git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"Updates for the input subsystem. You will get an new drivers for
Hyper-V synthetic keyboard and for Neonode zForce touchscreens, plus a
bunch of driver fixes and cleanups"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (49 commits)
Revert "Input: ALPS - add support for model found on Dell XT2"
arm: dts: am335x sk: add touchscreen support
Input: ti_am335x_tsc - fix spelling mistake in TSC/ADC DT binding
Input: cyttsp4 - replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO
Input: mma8450 - add missing i2c_set_clientdata() in mma8450_probe()
Input: mpu3050 - add missing i2c_set_clientdata() in mpu3050_probe()
Input: tnetv107x-keypad - make irqs signed for error handling
Input: add driver for Neonode zForce based touchscreens
Input: sh_keysc - enable the driver on all ARM platforms
Input: remove a redundant max() call
Input: mousedev - allow disabling even without CONFIG_EXPERT
Input: allow deselecting serio drivers even without CONFIG_EXPERT
Input: i8042 - add PNP modaliases
Input: evdev - fall back to vmalloc for client event buffer
Input: cypress_ps2 - do not consider data bad if palm is detected
Input: cypress_ps2 - remove useless cast
Input: fix PWM-related undefined reference errors
Input: ALPS - change secondary device's name
Input: wacom - not all multi-interface devices support touch
Input: nspire-keypad - add missing clk_disable_unprepare() on error path
Pull ARM updates from Russell King:
"Included in this series are:
1. BE8 (modern big endian) changes for ARM from Ben Dooks
2. big.Little support from Nicolas Pitre and Dave Martin
3. support for LPAE systems with all system memory above 4GB
4. Perf updates from Will Deacon
5. Additional prefetching and other performance improvements from Will.
6. Neon-optimised AES implementation fro Ard.
7. A number of smaller fixes scattered around the place.
There is a rather horrid merge conflict in tools/perf - I was never
notified of the conflict because it originally occurred between Will's
tree and other stuff. Consequently I have a resolution which Will
forwarded me, which I'll forward on immediately after sending this
mail.
The other notable thing is I'm expecting some build breakage in the
crypto stuff on ARM only with Ard's AES patches. These were merged
into a stable git branch which others had already pulled, so there's
little I can do about this. The problem is caused because these
patches have a dependency on some code in the crypto git tree - I
tried requesting a branch I can pull to resolve these, and all I got
each time from the crypto people was "we'll revert our patches then"
which would only make things worse since I still don't have the
dependent patches. I've no idea what's going on there or how to
resolve that, and since I can't split these patches from the rest of
this pull request, I'm rather stuck with pushing this as-is or
reverting Ard's patches.
Since it should "come out in the wash" I've left them in - the only
build problems they seem to cause at the moment are with randconfigs,
and since it's a new feature anyway. However, if by -rc1 the
dependencies aren't in, I think it'd be best to revert Ard's patches"
I resolved the perf conflict roughly as per the patch sent by Russell,
but there may be some differences. Any errors are likely mine. Let's
see how the crypto issues work out..
* 'for-linus' of git://git.linaro.org/people/rmk/linux-arm: (110 commits)
ARM: 7868/1: arm/arm64: remove atomic_clear_mask() in "include/asm/atomic.h"
ARM: 7867/1: include: asm: use 'int' instead of 'unsigned long' for 'oldval' in atomic_cmpxchg().
ARM: 7866/1: include: asm: use 'long long' instead of 'u64' within atomic.h
ARM: 7871/1: amba: Extend number of IRQS
ARM: 7887/1: Don't smp_cross_call() on UP devices in arch_irq_work_raise()
ARM: 7872/1: Support arch_irq_work_raise() via self IPIs
ARM: 7880/1: Clear the IT state independent of the Thumb-2 mode
ARM: 7878/1: nommu: Implement dummy early_paging_init()
ARM: 7876/1: clear Thumb-2 IT state on exception handling
ARM: 7874/2: bL_switcher: Remove cpu_hotplug_driver_{lock,unlock}()
ARM: footbridge: fix build warnings for netwinder
ARM: 7873/1: vfp: clear vfp_current_hw_state for dying cpu
ARM: fix misplaced arch_virt_to_idmap()
ARM: 7848/1: mcpm: Implement cpu_kill() to synchronise on powerdown
ARM: 7847/1: mcpm: Factor out logical-to-physical CPU translation
ARM: 7869/1: remove unused XSCALE_PMU Kconfig param
ARM: 7864/1: Handle 64-bit memory in case of 32-bit phys_addr_t
ARM: 7863/1: Let arm_add_memory() always use 64-bit arguments
ARM: 7862/1: pcpu: replace __get_cpu_var_uses
ARM: 7861/1: cacheflush: consolidate single-CPU ARMv7 cache disabling code
Pull networking updates from David Miller:
1) The addition of nftables. No longer will we need protocol aware
firewall filtering modules, it can all live in userspace.
At the core of nftables is a, for lack of a better term, virtual
machine that executes byte codes to inspect packet or metadata
(arriving interface index, etc.) and make verdict decisions.
Besides support for loading packet contents and comparing them, the
interpreter supports lookups in various datastructures as
fundamental operations. For example sets are supports, and
therefore one could create a set of whitelist IP address entries
which have ACCEPT verdicts attached to them, and use the appropriate
byte codes to do such lookups.
Since the interpreted code is composed in userspace, userspace can
do things like optimize things before giving it to the kernel.
