path: root/arch/alpha
2009-12-18alpha: Convert BUG() to use unreachable()David Daney
Use the new unreachable() macro instead of for(;;); Signed-off-by: David Daney <ddaney@caviumnetworks.com> CC: Richard Henderson <rth@twiddle.net> CC: Ivan Kokshaysky <ink@jurassic.park.msu.ru> CC: linux-alpha@vger.kernel.org Signed-off-by: Matt Turner <mattst88@gmail.com>
2009-12-18alpha: Add minimal support for software performance eventsMichael Cree
In the kernel the patch enables configuration of the perf event option, adds the perf_event_open syscall, and includes a minimal architecture specific asm/perf_event.h header file. Signed-off-by: Michael Cree <mcree@orcon.net.nz> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Matt Turner <mattst88@gmail.com>
2009-12-18alpha: Wire up missing/new syscallsDaniele Calore
This wire up the: fallocate, timerfd_create, timerfd_settime, timerfd_gettime, signalfd4, eventfd2, epoll_create1, dup3, pipe2, inotify_init1, preadv, pwritev and rt_tgsigqueueinfo syscalls for the alpha port. For umount2, alpha have an "old" and "new" version called: oldumount and umount; so ignore umount2. Rebased on top of 6e17e8b9fb74b9fb9f6ea331f7f4a049c5b4c4b8 by Matt Turner. Signed-off-by: Daniele Calore <orkaan@orkaan.org> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Matt Turner <mattst88@gmail.com>
2009-12-17Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: kill I_LOCK fold do_sync_file_range into sys_sync_file_range fix up O_SYNC comments VFS/fsstack: handle 32-bit smp + preempt + large files in fsstack_copy_inode_size fsstack/ecryptfs: remove unused get_nlinks param to fsstack_copy_attr_all vfs: remove extraneous NULL d_inode check from do_filp_open fs: no games with DCACHE_UNHASHED fs: anon_inodes implement dname dio: fix use-after-free
2009-12-17fix up O_SYNC commentsChristoph Hellwig
Proper Posix O_SYNC handling only made it into 2.6.33, not 2.6.32. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-17Merge branch 'for-33' of git://repo.or.cz/linux-kbuildLinus Torvalds
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits) net: fix for utsrelease.h moving to generated gen_init_cpio: fixed fwrite warning kbuild: fix make clean after mismerge kbuild: generate modules.builtin genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}() score: add asm/asm-offsets.h wrapper unifdef: update to upstream revision 1.190 kbuild: specify absolute paths for cscope kbuild: create include/generated in silentoldconfig scripts/package: deb-pkg: use fakeroot if available scripts/package: add KBUILD_PKG_ROOTCMD variable scripts/package: tar-pkg: use tar --owner=root Kbuild: clean up marker net: add net_tstamp.h to headers_install kbuild: move utsrelease.h to include/generated kbuild: move autoconf.h to include/generated drop explicit include of autoconf.h kbuild: move compile.h to include/generated kbuild: drop include/asm kbuild: do not check for include/asm-$ARCH ... Fixed non-conflicting clean merge of modpost.c as per comments from Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h that needed to be changed to generated/autoconf.h)
2009-12-16elf: kill USE_ELF_CORE_DUMPChristoph Hellwig
Currently all architectures but microblaze unconditionally define USE_ELF_CORE_DUMP. The microblaze omission seems like an error to me, so let's kill this ifdef and make sure we are the same everywhere. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: <linux-arch@vger.kernel.org> Cc: Michal Simek <michal.simek@petalogix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15Merge branch 'core-locking-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (26 commits) clockevents: Convert to raw_spinlock clockevents: Make tick_device_lock static debugobjects: Convert to raw_spinlocks perf_event: Convert to raw_spinlock hrtimers: Convert to raw_spinlocks genirq: Convert irq_desc.lock to raw_spinlock smp: Convert smplocks to raw_spinlocks rtmutes: Convert rtmutex.lock to raw_spinlock sched: Convert pi_lock to raw_spinlock sched: Convert cpupri lock to raw_spinlock sched: Convert rt_runtime_lock to raw_spinlock sched: Convert rq->lock to raw_spinlock plist: Make plist debugging raw_spinlock aware bkl: Fixup core_lock fallout locking: Cleanup the name space completely locking: Further name space cleanups alpha: Fix fallout from locking changes locking: Implement new raw_spinlock locking: Convert raw_rwlock functions to arch_rwlock locking: Convert raw_rwlock to arch_rwlock ...
