Update all 32bit rockchip devicetree files to use SPDX-License-Identifiers.
All files except rk3288-veyron-analog-audio.dtsi (which is GPL 2.0 only)
claim to be GPL and X11 while the actual license text is MIT. Use the
MIT SPDX tag for them.
Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com>
Acked-by: Brian Norris <briannorris@chromium.org>
Acked-by: Matthias Brugger <mbrugger@suse.com>
Acked-by: Douglas Anderson <dianders@chromium.org>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Use macros to describe gpios will make the dts easier to
read and write.
All the modifications done with sed:
sed -i -e 's/ 0 GPIO_ACTIVE_/ RK_PA0 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 1 GPIO_ACTIVE_/ RK_PA1 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 2 GPIO_ACTIVE_/ RK_PA2 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 30 GPIO_ACTIVE_/ RK_PD6 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
sed -i -e 's/ 31 GPIO_ACTIVE_/ RK_PD7 GPIO_ACTIVE_/' arch/arm/boot/dts/rk*
Tested with:
for i in dts-old/*dtb; do scripts/dtc/dtx_diff $i dts-new/$(basename $i); done
Signed-off-by: Andy Yan <andy.yan@rock-chips.com>
[also adapted the gpio interrupts]
This adds support for Firefly-RK3288, Rockchip RK3288 based development
boards made by Firefly.
There are 2 dts for 2 versions of the board. rk3288-firefly-beta.dts is
for the beta version, rk3288-firefly.dts is for the mass production version.
Signed-off-by: FUKAUMI Naoki <naobsd@gmail.com>
[removed gmac reference, due to the gmac node going through the net-tree]
Tested-by: Heiko Stuebner <heiko@sntech.de>
