU to Kconfig ARM: clps711x: Added missing register definitions ARM: clps711x: Used own subarch directory for store header file Dove: Fix Section mismatch warnings ARM: orion5x: ts78xx debugging changes ARM: orion5x: remove PM dependency from ts78xx ARM: orion5x: ts78xx fix NAND resource off by one ARM: orion5x: ts78xx whitespace cleanups Orion5x: Fix Section mismatch warnings Orion5x: Fix warning: struct pci_dev declared inside paramter list ARM: clps711x: Combine header files into one for clps711x-targets ARM: S3C24XX: Use common macro to define resources on mach-qt2410.c ARM: S3C24XX: Use common macro to define resources on mach-osiris.c ARM: EXYNOS: Adapt to cpuidle core time keeping and irq enable ARM: S5PV210: Use common macro to define resources on mach-smdkv210.c ARM: S5PV210: Use common macro to define resources on dev-audio.c ARM: S5PC100: Use common macro to define resources on dev-audio.c ARM: S5P64X0: Use common macro to define resources on dev-audio.c ...
2012-05-22Merge branch 'for-next-arm-dma' into for-linusMarek Szyprowski
Conflicts: arch/arm/Kconfig arch/arm/mm/dma-mapping.c Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2012-05-21Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull smp hotplug cleanups from Thomas Gleixner: "This series is merily a cleanup of code copied around in arch/* and not changing any of the real cpu hotplug horrors yet. I wish I'd had something more substantial for 3.5, but I underestimated the lurking horror..." Fix up trivial conflicts in arch/{arm,sparc,x86}/Kconfig and arch/sparc/include/asm/thread_info_32.h * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (79 commits) um: Remove leftover declaration of alloc_task_struct_node() task_allocator: Use config switches instead of magic defines sparc: Use common threadinfo allocator score: Use common threadinfo allocator sh-use-common-threadinfo-allocator mn10300: Use common threadinfo allocator powerpc: Use common threadinfo allocator mips: Use common threadinfo allocator hexagon: Use common threadinfo allocator m32r: Use common threadinfo allocator frv: Use common threadinfo allocator cris: Use common threadinfo allocator x86: Use common threadinfo allocator c6x: Use common threadinfo allocator fork: Provide kmemcache based thread_info allocator tile: Use common threadinfo allocator fork: Provide weak arch_release_[task_struct|thread_info] functions fork: Move thread info gfp flags to header fork: Remove the weak insanity sh: Remove cpu_idle_wait() ...
2012-05-21arm: bury unused _TIF_RESTORE_SIGMASKAl Viro
2012-05-21arm: new way of handling ERESTART_RESTARTBLOCKAl Viro
new "syscall start" flag; handled in syscall_trace() by switching syscall number to that of syscall_restart(2). Restarts of that kind (ERESTART_RESTARTBLOCK) are handled by setting that bit; syscall number is not modified until the actual call. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-21arm: trim _TIF_WORK_MASK, get rid of useless test and branch...Al Viro
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-21Merge branch 'v3-removal' into for-linusRussell King
Conflicts: arch/arm/boot/compressed/head.S
2012-05-21Merge branch 'misc' into for-linusRussell King
2012-05-21Merge branches 'amba', 'devel-stable', 'fixes', 'mach-types', 'mmci', 'pci' ↵Russell King
and 'versatile' into for-linus
2012-05-21ARM: integrate CMA with DMA-mapping subsystemMarek Szyprowski
This patch adds support for CMA to dma-mapping subsystem for ARM architecture. By default a global CMA area is used, but specific devices are allowed to have their private memory areas if required (they can be created with dma_declare_contiguous() function during board initialisation). Contiguous memory areas reserved for DMA are remapped with 2-level page tables on boot. Once a buffer is requested, a low memory kernel mapping is updated to to match requested memory access type. GFP_ATOMIC allocations are performed from special pool which is created early during boot. This way remapping page attributes is not needed on allocation time. CMA has been enabled unconditionally for ARMv6+ systems. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Michal Nazarewicz <mina86@mina86.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
2012-05-21ARM: dma-mapping: add support for IOMMU mapperMarek Szyprowski
