[ Upstream commit fa51e1dc4b91375bc18349663a52395ad585bd3c ]
On a custom carrier board with a i.MX6Q Apalis SoM, the sgtl5000 codec
on the SoM is often not detected and the following error message is
seen when the sgtl5000 driver tries to read the ID register:
sgtl5000 1-000a: Error reading chip id -6
The reason for the error is that the MCLK clock is not provided
early enough.
Fix the problem by describing the MCLK pinctrl inside the codec
node instead of placing it inside the audmux pinctrl group.
With this change applied the sgtl5000 is always detected on every boot.
Fixes: 693e3ffaae5a ("ARM: dts: imx6: Add support for Toradex Apalis iMX6Q/D SoM")
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Reviewed-by: Tim Harvey <tharvey@gateworks.com>
The conversion of the spi-imx driver to use GPIO descriptors
in commit 8cdcd8aeee28 ("spi: imx/fsl-lpspi: Convert to GPIO descriptors")
helped to detect the following SPI chipselect polarity mismatch on an
imx6q-sabresd:
[ 4.854337] m25p80@0 enforce active low on chipselect handle
Prior to the above commit, the chipselect polarity passed via cs-gpios
property was ignored and considered active-low.
The reason for such mismatch is clearly explained in the comments inside
drivers/gpio/gpiolib-of.c:
* SPI children have active low chip selects
* by default. This can be specified negatively
* by just omitting "spi-cs-high" in the
* device node, or actively by tagging on
* GPIO_ACTIVE_LOW as flag in the device
* tree. If the line is simultaneously
* tagged as active low in the device tree
* and has the "spi-cs-high" set, we get a
* conflict and the "spi-cs-high" flag will
* take precedence.
To properly represent the SPI chipselect polarity, change it to active-low
when the "spi-cs-high" property is absent.
The imx-pwm driver supports 3 cells and this is the more flexible setting.
So use it by default and overwrite it back to two for the files that
reference the PWMs with just 2 cells to minimize changes.
This allows to drop explicit setting to 3 cells for the boards that already
depend on this. The boards that are now using 2 cells explicitly can be
converted to 3 individually.
Pull ARM devicetree updates from Arnd Bergmann:
"Most of the commits are for additional hardware support and minor
fixes for existing machines for all the usual platforms: qcom,
amlogic, at91, gemini, mediatek, ti, socfpga, i.mx, layerscape,
uniphier, rockchip, exynos, ux500, mvebu, tegra, stm32, renesas,
sunxi, broadcom, omap, and versatile.
The conversion of binding files to machine-readable yaml format
continues, along with fixes found during the validation. Andre
Przywara takes over maintainership for the old Calxeda Highbank
platform and provides a number of updates.
The OMAP2+ platforms see a continued move from platform data into dts
files, for many devices that relied on a mix of auxiliary data in
addition to the DT description
A moderate number of new SoCs and machines are added, here is a full
list:
- Two new Qualcomm SoCs with their evaluation boards: Snapdragon 865
(SM8250) is the current high-end phone chip, and IPQ6018 is a new
WiFi-6 router chip.
- Mediatek MT8516 application processor SoC for voice assistants,
along with the "pumpkin" development board
- NXP i.MX8M Plus SoC, a variant of the popular i.MX8M, along with an
evaluation board.
- Kontron "sl28" board family based on NXP LS1028A
- Eleven variations of the new i.MX6 TechNexion Pico board, combining
the "dwarf", "hobbit", "nymph" and "pi" baseboards with i.MX6/i.MX7
SoM carriers
- Three additional variants of the Toradex Colibri board family, all
based on versions of the NXP i.MX7.