Another major improvement is the capability of atomically updating
portions of the ruleset. In the existing netfilter implementation,
one has to update the entire rule set in order to make a change and
this is very expensive.
Userspace tools exist to create nftables rules using existing
netfilter rule sets, but both kernel implementations will need to
co-exist for quite some time as we transition from the old to the
new stuff.
Kudos to Patrick McHardy, Pablo Neira Ayuso, and others who have
worked so hard on this.
2) Daniel Borkmann and Hannes Frederic Sowa made several improvements
to our pseudo-random number generator, mostly used for things like
UDP port randomization and netfitler, amongst other things.
In particular the taus88 generater is updated to taus113, and test
cases are added.
3) Support 64-bit rates in HTB and TBF schedulers, from Eric Dumazet
and Yang Yingliang.
4) Add support for new 577xx tigon3 chips to tg3 driver, from Nithin
Sujir.
5) Fix two fatal flaws in TCP dynamic right sizing, from Eric Dumazet,
Neal Cardwell, and Yuchung Cheng.
6) Allow IP_TOS and IP_TTL to be specified in sendmsg() ancillary
control message data, much like other socket option attributes.
From Francesco Fusco.
7) Allow applications to specify a cap on the rate computed
automatically by the kernel for pacing flows, via a new
SO_MAX_PACING_RATE socket option. From Eric Dumazet.
8) Make the initial autotuned send buffer sizing in TCP more closely
reflect actual needs, from Eric Dumazet.
9) Currently early socket demux only happens for TCP sockets, but we
can do it for connected UDP sockets too. Implementation from Shawn
Bohrer.
10) Refactor inet socket demux with the goal of improving hash demux
performance for listening sockets. With the main goals being able
to use RCU lookups on even request sockets, and eliminating the
listening lock contention. From Eric Dumazet.
11) The bonding layer has many demuxes in it's fast path, and an RCU
conversion was started back in 3.11, several changes here extend the
RCU usage to even more locations. From Ding Tianhong and Wang
Yufen, based upon suggestions by Nikolay Aleksandrov and Veaceslav
Falico.
12) Allow stackability of segmentation offloads to, in particular, allow
segmentation offloading over tunnels. From Eric Dumazet.
13) Significantly improve the handling of secret keys we input into the
various hash functions in the inet hashtables, TCP fast open, as
well as syncookies. From Hannes Frederic Sowa. The key fundamental
operation is "net_get_random_once()" which uses static keys.
Hannes even extended this to ipv4/ipv6 fragmentation handling and
our generic flow dissector.
14) The generic driver layer takes care now to set the driver data to
NULL on device removal, so it's no longer necessary for drivers to
explicitly set it to NULL any more. Many drivers have been cleaned
up in this way, from Jingoo Han.
15) Add a BPF based packet scheduler classifier, from Daniel Borkmann.
16) Improve CRC32 interfaces and generic SKB checksum iterators so that
SCTP's checksumming can more cleanly be handled. Also from Daniel
Borkmann.
17) Add a new PMTU discovery mode, IP_PMTUDISC_INTERFACE, which forces
using the interface MTU value. This helps avoid PMTU attacks,
particularly on DNS servers. From Hannes Frederic Sowa.
18) Use generic XPS for transmit queue steering rather than internal
(re-)implementation in virtio-net. From Jason Wang.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1622 commits)
random32: add test cases for taus113 implementation
random32: upgrade taus88 generator to taus113 from errata paper
random32: move rnd_state to linux/random.h
random32: add prandom_reseed_late() and call when nonblocking pool becomes initialized
random32: add periodic reseeding
random32: fix off-by-one in seeding requirement
PHY: Add RTL8201CP phy_driver to realtek
xtsonic: add missing platform_set_drvdata() in xtsonic_probe()
macmace: add missing platform_set_drvdata() in mace_probe()
ethernet/arc/arc_emac: add missing platform_set_drvdata() in arc_emac_probe()
ipv6: protect for_each_sk_fl_rcu in mem_check with rcu_read_lock_bh
vlan: Implement vlan_dev_get_egress_qos_mask as an inline.
ixgbe: add warning when max_vfs is out of range.
igb: Update link modes display in ethtool
netfilter: push reasm skb through instead of original frag skbs
ip6_output: fragment outgoing reassembled skb properly
MAINTAINERS: mv643xx_eth: take over maintainership from Lennart
net_sched: tbf: support of 64bit rates
ixgbe: deleting dfwd stations out of order can cause null ptr deref
ixgbe: fix build err, num_rx_queues is only available with CONFIG_RPS
arch/arm/include/asm/atomic.h
arch/arm/include/asm/hardirq.h
arch/arm/kernel/smp.c
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull devicetree updates from Rob Herring:
"DeviceTree updates for 3.13. This is a bit larger pull request than
usual for this cycle with lots of clean-up.
- Cross arch clean-up and consolidation of early DT scanning code.
- Clean-up and removal of arch prom.h headers. Makes arch specific
prom.h optional on all but Sparc.
- Addition of interrupts-extended property for devices connected to
multiple interrupt controllers.
- Refactoring of DT interrupt parsing code in preparation for
deferred probe of interrupts.
- ARM cpu and cpu topology bindings documentation.
