This driver uses GPIO descriptors to drive the touchscreen RESET line. In
the existing device trees this has in conflict with intution been flagged
as GPIO_ACTIVE_HIGH and the driver then applies the reverse action by
driving the line low (setting to 0) to enter reset state and driving the
line high (setting to 1) to get out of reset state.
The correct way to handle active low GPIO lines is to provide the
GPIO_ACTIVE_LOW in the device tree (thus properly describing the hardware)
and letting the GPIO framework invert the assertion (driving high) to a
low level and vice versa.
This is considered a bug since the device trees are incorrectly
mis-specifying the line as active high.
Fix the driver and all device trees specifying a reset line.
Reviewed-by: Philippe Schenker <philippe.schenker@toradex.com>
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Link: https://lore.kernel.org/r/20201104153032.1387747-1-linus.walleij@linaro.org
Pull ARM devicetree updates from Arnd Bergmann:
"Most of the commits are for additional hardware support and minor
fixes for existing machines for all the usual platforms: qcom,
amlogic, at91, gemini, mediatek, ti, socfpga, i.mx, layerscape,
uniphier, rockchip, exynos, ux500, mvebu, tegra, stm32, renesas,
sunxi, broadcom, omap, and versatile.
The conversion of binding files to machine-readable yaml format
continues, along with fixes found during the validation. Andre
Przywara takes over maintainership for the old Calxeda Highbank
platform and provides a number of updates.
The OMAP2+ platforms see a continued move from platform data into dts
files, for many devices that relied on a mix of auxiliary data in
addition to the DT description
A moderate number of new SoCs and machines are added, here is a full
list:
- Two new Qualcomm SoCs with their evaluation boards: Snapdragon 865
(SM8250) is the current high-end phone chip, and IPQ6018 is a new
WiFi-6 router chip.
- Mediatek MT8516 application processor SoC for voice assistants,
along with the "pumpkin" development board
- NXP i.MX8M Plus SoC, a variant of the popular i.MX8M, along with an
evaluation board.
- Kontron "sl28" board family based on NXP LS1028A
- Eleven variations of the new i.MX6 TechNexion Pico board, combining
the "dwarf", "hobbit", "nymph" and "pi" baseboards with i.MX6/i.MX7
SoM carriers
- Three additional variants of the Toradex Colibri board family, all
based on versions of the NXP i.MX7.
- The Pinebook Pro laptop based on Rockchip RK3399
- Samsung S7710 Galaxy Xcover 2, a 2013 vintage Android phone based
on the ST-Ericsson u8500 platform
- DH Electronics DHCOM SoM and PDK2 rev. 400 carrier based on
STMicroelectronics stm32mp157
- Renesas M3ULCB starter kit for R-Car M3-W+
- Hoperun HiHope development board with Renesas RZ/G2M
- Pine64 PineTab tablet and PinePhone phone, both based on Allwinner
A64
- Linutronix Testbox v2 for the Lamobo R1 router, based on Allwinner
A20
- PocketBook Touch Lux 3 ebook reader, based on Allwinner A13"
* tag 'arm-dt-5.7' of git://git.kernel.org/pub/scm/linux/kernel/git/soc/soc: (520 commits)
ARM: dts: ux500: Fix missing node renames
arm64: dts: Revert "specify console via command line"
MAINTAINERS: Update Calxeda Highbank maintainership
arm: dts: calxeda: Group port-phys and sgpio-gpio items
arm: dts: calxeda: Fix interrupt grouping
arm: dts: calxeda: Provide UART clock
arm: dts: calxeda: Basic DT file fixes
arm64: dts: specify console via command line
ARM: dts: at91: sama5d27_wlsom1_ek: add USB device node
ARM: dts: gemini: Add thermal zone to DIR-685
ARM: dts: gemini: Rename IDE nodes
ARM: socfpga: arria10: Add ptp_ref clock to ethernet nodes
arm64: dts: ti: k3-j721e-mcu: add scm node and phy-gmii-sel nodes
arm64: dts: ti: k3-am65-mcu: add phy-gmii-sel node
arm64: dts: ti: k3-am65-mcu: Add DMA entries for ADC
arm64: dts: ti: k3-am65-main: Add DMA entries for main_spi0
arm64: dts: ti: k3-j721e-mcu-wakeup: Add DMA entries for ADC
arm64: dts: ti: k3-am65: Add clocks to dwc3 nodes
arm64: dts: meson-g12b-odroid-n2: add SPIFC controller node
arm64: dts: khadas-vim3: add SPIFC controller node
1. Replace boiler plate licenses texts with the SPDX license
identifiers in Toradex iMX6-based SoM device trees.
2. As X11 is identical to the MIT License, but with an extra sentence
that prohibits using the copyright holders' names for advertising or
promotional purposes without written permission, use MIT license instead
of X11 ('s/X11/MIT/g').