2009-12-15alpha: convert srm code to seq_fileAlexey Dobriyan
Convert code away from ->read_proc/->write_proc interfaces. Switch to proc_create()/proc_create_data() which make addition of proc entries reliable wrt NULL ->proc_fops, NULL ->data and so on. Problem with ->read_proc et al is described here commit 786d7e1612f0b0adb6046f19b906609e4fe8b1ba "Fix rmmod/read/write races in /proc entries" Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-14genirq: Convert irq_desc.lock to raw_spinlockThomas Gleixner
Convert locks which cannot be sleeping locks in preempt-rt to raw_spinlocks. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-14alpha: Fix fallout from locking changesThomas Gleixner
spin_* functions are mostly static inline now. That causes the alpha compile to fail: CC arch/alpha/kernel/sys_sable.o cc1: warnings being treated as errors In file included from arch/alpha/kernel/sys_sable.c:25: arch/alpha/include/asm/core_t2.h: In function 't2_readb': arch/alpha/include/asm/core_t2.h:451: error: 'spinlock_check' is static but \ used in inline function 't2_readb' which is not static arch/alpha/include/asm/core_t2.h:456: error: 'spin_unlock_irqrestore' is \ static but used in inline function 't2_readb' which is not static That's caused by the "extern inline" magic which is used for the subarch specific read/write[bwl] functions. I tried to distangle the uncountable macro onion layers, but failed miserably. Last resort solution: switch the t2_hae_lock to raw_spinlock_t so the lock functions are pure macros and function calls again. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Richard Henderson <rth@twiddle.net> Cc: linux-alpha@vger.kernel.org
2009-12-14locking: Convert raw_rwlock functions to arch_rwlockThomas Gleixner
Name space cleanup for rwlock functions. No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: linux-arch@vger.kernel.org
2009-12-14locking: Convert raw_rwlock to arch_rwlockThomas Gleixner
Not strictly necessary for -rt as -rt does not have non sleeping rwlocks, but it's odd to not have a consistent naming convention. No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: linux-arch@vger.kernel.org
2009-12-14locking: Convert __raw_spin* functions to arch_spin*Thomas Gleixner
Name space cleanup. No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: linux-arch@vger.kernel.org
2009-12-14locking: Rename __RAW_SPIN_LOCK_UNLOCKED to __ARCH_SPIN_LOCK_UNLOCKEDThomas Gleixner
Further name space cleanup. No functional change Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: linux-arch@vger.kernel.org
2009-12-14locking: Convert raw_spinlock to arch_spinlockThomas Gleixner
The raw_spin* namespace was taken by lockdep for the architecture specific implementations. raw_spin_* would be the ideal name space for the spinlocks which are not converted to sleeping locks in preempt-rt. Linus suggested to convert the raw_ to arch_ locks and cleanup the name space instead of using an artifical name like core_spin, atomic_spin or whatever No functional change. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: linux-arch@vger.kernel.org
2009-12-12kbuild: move utsrelease.h to include/generatedSam Ravnborg
Fix up all users of utsrelease.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-12kbuild: move asm-offsets.h to include/generatedSam Ravnborg
The simplest method was to add an extra asm-offsets.h file in arch/$ARCH/include/asm that references the generated file. We can now migrate the architectures one-by-one to reference the generated file direct - and when done we can delete the temporary arch/$ARCH/include/asm/asm-offsets.h file. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2009-12-11Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (21 commits) ext3: PTR_ERR return of wrong pointer in setup_new_group_blocks() ext3: Fix data / filesystem corruption when write fails to copy data ext4: Support for 64-bit quota format ext3: Support for vfsv1 quota format quota: Implement quota format with 64-bit space and inode limits quota: Move definition of QFMT_OCFS2 to linux/quota.h ext2: fix comment in ext2_find_entry about return values ext3: Unify log messages in ext3 ext2: clear uptodate flag on super block I/O error ext2: Unify log messages in ext2 ext3: make "norecovery" an alias for "noload" ext3: Don't update the superblock in ext3_statfs() ext3: journal all modifications in ext3_xattr_set_handle ext2: Explicitly assign values to on-disk enum of filetypes quota: Fix WARN_ON in lookup_one_len const: struct quota_format_ops ubifs: remove manual O_SYNC handling afs: remove manual O_SYNC handling kill wait_on_page_writeback_range vfs: Implement proper O_SYNC semantics ...