- Various DT vendor binding documentation updates"
* tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits)
powerpc: add missing explicit OF includes for ppc
dt/irq: add empty of_irq_count for !OF_IRQ
dt: disable self-tests for !OF_IRQ
of: irq: Fix interrupt-map entry matching
MIPS: Netlogic: replace early_init_devtree() call
of: Add Panasonic Corporation vendor prefix
of: Add Chunghwa Picture Tubes Ltd. vendor prefix
of: Add AU Optronics Corporation vendor prefix
of/irq: Fix potential buffer overflow
of/irq: Fix bug in interrupt parsing refactor.
of: set dma_mask to point to coherent_dma_mask
of: add vendor prefix for PHYTEC Messtechnik GmbH
DT: sort vendor-prefixes.txt
of: Add vendor prefix for Cadence
of: Add empty for_each_available_child_of_node() macro definition
arm/versatile: Fix versatile irq specifications.
of/irq: create interrupts-extended property
microblaze/pci: Drop PowerPC-ism from irq parsing
of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code.
of/irq: Use irq_of_parse_and_map()
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control updates from Linus Walleij:
"Main pin control pull request for the v3.13 cycle.
The changes hitting arch/blackfin are ACKed by the Blackfin
maintainer, and the device tree bindings are ACKed to the extent
possible by someone from the device tree maintainers group.
- Blackfin ADI pin control driver, we move yet another architecture
under this subsystem umbrella.
- Incremental updates to the Renesas Super-H PFC pin control driver.
New subdriver for the r8a7791 SoC.
- Non-linear GPIO ranges from the gpiolib side of things, this
enabled simplified device tree bindings by referring entire groups
of pins on some pin controller to act as back-end for a certain
GPIO-chip driver.
- Add the Abilis TB10x pin control driver used on the ARC
architecture. Also the corresponding GPIO driver is merged through
this tree, so the ARC has full support for pins and GPIOs after
this.
- Subdrivers for Freescale i.MX1, i.MX27 and i.MX50 pin controller
instances. The i.MX1 and i.MX27 is an entirely new family
(silicon) of controllers whereas i.MX50 is a variant of the
previous supported controller.
- Then the usual slew of fixes, cleanups and incremental updates"
The ARC DT changes are apparently still pending, that hopefully gets
sorted out in a timely manner.
* tag 'pinctrl-for-v3.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (48 commits)
pinctrl: imx50: add pinctrl support code for the IMX50 SoC
pinctrl: at91: copy define to driver
pinctrl: remove minor dead code
pinctrl: imx: fix using pin->input_val wrongly
pinctrl: imx1: fix return value check in imx1_pinctrl_core_probe()
gpio: tb10x: fix return value check in tb10x_gpio_probe()
gpio: tb10x: use module_platform_driver to simplify the code
pinctrl: imx27: imx27 pincontrol driver
pinctrl: imx1 core driver
pinctrl: sh-pfc: r8a7791 PFC support
sh-pfc: r8a7778: Add CAN pin groups
gpio: add TB10x GPIO driver
pinctrl: at91: correct a few typos
pinctrl: mvebu: remove redundant of_match_ptr
pinctrl: tb10x: use module_platform_driver to simplify the code
pinctrl: tb10x: fix the error handling in tb10x_pinctrl_probe()
pinctrl: add documentation for pinctrl_get_group_pins()
pinctrl: rockchip: emulate both edge triggered interrupts
pinctrl: rockchip: add rk3188 specifics
pinctrl: rockchip: remove redundant check
Pull timer changes from Ingo Molnar:
"Main changes in this cycle were:
- Updated full dynticks support.
- Event stream support for architected (ARM) timers.
- ARM clocksource driver updates.
- Move arm64 to using the generic sched_clock framework & resulting
cleanup in the generic sched_clock code.
- Misc fixes and cleanups"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (50 commits)
x86/time: Honor ACPI FADT flag indicating absence of a CMOS RTC
clocksource: sun4i: remove IRQF_DISABLED
clocksource: sun4i: Report the minimum tick that we can program
clocksource: sun4i: Select CLKSRC_MMIO
clocksource: Provide timekeeping for efm32 SoCs
clocksource: em_sti: convert to clk_prepare/unprepare
time: Fix signedness bug in sysfs_get_uname() and its callers
timekeeping: Fix some trivial typos in comments
alarmtimer: return EINVAL instead of ENOTSUPP if rtcdev doesn't exist
clocksource: arch_timer: Do not register arch_sys_counter twice
timer stats: Add a 'Collection: active/inactive' line to timer usage statistics
sched_clock: Remove sched_clock_func() hook
arch_timer: Move to generic sched_clock framework
clocksource: tcb_clksrc: Remove IRQF_DISABLED
clocksource: tcb_clksrc: Improve driver robustness
clocksource: tcb_clksrc: Replace clk_enable/disable with clk_prepare_enable/disable_unprepare
clocksource: arm_arch_timer: Use clocksource for suspend timekeeping
clocksource: dw_apb_timer_of: Mark a few more functions as __init
clocksource: Put nodes passed to CLOCKSOURCE_OF_DECLARE callbacks centrally
arm: zynq: Enable arm_global_timer
Pull ARM SoC DT updates from Olof Johansson:
"Most of this branch consists of updates, additions and general churn
of the device tree source files in the kernel (arch/arm/boot/dts).
Besides that, there are a few things to point out:
- Lots of platform conversion on OMAP2+, with removal of old board
files for various platforms.