This patch add a complete implementation of DMA-mapping API for devices which have IOMMU support. This implementation tries to optimize dma address space usage by remapping all possible physical memory chunks into a single dma address space chunk. DMA address space is managed on top of the bitmap stored in the dma_iommu_mapping structure stored in device->archdata. Platform setup code has to initialize parameters of the dma address space (base address, size, allocation precision order) with arm_iommu_create_mapping() function. To reduce the size of the bitmap, all allocations are aligned to the specified order of base 4 KiB pages. dma_alloc_* functions allocate physical memory in chunks, each with alloc_pages() function to avoid failing if the physical memory gets fragmented. In worst case the allocated buffer is composed of 4 KiB page chunks. dma_map_sg() function minimizes the total number of dma address space chunks by merging of physical memory chunks into one larger dma address space chunk. If requested chunk (scatter list entry) boundaries match physical page boundaries, most calls to dma_map_sg() requests will result in creating only one chunk in dma address space. dma_map_page() simply creates a mapping for the given page(s) in the dma address space. All dma functions also perform required cache operation like their counterparts from the arm linear physical memory mapping version. This patch contains code and fixes kindly provided by: - Krishna Reddy <vdumpa@nvidia.com>, - Andrzej Pietrasiewicz <andrzej.p@samsung.com>, - Hiroshi DOYU <hdoyu@nvidia.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Tested-By: Subash Patel <subash.ramaswamy@linaro.org>
2012-05-21ARM: dma-mapping: use alloc, mmap, free from dma_opsMarek Szyprowski
This patch converts dma_alloc/free/mmap_{coherent,writecombine} functions to use generic alloc/free/mmap methods from dma_map_ops structure. A new DMA_ATTR_WRITE_COMBINE DMA attribute have been introduced to implement writecombine methods. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-By: Subash Patel <subash.ramaswamy@linaro.org>
2012-05-21ARM: dma-mapping: move all dma bounce code to separate dma ops structureMarek Szyprowski
This patch removes dma bounce hooks from the common dma mapping implementation on ARM architecture and creates a separate set of dma_map_ops for dma bounce devices. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Tested-By: Subash Patel <subash.ramaswamy@linaro.org>
2012-05-21ARM: dma-mapping: use asm-generic/dma-mapping-common.hMarek Szyprowski
This patch modifies dma-mapping implementation on ARM architecture to use common dma_map_ops structure and asm-generic/dma-mapping-common.h helpers. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Tested-By: Subash Patel <subash.ramaswamy@linaro.org>
2012-05-21ARM: dma-mapping: remove offset parameter to prepare for generic dma_opsMarek Szyprowski
This patch removes the need for the offset parameter in dma bounce functions. This is required to let dma-mapping framework on ARM architecture to use common, generic dma_map_ops based dma-mapping helpers. Background and more detailed explaination: dma_*_range_* functions are available from the early days of the dma mapping api. They are the correct way of doing a partial syncs on the buffer (usually used by the network device drivers). This patch changes only the internal implementation of the dma bounce functions to let them tunnel through dma_map_ops structure. The driver api stays unchanged, so driver are obliged to call dma_*_range_* functions to keep code clean and easy to understand. The only drawback from this patch is reduced detection of the dma api abuse. Let us consider the following code: dma_addr = dma_map_single(dev, ptr, 64, DMA_TO_DEVICE); dma_sync_single_range_for_cpu(dev, dma_addr+16, 0, 32, DMA_TO_DEVICE); Without the patch such code fails, because dma bounce code is unable to find the bounce buffer for the given dma_address. After the patch the above sync call will be equivalent to: dma_sync_single_range_for_cpu(dev, dma_addr, 16, 32, DMA_TO_DEVICE); which succeeds. I don't consider this as a real problem, because DMA API abuse should be caught by debug_dma_* function family. This patch lets us to simplify the internal low-level implementation without chaning the driver visible API. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Tested-By: Subash Patel <subash.ramaswamy@linaro.org>
2012-05-21ARM: dma-mapping: introduce DMA_ERROR_CODE constantMarek Szyprowski
Replace all uses of ~0 with DMA_ERROR_CODE, what should make the code easier to read. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Tested-By: Subash Patel <subash.ramaswamy@linaro.org>