2009-12-11Unify sys_mmap*Al Viro
New helper - sys_mmap_pgoff(); switch syscalls to using it. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-10vfs: Implement proper O_SYNC semanticsChristoph Hellwig
While Linux provided an O_SYNC flag basically since day 1, it took until Linux 2.4.0-test12pre2 to actually get it implemented for filesystems, since that day we had generic_osync_around with only minor changes and the great "For now, when the user asks for O_SYNC, we'll actually give O_DSYNC" comment. This patch intends to actually give us real O_SYNC semantics in addition to the O_DSYNC semantics. After Jan's O_SYNC patches which are required before this patch it's actually surprisingly simple, we just need to figure out when to set the datasync flag to vfs_fsync_range and when not. This patch renames the existing O_SYNC flag to O_DSYNC while keeping it's numerical value to keep binary compatibility, and adds a new real O_SYNC flag. To guarantee backwards compatiblity it is defined as expanding to both the O_DSYNC and the new additional binary flag (__O_SYNC) to make sure we are backwards-compatible when compiled against the new headers. This also means that all places that don't care about the differences can just check O_DSYNC and get the right behaviour for O_SYNC, too - only places that actuall care need to check __O_SYNC in addition. Drivers and network filesystems have been updated in a fail safe way to always do the full sync magic if O_DSYNC is set. The few places setting O_SYNC for lower layers are kept that way for now to stay failsafe. We enforce that O_DSYNC is set when __O_SYNC is set early in the open path to make sure we always get these sane options. Note that parisc really screwed up their headers as they already define a O_DSYNC that has always been a no-op. We try to repair it by using it for the new O_DSYNC and redefinining O_SYNC to send both the traditional O_SYNC numerical value _and_ the O_DSYNC one. Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Andreas Dilger <adilger@sun.com> Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-08Merge branch 'for-2.6.33' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.33' of git://git.kernel.dk/linux-2.6-block: (113 commits) cfq-iosched: Do not access cfqq after freeing it block: include linux/err.h to use ERR_PTR cfq-iosched: use call_rcu() instead of doing grace period stall on queue exit blkio: Allow CFQ group IO scheduling even when CFQ is a module blkio: Implement dynamic io controlling policy registration blkio: Export some symbols from blkio as its user CFQ can be a module block: Fix io_context leak after failure of clone with CLONE_IO block: Fix io_context leak after clone with CLONE_IO cfq-iosched: make nonrot check logic consistent io controller: quick fix for blk-cgroup and modular CFQ cfq-iosched: move IO controller declerations to a header file cfq-iosched: fix compile problem with !CONFIG_CGROUP blkio: Documentation blkio: Wait on sync-noidle queue even if rq_noidle = 1 blkio: Implement group_isolation tunable blkio: Determine async workload length based on total number of queues blkio: Wait for cfq queue to get backlogged if group is empty blkio: Propagate cgroup weight updation to cfq groups blkio: Drop the reference to queue once the task changes cgroup blkio: Provide some isolation between groups ...