- Final conversion of a bunch of ux500 (ST-Ericsson) platforms as
well
- Some updates to pinctrl and other subsystems. Most of these are
for DT-enablement of the various platforms and acks have been
collected"
* tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (385 commits)
ARM: dts: bcm11351: Use GIC/IRQ defines for sdio interrupts
ARM: dts: bcm: Add missing UARTs for bcm11351 (bcm281xx)
ARM: dts: bcm281xx: Add card detect GPIO
ARM: dts: rename ARCH_BCM to ARCH_BCM_MOBILE (dt)
ARM: bcm281xx: Add device node for the GPIO controller
ARM: mvebu: Add Netgear ReadyNAS 104 board
ARM: tegra: fix Tegra114 IOMMU register address
ARM: kirkwood: add support for OpenBlocks A7 platform
ARM: dts: omap4-panda: add DPI pinmuxing
ARM: dts: AM33xx: Add RNG node
ARM: dts: AM33XX: Add hwspinlock node
ARM: dts: OMAP5: Add hwspinlock node
ARM: dts: OMAP4: Add hwspinlock node
ARM: dts: use 'status' property for PCIe nodes
ARM: dts: sirf: add missed address-cells and size-cells for prima2 I2C
ARM: dts: sirf: add missed cell, cs and dma channel for SPI nodes
ARM: dts: sirf: add missed graphics2d iobg in atlas6 dts
ARM: dts: sirf: add missed chhifbg node in prima2 and atlas6 dts
ARM: dts: sirf: add missed memcontrol-monitor node in prima2 and atlas6 dts
ARM: mvebu: Add the core-divider clock to Armada 370/XP
Add missing nodes for the touchscreen available on AM335x EVM SK.
Signed-off-by: Felipe Balbi <balbi@ti.com>
There was a spelling mistake on TSC/ADC binding where "coordinate" was
spelled as "coordiante".
We can't simply fix the error due to DT being an ABI, the approach taken
was to first use correct spelling and if that fails, fall back to
miss-spelled version.
It's unfortunate that has creeped into the tree.
Pull ARM SoC board updates from Olof Johansson:
"Board-related updates. This branch is getting smaller and smaller,
which is the whole idea so that's reassuring.
Right now by far most of the code is related to shmobile updates, and
they are now switching over to removal of board code and migration to
multiplatform, so we'll see their board code base shrink in the near
future too, I hope.
In addition to that is some defconfig updates, some display updates
for OMAP and a bit of new board support for Rockchip boards"
* tag 'boards-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (56 commits)
ARM: rockchip: add support for rk3188 and Radxa Rock board
ARM: rockchip: add dts for bqcurie2 tablet
ARM: rockchip: enable arm-global-timer
ARM: rockchip: move shared dt properties to common source file
ARM: OMAP2+: display: Create omap_vout device inside omap_display_init
ARM: OMAP2+: display: Create omapvrfb and omapfb devices inside omap_display_init
ARM: OMAP2+: display: Create omapdrm device inside omap_display_init
ARM: OMAP2+: drm: Don't build device for DMM
ARM: tegra: defconfig updates
RX-51: Add support for OMAP3 ROM Random Number Generator
ARM: OMAP3: RX-51: ARM errata 430973 workaround
ARM: OMAP3: Add secure function omap_smc3() which calling instruction smc #1
ARM: shmobile: marzen: enable INTC IRQ
ARM: shmobile: bockw: add SMSC support on reference
ARM: shmobile: Use SMP on Koelsch
ARM: shmobile: Remove KZM9D reference DTS
ARM: shmobile: Let KZM9D multiplatform boot with KZM9D DTB
ARM: shmobile: Remove non-multiplatform KZM9D reference support
ARM: shmobile: Use KZM9D without reference for multiplatform
ARM: shmobile: Sync KZM9D DTS with KZM9D reference DTS
Pull ARM SoC platform changes from Olof Johansson:
"New and updated SoC support. Among the things new for this release
are:
- More support for the AM33xx platforms from TI
- Tegra 124 support, and some updates to older tegra families as well
- imx cleanups and updates across the board
- A rename of Broadcom's Mobile platforms which were introduced as
ARCH_BCM, and turned out to be too broad a name. New name is
ARCH_BCM_MOBILE.
- A whole bunch of updates and fixes for integrator, making the
platform code more modern and switches over to DT-only booting.
- Support for two new Renesas shmobile chipsets. Next up for them is
more work on consolidation instead of introduction of new
non-multiplatform SoCs, we're all looking forward to that!
- Misc cleanups for older Samsung platforms, some Allwinner updates,
etc"
* tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (159 commits)
ARM: bcm281xx: Add ARCH_BCM_MOBILE to bcm config
ARM: bcm_defconfig: Run "make savedefconfig"
ARM: bcm281xx: Add ARCH Timers to config
rename ARCH_BCM to ARCH_BCM_MOBILE (mach-bcm)
ARM: vexpress: Enable platform-specific options in defconfig
ARM: vexpress: Make defconfig work again
ARM: sunxi: remove .init_time hooks
ARM: imx: enable suspend for imx6sl
ARM: imx: ensure dsm_request signal is not asserted when setting LPM
ARM: imx6q: call WB and RBC configuration from imx6q_pm_enter()
ARM: imx6q: move low-power code out of clock driver
ARM: imx: drop extern with function prototypes in common.h
ARM: imx: reset core along with enable/disable operation
ARM: imx: do not return from imx_cpu_die() call
ARM: imx_v6_v7_defconfig: Select CONFIG_PROVE_LOCKING
ARM: imx_v6_v7_defconfig: Enable LEDS_GPIO related options
ARM: mxs_defconfig: Turn off CONFIG_DEBUG_GPIO
ARM: imx: replace imx6q_restart() with mxc_restart()
ARM: mach-imx: mm-imx5: Retrieve iomuxc base address from dt
ARM: mach-imx: mm-imx5: Retrieve tzic base address from dt
Pull ARM SoC cleanups from Olof Johansson:
"This branch contains code cleanups, moves and removals for 3.13.