- The Pinebook Pro laptop based on Rockchip RK3399
- Samsung S7710 Galaxy Xcover 2, a 2013 vintage Android phone based
on the ST-Ericsson u8500 platform
- DH Electronics DHCOM SoM and PDK2 rev. 400 carrier based on
STMicroelectronics stm32mp157
- Renesas M3ULCB starter kit for R-Car M3-W+
- Hoperun HiHope development board with Renesas RZ/G2M
- Pine64 PineTab tablet and PinePhone phone, both based on Allwinner
A64
- Linutronix Testbox v2 for the Lamobo R1 router, based on Allwinner
A20
- PocketBook Touch Lux 3 ebook reader, based on Allwinner A13"
* tag 'arm-dt-5.7' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc: (520 commits)
ARM: dts: ux500: Fix missing node renames
arm64: dts: Revert "specify console via command line"
MAINTAINERS: Update Calxeda Highbank maintainership
arm: dts: calxeda: Group port-phys and sgpio-gpio items
arm: dts: calxeda: Fix interrupt grouping
arm: dts: calxeda: Provide UART clock
arm: dts: calxeda: Basic DT file fixes
arm64: dts: specify console via command line
ARM: dts: at91: sama5d27_wlsom1_ek: add USB device node
ARM: dts: gemini: Add thermal zone to DIR-685
ARM: dts: gemini: Rename IDE nodes
ARM: socfpga: arria10: Add ptp_ref clock to ethernet nodes
arm64: dts: ti: k3-j721e-mcu: add scm node and phy-gmii-sel nodes
arm64: dts: ti: k3-am65-mcu: add phy-gmii-sel node
arm64: dts: ti: k3-am65-mcu: Add DMA entries for ADC
arm64: dts: ti: k3-am65-main: Add DMA entries for main_spi0
arm64: dts: ti: k3-j721e-mcu-wakeup: Add DMA entries for ADC
arm64: dts: ti: k3-am65: Add clocks to dwc3 nodes
arm64: dts: meson-g12b-odroid-n2: add SPIFC controller node
arm64: dts: khadas-vim3: add SPIFC controller node
Until now a PHY-fixup in mach-imx set our rgmii timing correctly. For
the PHY KSZ9131 there is no PHY-fixup in mach-imx. To support this PHY
too, use rgmii-id.
For the now used KSZ9031 nothing will change, as rgmii-id is only
implemented and supported by the KSZ9131.
1. Replace boiler plate licenses texts with the SPDX license
identifiers in Toradex iMX6-based SoM device trees.
2. As X11 is identical to the MIT License, but with an extra sentence
that prohibits using the copyright holders' names for advertising or
promotional purposes without written permission, use MIT license instead
of X11 ('s/X11/MIT/g').
3. Replace "Toradex AG" with "Toradex" in the Copyright notice.
4. Use GPL2.0+ instead of GPL2.0, as it's used now by default for all
new DTS files from Toradex.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Mux the HDMI CEC pin to make HDMI CEC working. With this change HDMI CEC
seems to work fine on a Apalis iMX6 on Ixora using cec-ctl.
This patch adds missing i2c recovery modes and corrects wrongly named
ones.
This patch prepares the devicetree for the new Ixora V1.2 where we are
able to turn off the supply of the can transceiver. This implies to use
a sleep state on transmission pins in order to prevent backfeeding.
Add the stmpe-adc DT node as found on Toradex iMX6 modules
Reviewed-by: Stefan Agner <stefan@agner.ch>
Since commit d2d0ad2aec4a ("i2c: imx: use open drain for recovery
GPIO") GPIO lib expects this GPIO to be configured as open drain.
Make sure we define this GPIO as open drain in the device tree.
This gets rid of the following warning:
gpio-81 (scl): enforced open drain please flag it properly in DT/ACPI DSDT/board file
Note that currently the i.MX pinctrl driver does not support
enabling open drain directly, so this patch has no effect in
practice. Open drain is enabled by the fixed pinmux entry.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Reviewed-by: Philippe Schenker <philippe.schenker@toradex.com>
Boards based on imx6qdl have duplicate memory nodes:
- One coming from the board device tree file: memory@
- One coming from the imx6qdl.dtsi file.
Fix the duplication by removing the memory node from
the imx6qdl.dtsi file and by adding 'device_type = "memory";'
in the board Device Tree.
Converted using the following command:
perl -p0777i -e 's/memory\@10000000 \{\n/memory\@10000000 \{\n\t\tdevice_type = \"memory\";\n/m' `find ./arch/arm/boot/dts -name "imx6*"``
Reported-by: Rob Herring <robh@kernel.org>
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
The pinctrl properties on the IOMUXC node get overwritten by the
carrier board level device tree, hence the pinctrl_reset_moci
pinctrl does not get applied.
Associate the pinctrl_reset_moci pinctrl with the PCIe node where
we also make use of the pin as a reset GPIO.
Since the pin is muxed as a GPIO by default not muxing it explicitly
worked fine in practise.
100/200MHz states for USDHC3 are not required since the SoC
does not support modes faster than DDR52 for the on board eMMC.