2012-05-16fork: move the real prepare_to_copy() users to arch_dup_task_struct()Suresh Siddha
Historical prepare_to_copy() is mostly a no-op, duplicated for majority of the architectures and the rest following the x86 model of flushing the extended register state like fpu there. Remove it and use the arch_dup_task_struct() instead. Suggested-by: Oleg Nesterov <oleg@redhat.com> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Link: http://lkml.kernel.org/r/1336692811-30576-1-git-send-email-suresh.b.siddha@intel.com Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <chris@zankel.net> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Mark Salter <msalter@redhat.com> Cc: Aurelien Jacquiot <a-jacquiot@ti.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: David S. Miller <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2012-05-16ARM: PCI: remove per-pci_hw list of busesRussell King
No one uses the per-hw list of buses, so get rid of this. Instead, build the list locally. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-05-16Merge branch 'clps711x/cleanup' into next/cleanupArnd Bergmann
* clps711x/cleanup: ARM: clps711x: Cleanup IRQ handling ARM clps711x: Removed unused header mach/time.h ARM: clps711x: Added note about support EP731x CPU to Kconfig ARM: clps711x: Added missing register definitions ARM: clps711x: Used own subarch directory for store header file Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-14ARM: clps711x: Used own subarch directory for store header fileAlexander Shiyan
There is no reason to have the clps7111.h header in a globally visible location, so move it to a place that is only visible when building for mach-clps711x. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-13Merge branch 'clps711x/cleanup' into next/cleanupArnd Bergmann
* clps711x/cleanup: ARM: clps711x: Combine header files into one for clps711x-targets Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-13ARM: clps711x: Combine header files into one for clps711x-targetsAlexander Shiyan
Current ARM7 Cirrus Logic product line contains only 3 cpu. EP7312 - Fully functional. EP7309 - Missing SDRAM interface. EP7311 - Missing DAI. It makes no sense to separate the header files to identify these differences, it is only necessary to keep in mind the presence or lack of any features of a specific CPU when writing code. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-13ARM: PCI: provide a default bus scan implementationRussell King
Most PCI implementations perform simple root bus scanning. Rather than having each group of platforms provide a duplicated bus scan function, provide the PCI configuration ops structure via the hw_pci structure, and call the root bus scanning function from core ARM PCI code. Acked-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-05-13ARM: PCI: get rid of pci_std_swizzle()Russell King
Most PCI implementations use the standard PCI swizzle function, which handles the well defined behaviour of PCI-to-PCI bridges which can be found on cards (eg, four port ethernet cards.) Rather than having almost every platform specify the standard swizzle function, make this the default when no swizzle function is supplied. Therefore, a swizzle function only needs to be provided when there is something exceptional which needs to be handled. This gets rid of the swizzle initializer from 47 files, and leaves us with just two platforms specifying a swizzle function: ARM Integrator and Chalice CATS. Acked-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-05-12ARM: 7416/1: LPAE: Remove unused L_PTE_(BUFFERABLE|CACHEABLE) macrosCatalin Marinas
These have already been removed from the classic MMU in favour of L_PTE_MT_* macros. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-05-11Merge branch 'clps711x/cleanup' into next/cleanupArnd Bergmann
A single patch from Alexander Shiyan <shc_work@mail.ru>: * clps711x/cleanup: ARM: clps711x: Using a single definition for the PHYS and VIRT registers offset Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-11ARM: clps711x: Using a single definition for the PHYS and VIRT registers offsetAlexander Shiyan
Using a single definition for the physical and virtual address register for all variants boards clps711x. This patch also includes the use of a single function clps_read/write in some units. Signed-off-by: Alexander Shiyan <shc_work@mail.ru> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-05-11Merge branch 'clean/late_initcall_v2' of ↵Olof Johansson