Qualcomm msm targets had a bunch of code removal for legacy non-DT
platforms. Nomadik saw more device tree conversions and cleanup of
old code. Tegra has some code refactoring, etc.
One longish patch series from Sebastian Hasselbarth changes the
init_time hooks and tries to use a generic implementation for most
platforms, since they were all doing more or less the same things.
Finally the "shark" platform is removed in this release. It's been
abandoned for a while and nobody seems to care enough to keep it
around. If someone comes along and wants to resurrect it, the removal
can easily be reverted and code brought back.
Beyond this, mostly a bunch of removals of stale content across the
board, etc"
* tag 'cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (79 commits)
ARM: gemini: convert to GENERIC_CLOCKEVENTS
ARM: EXYNOS: remove CONFIG_MACH_EXYNOS[4, 5]_DT config options
ARM: OMAP3: control: add API for setting IVA bootmode
ARM: OMAP3: CM/control: move CM scratchpad save to CM driver
ARM: OMAP3: McBSP: do not access CM register directly
ARM: OMAP3: clock: add API to enable/disable autoidle for a single clock
ARM: OMAP2: CM/PM: remove direct register accesses outside CM code
MAINTAINERS: Add patterns for DTS files for AT91
ARM: at91: remove init_machine() as default is suitable
ARM: at91/dt: split sama5d3 peripheral definitions
ARM: at91/dt: split sam9x5 peripheral definitions
ARM: Remove temporary sched_clock.h header
ARM: clps711x: Use linux/sched_clock.h
MAINTAINERS: Add DTS files to patterns for Samsung platform
ARM: EXYNOS: remove unnecessary header inclusions from exynos4/5 dt machine file
ARM: tegra: fix ARCH_TEGRA_114_SOC select sort order
clk: nomadik: fix missing __init on nomadik_src_init
ARM: drop explicit selection of HAVE_CLK and CLKDEV_LOOKUP
ARM: S3C64XX: Kill CONFIG_PLAT_S3C64XX
ASoC: samsung: Use CONFIG_ARCH_S3C64XX to check for S3C64XX support
Pull ARM SoC low-priority fixes from Olof Johansson:
"A set of fixes for various platforms that weren't considered bad
enough to include in 3.12 (nor -stable). Mostly simple typo fixes,
etc"
* tag 'fixes-nc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc:
ARM: OMAP2+: irq, AM33XX add missing register check
ARM: OMAP2+: wakeupgen: AM43x adaptation
ARM: OMAP1: Fix a bunch of GPIO related section warnings after initdata got corrected
ARM: dts: fix PL330 MDMA1 address in DT for Universal C210 board
ARM: dts: Work around lack of cpufreq regulator lookup for exynos4210-origen and trats boards
ARM: dts: Fix typo earlyprintk in exynos5440-sd5v1 and ssdk5440 boards
ARM: dts: Correct typo in use of samsung,pin-drv for exynos5250
ARM: rockchip: remove obsolete rockchip,config properties
ARM: rockchip: fix wrong use of non-existent CONFIG_LOCAL_TIMERS
ARM: mach-omap1: Fix omap1510_fpga_init_irq() implicit declarations.
ARM: OMAP1: fix incorrect placement of __initdata tag
ARM: OMAP: remove deprecated IRQF_DISABLED
ARM: OMAP2+: throw the die id into the entropy pool
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging driver update from Greg KH:
"Here's the big drivers/staging/ update for 3.13-rc1.
Nothing major here, just a _ton_ of fixes and cleanups, mostly driven
by the new round of OPW applicants, but also there are lots of other
people doing staging tree cleanups these days in order to help get the
drivers into mergable shape.
We also merge, and then revert, the ktap code, as Ingo and the other
perf/ftrace developers feel it should go into the "real" part of the
kernel with only a bit more work, so no need to put it in staging for
now.
All of this has been in linux-next for a while with no reported
issues"
* tag 'staging-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (1045 commits)
staging: drm/imx: fix return value check in ipu_add_subdevice_pdata()
Staging: zram: Fix access of NULL pointer
Staging: zram: Fix variable dereferenced before check
Staging: rtl8187se: space prohibited before semicolon in r8185b_init.c
Staging: rtl8187se: fix space prohibited after that open parenthesis '(' in r8185b_init.c
Staging: rtl8187se: fix braces {} are not necessary for single statement blocks in r8185b_init.c
Staging: rtl8187se: fix trailing whitespace in r8185b_init.c
Staging: rtl8187se: fix please, no space before tabs in r8185b_init.c
drivers/staging/nvec/Kconfig: remove trailing whitespace
Staging: dwc2: Fix variable dereferenced before check
Staging: xgifb: fix braces {} are not necessary for any arm of this statement
staging: rtl8192e: remove unneeded semicolons
staging: rtl8192e: use true and false for bool variables
staging: ft1000: return values corrected in scram_start_dwnld
staging: ft1000: change values of status return variable in write_dpram32_and_check
staging: bcm: Remove unnecessary pointer casting
imx-drm: ipuv3-crtc: Invert IPU DI0 clock polarity
staging: r8188eu: Fix sparse warnings in rtl_p2p.c
staging: r8188eu: Fix sparse warnings in rtw_mlme_ext.c
staging: r8188eu: Fix sparse warnings in rtl8188e.cmd.c
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB driver update from Greg KH:
"Here's the big USB driver update for 3.13-rc1.
