Force HS200 by masking bit 63 of the SDHCI capability register.
The i.MX ESDHC driver uses SDHCI_QUIRK2_CAPS_BIT63_FOR_HS400. With
that the stack checks bit 63 to descide whether HS400 is available.
Using sdhci-caps-mask allows to mask bit 63. The stack then selects
HS200 as operating mode.
This prevents rare communication errors with minimal effect on
performance:
sdhci-esdhc-imx 30b60000.usdhc: warning! HS400 strobe DLL status REF not lock!
There is no fixed 1.8V regulator. VDDD is connected to the PMIC.
Add support for Aster Carrier Board with Colibri iMX6ULL.
The current Colibri iMX7 device tree are prepared for flexcan1 and
flexcan2. However their settings are different and the integration
is done to a different degree.
Unify that.
Switch on 22 kOhm pull ups and lower the I2C frequency to around 40kHz
to get a more reliable communication.
The apalis has a 8 and 4 bit SD/MMC interface.
Switch on a 100k pull up on the card detect pins for carrier boards
which leave the pin floating.
Switch on hysteresis in case the signal has slow rise or fall times.
On imx6 the SGTL5000 audio codec supply voltage is 3.3V and
not 2.5V as might have been copied over from other modules.
Output is slightly overamplified if the value is not corrected,
which may lead to signal clipping.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
The i.MX6 ULL's watchdog is used to reset the SoC on reboot. The watchdog is
configured to use the SoC's internal reset signal which does not generate a
reset pulse on nRESET_OUT. Change the watchdog configuration to use a SoC
external HW signal.
This will additionally change the 'Reset cause' message from U-Boot
from WDOG to POR.
Use a pinmux configuration for SD/MMC card detect and SPI chip
select instead of relying on reset/boot settings. There have
been no adverse effects observed, but it seems sensible to mux
the pads explicitly.
This reverts commit 5f60d82d38a8af8529d1493463e301e548595ccb.
Several modules have issues with HS400 at 100MHz at room temperature
but they seem to work fine at HS400 at 200MHz. Do not restrict
frequency for now.
The Capacitive Touch Adapter is an interface board designed to easily
connect the Capacitive Touch Display 7" Parallel to the Colibri Carrier
boards which do not have PCAP connector yet available on board.
Change the pins for interrupt and reset to those defined in the
Capacitive Touch Adapter's datasheet.
While at it remove the '#ifdef PCAP' in favour of disabled nodes.
That way one can fixup the device tree in U-Boot to disable the
pwm nodes and enable the connected touch controller.
e.g. for a Colibri iMX6S/DL:
Colibri iMX6 # setenv fdt_fixup 'fdt addr ${fdt_addr_r} && fdt resize && fdt set /soc/aips-bus@02100000/i2c@021a8000/atmel_mxt_ts@4a status okay; fdt set /soc/aips-bus@02000000/pwm@02080000 status disabled; fdt set /soc/aips-bus@02000000/pwm@0208c000 status disabled'
Colibri iMX6 # saveenv
Toradex Carrier boards use the ST M41T0 RTC (not M41T00). The RTC
is almost the same, but the M41T0 needs some special handling in
case the oscillator fails. Now that support for this difference is
available, using the new compatible string to make use of it.
Sync with commit 10e718b1c60c4e490e6972cfa58e97fcf5260685
Synced with 558d378d522189ad68fcb00aff05fd134bf20924
Add mxt nodes to dts and gpio-reset functionality.
Synchronize with commit fcfdb9c32075501e64751cc6a79fd91d15933692
Prepare FlexCAN use on SODIMM 55/63. Those SODIMM pins are compatible
for CAN bus use with several modules from the Colibri family.
Commit 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif")
changed many more clocks than only the SPDIF core clock as stated in
the commit message.
The MLB clock has been added and this causes SPDIF regression as
reported by Xavi Drudis Ferran and also in this forum post:
https://forum.digikey.com/thread/34240
The MX6Q Reference Manual does not mention that MLB is a clock related
to SPDIF, so change it back to a dummy clock to restore SPDIF
functionality.
Thanks to Ambika for providing the fix at:
https://community.nxp.com/thread/387131
Fixes: 833f2cbf7091 ("ARM: dts: imx6: change the core clock of spdif")
Cc: <stable@vger.kernel.org> # 4.4.x
Reported-by: Xavi Drudis Ferran <xdrudis@tinet.cat>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Tested-by: Xavi Drudis Ferran <xdrudis@tinet.cat>
(cherry picked from commit f065e9e4addd75c21bb976bb2558648bf4f61de6)
This fix was correct, but overwritten by commit 833f2cbf7091099baee28136dc68678e974c0ac5.