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-03Merge branch 'master' into for-2.6.33Jens Axboe
2009-12-01Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/ht.c
2009-11-30alpha: Fixup last users of irq_chip->typenameThomas Gleixner
The typename member of struct irq_chip was kept for migration purposes and is obsolete since more than 2 years. Fix up the leftovers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Richard Henderson <rth@twiddle.net> Cc: linux-alpha@vger.kernel.org Signed-off-by: Matt Turner <mattst88@gmail.com>
2009-11-30Alpha: Rearrange thread info flags fixing two regressionsMichael Cree
The removal of the TIF_NOTIFY_RESUME flag, commit a583f1b54249b "remove unused TIF_NOTIFY_RESUME flag," resulted in incorrect setting of the unaligned access control flags by the prctl syscall. The re-addition of the TIF_NOTIFY_RESUME flag, commit d0420c83f39f "KEYS: Extend TIF_NOTIFY_RESUME to (almost) all architectures [try #6]" further caused problems, namely incorrect operands to assembler code as evidenced by: AS arch/alpha/kernel/entry.o arch/alpha/kernel/entry.S: Assembler messages: arch/alpha/kernel/entry.S:326: Warning: operand out of range (0x0000000000000406 is not between 0x0000000000000000 and 0x00000000000000ff) Both regressions fixed by (1) rearranging TIF_NOTIFY_RESUME flag to be in lower 8 bits of the thread info flags, and (2) making sure that ALPHA_UAC_SHIFT matches the rearrangement of the thread info flags. Signed-off-by: Michael Cree <mcree@orcon.net.nz> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: David Howells <dhowells@redhat.com>, Signed-off-by: Matt Turner <mattst88@gmail.com>
2009-11-30arch/alpha/kernel: Add kmalloc NULL testsJulia Lawall
Check that the result of kmalloc is not NULL before passing it to other functions. The semantic match that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression *x; identifier f; constant char *C; @@ x = \(kmalloc\|kcalloc\|kzalloc\)(...); ... when != x == NULL when != x != NULL when != (x || ...) ( kfree(x) f(...,C,...,x,...) | *f(...,x,...) | *x->f ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Matt Turner <mattst88@gmail.com>
2009-11-30arch/alpha/kernel/sys_ruffian.c: Use DIV_ROUND_CLOSESTJulia Lawall
The kernel.h macro DIV_ROUND_CLOSEST performs the computation (x + d/2)/d but is perhaps more readable. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @haskernel@ @@ @depends on haskernel@ expression x,__divisor; @@ - (((x) + ((__divisor) / 2)) / (__divisor)) + DIV_ROUND_CLOSEST(x,__divisor) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Matt Turner <mattst88@gmail.com>
2009-11-26block: add helpers to run flush_dcache_page() against a bio and a request's ↵Ilya Loginov
pages Mtdblock driver doesn't call flush_dcache_page for pages in request. So, this causes problems on architectures where the icache doesn't fill from the dcache or with dcache aliases. The patch fixes this. The ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE symbol was introduced to avoid pointless empty cache-thrashing loops on architectures for which flush_dcache_page() is a no-op. Every architecture was provided with this flush pages on architectires where ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE is equal 1 or do nothing otherwise. See "fix mtd_blkdevs problem with caches on some architectures" discussion on LKML for more information. Signed-off-by: Ilya Loginov <isloginov@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Peter Horton <phorton@bitbox.co.uk> Cc: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/sfc/sfe4001.c drivers/net/wireless/libertas/cmd.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/rtl8187se/Kconfig drivers/staging/rtl8192e/Kconfig
2009-11-17Merge branch 'hostprogs-wmissing-prototypes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc * 'hostprogs-wmissing-prototypes' of git://git.kernel.org/pub/scm/linux/kernel/git/josh/linux-misc: Makefile: Add -Wmising-prototypes to HOSTCFLAGS oss: Mark loadhex static in hex2hex.c dtc: Mark various internal functions static dtc: Set "noinput" in the lexer to avoid an unused function drm: radeon: Mark several functions static in mkregtable arch/sparc/boot/*.c: Mark various internal functions static arch/powerpc/boot/addRamDisk.c: Mark several internal functions static arch/alpha/boot/tools/objstrip.c: Mark "usage" static Documentation/vm/page-types.c: Declare checked_open static genksyms: Mark is_reserved_word static kconfig: Mark various internal functions static kconfig: Make zconf.y work with current bison
2009-11-17fcntl: Use consistent values for F_[GS]ETOWN_EXStephen Rothwell