It includes the usual xhci changes, EHCI updates to get the scheduling
of USB transactions working better, and a raft of gadget and musb
updates as well.
issues"
* tag 'usb-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (305 commits)
USB: Maintainers change for usb serial drivers
usb: usbtest: support container id descriptor test
usb: usbtest: support superspeed device capbility descriptor test
usb: usbtest: support usb2 extension descriptor test
usb: chipidea: only get vbus regulator for non-peripheral mode
USB: ehci-atmel: add usb_clk for transition to CCF
usb: cdc-wdm: ignore speed change notifications
USB: cdc-wdm: support back-to-back USB_CDC_NOTIFY_RESPONSE_AVAILABLE notifications
usbatm: Fix dynamic_debug / ratelimited atm_dbg and atm_rldbg macros
printk: pr_debug_ratelimited: check state first to reduce "callbacks suppressed" messages
usb: usbtest: support bos descriptor test for usb 3.0
USB: phy: samsung: Support multiple PHYs of same type
usb: wusbcore: change WA_SEGS_MAX to a legal value
usb: wusbcore: add a quirk for Alereon HWA device isoc behavior
usb: wusbcore: combine multiple isoc frames in a single transfer request.
usb: wusbcore: set the RPIPE wMaxPacketSize value correctly
usb: chipidea: host: more enhancement when ci->hcd is NULL
usb: ohci: remove ep93xx bus glue platform driver
usb: usbtest: fix checkpatch warning as sizeof code style
UWB: clean up attribute use by using ATTRIBUTE_GROUPS()
drivers/net/ethernet/emulex/benet/be.h
drivers/net/netconsole.c
net/bridge/br_private.h
Three mostly trivial conflicts.
The net/bridge/br_private.h conflict was a function signature (argument
addition) change overlapping with the extern removals from Joe Perches.
In drivers/net/netconsole.c we had one change adjusting a printk message
whilst another changed "printk(KERN_INFO" into "pr_info(".
Lastly, the emulex change was a new inline function addition overlapping
with Joe Perches's extern removals.
Commit 2361613206e6, "of/irq: Refactor interrupt-map parsing" introduced
a bug. The irq parsing will fail for some nodes that don't have a reg
property. It is fixed by deferring the check for reg until it is
actually needed. Also adjust the testcase data to catch the bug.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Tested-by: Ming Lei <tom.leiming@gmail.com>
Cc: Rob Herring <rob.herring@calxeda.com>
From Jason Cooper:
- add the Openblocks A7 board
- add Netgear ReadyNAS 104 board
* tag 'dt-3.13-5' of git://git.infradead.org/linux-mvebu:
A handful of DT updates from Christian Daudt for the broadcom mobile
platforms, including their rename of the platform to BCM_MOBILE to keep
BCM for the vendor-level options.
* bcm/dt:
Trivial patch to make use of GIC/IRQ defines on the bcm11351 sdio
interrupt properties.
Signed-off-by: Matt Porter <matt.porter@linaro.org>
Signed-off-by: Christian Daudt <bcm@fixthebug.org>
This adds in three more UARTs that were not declared earlier.
Signed-off-by: Tim Kryger <tim.kryger@linaro.org>
Reviewed-by: Markus Mayer <markus.mayer@linaro.org>
Reviewed-by: Matt Porter <matt.porter@linaro.org>
Register GPIO 14 as card detect interrupt for the SD card slot.
Signed-off-by: Markus Mayer <markus.mayer@linaro.org>
Currently ARCH_BCM has been used for Broadcom
Mobile V7 based SoCs. In order to allow other Broadcom
SoCs to also use mach-bcm directory and files, this patch
renames the original ARCH_BCM to ARCH_BCM_MOBILE, and
uses ARCH_BCM to define any Broadcom chip residing
in mach-bcm directory.
Add the GPIO controller device node for the Broadcom bcm281xx family of
mobile SoCs.
Reviewed-by: Tim Kryger <tim.kryger@linaro.org>
Reviewed-by: Tomasz Figa <t.figa@samsung.com>
Main hardware parts of the (Armada 370 based) NETGEAR ReadyNAS 104 are
supported by mainline kernel (USB 3.0 rear ports, USB 2.0 front port,
Gigabit controller and PHYs, serial port, LEDs, buttons, SATA ports,
G762 fan controller) and referenced in provided .dts file. Some additonal
work remains for:
- Intersil ISL12057 I2C RTC and Alarm chip: working driver but needs
to be splitted for submission of RTC part first;
- Front LCD (Winstar 1602G): driver needs to be written
- Armada NAND controller (to access onboard 128MB of NAND): support
being pushed by @free-electrons people
- 4 front SATA LEDs controlled via GPIO brought by NXP PCA9554:
driver is available upstream. Not referenced/tested yet.
but the device is usable w/o those.
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
Acked-by: Andrew Lunn <andrew@lunn.ch>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
The IOMMU node's reg property contains completely bogus values! Somehow,
this had no practical effect, despite the fact the IOMMU driver appears
to be writing to those registers. I suppose that since no HW modules is
actually at that address, the writes simply had no effect.
Note that I'm not CCing stable here, even though the problem exists as
far back as v3.9, simply because this patch doesn't fix any observed
issue, and I don't want to run the risk of suddenly writing to some
registers and causing a regression.