git://git.linaro.org/people/shawnguo/linux-2.6 into staging/cleanup By Shawn Guo via Shawn Guo * 'clean/late_initcall_v2' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: ux500: use machine specific hook for late init ARM: tegra: use machine specific hook for late init ARM: shmobile: use machine specific hook for late init ARM: sa1100: use machine specific hook for late init ARM: s3c64xx: use machine specific hook for late init ARM: prima2: use machine specific hook for late init ARM: pnx4008: use machine specific hook for late init ARM: omap2: use machine specific hook for late init ARM: omap1: use machine specific hook for late init ARM: msm: use machine specific hook for late init ARM: imx: use machine specific hook for late init ARM: exynos: use machine specific hook for late init ARM: ep93xx: use machine specific hook for late init ARM: davinci: use machine specific hook for late init ARM: provide a late_initcall hook for platform initialization
2012-05-09Merge tag 'v3.4-rc6' into next/cleanupOlof Johansson
Linux 3.4-rc6 Resolve conflict where an u5500 file had a bugfix go in, but was deleted in the branch staged for next merge window. Signed-off-by: Olof Johansson <olof@lixom.net>
2012-05-08Merge branch 'smp/threadalloc' into smp/hotplugThomas Gleixner
Reason: Pull in the separate branch which was created so arch/tile can base further work on it. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-05-08arm: Remove unused cpu_idle_wait()Thomas Gleixner
cpuidle uses a generic function now. Remove the unused code. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Russell King <linux@arm.linux.org.uk> Link: http://lkml.kernel.org/r/20120507175652.260797846@linutronix.de
2012-05-06ARM: 7413/1: move read_{boot,persistent}_clock to the architecture levelMarc Zyngier
At the moment, read_persistent_clock is implemented at the platform level, which makes it impossible to compile these platforms in a single kernel. Implement these two functions at the architecture level, and provide a thin registration interface for both read_boot_clock and read_persistent_clock. The two affected platforms (OMAP and Tegra) are converted at the same time. Reported-by: Jeff Ohlstein <johlstei@codeaurora.org> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-05-05ARM: Remove support for ARMv3 ARM610 and ARM710 CPUsRussell King
This patch removes support for ARMv3 CPUs, which haven't worked properly for quite some time (see the FIXME comment in arch/arm/mm/fault.c). The only V3 parts left is the cache model for ARMv3, which is needed for some odd reason by ARM740T CPUs, and being able to build with -march=armv3, which is required for the RiscPC platform due to its bus structure. Acked-by: Will Deacon <will.deacon@arm.com> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-05-04Merge branch 'timers-v3.4-rc4' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/maz/arm-platforms into devel-stable
2012-05-03ARM: provide a late_initcall hook for platform initializationShawn Guo
This allows platforms to set up things that need to be done at late_initcall time. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Tested-by: Robert Lee <rob.lee@linaro.org> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-05-02ARM: 7408/1: cacheflush: return error to userspace when flushing syscall failsWill Deacon
The cacheflush syscall can fail for two reasons: (1) The arguments are invalid (nonsensical address range or no VMA) (2) The region generates a translation fault on a VIPT or PIPT cache This patch allows do_cache_op to return an error code to userspace in the case of the above. The various coherent_user_range implementations are modified to return 0 in the case of VIVT caches or -EFAULT in the case of an abort on v6/v7 cores. Reviewed-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2012-04-28ARM: 7404/1: cmpxchg64: use atomic64 and local64 routines for cmpxchg64Will Deacon
The cmpxchg64 routines for ARMv6+ CPUs replicate inline assembly that already exists for atomic64 operations. Furthermore, the cmpxchg64 code uses the "memory" constraint in the clobber list rather than identifying the region of memory that is actually modified. This patch replaces the ARMv6+ cmpxchg64 code with macros that expand to the atomic64_ and local64_ variants, casting the pointer parameter to the appropriate container type. Cc: Nicolas Pitre <nico@linaro.org> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