3. Replace "Toradex AG" with "Toradex" in the Copyright notice.
4. Use GPL2.0+ instead of GPL2.0, as it's used now by default for all
new DTS files from Toradex.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
The sram-node compatible properties have mistakingly combined the
model-specific string with the generic "mtd-ram" string.
Note that neither "cy7c1019dv33-10zsxi, mtd-ram" or
"cy7c1019dv33-10zsxi" are used by any in-kernel driver and they are
not present in any binding.
The physmap driver will however bind to platform devices that specify
"mtd-ram".
Fixes: fc48e76489fd ("ARM: dts: imx6: Add support for Toradex Colibri iMX6 module")
Cc: Sanchayan Maity <maitysanchayan@gmail.com>
Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Cc: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Johan Hovold <johan@kernel.org>
Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
This patch adds some missing pinmuxing that is in the colibri
standard to the dts.
This commit adds the touchscreen from Toradex so one can enable it.
It is disabled by default because the pins are also used for PWM<B>,
PWM<C>, aka pwm2, pwm3 which is the standard use for colibri boards.
A valid WEIM range configuration must specify range entries for
all four chip selects. This fixes an error on boot:
imx-weim: probe of 21b8000.weim failed with error -22
Signed-off-by: Stefan Agner <stefan@agner.ch>
Boards based on imx6qdl have duplicate memory nodes:
- One coming from the board device tree file: memory@
- One coming from the imx6qdl.dtsi file.
Fix the duplication by removing the memory node from
the imx6qdl.dtsi file and by adding 'device_type = "memory";'
in the board Device Tree.
Converted using the following command:
perl -p0777i -e 's/memory\@10000000 \{\n/memory\@10000000 \{\n\t\tdevice_type = \"memory\";\n/m' `find ./arch/arm/boot/dts -name "imx6*"``
Reported-by: Rob Herring <robh@kernel.org>
Signed-off-by: Marco Franchi <marco.franchi@nxp.com>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
dtc has new checks for SPI buses. Fix the warnings in node names and
unit-addresses.
There's over 100 warnings for FSL boards, a few examples:
arch/arm/boot/dts/imx28-duckbill-2-spi.dtb: Warning (spi_bus_bridge): /apb@80000000/apbh@80000000/ssp@80014000: node name for SPI buses should be 'spi'
arch/arm/boot/dts/imx53-ppd.dtb: Warning (spi_bus_bridge): /soc/aips@50000000/spba@50000000/ecspi@50010000: node name for SPI buses should be 'spi'
arch/arm/boot/dts/imx6dl-colibri-eval-v3.dtb: Warning (spi_bus_reg): /soc/aips-bus@2000000/spba-bus@2000000/spi@2014000/mcp251x@1: SPI bus unit address format error, expected "0"
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Pengutronix Kernel Team <kernel@pengutronix.de>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: NXP Linux Team <linux-imx@nxp.com>
Cc: Li Yang <leoyang.li@nxp.com>
Cc: Stefan Agner <stefan@agner.ch>
Signed-off-by: Rob Herring <robh@kernel.org>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Acked-by: Stefan Agner <stefan@agner.ch>
Muxing the card detect only in the carrier board device tree
overwrites the USDHC muxing in the module level device tree.
Move card detect to the module level device tree since this
is also a default pinout of the Colibri standard. If a carrier
board requires a different setting it still can overwrite the
nodes in the carrier board specific device tree.
For soc level of clocks which are input to Clock Control Module, clock
driver expects them to be under 'clocks' container node. But for board
level clocks, this container is not really necessary. Let's drop it and
use an unique name for fixed rate clock, so that 'reg' property can be
saved as well.
Acked-By: Lothar Waßmann <LW@KARO-electronics.de>
Add Colibri UART_A as default serial console.
Pass the memory unit-adress to fix the following build warnings with W=1:
Warning (unit_address_vs_reg): Node /memory has a reg or ranges property, but no unit name
There are cases where dts passes an empty memory node, which will be filled
by the bootloader. Passing the memory base address still allows the
bootloader to fill the memory size.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
In preparation for removing 'reg = <0 0>;' from the dtsi SoC files, pass
'reg = <0 0 >;' to the dts/dtsi board files that do not pass the memory
size.
All Toradex Carrier Boards use a st,m41t0 compatible RTC. Compared
to a st,m41t00 this RTC has also an oscillator fail bit which allows
to detect when the RTC lost track of time.
The following build warnings are seen with W=1:
Warning (unit_address_vs_reg): Node /display@di0 has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /display@di1 has a unit name, but no reg property
Fix all these warnings by changing 'display@diX' to 'dispX'.
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
The license text has been mangled at some point then copy pasted across
multiple files. Restore it to what it should be.
Note that this is not intended as a license change.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Acked-by: Afzal Mohammed <afzal.mohd.ma@gmail.com>
Acked-by: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Add support for Toradex Colibri iMX6 module.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
