2015-01-21 | ARM: sunxi: DT: Convert the DTs to use a header for the pinctrl nodes | Maxime Ripard | |
The pinctrl nodes require some extra opaque arguments for the pull up and drive strength values. Introduce a new header file and convert the device trees to replace these opaque numbers by defines. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> | |||
2015-01-21 | ARM: sunxi: DT: Convert to device tree includes | Maxime Ripard | |
Prepare the device trees to use the C preprocessor. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> | |||
2015-01-21 | ARM: dts: sun6i: Add dts file for CSQ CS908 board | Hans de Goede | |
The CSQ CS908 is an A31s based top-set box, with 1G RAM, 8G NAND, rtl8188etv usb wifi, 2 USB A receptacles (1 connected through the OTG controller), ethernet, 3.5 mm jack with a/v out and hdmi out. Note it has no sdcard slot and therefore can only be fel booted. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> |
