path: root/arch/arm/boot/dts/armada-xp-openblocks-ax3-4.dts
2013-08-06ARM: mvebu: Relocate Armada 370/XP PCIe device tree nodesEzequiel Garcia
Now that mbus has been added to the device tree, it's possible to move the PCIe nodes out of internal registers, placing it directly below the mbus. This is a more accurate representation of the hardware. Moving the PCIe nodes, we now need to introduce an extra cell to encode the window target ID and attribute. Since this depends on the PCIe port, we split the ranges translation entries, to correspond to each MBus window. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06ARM: mvebu: Relocate Armada 370/XP DeviceBus device tree nodesEzequiel Garcia
Now that mbus has been added to the device tree, it's possible to move the DeviceBus out of internal registers, placing it directly below the mbus. This is a more accurate representation of the hardware. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06ARM: mvebu: Add BootROM to Armada 370/XP device treeEzequiel Garcia
In order to access the SoC BootROM, we need to declare a mapping (through a ranges property). The mbus driver will use this property to allocate a suitable address decoding window. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06ARM: mvebu: Add MBus to Armada 370/XP device treeEzequiel Garcia
The Armada 370/XP SoC family has a completely configurable address space handled by the MBus controller. This patch introduces the device tree layout of MBus, making the 'soc' node as mbus-compatible. Since every peripheral/controller is a child of this 'soc' node, this makes all of them sit behind the mbus, thus describing the hardware accurately. A translation entry has been added for the internal-regs mapping. This can't be done in the common armada-370-xp.dtsi because A370 and AXP have different addressing width. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Tested-by: Andrew Lunn <andrew@lunn.ch> Tested-by: Sebastian Hesselbarth <sebastian.hesselbarth@gmail.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-08-06ARM: mvebu: Use the preprocessor on Armada 370/XP device tree filesEzequiel Garcia
2013-06-20Merge tag 'mxs-dt-3.11' of git://git.linaro.org/people/shawnguo/linux-2.6 ↵Arnd Bergmann
into next/dt From Shawn Guo: mxs device tree changes for 3.11: * A couple of new board support, cfa10055 and cfa10057 * A few updates on cfa10036 device tree source * Some auart pinctrl data addition * Adopt soc bus infrastructure for mach-mxs * tag 'mxs-dt-3.11' of git://git.linaro.org/people/shawnguo/linux-2.6: ARM: mxs: dt: Add Crystalfontz CFA-10057 device tree ARM: mxs: dt: Add the Crystalfontz CFA-10055 device tree ARM: cfa10049: Switch the chip select pin of the LCD controller ARM: cfa10036: Add USB0 OTG port ARM: dts: apf28dev: Add touchscreen support for APF28dev ARM: mxs: Fix UARTs on M28EVK ARM: cfa10036: dt: Change i2c0 clock frequency ARM: dts: cfa10036: Change the OLED display to SSD1306 ARM: mx28: add auart4 2 pins pinmux to imx28.dtsi ARM: mx28: add auart3 2 pins pinmux to imx28.dtsi ARM: mx28: add auart2 2 pins pinmux to imx28.dtsi ARM: mxs: Use soc bus infrastructure ARM: dts: mx28: Adjust the digctl compatible string ARM: mxs: Remove init_irq declaration in machine description Includes an update to 3.10-rc6 Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2013-06-06arm: mvebu: armada-xp-{gp,openblocks-ax3-4}: specify PCIe rangeThomas Petazzoni
The ranges DT entry needed by the PCIe controller is defined at the SoC .dtsi level. However, some boards have a NOR flash, and to support it, they need to override the SoC-level ranges property to add an additional range. Since PCIe and NOR support came separately, some boards were not properly changed to include the PCIe range in their ranges property at the .dts level. This commit fixes those platforms. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-31Merge tag 'dt-3.11-3' of git://git.infradead.org/users/jcooper/linux into ↵Olof Johansson