MLB (Media Local Bus) Clock is in fact not related to SPDIF according to the MX6Q Reference
Manual. Tested playback and record on pulseaudio with 44.1kHz samples.
dtc recently added PCI bus checks. Fix these warnings.
Signed-off-by: Rob Herring <robh@kernel.org>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
(cherry picked from commit 3e1b857786f0d46a92b3a4d7878767883ed90bdc)
To operate RS-485 on Toradex Carrier Boards a low active RTS signal
is required. Furthermore, a low active RTS signal requires the
receiver to be active (this seems to be a hardware limitation of the
i.MX UART).
Remove duplicate nodes introduced with the move to L4.9.11
release.
The new Apalis iMX6 Mezzanine board allows access to the MIPI-CSI2
interface from the evaluation board. The current device tree has
different GPIO pin assignments for the camera reset and power pins.
Change the pin assignment to use Apalis GPIO1 for reset and Apalis
GPIO2 for power down.
Add timings for LTTD1280800101-L4WH-CT1 panel used in the new
Capacitive Touch 10.1" LVDS display.
Note that the color mapping is to be set as follows:
fsl,data-mapping = "spwg";
fsl,data-width = <24>;
The Atmel maXTouch multitouch controller driver does not control the
reset line connected to the chip. Use a GPIO reset controller node to
release the reset line and make the controller work.
Note that both the reset controller's and the mxt mutitouch controller's
node are set to disabled. Either change this in the dtsi source or fix
this from U-Boot if you use an Atmel maXTouch multitouch controller.
setenv fdt_fixup 'fdt addr ${fdt_addr_r} && fdt set /soc/aips-bus@02100000/i2c@021a0000/atmel_mxt_ts@4a status okay && fdt set /mxt-reset status okay'
Add alias for Ethernet controllers. This allows code to determine
id of controllers using of_alias_get_id.
Commit 95c163471135 ("usb: chipidea: use of extcon framework to
work for non OTG case") requires both pins to be specified (ID and
VBUS pin) to work correctly.
Fix the remaining dts.
toradex_4.9-1.0.x-imx-next
This is the 4.9.87 stable release
drivers/dma/fsl-edma.c
commit 74402055a2d3ec998a1ded599e86185a27d9bbf4 upstream.
The pinmuxing was missing for I2C1 which was causing intermittent issues
with the PMIC which is connected to I2C1. The bootloader did not quite
configure the I2C1 either, so when running at 2.6MHz, it was generating
errors at time.
This correctly sets the I2C1 pinmuxing so it can operate at 2.6MHz
Fixes: 687c27676151 ("ARM: dts: Add minimal support for LogicPD Torpedo
DM3730 devkit")
commit 84c7efd607e7fb6933920322086db64654f669b2 upstream.
errors at times.
Fixes: ab8dd3aed011 ("ARM: DTS: Add minimal Support for Logic PD DM3730
SOM-LV")
The SNVS RTC does not use an address in its node name anymore.
Instead of using the full path, simply use the SNVS RTC label.
The SNVS subnodes reenable the power key which is not used on the
Colibri iMX7 modules. Disable the power key again.
Also make sure that the priority of the RTCs used is defined.
Add SNVS subnodes such as internal SNVS RTC.
Fixes: b66e57551f4e ("ARM: dts: imx7d: move nodes to i.MX 7Solo device tree")
The operating points are already present in imx7d.dtsi, there is
no need to dupplicate the operating points in the module level
device tree.
The i.MX Thermal driver requires a cpufreq device to be present.
Create a single operating point to make sure cpufreq device can
successfully probe.
[ Upstream commit 506e8a912661c97b41adc8a286b875d01323ec45 ]
dtc warns about two 'clocks' properties that have an extraneous '1'
at the end:
arch/arm/boot/dts/ls1021a-qds.dtb: Warning (clocks_property): arch/arm/boot/dts/ls1021a-twr.dtb: Warning (clocks_property): Property 'clocks', cell 1 is not a phandle reference in /soc/i2c@2180000/mux@77/i2c@4/sgtl5000@2a
arch/arm/boot/dts/ls1021a-qds.dtb: Warning (clocks_property): Missing property '#clock-cells' in node /soc/interrupt-controller@1400000 or bad phandle (referred from /soc/i2c@2180000/mux@77/i2c@4/sgtl5000@2a:clocks[1])
Property 'clocks', cell 1 is not a phandle reference in /soc/i2c@2190000/sgtl5000@a
arch/arm/boot/dts/ls1021a-twr.dtb: Warning (clocks_property): Missing property '#clock-cells' in node /soc/interrupt-controller@1400000 or bad phandle (referred from /soc/i2c@2190000/sgtl5000@a:clocks[1])
The clocks that get referenced here are fixed-rate, so they do not
take any argument, and dtc interprets the next cell as a phandle, which
is invalid.