Signed-off-by: Hiroshi Doyu <hdoyu@nvidia.com>
[swarren, wrote commit description]
The OpenBlocks A7 board is designed and sold by PlatHome, and based on
a Kirkwood 6283 Marvell SoC. It is quite similar to the OpenBlocks A6
already supported in the kernel, with the following main differences:
- The A6 uses a RTC on I2C, while the A7 uses the internal SoC RTC.
- The A6 has one Ethernet port, while the A7 has two Ethernet ports
- The A6 has only one USB port, while the A7 integrates a USB hub,
which provides two front-side USB port, and an internal USB port as
well.
- The A6 has 512 MB of RAM, while the A7 has 1 GB of RAM.
- Slightly different GPIOs for some functions.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/dt
From Tony Lindgren:
Few device tree changes that fix boot time warnings and
make panda display work with recent u-boot.
* tag 'omap-for-v3.13/dt-fixes-for-merge-window' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
New u-boot versions no longer set the pinmuxing for Panda's DPI output,
and the muxing has to be done in the .dts file.
Add pinmuxing for DPI and TFP410. Without these, the DVI output on Panda
does not work with recent u-boot.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
Add the AM33xx RNG module's device tree data.
Also add Documentation file describing the data
for the RNG module.
Add the hwspinlock device tree node for AM33xx family
of SoCs.
Signed-off-by: Suman Anna <s-anna@ti.com>
Add the hwspinlock device tree node for OMAP5 SoCs.
Add the hwspinlock device tree node for OMAP4 family
of SoCs.
Set the default status for PCIe to disabled in the exynos5440.dtsi
file and let the board dts files such as exynos5440-ssdk5440.dts
enable the PCIe. However, keep the PCIe for SD5v1 board disabled,
because there is no PCIe slot on SD5v1 board.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
From Barry Song:
Some missed dt nodes for sirf dts for 3.13. Among them:
- add missed chhifbg node in prima2 and atlas6 dts
- add missed cell, cs and dma channel for SPI nodes
- add missed graphics2d iobg in atlas6 dts
- add missed address-cells and size-cells for prima2 I2C
- add missed memcontrol-monitor node in prima2 and atlas6 dts
* sirf/dt:
here prima2 i2c node is lacking of address-cells and size-cells.
Signed-off-by: Renwei Wu <Renwei.Wu@csr.com>
Signed-off-by: Barry Song <Baohua.Song@csr.com>
here we need to add missed cell, cs and dma channels prop in SPI nodes
to match with drivers.
there is a bus bridge for graphics 2D module lost in current dts, this patch takes it
back.
Signed-off-by: Jiansong Chen <jiansong.chen@csr.com>
CPHIF(Cell phone interface) is behind sys bridge, this patch adds the
missed node.
memcontrol-monitor provides the ability of monitoring the memory bandwidth.
Signed-off-by: Ye He <ye.he@csr.com>
Two of the versatile irq definitions are incorrect, mostly because two
devices have connections to more than one interrupt controller. Fix them
by using the new interrupts-extended property to fan out without using
an awful interrupt-map nexus node.
The standard interrupts property in device tree can only handle
interrupts coming from a single interrupt parent. If a device is wired
to multiple interrupt controllers, then it needs to be attached to a
node with an interrupt-map property to demux the interrupt specifiers
which is confusing. It would be a lot easier if there was a form of the
interrupts property that allows for a separate interrupt phandle for
each interrupt specifier.
This patch does exactly that by creating a new interrupts-extended
property which reuses the phandle+arguments pattern used by GPIOs and
other core bindings.
Acked-by: Kumar Gala <galak@codeaurora.org>
[grant.likely: removed versatile platform hunks into separate patch]
Some more dts changes from Benoit Cousson <bcousson@baylibre.com> via
Tony Lindgren:
- Add a lot of N900 nodes
- Add OPP table to OMAP5/DRA7
- Add support for Newflow NanoBone board
- Add i2c aliases
- Add McASP and audio support
- Add reset/idle on init bindings for OMAP
- Add more nodes for AM4272
* tag 'omap-for-v3.13/dt-late' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: (42 commits)
ARM: dts: omap5-uevm: Remove pinmux for dmic pins
ARM: dts: omap5-uevm: Correct twl6040 reset GPIO pinmux
ARM: dts: TWL4030: Add power button support
ARM: dts: omap3-n900: Add LP5523 support
ARM: dts: omap3-n900: Add TLV320AIC3X support
ARM: dts: omap3-n900:: Mux RX51_LCD_RESET_GPIO in DTS
ARM: dts: omap3-n900: Add NAND support
ARM: dts: omap3-n900: Specify regulator info
ARM: dts: TWL4030: Add missing regulators
ARM: dts: omap3-n900: Add vibrator device
ARM: dts: omap3-n900: GPIO key definitions
ARM: dts: omap3-n900: Add support for SD cards
ARM: dts: omap3-n900: Add UART support
ARM: dts: omap3-n900: Fix i2c bus speed
ARM: dts: omap3-n900: Add pinctrl for i2c devices
ARM: dts: DRA7: Add CPU OPP table
ARM: dts: OMAP5: Add CPU OPP table
ARM: dts: dra7-evm: add smps123 supply for CPU
ARM: dts: omap5-uevm: add smps123 supply for CPU
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into next/cleanup
From Paul Walmsley <paul@pwsan.com> via Tony Lindgren:
Move some of the OMAP2+ CM and System Control Module direct
register accesses into CM- and System Control
Module-specific "drivers" underneath arch/arm/mach-omap2/. This
is a prerequisite for moving this code out of arch/arm/mach-omap2/ into
drivers/.