These values were only introduced during this release cycle, so it is still early enough to get them right. alpha uses the same values that are in asm-generic/fcntl.h, so just remove them. parisc uses the values interchanged for no apparent reason, so remove them to give us consistency across all architectures. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-15arch/alpha/boot/tools/objstrip.c: Mark "usage" staticJosh Triplett
Nothing outside of arch/alpha/boot/tools/objstrip.c references the usage function. Signed-off-by: Josh Triplett <josh@joshtriplett.org>
2009-11-14alpha: Fixup recvmmsg syscall glueArnaldo Carvalho de Melo
Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-12alpha: move THREAD_SIZE definition outside #ifndef ASSEMBLYAndrew Morton
arch/alpha/kernel/vmlinux.lds.S uses it: arch/alpha/kernel/vmlinux.lds:241: undefined symbol `THREAD_SIZE' referenced in expression Seems to have been caused by commit 9d93f00580243cc059510d9d6ac4d2f5e97e5b83 Author: Geoffrey Thomas <geofft@ksplice.com> AuthorDate: Thu Sep 24 10:36:26 2009 -0400 Commit: Linus Torvalds <torvalds@linux-foundation.org> CommitDate: Thu Sep 24 17:16:22 2009 -0700 alpha: Clean up linker script using new linker script macros. Note that .data.page_aligned and .data.cacheline_aligned are now after _data; it was probably a bug that they were before it. Also, some explicit ALIGN(8)'s between various initcall sections were removed; this should be harmless as the implicit alignment of initcall_t was already 8. Cc: Geoffrey Thomas <geofft@ksplice.com> Cc: Tim Abbott <tabbott@ksplice.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-12alpha: fix F_SETOWN_EX and F_GETLK64 conflictPeter Zijlstra
Fix a bug in commit ba0a6c9f6fceed11c6a99e8326f0477fe383e6b5 Author: Peter Zijlstra <a.p.zijlstra@chello.nl> AuthorDate: Wed Sep 23 15:57:03 2009 -0700 Commit: Linus Torvalds <torvalds@linux-foundation.org> CommitDate: Thu Sep 24 07:21:01 2009 -0700 fcntl: add F_[SG]ETOWN_EX In asm-generic/fcntl.h, F_SETOWN_EX and F_GETLK64 both have value 12, and F_GETOWN_EX and F_SETLK64 both have value 13. Reported-by: "Joseph S. Myers" <joseph@codesourcery.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Andreas Schwab <schwab@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-12net: Introduce recvmmsg socket syscallArnaldo Carvalho de Melo
Meaning receive multiple messages, reducing the number of syscalls and net stack entry/exit operations. Next patches will introduce mechanisms where protocols that want to optimize this operation will provide an unlocked_recvmsg operation. This takes into account comments made by: . Paul Moore: sock_recvmsg is called only for the first datagram, sock_recvmsg_nosec is used for the rest. . Caitlin Bestler: recvmmsg now has a struct timespec timeout, that works in the same fashion as the ppoll one. If the underlying protocol returns a datagram with MSG_OOB set, this will make recvmmsg return right away with as many datagrams (+ the OOB one) it has received so far. . Rémi Denis-Courmont & Steven Whitehouse: If we receive N < vlen datagrams and then recvmsg returns an error, recvmmsg will return the successfully received datagrams, store the error and return it in the next call. This paves the way for a subsequent optimization, sk_prot->unlocked_recvmsg, where we will be able to acquire the lock only at batch start and end, not at every underlying recvmsg call. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-12net: Generalize socket rx gap / receive queue overflow cmsgNeil Horman
Create a new socket level option to report number of queue overflows Recently I augmented the AF_PACKET protocol to report the number of frames lost on the socket receive queue between any two enqueued frames. This value was exported via a SOL_PACKET level cmsg. AFter I completed that work it was requested that this feature be generalized so that any datagram oriented socket could make use of this option. As such I've created this patch, It creates a new SOL_SOCKET level option called SO_RXQ_OVFL, which when enabled exports a SOL_SOCKET level cmsg that reports the nubmer of times the sk_receive_queue overflowed between any two given frames. It also augments the AF_PACKET protocol to take advantage of this new feature (as it previously did not touch sk->sk_drops, which this patch uses to record the overflow count). Tested successfully by me. Notes: 1) Unlike my previous patch, this patch simply records the sk_drops value, which is not a number of drops between packets, but rather a total number of drops. Deltas must be computed in user space. 2) While this patch currently works with datagram oriented protocols, it will also be accepted by non-datagram oriented protocols. I'm not sure if thats agreeable to everyone, but my argument in favor of doing so is that, for those protocols which aren't applicable to this option, sk_drops will always be zero, and reporting no drops on a receive queue that isn't used for those non-participating protocols seems reasonable to me. This also saves us having to code in a per-protocol opt in mechanism. 3) This applies cleanly to net-next assuming that commit 977750076d98c7ff6cbda51858bb5a5894a9d9ab (my af packet cmsg patch) is reverted Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-27alpha: Fix duplicate <asm/thread_info.h> includeLinus Torvalds
