Based on 1 normalized pattern(s):
licensed under gplv2 or later
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 118 file(s).
Reviewed-by: Jilayne Lovejoy <opensource@jilayne.com>
Reviewed-by: Steve Winslow <swinslow@gmail.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190519154040.961286471@linutronix.de
Use tcb0 for timers as selected in at91_dt_defconfig.
Cc: Fabio Porcedda <fabio.porcedda@gmail.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Fix dtc warnings for 'simple_bus_reg' due to leading 0s. Converted using
the following command:
perl -p -i -e 's/\@0+([0-9a-f])/\@$1/g' `find arch/arm/boot/dts -type -f -name '*.dts*'
Dropped changes to ARM, Ltd. boards LED nodes and manually fixed up some
occurrences of uppercase hex.
Signed-off-by: Rob Herring <robh@kernel.org>
Use the new EBI/NAND bindings to declare NAND chips and remove old NAND
nodes along the way.
Note that we keep using old bindings in at91rm9200.dtsi because this
SoC is not supported by the EBI driver.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Tested-by: Peter Rosin <peda@axentia.se>
The clocks group properties and the clock@0 node have been obsolete for two
years, remove them.
Define Telit GE863-PRO3 main crystal frequency.
to prepare the switch to the macro.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Fabio Porcedda <fabio.porcedda@gmail.com>