Basic test logs are available here:
http://www.pwsan.com/omap/testlogs/cm_scm_cleanup_a_v3.13/20131019101809/
* tag 'omap-for-v3.13/cm-scm-cleanup-signed' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap:
+ Linux 3.12-rc4
From Jason Cooper, mvebu dt changes for v3.13 (round 4):
- mvebu
- core divider clock driver dt binding and nodes
* tag 'dt-3.13-4' of git://git.infradead.org/linux-mvebu:
ARM: mvebu: Add a 2 GHz fixed-clock Armada 370/XP
ARM: mvebu: Add Core Divider clock device-tree binding
into next/dt
From Shawn Guo:
The imx/mxs device tree changes for 3.13:
- Use macros for mxs pinctrl settings
- New board support: VF610 Cosmic/Cosmic+, imx6q-udoo, MSR M28CU3
- Support DSPI device for vf610
- Add PCIe device for imx6qdl
- Add UHS pinctrl states for imx6sl and imx6qdl
- Display support for APF and imx51-babbage boards
- Enable SPI NOR and USB for imx6sl-evk board
- Enable LVDS for imx6q-sabrelite and SPDIF for imx6qdl-wandboard
- Misc updates on boards: TX28, imx6qdl-wandboard, imx53-qsb etc.
- Some random updates on imx51 device tree
* tag 'imx-dt-3.13' of git://git.linaro.org/people/shawnguo/linux-2.6: (44 commits)
ARM: imx: imx6sl iomuxc syscon is compatible to imx6q
ARM: dts: imx6sl-evk: enable the SPI NOR
ARM: dts: imx6sl: add a pinctrl for ECSPI1
ARM: imx27: add missing #pwm-cells property
ARM: dts: imx6sl: add pinctrl uhs states for usdhc
ARM: dts: imx6qdl-sabresd: Add backlight support for lvds
ARM: dts: imx51-babbage: Make DVI and WVGA panel functional
ARM: imx27-apf27dev: Add framebuffer support
ARM: imx51-apf51dev: Add parallel display support
ARM: dts: imx53-qsb: Do not use GPIO1_8 as wakeup source
ARM: dts: imx53-qsb: SDHC1 does not have cd-gpios
ARM: dts: imx53-qsb: SDHC3 is connected in 8-bit mode
ARM: dts: mxs: Add MSR M28CU3 board
ARM: dts: imx6qdl-wandboard: Provide phy-reset-gpios
ARM: dts: imx6qdl-sabresd: Provide phy-reset-gpios
ARM: dts: imx6q-sabrelite: Add ethernet phy reset pin into hog
ARM: dts: imx6qdl: add pcie device node
ARM: dts: imx6q-udoo: Add initial board support
ARM: dts: mxs: Add muxing options for the SSP2 MMC
ARM: dts: add initial VF610 Cosmic/Cosmic+ board support
into next/soc
From Shawn Guo:
The imx/mxs soc changes for 3.13:
* Low-level debug support for Vybrid
* Support soc bus/device for imx6
* Suspend support for imx6dl and imx6sl
* The imx6q clock updates for PCIe and audio PLL support
* IOMUXC GPR update for fec support
* Some random cleanup
* A few defconfig updates
* tag 'imx-soc-3.13' of git://git.linaro.org/people/shawnguo/linux-2.6: (31 commits)
ARM: mach-imx: clk-imx51-imx53: Retrieve base address and irq from dt
ARM: mxs_defconfig: Add CHIPIDEA_UDC support
ARM: imx: Include linux/err.h
ARM: imx_v6_v7_defconfig: Add CHIPIDEA_UDC support
ARM: imx_v6_v7_defconfig: Add SPDIF support
ARM: imx6q: clock and Kconfig update for PCIe support
ARM: imx: Add LVDS general-purpose clocks to i.MX6Q
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung.git into next/dt
From Kukjin Kim, these are device-tree updates for Exynos. Among the changes:
- add MIPI PHY node for exynos4
- update regulator for origen and exynos5250-arndale
- add support HDMI for exynos5250, exynos5420
* commit '93457b9cb980ffeeef020c3bcd99065c3807619b':
ARM: dts: Add HDMI related I2C nodes for Arndale board
ARM: dts: enable hdmi subsystem for exynos5420 smdk board
ARM: dts: add dt nodes for hdmi subsystem for exynos5420
ARM: dts: add i2c device nodes for Exynos5420
ARM: dts: add clocks to hdmi dt node for exynos5250
ARM: dts: add mixer clocks to mixer node for Exynos5250
of/documentation: update with clock information for exynos hdmi subsystem
ARM: dts: Disable Exynos5250 I2S controllers by default
ARM: dts: Add reg property to regulator nodes in exynos5250-arndale
ARM: dts: Add fixed voltage regulator to simple bus for origen
ARM: dts: Add MIPI PHY node to exynos4.dtsi
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson into next/dt
From Linus Walleij:
Five incremental device tree patches around the clock handling,
and adding SSP/SPI devices to the device tree.
* tag 'ux500-dt-for-v3.13-3' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-stericsson:
ARM: ux500: register all SSP and SPI blocks
ARM: ux500: fix I2C4 clock bit
ARM: ux500: fix clock for GPIO blocks 6 and 7
clk: ux500: fix erroneous bit assignment
ARM: ux500: fix clock for GPIO block 8