VDDD is connected to VGEN4 of the PF0100. This rail should only
run at 1.8V since there are multiple consumer and they all
expect the rail to be at 1.8V.
Remove the 2.5V regulator, it does not exist. There is 3.3V and
3.3V_AUDIO provided to the module through the edge connector,
model those as fixed regulators like we use to do in other
Colibri device trees. The SGTL5000 uses 3.3V_AUDIO as VDDA. Note
that the driver derives the analog ground voltage (VAG) from this
supply. The new value should allow higher output swings before
clipping occurs. Refer to the SGTL5000 datasheet for details.
The fixed 1.8V regulator is not used, and there is in fact no
fixed 1.8V regulator on the module. Remove it.
Use the disable-wp to indicate that Apalis and Colibri iMX6 do not
make use of the native write-protect signal available on the i.MX 6
SoCs. This prevents warnings:
mmc0: host does not support reading read-only switch, assuming write-enable
Use no-1-8-v device tree property to indicate that the board does
not support 1.8V signaling. The property voltage-ranges seems not
appropriate in our case since we do not have level shifters in
place.
Remove unnecessary #address-cells/#size-cells to fix the following
DTC warnings:
arch/arm/boot/dts/imx6q-novena.dtb: Warning (avoid_unnecessary_addr_size): /soc/aips-bus@2100000/i2c@21a0000/stmpe811@44: unnecessary #address-cells/#size-cells without "ranges" or child "reg"
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Pass the memory unit-adress to fix the following build warnings with W=1:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
There are cases where dts passes an empty memory node, which will be filled
by the bootloader. Passing the memory base address still allows the
bootloader to fill the memory size.
Acked-By: Lothar Waßmann <LW@KARO-electronics.de>
In preparation for removing 'reg = <0 0>;' from the dtsi SoC files, pass
'reg = <0 0 >;' to the dts/dtsi board files that do not pass the memory
size.
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
As described in
Documentation/devicetree/bindings/input/touchscreen/stmpe.txt
there is no 'reg' property under stmpe_touchscreen, so remove it
to fix the following build warning with W=1:
arch/arm/boot/dts/imx6q-apalis-eval.dtb: Warning (unit_address_vs_reg): Node /soc/aips-bus@2100000/i2c@21a4000/stmpe811@41/stmpe_touchscreen has a reg or ranges property, but no unit name
Fix dtc warnings for 'simple_bus_reg' due to leading 0s. Converted using
perl -p -i -e 's/\@0+([0-9a-f])/\@$1/g' `find arch/arm/boot/dts -type -f -name '*.dts*'
Dropped changes to ARM, Ltd. boards LED nodes and manually fixed up some
occurrences of uppercase hex.
Signed-off-by: Rob Herring <robh@kernel.org>
Migrate to using functionally-reduced I2C master contained in the DWC
HDMI. Therefore drop the GPIO bitbanging based i2cddc definition and
modify resp. pinctrl.
While at it re-order the I2C aliases to start with the generic, followed
by the camera and concluded by the power I2C one.
gen1_i2c comment
Split the pinctrl property for usdhc1 into a 4-bit SD interface
and an extension to 8-bit. This is required to support both 8-bit
and 4-bit interface on usdhc1 as per the carrier board.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com>
Acked-by: Michael Trimarchi <michael@amarulasolutions.com>
Acked-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Since commit b36581df7e78 ("spi: imx: Using existing properties for
chipselects") the device tree property 'fsl,spi-num-chipselects' is
unused and it is already marked as obsolete in device tree binding
documentation. Remove the property from the existing DTS files to
avoid its reoccurence on copying.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Use enable-gpios property of PWM backlight driver for backlight
control.
Several dts files set a bit in the SPEED field for pads
RGMII_{R,T}{XC,D0,D1,D2,D3,X_CTL}, but that doesn't exist. Writing there
doesn't have an effect and the bit reads as zero.
Signed-off-by: Uwe Kleine-König <uwe@kleine-koenig.org>
As of commit 1006ed7e1b258dac ("serial: imx: Use generic uart-has-rtscts
DT property"), the Freescale IMX UART driver recognizes the generic
"uart-has-rtscts" DT property, deprecating the vendor-specific
"fsl,uart-has-rtscts" DT property. Hence replace the latter by the
former in all DTS files.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Using "IMX6QDL_CLK_CKO" for the clock is easier to read instead of
the hardcoded clock number.
Signed-off-by: Petr Štetiar <ynezz@true.cz>