This is the 4.9.84 stable release
[ Upstream commit d364b038bc962f494cffb8f6cb6cddbe41bcb5b6 ]
Looks like the interrupt property is missing the controller and level
information causing:
Warning (interrupts_property): interrupts size is (4), expected multiple
of 12 in /ocp/elm@48078000
[ Upstream commit ca41e244517d6d3f1600c229ff7ca615049c1e9c ]
The DMA binding for eDMA needs 2 parameters, not 1.
The second, missing parameter is the tptc to be used for the channel.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
[ Upstream commit 627395a6f8091c0aa18f49dca7df59ba3ec147ef ]
Fixes the following warnings:
arch/arm/boot/dts/am437x-cm-t43.dtb: Warning (interrupts_property):
interrupts size is (8), expected multiple of 12 in
/ocp@44000000/mcasp@48038000
/ocp@44000000/mcasp@4803C000
[ Upstream commit cd7594ac3281722cb8f10d6f6c7e4287747c7a9d ]
The pin assignment for the wl127x interrupt was incorrect. I am
not sure how this every worked. This also eliminates a conflict with
the SMC911x ethernet driver and properly moves pinmuxes for the
related gpio to omap3_pmx_wkup from omap3_pmx_core.
DM3730 SOM-LV")
[ Upstream commit 3c18bbf3d11d2005da08b57ff26f44ff1c2b12d0 ]
This patch fixes and issue where the NAND and GPMC based ethernet
controller stopped working. This also updates the GPMC settings
to be consistent with the Logic PD Torpedo development from the
commit listed above.
Fixes: 44e4716499b8 ("ARM: dts: omap3: Fix NAND device nodes")
[ Upstream commit cf87634c8b24e24bf379b8c6807c8b0fb5f23567 ]
There's been a reproducable USB OHCI/EHCI cpuidle related hang on omap4
for a while that happens after about 20 - 40 minutes on an idle system
with some data feeding device being connected, like a USB GPS device or
a cellular modem.
This issue happens in cpuidle states C2 and C3 and does not happen if
cpuidle is limited to C1 state only. The symptoms are that the whole
system hangs and never wakes up from idle, and if a watchdog is
configured the system reboots after a while.
Turns out that OHCI/EHCI devices on omap4 are trying to use the GIC
interrupt controller directly as a parent instead of the WUGEN. We
need to pass the interrupts through WUGEN to GIC to provide the wakeup
events for the processor.
Let's fix the issue by removing the gic interrupt-parent and use the
default interrupt-parent wakeupgen instead. Note that omap5.dtsi had
this already fixes earlier by commit 7136d457f365 ("ARM: omap: convert
wakeupgen to stacked domains") but we somehow missed omap4 at that
point.
Fixes: 7136d457f365 ("ARM: omap: convert wakeupgen to stacked domains")
Cc: Dave Gerlach <d-gerlach@ti.com>
Cc: Nishanth Menon <nm@ti.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
Reviewed-by: Roger Quadros <rogerq@ti.com>
commit 586b2a4befad88cd87b372a1cea01e58c6811ea9 upstream.
The EB MP board probably has a character LCD but the board manual does
not really state which IRQ it has assigned to this device. The invalid
assignment was a mistake by me during submission of the DTSI where I was
looking for the reference, didn't find it and didn't fill it in.
Delete this for now: it can probably be fixed but that requires access
to the actual board for some trial-and-error experiments.
commit ae72e95b5e4ded145bfc6926ad9457b74e3af41a upstream.
The hifsys and ethsys needs the definition of the reset-cells
property. Fix this.
Reviewed-by: Rob Herring <robh@kernel.org>
Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
commit 5c1037196b9ee75897c211972de370ed1336ec8f upstream.
The ohci-hcd node has an interrupt number but no interrupt-parent,
leading to a warning with current dtc versions:
arch/arm/boot/dts/s5pv210-aquila.dtb: Warning (interrupts_property): Missing interrupt-parent for /soc/ohci@ec300000
arch/arm/boot/dts/s5pv210-goni.dtb: Warning (interrupts_property): Missing interrupt-parent for /soc/ohci@ec300000
arch/arm/boot/dts/s5pv210-smdkc110.dtb: Warning (interrupts_property): Missing interrupt-parent for /soc/ohci@ec300000
arch/arm/boot/dts/s5pv210-smdkv210.dtb: Warning (interrupts_property): Missing interrupt-parent for /soc/ohci@ec300000
arch/arm/boot/dts/s5pv210-torbreck.dtb: Warning (interrupts_property): Missing interrupt-parent for /soc/ohci@ec300000
As seen from the related exynos dts files, the ohci and ehci controllers
always share one interrupt number, and the number is the same here as
well, so setting the same interrupt-parent is the reasonable solution
here.
Reviewed-by: Krzysztof Kozlowski <krzk@kernel.org>