next/dt From jason Cooper, mvebu dt changes for v3.11. Signed-off-by: Olof Johansson <olof@lixom.net> * tag 'dt-3.11-3' of git://git.infradead.org/users/jcooper/linux: (27 commits) arm: kirkwood: openblocks-a6: add support for Init button arm: kirkwood: openblocks-a6: group pinmux configurations arm: kirkwood: ts219: move pinmux configs to the right devices arm: kirkwood: topkick: move pinmux configs to the right devices arm: kirkwood: openblocks_a6: move pinmux configs to the right devices arm: kirkwood: nsa310: move pinmux configs to the right devices arm: kirkwood: readynas: move pinmux configs to the right devices arm: kirkwood: mplcec4: move pinmux configs to the right devices arm: kirkwood: buffalo linkstation: move pinmux configs to the right devices arm: kirkwood: keymile: move pinmux configs to the right devices arm: kirkwood: ns2: move pinmux configs to the right devices arm: kirkwood: iomega ix2-200: move pinmux configs to the right devices arm: kirkwood: iconnect: move pinmux configs to the right devices arm: kirkwood: iconnect: give meaningful names to pinmux configs arm: kirkwood: ib62x0: move pinmux configs to the right devices arm: kirkwood: guruplug: move pinmux configs to the right devices arm: kirkwood: goflexnet: move pinmux configs to the right devices arm: kirkwood: dreamplug: move pinmux configs to the right devices arm: kirkwood: dockstar: move pinmux configs to the right devices arm: kirkwood: dlink dns: move pinmux configs to the right devices ...
2013-05-20arm: mvebu: enable the third USB interface on OpenBlocks AX3Thomas Petazzoni
Besides the two "classic" USB interfaces with normal USB ports on the front side, the PlatHome OpenBlocks AX3 uses the third USB interface of the Marvell SoC in the mini-PCIe connector. This allows certain mini-PCIe cards to expose parts of their functionality as a USB peripheral. This commit enables this third USB interface in the OpenBlocks AX3 Device Tree, and also adds comments on top of the two other USB interfaces so that the Device Tree makes it clear which USB interface at the SoC level matches which USB interface visible on the board. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Tested-by: Atsushi Yamagata <yamagata@plathome.co.jp> Tested-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-05-13ARM: mvebu: Add a ranges entry to translate devbus childsEzequiel Garcia
With the latest device tree reorganization which introduced the 'internal-reg' node, now the only region translated is the internal register's. This makes the description of the hardware incomplete, for it lacks the Device Bus childs address space. In order to fix this, it's required to add a 'ranges' entry with a suitable address space to map Device Bus childs, on a per-board basis. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-15ARM: dts: mvebu: Convert mvebu device tree files to 64 bitsGregory CLEMENT
In order to be able to use more than 4GB of RAM when the LPAE is activated, the dts must be converted in 64 bits. Only Armada XP is LPAE capable, but as it shares a common dtsi file with Armada 370, then the common file include the skeleton64. Thanks to the use of the overload capability of the device tree format, armada-370 include the 32 bit skeleton and all the armada 370 based dts can remain the same. This was heavily based on the work of Lior Amsalem. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-15ARM: dts: mvebu: introduce internal-regs nodeGregory CLEMENT
Introduce a 'internal-regs' subnode, under which all devices are moved. This is not really needed for now, but will be for the mvebu-mbus driver. This generates a lot of code movement since it's indenting by one more tab all the devices. So it was a good opportunity to fix all the bad indentation. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-15ARM: dts: mvebu: Convert all the mvebu files to use the range propertyGregory CLEMENT
This conversion will allow to keep 32 bits addresses for the internal registers whereas the memory of the system will be 64 bits. Later it will also ease the move of the mvebu-mbus driver to the device tree support. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-15arm: mvebu: PCIe Device Tree informations for OpenBlocks AX3-4Thomas Petazzoni
The PlatHome OpenBlocks AX3-4 has an internal mini-PCIe slot that can be used to plug mini-PCIe devices. We therefore enable the PCIe interface that corresponds to this slot. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-04-11ARM: mvebu: Add support for NOR flash device on Openblocks AX3 boardEzequiel Garcia
