Based on 1 normalized pattern(s):
licensed under gplv2 or later
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 118 file(s).
Reviewed-by: Jilayne Lovejoy <opensource@jilayne.com>
Reviewed-by: Steve Winslow <swinslow@gmail.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190519154040.961286471@linutronix.de
Use tcb0 for timers as selected in at91_dt_defconfig.
[tested on usb_a9g20 and usb_a9263]
Tested-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Use the new EBI/NAND bindings to declare NAND chips and remove old NAND
nodes along the way.
Note that we keep using old bindings in at91rm9200.dtsi because this
SoC is not supported by the EBI driver.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Tested-by: Peter Rosin <peda@axentia.se>
i2c-gpio doesn't need a reg property. Change the node names to i2c-gpio-x
as used in other dts to remove the unit-address.
Solves:
Warning (unit_address_vs_reg): Node /i2c@0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c@1 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /i2c@2 has a unit name, but no reg property
The clocks group properties and the clock@0 node have been obsolete for two
years, remove them.
Remove leading zeros in OHCI node for at91sam9260 based boards.
Signed-off-by: Raashid Muhammed <raashidmuhammed@zilogic.com>
Reviewed-by: Vijay Kumar B. <vijaykumar@bravegnu.org>
Though the keyboard driver for GPIO buttons(gpio-keys) will continue to
check for/support the legacy "gpio-key,wakeup" boolean property to
enable gpio buttons as wakeup source, "wakeup-source" is the new
standard binding.
This patch replaces the legacy "gpio-key,wakeup" with the unified
"wakeup-source" property in order to avoid any futher copy-paste
duplication.
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Define Calao USB-A9260, USB-A9G20 and USB-A9G20-LPW main and slow crystals
frequencies.
This will simplify the adding of the A9260.