.. duplicated by merging the same fix twice, for details see commit 0d9df2515dbceb67d343c0f10fd3ff218380d524 ("Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes") Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: alpha: fix build after vmlinux.lds.S cleanup mips: fix build of vmlinux.lds
2009-09-25alpha: fix build after vmlinux.lds.S cleanupSam Ravnborg
Add include to get missing THREAD_SIZE definition Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Cc: Tim Abbott <tabbott@ksplice.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net>
2009-09-24alpha: Clean up linker script using new linker script macros.Geoffrey Thomas
Note that .data.page_aligned and .data.cacheline_aligned are now after _data; it was probably a bug that they were before it. Also, some explicit ALIGN(8)'s between various initcall sections were removed; this should be harmless as the implicit alignment of initcall_t was already 8. Signed-off-by: Geoffrey Thomas <geofft@ksplice.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Richard Henderson <rth@twiddle.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24alpha: use .data.init_task instead of .data.init_thread.Tim Abbott
alpha is the only architecture that uses the section name .data.init_thread instead of .data.init_task. So convert alpha to use .data.init_task like everything else. .data.init_task does not need a separate output section; this change also moves it into the .data output section. Signed-off-by: Tim Abbott <tabbott@mit.edu> Cc: Richard Henderson <rth@twiddle.net> Cc: linux-alpha@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24alpha: AGP update (fixes compile failure)Ivan Kokshaysky
This brings Alpha AGP platforms in sync with the change to struct agp_memory (unsigned long *memory => struct page **pages). Only compile tested (I don't have titan/marvel hardware), but this change looks pretty straightforward, so hopefully it's ok. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Dave Airlie <airlied@linux.ie> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24fcntl: add F_[SG]ETOWN_EXPeter Zijlstra
In order to direct the SIGIO signal to a particular thread of a multi-threaded application we cannot, like suggested by the manpage, put a TID into the regular fcntl(F_SETOWN) call. It will still be send to the whole process of which that thread is part. Since people do want to properly direct SIGIO we introduce F_SETOWN_EX. The need to direct SIGIO comes from self-monitoring profiling such as with perf-counters. Perf-counters uses SIGIO to notify that new sample data is available. If the signal is delivered to the same task that generated the new sample it can augment that data by inspecting the task's user-space state right after it returns from the kernel. This is esp. convenient for interpreted or virtual machine driven environments. Both F_SETOWN_EX and F_GETOWN_EX take a pointer to a struct f_owner_ex as argument: struct f_owner_ex { int type; pid_t pid; }; Where type is one of F_OWNER_TID, F_OWNER_PID or F_OWNER_GID. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Tested-by: stephane eranian <eranian@googlemail.com> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Roland McGrath <roland@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (39 commits) cpumask: Move deprecated functions to end of header. cpumask: remove unused deprecated functions, avoid accusations of insanity cpumask: use new-style cpumask ops in mm/quicklist. cpumask: use mm_cpumask() wrapper: x86 cpumask: use mm_cpumask() wrapper: um cpumask: use mm_cpumask() wrapper: mips cpumask: use mm_cpumask() wrapper: mn10300 cpumask: use mm_cpumask() wrapper: m32r cpumask: use mm_cpumask() wrapper: arm cpumask: Use accessors for cpu_*_mask: um cpumask: Use accessors for cpu_*_mask: powerpc cpumask: Use accessors for cpu_*_mask: mips cpumask: Use accessors for cpu_*_mask: m32r cpumask: remove arch_send_call_function_ipi cpumask: arch_send_call_function_ipi_mask: s390 cpumask: arch_send_call_function_ipi_mask: powerpc cpumask: arch_send_call_function_ipi_mask: mips cpumask: arch_send_call_function_ipi_mask: m32r cpumask: arch_send_call_function_ipi_mask: alpha cpumask: remove obsolete topology_core_siblings and topology_thread_siblings: ia64 ...
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