The Plat'home Openblocks AX3 has a 128 MiB NOR flash device connected to the Device Bus. This commit adds the device tree node to support this device. The SoC supports a flexible and dynamic decoding window allocation scheme; but since this feature is still not implemented we need to specify the window base address in the device tree node itself. This base address has been selected in a completely arbitrary fashion. Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-28arm: mvebu: Enable USB controllers on Armada 370/XP boardsEzequiel Garcia
This patch activates every USB port provided by each SoC. Except for Armada XP Openblocks AX3-4 board, where we enable only the first two USB ports until we have more information on the third one usage. Cc: Lior Amsalem <alior@marvell.com> Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Cc: Gregory CLEMENT <gregory.clement@free-electrons.com> Tested-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Tested-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2013-02-28arm: mvebu: add button for OpenBlocks AX3-4Thomas Petazzoni
The OpenBlocks AX3-4 board has one software-controlled button on the front side, labeled "INIT", so we add minimal support for this button in the kernel. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Signed-off-by: Jason Cooper <jason@lakedaemon.net>
2012-11-21ARM: mvebu: Add SATA support for OpenBlocks AX3-4Thomas Petazzoni
This patch enables SATA support on the OpenBlocks AX3-4. It has one internal SATA port, and an external eSATA port. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-21ARM: mvebu: Add support for the RTC in OpenBlocks AX3-4Nobuhiro Iwamatsu
The OpenBlocks AX3-4 has a Seiko Instruments S-35390A as the RTC controller. This patch enables this RTC device in the OpenBlocks AX3-4 Device Tree. [Thomas Petazzoni: updated with other OpenBlocks changes, rephrased commit log.] Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-21ARM: mvebu: Add support for I2C on OpenBlocks AX3-4Nobuhiro Iwamatsu
The OpenBlocks AX3-4 board, based on the Armada XP SoC, has an I2C bus. This patch enables this bus and sets the clock frequency of the bus. [Thomas Petazzoni: updated with other changes on OpenBlocks, rephrased commit log.] Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-20arm: mvebu: remove 'clock-frequency' properties from Armada 370/XP Ethernet ↵Thomas Petazzoni
nodes The mvneta driver for the Marvell Armada 370/XP Ethernet devices has gained proper clock framework integration, and the corresponding Device Tree nodes now have a correct 'clocks' pointer. The 'clock-frequency' properties in the various .dts files for Armada 370/XP boards have therefore become useless. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-16arm: mvebu: enable Ethernet controllers on OpenBlocks AX3-4 platformThomas Petazzoni
The PlatHome OpenBlocks AX3-4 platform has 4 Ethernet ports, connected to a single quad-port PHY through SGMII. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
2012-11-14arm: mvebu: support for the PlatHome OpenBlocks AX3-4 boardThomas Petazzoni
This platform, available in Japan from PlatHome, has a dual-core Armada XP, the MV78260. For now, only the two serial ports and the three front LEDs are supported. Support for SMP, network, SATA, USB and other peripherals will be added as drivers for them become available for Armada XP in mainline. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Tested-by: Gregory CLEMENT <gregory.clement@free-electrons.com> --- This is 3.8 material. Changes since v2: * Renamed the .dts file to armada-xp-openblocks-ax3-4.dts * Removed the compatible string from armada-370-xp.c (which now only lists the common SoC compatible string) Changes since v1: * Renamed the board to OpenBlocks AX3-4, since there is a variant called AX3-2 which has less RAM, and no mini PCIe port. Requested by Andrew Lunn. * Fix the amount of memory to 3 GB. In fact, the board has 1 GB soldered, and 2 GB in a SODIMM slot (which is therefore removable). But as the board is delivered as is, we'll assume it has 3 GB of memory by default.
